C6657 SPI + EDMA3 Help
Other Parts Discussed in Thread: TMS320C6657
I have been trying to get the SPI + EDMA3 to work on the TMS320C6657 and I have been working off this form that is 2 years old. My issue is that my code seems to stop on a single lane the second time around when I try to transmit over the SPI peripheral. Below is the line of code that I am getting stuck at when I try to transmit something the second time.  Is there some piece of code that I am missing that will allow me to transmit over the SPI more than once.
while(!(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIFLG & 0x00000100)); <--- I get stuck here
 *  ======== main.c ========
#include <xdc/std.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/csl/tistdtypes.h>
#include <ti/csl/cslr_spi.h>
#include <ti/csl/soc.h>
#include <ti/csl/csl_chip.h>
#include <ti/csl/csl_types.h>
#include <ti/csl/csl_edma3.h>
#include <ti/csl/csl_edma3Aux.h>
#include <stdio.h>
#include "spi_common.h"
#define TEST_ACNT 2
#define TEST_BCNT 1024
#define TEST_CCNT 1
#define TEST_SYCTYPE_AB     1
#define TEST_SYCTYPE_A      0
#define BUF_SIZE TEST_BCNT
#define BUF_NUM 5
#pragma DATA_SECTION(dstBuf, ".gem1_data")
#pragma DATA_ALIGN(dstBuf, 8)
Uint16 dstBuf[BUF_NUM][BUF_SIZE];
#pragma DATA_SECTION(srcBuf, ".gem0_data")
#pragma DATA_ALIGN(srcBuf, 8)
Uint16 srcBuf[BUF_NUM][BUF_SIZE];
CSL_Uint64 profileTxStart;
CSL_Uint64 profileTxStop;
CSL_Uint64 profileRxStart;
CSL_Uint64 profileRxStop;
CSL_Uint64 profileTx;
CSL_Uint64 profileRx;
Uint32 global_address (Uint32 addr)
	Uint32 corenum;
	corenum = CSL_chipReadReg(CSL_CHIP_DNUM);
	addr = addr + (0x10000000 + corenum*0x1000000);
	return addr;
void Enable_Edma_Channels(void)
   	// Trigger channel
   	CSL_edma3HwChannelControl(hChannel0,CSL_EDMA3_CMD_CHANNEL_ENABLE,NULL);
   	// Trigger channel
   	CSL_edma3HwChannelControl(hChannel1,CSL_EDMA3_CMD_CHANNEL_ENABLE,NULL);
void Setup_Edma_Init ()
    // EDMA Module Initialization
	CSL_edma3Init(NULL);
 	// EDMA Module Open
    hModule = CSL_edma3Open(&moduleObj,CSL_TPCC_2,NULL,&EdmaStat);
	// SPI Tx Channel Open - Channel 2 for Tx (SPIXEVT)
	chParam.regionNum  = CSL_EDMA3_REGION_GLOBAL;
	chSetup.que        = CSL_EDMA3_QUE_0;
	chParam.chaNum     = CSL_EDMA3_CHA_30;
	//This might have to change to CSL_TPCC_2
	hChannel0 = CSL_edma3ChannelOpen(&ChObj0, CSL_TPCC_2, &chParam, &EdmaStat);
	chSetup.paramNum   = chParam.chaNum; //CSL_EDMA3_CHA_30;
    CSL_edma3HwChannelSetupParam(hChannel0,chSetup.paramNum);
	// SPI Rx Channel Open - Channel 3 for Rx (SPIREVT)
	chParam.chaNum     = CSL_EDMA3_CHA_31;
	hChannel1 = CSL_edma3ChannelOpen(&ChObj1, CSL_TPCC_2, &chParam, &EdmaStat);
	chSetup.paramNum = chParam.chaNum; //CSL_EDMA3_CHA_31;
    CSL_edma3HwChannelSetupParam(hChannel1,chSetup.paramNum);
    Enable_Edma_Channels();
void Setup_Edma_Params (Uint32 srcBuf, Uint32 dstBuf){
