Other Parts Discussed in Thread: OMAPL138
I am following the steps in the IPC Install Guide Linuxand have become stuck at the ipc-bios.mak step. The previous steps complete successfully, however the command to build ipc-nios fails. I've copied the error message and products.mak below.
[rpreston@local-pc ipc_3_22_00_05]$ make -f ipc-bios.mak all building ipc packages ... making all: Fri Jun 13 10:16:43 EDT 2014 ... ======== .interfaces [./packages/ti/grcm/] ======== making package.mak (because of package.bld) ... js: "/home/rpreston/ti/ipc_3_22_00_05/ipc-bios.bld", line 160: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: can't locate the package 'gnu.targets.arm' along the path: '/home/rpreston/ti/bios_6_37_00_20/packages;/home/rpreston/ti/xdctools_3_30_02_35_core_eng/packages;../..;'. Ensure that the package path is set correctly. gmake[1]: *** No rule to make target `package.mak', needed by `.interfaces'. Stop. gmake: *** [packages/ti/grcm/,.interfaces] Error 2 make: *** [all] Error 2
Products.mak :
# Copyright (c) 2012-2014, Texas Instruments Incorporated
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of Texas Instruments Incorporated nor the names of
# its contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
# THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
# OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
# OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
# EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# ======== products.mak ========
# Note that these variables can be explicitly set here or on the command line.
# If you want to use variables in the environment, see the GNU make manual's
# -e option: http://www.gnu.org/software/make/manual/make.html#Environment
# Optional: recommended to install all dependent components in one folder.
#DEPOT = _your_depot_folder_
DEPOT = /home/rpreston
# Platform to build for
# Supported platforms (choose one):
# OMAPL138, OMAP54XX, DRA7XX, 66AK2E, TCI6630, TCI6636, TCI6638
# Note, this is used for Linux, QNX and BIOS builds
PLATFORM = TCI6638
# Destination when installing the built binaries
# Note, this is used for Linux (if you use ipc-linux.mak to run the
# configure command), QNX and BIOS.
DESTDIR =
#################### IPC Linux ####################
# Set up required cross compiler path for IPC Linux configuration and build
TOOLCHAIN_LONGNAME = arm-linux-gnueabihf
#TOOLCHAIN_LONGNAME = arm-none-linux-gnueabi
#TOOLCHAIN_INSTALL_DIR = $(DEPOT)/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_7-2013q3
TOOLCHAIN_INSTALL_DIR = $(DEPOT)/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux
TOOLCHAIN_PREFIX = $(TOOLCHAIN_INSTALL_DIR)/bin/$(TOOLCHAIN_LONGNAME)-
# Path to Linux Kernel - needed to build the IPC user libraries
KERNEL_INSTALL_DIR = /var/lib/nfsdir/rpreston/usr/include
# Optional: Path to DRM Library
DRM_PREFIX = $(DEPOT)/ti/libdrm-2.4.42
# Optional: Path to TI Linux Utils product
CMEM_INSTALL_DIR = $(DEPOT)/arago-2013.12/sysroots/cortexa15hf-vfp-neon-3.8-oe-linux-gnueabi/usr/lib/
#################### IPC QNX ####################
# Path to QNX tools installation
QNX_INSTALL_DIR =
#################### IPC Bios ####################
# Path to required dependencies for IPC BIOS builds
XDC_INSTALL_DIR = $(DEPOT)/ti/xdctools_3_30_02_35_core_eng
BIOS_INSTALL_DIR = $(DEPOT)/ti/bios_6_37_00_20
# Do you want to build SMP-enabled libraries (if supported for your target)?
# Set to either 0 (disabled) or 1 (enabled)
BIOS_SMPENABLED=1
# Path to various cgtools
ti.targets.C28_large =
ti.targets.C28_float =
ti.targets.elf.C64P =
ti.targets.elf.C64P_big_endian =
ti.targets.elf.C64T =
ti.targets.elf.C66 =
ti.targets.elf.C66_big_endian =
ti.targets.elf.C674 =
ti.targets.arm.elf.Arm9 =
ti.targets.arm.elf.A8F =
ti.targets.arm.elf.A8Fnv =
ti.targets.arm.elf.M3 =
ti.targets.arm.elf.M4 =
ti.targets.arm.elf.M4F =
ti.targets.arp32.elf.ARP32 =
ti.targets.arp32.elf.ARP32_far =
gnu.targets.arm.A8F =
#gnu.targets.arm.A15F = $(DEPOT)/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_7-2013q3
gnu.targets.arm.A15F = $(DEPOT)/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux
