I installed the Graphics SDK 05.00.00.01 .When I compiled the Graphics SDK 05.00.00.01 with Linux-3.12,got the following error:
/home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: warning: ld-linux-armhf.so.3, needed by /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Builds/OGLES/LinuxARMV7/Lib/libGLES_CM.so, not found (try using -rpath or -rpath-link) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTModelPOD.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTModelPOD.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTVertex.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTVertex.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTglesExt.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTglesExt.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTPrint3D.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTPrint3D.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTPrint3DAPI.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTPrint3DAPI.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTTexture.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTTexture.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTTextureAPI.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTTextureAPI.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTResourceFile.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTResourceFile.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTString.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTString.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTUnicode.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTUnicode.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTVector.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTVector.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTError.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTError.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTMatrixF.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTMatrixF.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTQuaternionF.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTQuaternionF.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTTrans.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTTrans.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTDecompress.o) uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Tools/OGLES/Build/LinuxGeneric/../LinuxARMV7/ReleaseRaw/liboglestools.a(PVRTDecompress.o) /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Builds/OGLES/LinuxARMV7/Lib/libGLES_CM.so uses VFP register arguments, ../LinuxARMV7/ReleaseRaw/OGLESFilmTV does not /home/hzc/crosstools/arm-2013.05/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/hzc/OpenGL/Graphics_SDK_5_00_00_01/GFX_Linux_SDK/OGLES/SDKPackage/Builds/OGLES/LinuxARMV7/Lib/libGLES_CM.so collect2: error: ld returned 1 exit status
But I compiled the modules successfully with the command ''make all BUILD=debug OMAPES=8.x all_km''
