[DM8148] IPC_BITSINLINK:!WARNING!
Dear Experts,
I use DVRRDK3.5/DM8148. M3VPSS/M3Video/C6XDSP handle encode process. A8 handle encoded data.
I got some problem about IPC.
When below messages occurs, A8 cannot communicate with M3.
It seems IPC has some problems.
How can I fix this problem??
=== Error Message ===
...(many)...
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:3834,TimeSinceLastFree:3834
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:3836,TimeSinceLastFree:3836
thx ~
HB
  • The warning indicates ipcBitsInLink main thread is not getting scheduled. Do you have ipc notify enabled between ipcBitsOut and ipcBitsIn or do you use noNotifyMode ?
    What is your application callback function  from ipcBitsInLink doing ? Is it just posting a semaphore to trigger another thread or do you do some operation in the callback ?
    You will have to check why the ipcBitsInLink thread is not getting scheduled by adding some debug code.
  • Dear Badri,
    1) We don't use notify Mode. We are using noNotifyMode.
    2) We don't use callback function. At IpcBitsInLink_getFullBitBufs (ipcBitsInLink_tsk.c (dvr_rdk\mcfw\src_linux\links\ipcbitsin), we use
    status =  OSA_queGet(&pObj->outBitBufQue,
                         (Int32 *) (&pBitBufList->bufs[idx]), OSA_TIMEOUT_FOREVER);
    3) What debug code could be add to debug such issues? Could you provide us suggestion or example code.
     * Copyright (c) 2009 Texas Instruments Incorporated - http://www.ti.com/      *
     *                        ALL RIGHTS RESERVED                                  *
    #include <stddef.h>
    #include "ipcBitsInLink_priv.h"
    #include <ti/syslink/utils/IHeap.h>
    #include <ti/syslink/utils/Memory.h>
    #include <ti/syslink/utils/Cache.h>
    IpcBitsInLink_Obj gIpcBitsInLink_obj[IPC_BITS_IN_LINK_OBJ_MAX];
    static
    Int32 IpcBitsInLink_getFullBitBufs(IpcBitsInLink_Obj * pObj,
                                       Bitstream_BufList * pBitBufList);
    static
    Int32 IpcBitsInLink_putEmptyBitBufs(IpcBitsInLink_Obj * pObj,
    Void IpcBitsInLink_notifyCb(OSA_TskHndl * pTsk)
        OSA_tskSendMsg(pTsk, NULL, SYSTEM_CMD_NEW_DATA, NULL, 0);
    Void *IpcBitsInLink_periodicTaskFxn(Void * prm)
        IpcBitsInLink_Obj *pObj = (IpcBitsInLink_Obj *) prm;
        Int32 status;
        while (FALSE == pObj->prd.exitThread)
            OSA_waitMsecs(IPC_BITS_IN_PROCESS_PERIOD_MS);
            if (pObj->prd.numPendingCmd < IPC_BITS_IN_MAX_PENDING_NEWDATA_CMDS)
                pObj->prd.numPendingCmd++;
                status = System_sendLinkCmd(pObj->tskId, SYSTEM_CMD_NEW_DATA);
            else
                UInt32 curTime = OSA_getCurTimeInMsec();
                OSA_printf("IPC_BITSINLINK:!WARNING!.Commands not being processed by link."