	// Parameter Handle Open
	// Open all the handles and keep them ready
	paramHandle0            = CSL_edma3GetParamHandle(hChannel0,CSL_EDMA3_CHA_30,&EdmaStat);
  	paramHandle1            = CSL_edma3GetParamHandle(hChannel1,CSL_EDMA3_CHA_31,&EdmaStat);
    paramSetup.aCntbCnt     = CSL_EDMA3_CNT_MAKE(TEST_ACNT,(TEST_BCNT));
	paramSetup.srcDstBidx   = CSL_EDMA3_BIDX_MAKE(TEST_ACNT,0 );
	paramSetup.srcDstCidx   = CSL_EDMA3_CIDX_MAKE(0,0);
	paramSetup.cCnt         = TEST_CCNT;
	paramSetup.option       = CSL_EDMA3_OPT_MAKE(FALSE,FALSE,FALSE,TRUE,CSL_EDMA3_CHA_30,CSL_EDMA3_TCC_NORMAL, \
	      CSL_EDMA3_FIFOWIDTH_NONE,FALSE,CSL_EDMA3_SYNC_A,CSL_EDMA3_ADDRMODE_INCR,CSL_EDMA3_ADDRMODE_INCR);
	if( ((Uint32)srcBuf & 0xFFF00000) == 0x00800000)
		paramSetup.srcAddr      = (Uint32)(global_address((Uint32)srcBuf));
	else
		paramSetup.srcAddr      = (Uint32)(srcBuf);
	#ifdef _BIG_ENDIAN
    	paramSetup.dstAddr      = ((Uint32)&(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIDAT0)) + (4-TEST_ACNT);
	#else
    	paramSetup.dstAddr      = (Uint32)&(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIDAT0);
	#endif
	paramSetup.linkBcntrld  = CSL_EDMA3_LINKBCNTRLD_MAKE(CSL_EDMA3_LINK_NULL,0);
	CSL_edma3ParamSetup(paramHandle0,&paramSetup);
	CSL_edma3ParamSetup(paramHandle0_reload,&paramSetup);
    paramSetup.aCntbCnt     = CSL_EDMA3_CNT_MAKE(TEST_ACNT,TEST_BCNT);
	paramSetup.srcDstBidx   = CSL_EDMA3_BIDX_MAKE(0,TEST_ACNT );
	paramSetup.option       = CSL_EDMA3_OPT_MAKE(FALSE,FALSE,FALSE,TRUE,CSL_EDMA3_CHA_31,CSL_EDMA3_TCC_NORMAL, \
	#ifdef _BIG_ENDIAN
    	paramSetup.srcAddr      = ((Uint32)&(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIBUF)) + (4 -TEST_ACNT);
	#else
    	paramSetup.srcAddr      = (Uint32)&(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIBUF);
	#endif
	if( ((Uint32)dstBuf & 0xFFF00000) == 0x00800000)
		paramSetup.dstAddr      = (Uint32)(global_address((Uint32)dstBuf));
	else
		paramSetup.dstAddr      = (Uint32)dstBuf;
	CSL_edma3ParamSetup(paramHandle1,&paramSetup);
	CSL_edma3ParamSetup(paramHandle1_reload,&paramSetup);
void Test_Edma(void)
	// Wait for interrupt
    regionIpr.region  = CSL_EDMA3_REGION_GLOBAL;
	regionIpr.intr    = 0;
	regionIpr.intrh   = 0;
	do{
		CSL_edma3GetHwStatus(hModule,CSL_EDMA3_QUERY_INTRPEND,&regionIpr);
	}while ((regionIpr.intr & (1<<31)) != (1<<31));	//channel_31
	//profileTxStop = CSL_tscRead();
	do{
	}while ((regionIpr.intr & (1<<30)) != (1<<30));	//channel_30
	//profileRxStop = CSL_tscRead();
	/* Clear pending interrupt */
	CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR, &regionIpr);
void Close_Edma()
    CSL_FINST(hModule->regs->TPCC_SECR,TPCC_TPCC_SECR_SECR2,RESETVAL);
  	CSL_FINST(hModule->regs->TPCC_SECR,TPCC_TPCC_SECR_SECR3,RESETVAL);
 	CSL_edma3ChannelClose(hChannel0);
 	CSL_edma3ChannelClose(hChannel1);
 	CSL_edma3Close(hModule);
