Hello Dear Experts!
I have dm8107 dvr and I try to build rdk 3.5 and start dvrmain.
I use "DVR_RDK_BOARD_TYPE=DM810X_UD_DVR" option for building.
When I start dvrmain as
./init.sh n
./load.sh
$dvrapp_dir/dvrmain -qws hdmi0 hdmi1 &
I get following assert:
root@dvr:~# gVIDEOMOTION_ctrl.bufSize = 25344
gVIDEOMOTION_ctrl.bufNum = 16
app_pb: app_playback_init ... success
--------------- CHANNEL DETAILS-------------
Capture Channels => 16
Enc Channels => Primary 16, Secondary 16
Dec Channels => 16
Disp Channels => 32
[host] 2086: IPC_BITS_IN : Create Done !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3vpss ] 10012: IPC_IN_M3 : Create in progress !!!
[m3video] ENCLINK_H264:HEAPID:3 USED:45056
[m3vpss ] 10012: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3video] 9946: ENCODE: Creating CH4 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3vpss ] 10012: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3vpss ] 10013: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 10015: IPC_IN_M3 : Create Done !!!
[m3vpss ] 10017: MERGE : Create Done !!!
[m3video] ENCLINK_H264:HEAPID:3 USED:503808
[m3video] 9950: ENCODE: Creating CH5 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3vpss ] 10022: DUP : Create Done !!!
[m3vpss ] 10022: SWMS: Create in progress !!!
[m3video] 9954: ENCODE: Creating CH6 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3video] 9958: ENCODE: Creating CH7 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[m3video] 9963: ENCODE: Creating CH8 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3vpss ] SWMS: instance 0, sc id 4, start win 0 end win 17
ASSERT (multich_progressive_4d1_vcap_venc_vdec_vdis.c|MultiCh_createProgressive4D1VcapVencVdecVdis|1192)
[m3vpss ] 10070: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 10070: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3video] ENCLINK_H264:HEAPID:3 USED:1511424
[m3vpss ] 10071: SWMS : Co-effs Loading ... DONE !!!
[m3video] 9972: ENCODE: Creating CH9 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
[m3vpss ] 10071: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 10072: SWMS0 : Loading Vertical Co-effs (11/16)x ...
[m3vpss ] 10072: SWMS0 : Loading Horizontal Co-effs (7/16)x ...
[m3video] 9982: ENCODE: Creating CH10 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 1200 Kbps ...
[m3vpss ] 10072: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
This ssert is "OSA_assert(inChInfo.numCh == gVdecModuleContext.vdecConfig.numChn);"
I found out that inChInfo.numCh is 4 but gVdecModuleContext.vdecConfig.numChn is 16!
Then I changed gVdecModuleContext.vdecConfig.numChn on 4!
Now I get another assert :
[m3video] 10072: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] 10147: DISPLAY: Create Done !!!
[m3vpss ] 10148: DISPLAY: Create in progress !!!
[m3vpss ] 10148: DISPLAY: 43: Field Separate Mode ENABLED for Que 0 !!!
[m3video] 10075: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 10149: DISPLAY: Create Done !!!
[m3video] 10081: IPC_OUT_M3 : Create in progress !!!
[m3video] 10082: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 10502: DISPLAY: Start in progress !!!
[m3vpss ] 10557: DISPLAY: Start Done !!!
[m3vpss ] 10557: DISPLAY: AUX PATH: 36 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !
[m3vpss ] 10557: DISPLAY: Start in progress !!!
[m3vpss ] 10623: DISPLAY: Start Done !!!
[m3vpss ] 10624: DISPLAY: DVO2(BP1) : 14 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0
[m3vpss ] 10624: SWMS: Start in Progress !!!
[m3vpss ] 10624: SWMS: Start Done !!!
[m3vpss ] 11065: CAPTURE: Start in progress !!!
[m3vpss ] 11065: CAPTURE: Start Done !!!
[m3vpss ] 11165: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 11173: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 11192: DISPLAY: Stop in progress !!!
[m3vpss ] CAPTURE : Capture FPS: 0.0 fps ... in 4294956.1 secs
[m3vpss ] 11239: CAPTURE: Dynamic resolution change: width: 720, height: 576!
[m3vpss ] 11257: DISPLAY: Stop Done !!!
[m3vpss ] 11257: DISPLAY: Stop in progress !!!
[m3vpss ] 11257: Assertion @ Line: 1745 in links_m3vpss/display/displayLink_drv.c: status == FVID2_SOK : failed !!!
[m3video] 14287: SCD: CH4: NO Tamper Detected !!!
[m3video] 14298: SCD: CH5: NO Tamper Detected !!!
[m3video] 14310: SCD: CH6: NO Tamper Detected !!!
[m3video] 14320: SCD: CH7: NO Tamper Detected !!!
[m3video] 14473: SCD: CH4: Tamper Detected !!!
[m3video] 14480: SCD: CH5: Tamper Detected !!!
[m3video] 14489: SCD: CH6: Tamper Detected !!!
[m3video] 14495: SCD: CH7: Tamper Detected !!!
[m3vpss ] CAPTURE : Capture FPS: 238.3 fps ... in 10.0 secs
[m3vpss ] CAPTURE : Capture FPS: 239.2 fps ... in 10.0 secs
[m3vpss ] CAPTURE : Capture FPS: 238.4 fps ... in 10.0 secs
[m3vpss ] CAPTURE : Capture FPS: 238.8 fps ... in 10.0 secs
Could you help me with this problem?
Thank you!