                           "TimeSinceLastAlloc:%d,TimeSinceLastFree:%d\n",
                           (curTime - pObj->stats.lastGetBufTime),
                           (curTime - pObj->stats.lastFreeBufTime));
        return NULL;
    static Void IpcBitsInLink_initStats(IpcBitsInLink_Obj * pObj)
        memset(&pObj->stats, 0, sizeof(pObj->stats));
    static
    Int32 IpcBitsInLink_createPrdObj(IpcBitsInLink_Obj * pObj)
        pObj->prd.numPendingCmd = 0;
        pObj->prd.exitThread = FALSE;
        OSA_thrCreate(&pObj->prd.thrHandle,
                      IpcBitsInLink_periodicTaskFxn,
                      IPC_LINK_TSK_PRI, IPC_LINK_TSK_STACK_SIZE, pObj);
        return IPC_BITS_IN_LINK_S_SUCCESS;
    static
    Int32 IpcBitsInLink_deletePrdObj(IpcBitsInLink_Obj * pObj)
        pObj->prd.exitThread = TRUE;
        OSA_thrDelete(&pObj->prd.thrHandle);
    Int32 IpcBitsInLink_create(IpcBitsInLink_Obj * pObj,
                               IpcBitsInLinkHLOS_CreateParams * pPrm)
        Int32 status;
        System_LinkInQueParams *pInQueParams;
    #ifdef SYSTEM_DEBUG_IPC
        OSA_printf(" %d: IPC_BITS_IN   : Create in progress !!!\n",
                   OSA_getCurTimeInMsec());
    #endif
        memcpy(&pObj->createArgs, pPrm, sizeof(pObj->createArgs));
        OSA_printf(" %d: IPC_BITS_IN   : ListMPOpen start !!!\n",
        status =
            System_ipcListMPOpen(pObj->createArgs.baseCreateParams.inQueParams.
                                 prevLinkId, &pObj->listMPOutHndl,
                                 &pObj->listMPInHndl);
        OSA_assert(status == OSA_SOK);
        OSA_assert(pObj->listMPInHndl != NULL);
        OSA_printf(" %d: IPC_BITS_IN   : ListMPOpen done !!!\n",
        while(!ListMP_empty(pObj->listMPInHndl))
            Ptr listElem =
            ListMP_getHead(pObj->listMPInHndl);
            if (listElem != NULL)
                IPCBITSINLINK_INFO_LOG(pObj->tskId,
                                       "InList not empty!!!"
                                       "Stale entry:[%p]",
                                       listElem);
        status = OSA_queCreate(&pObj->outBitBufQue, SYSTEM_IPC_BITS_MAX_LIST_ELEM);
        pInQueParams = &pObj->createArgs.baseCreateParams.inQueParams;
        status = System_linkGetInfo(pInQueParams->prevLinkId, &pObj->inQueInfo);
        OSA_printf(" %d: IPC_BITS_IN   : System_linkGetInfo done !!!\n",
        IpcBitsInLink_initStats(pObj);
        if (pObj->createArgs.baseCreateParams.noNotifyMode)
            IpcBitsInLink_createPrdObj(pObj);
        OSA_printf(" %d: IPC_BITS_IN   : Create Done !!!\n",
    #endif
    Int32 IpcBitsInLink_delete(IpcBitsInLink_Obj * pObj)
        Int32 status;
            IpcBitsInLink_deletePrdObj(pObj);
                               "RECV:%d\tFREE:%d,DROPPED:%d,AVGLATENCY:%d,AVG_APP_CB_TIME:%d\n",
                               pObj->stats.recvCount,
                               pObj->stats.freeCount,
                               pObj->stats.droppedCount,
                        OSA_DIV(pObj->stats.totalRoundTrip ,
                                pObj->stats.freeCount),
                        OSA_DIV(pObj->stats.totalAppCallbackTime,
                                pObj->stats.numFreeBufCalls));
        OSA_printf(" %d: IPC_BITS_IN   : Delete in progress !!!\n",
    #endif
        status = System_ipcListMPClose(&pObj->listMPOutHndl, &pObj->listMPInHndl);
        OSA_queDelete(&pObj->outBitBufQue);
        OSA_printf(" %d: IPC_BITS_IN   : Delete Done !!!\n",
    #endif
    static Int32 IpcBitsInLink_getBitBuf(IpcBitsInLink_Obj * pObj,
                                         SystemIpcBits_ListElem * pListElem,
                                         Bitstream_Buf ** pBitBufPtr)
        OSA_assert(pListElem != NULL);
        /* No cache ops done since pListElem is allocated from non-cached memory */
        OSA_assert(SharedRegion_isCacheEnabled(SharedRegion_getId(pListElem)) ==