void Initiate_Buffers(Uint16 aCnt, Uint16 bCnt, Uint16 cCnt, Int16 srcBIdx, Int16 dstBIdx, Int16 srcCIdx, Int16 dstCIdx,Uint32 srcBuff,Uint32 dstBuff, Bool abSync)
	Uint8* srcArrayPtr = (Uint8*)srcBuff;
	Uint8* dstArrayPtr = (Uint8*)dstBuff;
	Uint8* srcFramePtr = (Uint8*)srcBuff;
	Uint8* dstFramePtr = (Uint8*)dstBuff;
	Uint8 cnt = 0;
	int i,j,k;
	for (i = 0; i < cCnt; i++)
		for (j = 0; j < bCnt ;j++)
			for (k = 0;k < aCnt;k++)
				srcArrayPtr[k] = cnt++;
				dstArrayPtr[k] = 0;
			srcArrayPtr = srcArrayPtr + srcBIdx;
			dstArrayPtr = dstArrayPtr + dstBIdx;
		if (abSync) {
			srcFramePtr = srcFramePtr + srcCIdx;
			srcArrayPtr = srcFramePtr;
			dstFramePtr = dstFramePtr + dstCIdx;
			dstArrayPtr = dstFramePtr;
		} else
		    srcFramePtr = srcArrayPtr + srcCIdx - srcBIdx;
			dstFramePtr = dstArrayPtr + dstCIdx - dstBIdx;
void Setup_SPI_Init ()
	//enable_spi();
    /* Reset SPI */
    ((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIGCR0=
    	CSL_SPI_SPIGCR0_RESET_IN_RESET<<CSL_SPI_SPIGCR0_RESET_SHIFT;
    /* Take SPI out of reset */
    	CSL_SPI_SPIGCR0_RESET_OUT_OF_RESET<<CSL_SPI_SPIGCR0_RESET_SHIFT;
    /* Configure SPI as master */
    ((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIGCR1=
        CSL_SPI_SPIGCR1_CLKMOD_INTERNAL<<CSL_SPI_SPIGCR1_CLKMOD_SHIFT|
        CSL_SPI_SPIGCR1_MASTER_MASTER<<CSL_SPI_SPIGCR1_MASTER_SHIFT;
    /* Configure SPI in 4-pin SCS mode */
    ((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIPC0=
        CSL_SPI_SPIPC0_SOMIFUN_SPI<<CSL_SPI_SPIPC0_SOMIFUN_SHIFT|
        CSL_SPI_SPIPC0_SIMOFUN_SPI<<CSL_SPI_SPIPC0_SIMOFUN_SHIFT|
        CSL_SPI_SPIPC0_CLKFUN_SPI<<CSL_SPI_SPIPC0_CLKFUN_SHIFT|
        CSL_SPI_SPIPC0_SCS0FUN0_SPI<<CSL_SPI_SPIPC0_SCS0FUN0_SHIFT;
	/* Put SPI in Lpbk mode*/
	((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIGCR1 |=
		CSL_SPI_SPIGCR1_LOOPBACK_ENABLE<<CSL_SPI_SPIGCR1_LOOPBACK_SHIFT;
    /* Chose SPIFMT0 */
	((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIDAT1=
		CSL_SPI_SPIDAT1_DFSEL_FORMAT0<<CSL_SPI_SPIDAT1_DFSEL_SHIFT;
    /* Configure add a delay,SHIFTDIR=MSB,POLARITY=HIGH,PHASE=IN,CHARLEN=16*/
    ((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIFMT[0]=
    	CSL_SPI_SPIFMT_WAITENA_DISABLE<<CSL_SPI_SPIFMT_WAITENA_SHIFT|
    	CSL_SPI_SPIFMT_SHIFTDIR_MSB<<CSL_SPI_SPIFMT_SHIFTDIR_SHIFT|
    	CSL_SPI_SPIFMT_POLARITY_LOW<<CSL_SPI_SPIFMT_POLARITY_SHIFT|
    	CSL_SPI_SPIFMT_PHASE_NO_DELAY<<CSL_SPI_SPIFMT_PHASE_SHIFT|
    	0x1<<CSL_SPI_SPIFMT_PRESCALE_SHIFT|
    	0x10<<CSL_SPI_SPIFMT_CHARLEN_SHIFT;
	((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIINT0 =
		CSL_SPI_SPIINT0_ENABLEHIGHZ_ENABLE<<CSL_SPI_SPIINT0_ENABLEHIGHZ_SHIFT|
		CSL_SPI_SPIINT0_OVRNINTENA_ENABLE<<CSL_SPI_SPIINT0_OVRNINTENA_SHIFT|
		CSL_SPI_SPIINT0_BITERRENA_ENABLE<<CSL_SPI_SPIINT0_BITERRENA_SHIFT|
		CSL_SPI_SPIINT0_DESYNCENA_ENABLE<<CSL_SPI_SPIINT0_DESYNCENA_SHIFT|
