DM8148 kernel crash: Unable to mount root fs via NFS... . PHY - Marvell Alaska 88E1512
Other Parts Discussed in Thread: PCF8575, TPS65910, PMP, TVP5158
Hello firends.
Have an problem with DM8148 on custom board and NFS.
Kernel loaded via TFTP strated to work, ip assigned and crashed on mount fs on NFS.
See below console log.
On board:
PHY - Marvell Alaska 88E1512.
CPU - DM8148 (PG3.0)
Used multichannel framework from ud-works, version 3.5
Wants remark that with this NFS and boot parameters Mistral DM8148 EVM works fine.
My boot parameters:
bootfile='uImage512'
serverip='10.0.0.9'
ipaddr='10.0.0.11'
rootdelay='15'
bootcmd='tftp 0x81000000 uImage512;bootm 0x81000000'
bootargs='mem=128M ddr_mem=512M console=ttyO0,115200n8 root=/dev/nfs rw rootfstype=jffs2 nfsroot=10.0.0.9:/home/marat/workdir/SmartCore/trunk/target/rfs_814x ip=10.0.0.11:10.0.0.9:10.0.0.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xbfd00000'
Here console prints:
link up on port 0, speed 1000, full duplex
Using cpsw device
TFTP from server 10.0.0.9; our IP address is 10.0.0.11
Filename 'uImage512'.
Load address: 0x81000000
Loading: #################################################################
done
Bytes transferred = 2770472 (0x2a4628)
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-2.6.37+
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2770408 Bytes = 2.6 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37+ (marat@marat-ubuntu) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #4 Thu Jun 19 17:36:26 IDT 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
vram size = 20971520 at 0x0
ti81xx_reserve: ### Reserved DDR region @87f00000
reserved size = 20971520 at 0x0
FB: Reserving 20971520 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 3.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 27136
Kernel command line: mem=128M ddr_mem=512M console=ttyO0,115200n8 root=/dev/nfs rw rootfstype=jffs2 nfsroot=10.0.0.9:/home/marat/workdir/SmartCore/trunk/target/rfs_814x ip=10.0.0.11:10.0.0.9:10.0.0.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xbfd00000
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 106MB 1MB = 107MB total
Memory: 102492k/102492k available, 28580k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc8800000 - 0xf8000000   ( 760 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0042000   ( 232 kB)
      .text : 0xc0042000 - 0xc053a000   (5088 kB)
      .data : 0xc053a000 - 0xc05877c0   ( 310 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x87f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio38
NOR: Can't request GPMC CS
clk get on i2c3 fck failed
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
registered ti81xx_vin device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xc8820000
ti81xx_pcie: forcing link width - x1
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
ti81xx_pcie: PCI scan done.
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
I2C: Transfer failed at pcf8575_cir_enable 256 with error code: -121
pcf857x: probe of 1-0021 failed with error -121
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1200 mV
regulator: VDD2: 600 <--> 1500 mV at 1200 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65910 1-002d: No interrupt support, no core IRQ
omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(29 12 14)
usb2phy: override computed values rxcalib(15)DACs(29 12 14)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6ed976
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c881e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(22 15 15)
usb2phy: override computed values rxcalib(15)DACs(22 15 15)
usb2phy_config: musb(1) rxcalib done, rxcalib read value 6f6b5f7e
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c8826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 200
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
ti81xx_interrupt 991: VBUS error workaround (delay coming)
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
ahci probe: devid name is ahci
ahci CAP register dump =0x6726ff80
Modified ahci CAP register dump =0x6f26ff80
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
omap2-nand driver initializing
ONFI flash detected
NAND device: Maf ID: 0x2c, Chip ID: 0xbc (Micron, )
 erasesize: 0x20000, writesize: 2048, oobsize: 64
Creating 7 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000580000 : "U-Boot Logo"
0x000000580000-0x0000009c0000 : "Kernel"
0x0000009c0000-0x00000d1e0000 : "File System"
0x00000d1e0000-0x000020000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
CAN device driver interface
CAN bus driver for Bosch D_CAN controller 1.0
d_can d_can: d_can device registered (irq=52, irq_obj=53)
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
ata1: SATA link down (SStatus 0 SControl 300)
qt602240_ts 1-004a: __qt602240_read_reg: i2c transfer failed
qt602240_ts: probe of 1-004a failed with error -5
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbfd00000
usbcore: registered new interface driver snd-usb-audio
Registered tvp5158 audio codec
*** Forcing SW CTS!
asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
  #0: TI81XX SOUND0
  #1: TI81XX SOUND1
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=7c:66:9d:36:b3:96
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
CPSW phy found : id is : 0x1410dd1
PHY 0:01 not found
IP-Config: Complete:
     device=eth0, addr=10.0.0.11, mask=255.255.255.0, gw=10.0.0.1,
     host=10.0.0.11, domain=, nis-domain=(none),
     bootserver=10.0.0.9, rootserver=10.0.0.9, rootpath=
PHY: 0:00 - Link is Up - 1000/Full
VFS: Unable to mount root fs via NFS, trying floppy.