                   FALSE);
        pListElem->bitBuf.addr = SharedRegion_getPtr(pListElem->srBufPtr);
        if (pListElem->bitBuf.fillLength)
            Cache_inv(pListElem->bitBuf.addr,
                      pListElem->bitBuf.fillLength, Cache_Type_ALL, TRUE);
        if(pListElem->bitBuf.mvDataFilledSize)
            Cache_inv(pListElem->bitBuf.addr + pListElem->bitBuf.mvDataOffset,
                      pListElem->bitBuf.mvDataFilledSize, Cache_Type_ALL, TRUE);
        *pBitBufPtr = &pListElem->bitBuf;
    Int32 IpcBitsInLink_processBitBufs(IpcBitsInLink_Obj * pObj)
        Bitstream_Buf *pBitBuf;
        SystemIpcBits_ListElem *pListElem;
        UInt32 numBitBufs;
        Int32 status;
        UInt32 curTime;
        numBitBufs = 0;
        while (1)
            pListElem = ListMP_getHead(pObj->listMPOutHndl);
            if (pListElem == NULL)
                break;
            IpcBitsInLink_getBitBuf(pObj, pListElem, &pBitBuf);
            OSA_assert(SYSTEM_IPC_BITS_GET_BUFSTATE(pListElem->bufState)
                       == IPC_BITBUF_STATE_OUTQUE);
            SYSTEM_IPC_BITS_SET_BUFOWNERPROCID(pListElem->bufState);
            SYSTEM_IPC_BITS_SET_BUFSTATE(pListElem->bufState,
                                         IPC_BITBUF_STATE_DEQUEUED);
            pBitBuf->reserved[0] = curTime;
            pObj->stats.recvCount++;
            status =
                OSA_quePut(&pObj->outBitBufQue, (Int32) pBitBuf, OSA_TIMEOUT_NONE);
            numBitBufs++;
    #ifdef SYSTEM_DEBUG_IPC_RT
        OSA_printf(" %d: IPC_BITS_IN   : Recevived %d bitbufs !!!\n",
                   OSA_getCurTimeInMsec(), numBitBufs);
    #endif
        if (numBitBufs)
            if (pObj->createArgs.cbFxn)
                pObj->createArgs.cbFxn(pObj->createArgs.cbCtx);
    static
        UInt32 idx;
        Int32 status;
        UInt32 curTime;
    #if 1
    	UInt32 bufNum=1;
    #else
    	UInt32 bufNum=VIDBITSTREAM_MAX_BITSTREAM_BUFS;
    #endif
        for (idx = 0; idx < bufNum; idx++)
    #if 0
            status =
                           (Int32 *) (&pBitBufList->bufs[idx]), OSA_TIMEOUT_NONE);
    #else
    #endif
            if (status != OSA_SOK)
                break;
            pBitBufList->bufs[idx]->reserved[1] = curTime;
        pBitBufList->numBufs = idx;
        pObj->stats.numGetBufCalls++;
        pObj->stats.lastGetBufTime = curTime;
    static
        UInt32 bufId;
        Int32 status;
        SystemIpcBits_ListElem *pListElem = NULL;
        UInt32 curTime;
        OSA_printf(" %d: IPC_BITS_IN   : Releasing %d bitbufs !!!\n",
                   OSA_getCurTimeInMsec(), pBitBufList->numBitBufs);
    #endif
        if (pBitBufList->numBufs)
            OSA_assert(pBitBufList->numBufs <= VIDBITSTREAM_MAX_BITSTREAM_BUFS);
            pObj->stats.freeCount += pBitBufList->numBufs;
            for (bufId = 0; bufId < pBitBufList->numBufs; bufId++)
                pBitBuf = pBitBufList->bufs[bufId];
                if (curTime > pBitBuf->reserved[0])
                    pObj->stats.totalRoundTrip += (curTime - pBitBuf->reserved[0]);
                if (curTime > pBitBuf->reserved[1])
                    pObj->stats.totalAppCallbackTime += (curTime - pBitBuf->reserved[1]);
                OSA_COMPILETIME_ASSERT(offsetof(SystemIpcBits_ListElem, bitBuf) ==
                                       0);
                pListElem = (SystemIpcBits_ListElem *) pBitBuf;
                OSA_assert(SharedRegion_getPtr(pListElem->srBufPtr) ==
                           pBitBuf->addr);
                                             IPC_BITBUF_STATE_INQUE);
                status =
                    ListMP_putTail(pObj->listMPInHndl, (ListMP_Elem *) pListElem);
                OSA_assert(status == ListMP_S_SUCCESS);
            if (pObj->createArgs.baseCreateParams.notifyPrevLink)
                System_ipcSendNotify(pObj->createArgs.baseCreateParams.inQueParams.
