USB powered Beaglebone Black
Hai
     I'm using Beaglebone black for last few days. I used USB mini cable to power-up the board not the AC charger. BBB comes with Angstrom TI image on eMMC that works fine in that. Now i prepared my own bootloader,kernel and rfs that given by TI for linux then i put with micro SD card to bring up the board and also delete the MLO file from eMMC flash. so it's only possible to load from micro SD card.
Whenever i bootup the board,  At first time it bring-up and load the linux OS upto rootfs command prompt from SD card but unfortunately sometimes it hung at the uboot command prompt and also print some spurious data. why it happens???
I'm using USB powered not AC charger, it makes any problem???
Reply as soon u can...
Roven