		CSL_SPI_SPIINT0_PARERRENA_ENABLE<<CSL_SPI_SPIINT0_PARERRENA_SHIFT|
		CSL_SPI_SPIINT0_TIMEOUTENA_ENABLE<<CSL_SPI_SPIINT0_TIMEOUTENA_SHIFT|
		CSL_SPI_SPIINT0_DLENERRENA_ENABLE<<CSL_SPI_SPIINT0_DLENERRENA_SHIFT;
void SPI_DMA_Request(void){
	 /* Enable communication */
   ((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIGCR1|=
       CSL_SPI_SPIGCR1_ENABLE_ENABLE<<CSL_SPI_SPIGCR1_ENABLE_SHIFT;
	((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIINT0 |=
			CSL_SPI_SPIINT0_DMAREQEN_ENABLE<<CSL_SPI_SPIINT0_DMAREQEN_SHIFT;
	while(!(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIFLG & 0x00000200));
	//profileTxStart = CSL_tscRead();
	//profileRxStart = CSL_tscRead();
		   CSL_SPI_SPIGCR1_ENABLE_DISABLE<<CSL_SPI_SPIGCR1_ENABLE_SHIFT;
			CSL_SPI_SPIINT0_DMAREQEN_DISABLE<<CSL_SPI_SPIINT0_DMAREQEN_SHIFT;
Bool Verify_Transfer(Uint16 aCnt, Uint16 bCnt, Uint16 cCnt, Int16 srcBIdx, Int16 dstBIdx, Int16 srcCIdx, Int16 dstCIdx,Uint32 srcBuff,Uint32 dstBuff, Bool abSync)
	int i,j,k;
				if (srcArrayPtr[k] != dstArrayPtr[k])
					return FALSE;
		if (abSync) {
		} else
	return TRUE;
 *  ======== main ========
Void main()
    volatile Uint32 failFlag = FALSE;
    int i = 0;
    //Initiate src/dst buffers
	for (i=0; i<BUF_NUM; i++)
		Initiate_Buffers(TEST_ACNT,TEST_BCNT, TEST_CCNT,TEST_ACNT ,TEST_ACNT, TEST_ACNT*TEST_BCNT, TEST_ACNT*TEST_BCNT,(Uint32)srcBuf[i],(Uint32)dstBuf[i], CSL_EDMA3_SYNC_A);
	//Initialize EDMA for SPI transfer
	Setup_Edma_Init();
   	//Configure SPI in loopback mode and enable DMA interrupt support
	Setup_SPI_Init();
	//CSL_tscEnable();
	for(i=0;i<BUF_NUM;i++){
		//Enable EDMA for SPI transfer
		Setup_Edma_Params((Uint32)srcBuf[i],(Uint32)dstBuf[i]);
		//Enable SPI DMA Request
		SPI_DMA_Request();
		//Check EDMA transfer completion status
		Test_Edma();
		//Verify src/dst buffers after transfer
		failFlag = Verify_Transfer(TEST_ACNT,TEST_BCNT, TEST_CCNT,TEST_ACNT ,TEST_ACNT, TEST_ACNT*TEST_BCNT, TEST_ACNT*TEST_BCNT,(Uint32)srcBuf[i],(Uint32)dstBuf[i], CSL_EDMA3_SYNC_A);
		if (failFlag == TRUE){
			System_printf("data verification passed\n");
		else
			System_printf("data verification failed\n");
	System_printf("end of test\n");
	BIOS_exit(0);
    //BIOS_start();     /* enable interrupts and start SYS/BIOS */
  • Jan Nevarez,
    Welcome to the TI E2E forum. I hope you will find many good answers here.
    In addition you can find some details through the TI.com documents and the TI Wiki Pages.
    Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics.
    There is no test code for SPI with EDMA. But you can find the sample code for SPI at the below,
    pdk_C6657_1_1_2_6\packages\ti\platform\evmc6657l\platform_lib\src
    And also find the CSL code for EDMA3
    pdk_C6657_1_1_2_6\packages\ti\csl\src\ip\edma
    If you are using the SPI EDMA, check setting the interrupt for EDMA event and not SPI event.