                                     prevLinkId);
        pObj->stats.lastFreeBufTime = curTime;
        pObj->stats.numFreeBufCalls++;
    Int32 IpcBitsInLink_getLinkInfo(OSA_TskHndl * pTsk, System_LinkInfo * info)
        IpcBitsInLink_Obj *pObj = (IpcBitsInLink_Obj *) pTsk->appData;
        memcpy(info, &pObj->inQueInfo, sizeof(*info));
    Int IpcBitsInLink_tskMain(struct OSA_TskHndl * pTsk, OSA_MsgHndl * pMsg,
                              Uint32 curState)
        UInt32 cmd = OSA_msgGetCmd(pMsg);
        Bool ackMsg, done;
        Int status = IPC_BITS_IN_LINK_S_SUCCESS;
        OSA_printf("%s:Entered\n", __func__);
        if (cmd != SYSTEM_CMD_CREATE)
            OSA_tskAckOrFreeMsg(pMsg, OSA_EFAIL);
            return status;
        status = IpcBitsInLink_create(pObj, OSA_msgGetPrm(pMsg));
        OSA_tskAckOrFreeMsg(pMsg, status);
            return status;
        done = FALSE;
        ackMsg = FALSE;
        while (!done)
            status = OSA_tskWaitMsg(pTsk, &pMsg);
                break;
            switch (cmd)
                case SYSTEM_CMD_DELETE:
                    done = TRUE;
                    ackMsg = TRUE;
                    break;
                case SYSTEM_CMD_NEW_DATA:
                        OSA_assert(pObj->prd.numPendingCmd > 0);
                        pObj->prd.numPendingCmd--;
                    IpcBitsInLink_processBitBufs(pObj);
                    break;
                default:
                    break;
        IpcBitsInLink_delete(pObj);
    #ifdef SYSTEM_DEBUG_IPC_BITS_IN
    #endif
        if (ackMsg && pMsg != NULL)
    Int32 IpcBitsInLink_init()
        Int32 status;
        System_LinkObj linkObj;
        UInt32 ipcBitsInId;
        IpcBitsInLink_Obj *pObj;
        char tskName[32];
        UInt32 procId = System_getSelfProcId();
        OSA_COMPILETIME_ASSERT(offsetof(SystemIpcBits_ListElem, bitBuf) == 0);
        OSA_COMPILETIME_ASSERT(offsetof(Bitstream_Buf, reserved) == 0);
        OSA_COMPILETIME_ASSERT(sizeof(((Bitstream_Buf *) 0)->reserved) ==
                               sizeof(ListMP_Elem));
        for (ipcBitsInId = 0; ipcBitsInId < IPC_BITS_IN_LINK_OBJ_MAX; ipcBitsInId++)
            pObj = &gIpcBitsInLink_obj[ipcBitsInId];
            memset(pObj, 0, sizeof(*pObj));
            pObj->tskId =
                SYSTEM_MAKE_LINK_ID(procId,
                                    SYSTEM_LINK_ID_IPC_BITS_IN_0) + ipcBitsInId;
            linkObj.pTsk = &pObj->tsk;
            linkObj.getLinkInfo = IpcBitsInLink_getLinkInfo;
            System_registerLink(pObj->tskId, &linkObj);
            OSA_SNPRINTF(tskName, "IPC_BITS_IN%d", ipcBitsInId);
            System_ipcRegisterNotifyCb(pObj->tskId, IpcBitsInLink_notifyCb);
            status = OSA_tskCreate(&pObj->tsk,
                                   IpcBitsInLink_tskMain,
                                   IPC_LINK_TSK_PRI,
                                   IPC_LINK_TSK_STACK_SIZE, 0, pObj);
        return status;
    Int32 IpcBitsInLink_deInit()
        UInt32 ipcBitsInId;
            OSA_tskDelete(&gIpcBitsInLink_obj[ipcBitsInId].tsk);
    Int32 IpcBitsInLink_getFullVideoBitStreamBufs(UInt32 linkId,
                                                  Bitstream_BufList *bufList)
        OSA_TskHndl * pTsk;
        IpcBitsInLink_Obj * pObj;
        Int status;
        OSA_assert(bufList != NULL);
        if (!((linkId  >= SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0)
              (linkId  < (SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0 + IPC_BITS_IN_LINK_OBJ_MAX))))
