I did not fully understand the notify flag between links. When Should I set it to true and when to false ?
For links connection
ipcOut --> ipcIn
core0 core1
if you require ipc notify mode set
ipcOutXXX.notifyNextLink = TRUE
ipcOutXXX.noNotifyMode = FALSE
ipcInXXX.notifyPrevLink = TRUE
ipcInXXX.noNotifyMode = FALSE
If using ipcFramesOutLink and the processLink is connected to ipcFramesIn in remote core then
ipcFramesOut.notifyProcessLink = TRUE
ipcFramesOut.noNotifyMode = FALSE
ipcFramesIn.notifyPrevLink = TRUE
ipcFramesIn.noNotifyMode = FALSE
if you require ipc in no notify mode set
ipcFramesOut.notifyProcessLink = FALSE
ipcFramesOut.noNotifyMode = TRUE
ipcFramesIn.notifyPrevLink = FALSE
ipcFramesIn.noNotifyMode = TRUE
Enabling ipc notify will result in remote core being interrupted on frame exchange. This reduces latency but increases load on remote core. For large number of channels noNotify mode is preferred.