List of all partitions:
1f00             128 mtdblock0  (driver?)
1f01            2304 mtdblock1  (driver?)
1f02             128 mtdblock2  (driver?)
1f03            3072 mtdblock3  (driver?)
1f04            4352 mtdblock4  (driver?)
1f05          204928 mtdblock5  (driver?)
1f06          309376 mtdblock6  (driver?)
No filesystem could mount root, tried:  jffs2
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
Backtrace:
[<c005096c>] (dump_backtrace+0x0/0x110) from [<c03e4148>] (dump_stack+0x18/0x1c)
 r6:00008000 r5:c5c08006 r4:c05883d0 r3:c0556ec4
[<c03e4130>] (dump_stack+0x0/0x1c) from [<c03e41ac>] (panic+0x60/0x17c)
[<c03e414c>] (panic+0x0/0x17c) from [<c0009288>] (mount_block_root+0x1d8/0x218)
 r3:00000000 r2:00000020 r1:c6429f58 r0:c04b190c
[<c00090b0>] (mount_block_root+0x0/0x218) from [<c0009374>] (mount_root+0xac/0xcc)
[<c00092c8>] (mount_root+0x0/0xcc) from [<c0009504>] (prepare_namespace+0x170/0x1d4)
 r4:c0587824
[<c0009394>] (prepare_namespace+0x0/0x1d4) from [<c00087bc>] (kernel_init+0x114/0x154)
 r5:c00086a8 r4:c05877c0
[<c00086a8>] (kernel_init+0x0/0x154) from [<c0079e50>] (do_exit+0x0/0x5e0)
 r4:00000000 r3:000000
I would be very glad for any suggestions.
  • Are you intentionally setting rootfstype=jffs2 ? Why are you doing this for nfs mount ? Check if you are able to mount the nfs share from uboot prompt. This will confirm there is no network connectivity or nfs share permission issue.
  • Hello Badri,
    thanX alot for your reply.
    I removed the jffs type and unfortunatelly have same a problem as in listed below log.
    From u-boot NFS isn't accessible, when type nfs from u-boot promt:
    "link up on port 0, speed 1000, full duplex
    Using cpsw device
    File transfer via NFS from server 10.0.0.9; our IP address is 10.0.0.11
    Filename 'uImage512/'.
    Loading: *** ERROR: Cannot mount
    T T T T T... "
    But when type tftp from u-boot promt, kernel loaded via TFTP without any problem:
    "Opgal_SCP#tftp
    Using cpsw device
    done
    Bytes transferred = 2770244 (0x2a4544)"
    NFS exports defined in file /etc/exports as:
    "/home/marat/workdir/SmartCore/trunk/target/rfs_814x *(rw,no_root_squash,no_all_squash,sync)"
    Iw want add that this NFS works fine on Mistral EVM.
    Please, tell me, I'm understood correctly: network devices (such EMAC and ethernet PHY) on nfs mount stage from kernel, already serviced by kernel driver and not keeps setting from u-boot?
  • Hi Badri,
    I am working on Mistral DM8148 EVM(Rev D) , trying to boot file system from NFS, not able to succeed.
    Help me out to resolve this problem.
    Please find the logs below.
    Boot parameters:
    bootfile='uImage'
    serverip='192.168.1.15'
    ipaddr='192.168.1.168'
    rootdelay='15'
    bootcmd='tftp 0x81000000 uImage;bootm 0x81000000'
    bootargs='mem=128M console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=192.168.1.15::/home/coreel/targetfs ip=192.168.1.168:192.168.1.15:192.168.1.1:255.255.255.0::eth0:off
    Log:
    U-Boot 2010.06 (Sep 03 2014 - 12:31:51)
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    DRAM:  2 GiB
    NAND:  HW ECC Hamming Code selected
    256 MiB
    Using default environment
    The 2nd stage U-Boot will now be auto-loaded
    Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
    Hit any key to stop autoboot:  0
    NAND read: device 0 offset 0x20000, size 0x40000
     262144 bytes read: OK
    ## Starting application at 0x81000000 ...
    U-Boot 2010.06 (Sep 03 2014 - 12:40:57)
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    I2C:   ready
    DRAM:  2 GiB
    256 MiB
                              .:;rrr;;.