            return IPC_BITS_IN_LINK_E_INVALIDLINKID;
        pTsk = System_getLinkTskHndl(linkId);
        pObj = pTsk->appData;
        bufList->numBufs = 0;
        status = IpcBitsInLink_getFullBitBufs(pObj,bufList);
        return status;
    Int32 IpcBitsInLink_putEmptyVideoBitStreamBufs(UInt32 linkId,
        OSA_TskHndl * pTsk;
        Int status;
        status = IpcBitsInLink_putEmptyBitBufs(pObj,bufList);
        return status;
    Thx ~
    HB
  • As I mentioned you have to figure out where the ipcBitsInLink task is blocked. The change you have done will not work if you have more than one channel being encoded but I don't think that is the cause of the ipcBitsInLink thread not being scheduled.
    You can have a variable in IpcBitsInLink instance object which indicates current stage of code .Attached is example code
    diff --git a/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_priv.h b/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_priv.h
    index 74b7eea..69e756d 100755
    --- a/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_priv.h
    +++ b/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_priv.h
    @@ -94,6 +94,22 @@ typedef enum IpcBitsInLink_State {
         IPC_BITS_IN_LINK_STATE_ACTIVE
     } IpcBitsInLink_State;
    +typedef enum IpcBitsInLink_Stage {
    +    IPC_BITS_IN_LINK_STAGE_RESET                         = 0,
    +    IPC_BITS_IN_LINK_STAGE_WAITMSG                       = (1u << 0),
    +    IPC_BITS_IN_LINK_STAGE_DELETEMSG_PROCESS             = (1u << 1),
    +    IPC_BITS_IN_LINK_STAGE_STOPMSG_PROCESS               = (1u << 2),
    +    IPC_BITS_IN_LINK_STAGE_DEFAULTMSG_PROCESS            = (1u << 3),
    +    IPC_BITS_IN_LINK_STAGE_OSAMSG_ACK                    = (1u << 4),
    +    IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_ENTRY          = (1u << 5),
    +    IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_PROCESSLOOP    = (1u << 6),
    +    IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_LISTMPGET      = (1u << 7),
    +    IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_BITBUFGET      = (1u << 8),
    +    IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_OUTBITBUFPUT   = (1u << 9),
    +    IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_IN_APPCB       = (1u << 10),
    +} IpcBitsInLink_Stage;
      * @brief   Structures defining members for supporting timer based periodic
    @@ -131,6 +147,7 @@ typedef struct IpcBitsInLink_Obj {
         IpcBitsInLink_PeriodicObj prd;/**< Periodic processing member */
         volatile IpcBitsInLink_State state;
    +    UInt32 execStage; /**< Execution stage of IPCBITSIN LINK thread */
     } IpcBitsInLink_Obj;
     diff --git a/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_tsk.c b/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_tsk.c
    index a115401..a632e2a 100755
    --- a/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_tsk.c
    +++ b/mcfw/src_linux/links/ipcBitsIn/ipcBitsInLink_tsk.c
    @@ -10,6 +10,11 @@
    +#define IPC_BITSINLINK_INIT_STAGE(stageVar) ((stageVar) = IPC_BITS_IN_LINK_STAGE_RESET)
    +#define IPC_BITSINLINK_SET_STAGE(stageVar,stage) (stageVar = (stageVar) | (stage))
    +#define IPC_BITSINLINK_RESET_STAGE(stageVar,stage) (stageVar = (stageVar) & ~(stage))
     static
    @@ -51,9 +56,11 @@ Void *IpcBitsInLink_periodicTaskFxn(Void * prm)
    -                           "TimeSinceLastAlloc:%d,TimeSinceLastFree:%d",
    +                           "TimeSinceLastAlloc:%d,TimeSinceLastFree:%d."