    This E2E discussion will help you to solve your issue.
    http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/p/211199/875179.aspx#875179
    Check this code for SPI with EDMA
    #include <spi_common.h>
    #include <stdio.h>
    #include <psc_util.h>
    #define TEST_ACNT 2
    #define TEST_CCNT 1
    Uint16 dstBuf[BUF_SIZE];
    Uint16 srcBuf[BUF_SIZE];
    void enable_spi(void)
    		if (enable_module(emif25_spi_pdctl,emif25_spi_mdctl) != 1)
        		printf ("SPI enable failed\n");
    	Uint32 corenum;
    	return addr;
    void Trigger_Edma_Channels(void)
       	// Trigger channel
       	// Trigger channel
    void Setup_Edma (Uint32 srcBuf,Uint32 dstBuf)
     	// EDMA Module Open
    	else
    	else
    	Trigger_Edma_Channels();
    	regionIpr.intr    = 0;
    	do{
    	do{
    void Close_Edma()
    void Setup_SPI (void)
    	//enable_spi();
        /* Reset SPI */
    	/* Put SPI in Lpbk mode */
        /* Chose SPIFMT0 */
        /* Configure for WAITEN=YES,SHIFTDIR=MSB,POLARITY=HIGH,PHASE=IN,CHARLEN=16*/
            CSL_SPI_SPIFMT_PHASE_DELAY<<CSL_SPI_SPIFMT_PHASE_SHIFT|
    	int i,j,k;
    					return FALSE;
    		if (abSync) {
    		} else
    	return TRUE;
    	Uint8 cnt = 0;
    	int i,j,k;
    				dstArrayPtr[k] = 0;
    		if (abSync) {
    		} else
    void main (void)
    	Initiate_Buffers(TEST_ACNT,TEST_BCNT, TEST_CCNT,TEST_ACNT ,TEST_ACNT, TEST_ACNT*TEST_BCNT, TEST_ACNT*TEST_BCNT,(Uint32)srcBuf,(Uint32)dstBuf, CSL_EDMA3_SYNC_A);
       	//Setup EDMA for SPI transfer
       	Setup_Edma((Uint32)srcBuf,(Uint32)dstBuf);
    	Setup_SPI();
        Test_Edma();
    	//Close EDMA channels/module                                        */
    	Close_Edma();
    	failFlag = Verify_Transfer(TEST_ACNT,TEST_BCNT, TEST_CCNT,TEST_ACNT ,TEST_ACNT, TEST_ACNT*TEST_BCNT, TEST_ACNT*TEST_BCNT,(Uint32)srcBuf,(Uint32)dstBuf, CSL_EDMA3_SYNC_A);
    	else
  • Pubesh,
    I have looked through the three following links and I cant find anything to fix my issue. Also I looked at the code that you sent and that code works for me but that is only good if I want to use SPI just a single time. I am trying to make my SPI transmit multiple pieces of data back to back. Also the other E2E discussion didn't help because I am running my code in little endian mode. The code that I originally posted will work for the first loop through to transmit data it is the second time around is when it gets stuck at the specific line. Any further guidance would be much appreciated.
    Jan
  • Pubesh,
    I am sorry but I do not see the answer to my question in your original post. If there is something I am missing could you please point it at by looking at my code and provide me another answer with better guidance to help solve my issue. I am having trouble getting the SPI + EDMA to work for multiple passes through the code right after another. It as on the second pass through that my code will get stuck at the line below. Please help me solve my issue.
    while(!(((CSL_SpiRegsOvly) CSL_SPI_REGS)->SPIFLG & 0x00000100)); <-- Here
    Jan
    #include <stdio.h>
    #define TEST_ACNT 2
    #define TEST_CCNT 1
    #define BUF_NUM 5
    	Uint32 corenum;
    	return addr;
       	// Trigger channel
       	// Trigger channel
     	// EDMA Module Open
    	else
    	#ifdef _BIG_ENDIAN
    	#else
    	#endif
    	#ifdef _BIG_ENDIAN
    	#else
    	#endif
    	else
    	regionIpr.intr    = 0;
    	do{
    	do{
    void Close_Edma()
    	Uint8 cnt = 0;
    	int i,j,k;
    				dstArrayPtr[k] = 0;
    		if (abSync) {
    		} else
    	//enable_spi();
        /* Reset SPI */
        /* Chose SPIFMT0 */
    	int i,j,k;
    					return FALSE;
    		if (abSync) {
    		} else
    	return TRUE;
    Void main()
        int i = 0;
    	Setup_Edma_Init();
    	Setup_SPI_Init();
    	//CSL_tscEnable();
    		SPI_DMA_Request();
    		Test_Edma();
    		else
    	BIOS_exit(0);
  • Jan,
    I'll do my best to support you here, but I am reaching the limits of my expertise with SPI. Can you try the original code with multiple transfer, change the main() function, I am not sure this will be Ok.
    void main (void)
    Setup_SPI();
    Test_Edma();
    Close_Edma();
    else