    +                           "IPBITSINEXECSTATE:0x%x",
    -                           (curTime - pObj->stats.lastFreeBufTime));
    +                           (curTime - pObj->stats.lastFreeBufTime),
    +                           pObj->execStage);
    @@ -138,6 +145,7 @@ Int32 IpcBitsInLink_create(IpcBitsInLink_Obj * pObj,
         pObj->state = IPC_BITS_IN_LINK_STATE_ACTIVE;
    +    IPC_BITSINLINK_INIT_STAGE(pObj->execStage);
    @@ -185,7 +193,7 @@ Int32 IpcBitsInLink_delete(IpcBitsInLink_Obj * pObj)
    @@ -226,15 +234,22 @@ Int32 IpcBitsInLink_processBitBufs(IpcBitsInLink_Obj * pObj)
         Int32 status;
         UInt32 curTime;
    +    IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_ENTRY);
         numBitBufs = 0;
    +    IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_PROCESSLOOP);
         while (1)
    +        IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_LISTMPGET);
    +        IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_LISTMPGET);
                 break;
    +        IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_BITBUFGET);
    +        IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_BITBUFGET);
    @@ -242,12 +257,15 @@ Int32 IpcBitsInLink_processBitBufs(IpcBitsInLink_Obj * pObj)
    +        IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_OUTBITBUFPUT);
             status =
    +        IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_OUTBITBUFPUT);
             numBitBufs++;
    +    IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_PROCESSLOOP);
    @@ -258,10 +276,12 @@ Int32 IpcBitsInLink_processBitBufs(IpcBitsInLink_Obj * pObj)
    +            IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_IN_APPCB);
    +            IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_IN_APPCB);
    +    IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_PROCESS_BITBUF_ENTRY);
    @@ -352,6 +372,13 @@ Int32 IpcBitsInLink_getLinkInfo(OSA_TskHndl * pTsk, System_LinkInfo * info)
    +static Void IpcBitsInLink_ackMsg(OSA_MsgHndl * pMsg,Int status,UInt32 execStage)
    +    IPC_BITSINLINK_SET_STAGE(execStage,IPC_BITS_IN_LINK_STAGE_OSAMSG_ACK);
    +    OSA_tskAckOrFreeMsg(pMsg,status);
    +    IPC_BITSINLINK_RESET_STAGE(execStage,IPC_BITS_IN_LINK_STAGE_OSAMSG_ACK);
                               Uint32 curState)
    @@ -369,13 +396,13 @@ Int IpcBitsInLink_tskMain(struct OSA_TskHndl * pTsk, OSA_MsgHndl * pMsg,
    -        OSA_tskAckOrFreeMsg(pMsg, OSA_EFAIL);
    +        IpcBitsInLink_ackMsg(pMsg, OSA_EFAIL,pObj->execStage);
             return status;
    -    OSA_tskAckOrFreeMsg(pMsg, status);
    +    IpcBitsInLink_ackMsg(pMsg, status,pObj->execStage);
             return status;
    @@ -385,7 +412,9 @@ Int IpcBitsInLink_tskMain(struct OSA_TskHndl * pTsk, OSA_MsgHndl * pMsg,
         while (!done)
    +        IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_WAITMSG);
    +        IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_WAITMSG);
                 break;
    @@ -394,11 +423,12 @@ Int IpcBitsInLink_tskMain(struct OSA_TskHndl * pTsk, OSA_MsgHndl * pMsg,
             switch (cmd)
    +                IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_DELETEMSG_PROCESS);
                     done = TRUE;
                     ackMsg = TRUE;
                     break;
    @@ -407,17 +437,22 @@ Int IpcBitsInLink_tskMain(struct OSA_TskHndl * pTsk, OSA_MsgHndl * pMsg,
                     break;
                 case SYSTEM_CMD_STOP:
    +                IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_STOPMSG_PROCESS);
                     IpcBitsInLink_stop(pObj);
    +                IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_STOPMSG_PROCESS);
                     break;
                 default:
    +                IPC_BITSINLINK_SET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_DEFAULTMSG_PROCESS);
    +                IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_DEFAULTMSG_PROCESS);
                     break;
    +    IPC_BITSINLINK_RESET_STAGE(pObj->execStage,IPC_BITS_IN_LINK_STAGE_DELETEMSG_PROCESS);
    @@ -425,7 +460,7 @@ Int IpcBitsInLink_tskMain(struct OSA_TskHndl * pTsk, OSA_MsgHndl * pMsg,
     #endif
    If you have gdb running on target refer these stackoverflow  posts on how to get backtrace for a specific thread to determine where it is blocked
    http://stackoverflow.com/questions/6671330/get-programmatic-info-on-threads-using-gdb-and-pthreads
    http://stackoverflow.com/questions/4765158/printing-a-stack-trace-from-another-thread/4778874#4778874
    http://stackoverflow.com/questions/6402160/getting-a-backtrace-of-other-thread
    Answers to other questions you raised in emai
    Do all IPC links use same Gate between M3-VPSS/M3-VIDEO/A8/DSP in syslink?
    No . Refer /dvr_rdk/mcfw/src_linux/links/system/system_ipc_listMP.c ListMP creation code. Each IPC link uses separate gate for each ListMP instance. The issue has got nothing to do with IPC gates. Your application if causing the ipcBitsInLink thread to get blocked
    Is there any relationship between ListMP and MessageQ? Will one part affect another part?
    No. MessageQ uses its own instance of ListMP different from the ListMP instance used for IPC links.
    Syslink have latest 2.21 version. Current we use 2.20 (DVR_RDK 3.5). Can we upgrade syslink to 2.21 in DVR_RDK3.5? Do you think we need to update it?
    It is better you migrate since there are some memory leaks fixed in last syslink release. The issue you are seeing will not get resolved simply by migrating syslink version. Migrating syslink version is not trivial. You will have to migrate lot of dependent components like cgtools,ipc,bios,xdc etc.
  • Dear Badri,
    By applying your dvr_rdk_ipcbitsin_exectrack.patch, here is the log that indicate "ListMP_getHead" is blocked.
    We are not familiar with these dvr_rdk code.
    Could you plz help us to clarify and resolve there issues?!
    thx ~
    [host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:2880080,TimeSinceLastFree:2880080.IPBITSINEXECSTATE:0xe0
    [host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:546,TimeSinceLastFree:546.IPBITSINEXECSTATE:0xe0
    [host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:675,TimeSinceLastFree:675.IPBITSINEXECSTATE:0xe0
    [host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:562,TimeSinceLastFree:562.IPBITSINEXECSTATE:0xe0
    (repeat)
    My modified ipcBitsInLink_tsk.c:
    #include <stddef.h>
    #if 1 // debug_code
    #endif
    static
    static
        Int32 status;
            else
    #if 1 // debug_code
               "IPBITSINEXECSTATE:0x%x\n",
               pObj->execStage);
    #else
    #endif
        return NULL;
    static
    static
        Int32 status;
    #endif
        status =
            Ptr listElem =
                                       "Stale entry:[%p]",
                                       listElem);
    #if 1 // debug_code
    #endif
        OSA_printf(" %d: IPC_BITS_IN   : Create Done pObj->execStage(0x%x)!!!\n",
                   OSA_getCurTimeInMsec(),pObj->execStage);
    #endif
    #if 1 // debug_code
    static
    Int32 IpcBitsInLink_stop(IpcBitsInLink_Obj * pObj)
        pObj->state = IPC_BITS_IN_LINK_STATE_INACTIVE;
        OSA_printf(" %d: IPC_BITS_IN   : Stop Done !!!\n",
    #endif
    #endif
        Int32 status;
    #endif
    #if 1// debug_code
    #endif
    #endif
                   FALSE);
        UInt32 numBitBufs;
        Int32 status;
        UInt32 curTime;
    #if 1//def debug_code
    	UInt32 t1,t2;//debug code
    #endif
    #if 1 //debug_code
    #endif
        numBitBufs = 0;
    #if 1// debug_code
    #endif
        while (1)
        	t1=OSA_getCurTimeInMsec();//debug code
    #endif
    #if 1 // debug_code
    #endif
    #if 1 // debug_code
    #endif
                break;
    #if 1 // debug_code
    #endif
    #if 1 // debug_code
    #endif
        	t2=OSA_getCurTimeInMsec();
    		if((t2-t1)>16)//debug code
    			OSA_Log(MCFW_LEVEL_LOG,"%s,id:%x,Diff:%d,Data from M3 to A8 too slow \n",__FUNCTION__,pObj->tskId,t2-t1);
    #endif
    #if 1 // debug_code
    #endif
            status =
    #if 1 // debug_code
    #endif
            numBitBufs++;
    #if 1 // debug_code
    #endif
    #endif
        if (numBitBufs)
    #if 1 // debug_code
    #endif
    #if 1 // debug_code
    #endif
    #if 1 // debug_code
    #endif
    static
        UInt32 idx;
        Int32 status;
        UInt32 curTime;
    #if 1
    	UInt32 bufNum=1;
    #else
    #endif
    #if 0
            status =
    #else
    #endif
                break;
    static
        UInt32 bufId;
        Int32 status;
        UInt32 curTime;
    #endif
                                       0);
                           pBitBuf->addr);
                status =
                                     prevLinkId);
    #if 1 // debug_code
    #endif
                              Uint32 curState)
        Bool ackMsg, done;
    #if 1 // debug_code
    #else
    #endif
            return status;
    #if 1 // debug_code
    #else
    #endif
            return status;
        done = FALSE;
        ackMsg = FALSE;
        while (!done)
    #if 1 // debug_code
    #endif
    #if 1 // debug_code
    #endif
                break;
            switch (cmd)
    #if 1 // debug_code
    #endif
                    done = TRUE;
                    ackMsg = TRUE;
                    break;
    #if 1 // debug_code
    #else
    #endif
                    break;
    #if 1 // debug_code
                     break;
    #endif
                default:
    #if 1 // debug_code
    #else
    #endif
                    break;
    #if 1 // debug_code
    #endif
    #endif
    #if 1 // debug_code
    #else
    #endif
        Int32 status;
        UInt32 ipcBitsInId;
        char tskName[32];
            pObj->tskId =
                                   IPC_LINK_TSK_PRI,
        return status;
        UInt32 ipcBitsInId;
        OSA_TskHndl * pTsk;
        Int status;
        return status;
        OSA_TskHndl * pTsk;
        Int status;
        return status;
    HB
  • ListMP_get is a non-blocking call. Control cant be inside ListMP_get. Add additional debug code and confirm ListMP_get  is invoked and didn't return for more than 500 ms or if control is not exiting the surrounding while loop. If control is really stuck inside ListMP_get it can only indicate ListMP_get is not able to acquire remote Gate which means remote ipc link on M3 acquired gate and crashed. THis is unlikely so first confirm where control is actually stuck.
  • Dear Badri,
    If we set kernel configuration "CONFIG_PREEMPT=y",
    will this setting cause the stuck of ListMP_get?
    HB
  • Have You found a solution for this issue ?
    I have a similar problem:
    e2e.ti.com/.../1378158