                        ,5#@@@@#####@@@@@@#2,
                     ,A@@@hi;;;r5;;;;r;rrSG@@@A,
                   r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
                 :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
                B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
               @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
              @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
             @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
            G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
            @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
           X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
           @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
           @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
           @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
           @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
           M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
           :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
            @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
             @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
             ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
              r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
               ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
                 B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
                  .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
                    .A@@#5r;;;r;;;rrr;r:r#AsM@@H.
                       ;&@@@@MhXS5i5SX9B@@@@G;
                           :ihM#@@@@@##hs,
    MMC:   OMAP SD/MMC: 0
    Net:   Detected MACID:0:18:32:61:57:18
    cpsw
    Hit any key to stop autoboot:  3 2 1 0
    Using cpsw device
    TFTP from server 192.168.1.15; our IP address is 192.168.1.168
    Filename 'uImage'.
    Loading: *T #################################################################
    done
    Bytes transferred = 2620812 (27fd8c hex)
       Data Size:    2620748 Bytes = 2.5 MiB
    OK
    Starting kernel ...
    Linux version 2.6.37 (coreel@VideoLabPC01) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #6 Fri Sep 5 18:18:42 IST 2014
    Machine: ti8148evm
    OMAP chip is TI8148 2.0
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 27392
    Kernel command line: mem=128M ddr_mem=512M console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=192.168.1.15:/home/coreel/targetfs ip=192.168.1.168:192.168.1.15:192.168.1.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xbfd00000
    Memory: 108MB = 108MB total
    Memory: 103808k/103808k available, 27264k reserved, 0K highmem
          .init : 0xc0008000 - 0xc003a000   ( 200 kB)
          .text : 0xc003a000 - 0xc04f8000   (4856 kB)
          .data : 0xc04f8000 - 0xc0541780   ( 294 kB)
    NR_IRQS:407
    GPMC revision 6.0
    regulator: dummy:
    registered ti814x_vpss device
    registered TI814x on-chip HDMI device
    Registered ti81xx_fb device
    vgaarb: loaded
    Cppi41 Init Done
    omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    pcf857x 1-0021: gpios 128..143 on a pcf8575
    usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
    TCP reno registered
    msgmni has been set to 202
    brd: module loaded
    loop: module loaded
    ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
    NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
    Creating 6 MTD partitions on "omap2-nand.0":
    0x000000280000-0x0000006c0000 : "Kernel"
    0x0000006c0000-0x00000cee0000 : "File System"
    0x00000cee0000-0x000010000000 : "Reserved"
    davinci_mdio davinci_mdio.0: detected phy mask fffffffc
    davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
    Atheros(R) L2 Ethernet Driver - version 2.2.3
    Copyright (c) 2007 Atheros Corporation.
    qt602240_ts 1-004a: Family ID: 128 Variant ID: 1 Version: 22 Build: 171
    qt602240_ts 1-004a: Matrix X Size: 18 Matrix Y Size: 12 Object Num: 17
    input: AT42QT602240/ATMXT224 Touchscreen as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/input/input0
    ALSA device list:
      #0: TI81XX EVM
    Detected MACID=0:18:32:61:57:18
    mmc0: new high speed SDHC card at address e624
    mmcblk0: mmc0:e624 SD08G 7.40 GiB
     mmcblk0: p1 p2
    CPSW phy found : id is : 0x4dd074
     Phy Address is 0
     In CTRL_1000
     Phy Address is 1
     In CTRL_1000IP-Config: Complete:
         device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=192.168.1.1,
         host=192.168.1.168, domain=, nis-domain=(none),
         bootserver=192.168.1.15, rootserver=192.168.1.15, rootpath=
    PHY: 0:01 - Link is Up - 0/Half
    PHY: 0:01 - Link is Down
    VFS: Cannot open root device "nfs" or unknown-block(2,0)
    Please append a correct "root=" boot option; here are the available partitions:
    1f03            4352 mtdblock3  (driver?)
    1f04          204928 mtdblock4  (driver?)
    1f05           50304 mtdblock5  (driver?)
    b300         7761920 mmcblk0  driver: mmcblk
      b301           40131 mmcblk0p1 00000000-0000-0000-0000-000000000mmcblk0p1
      b302         7719232 mmcblk0p2 00000000-0000-0000-0000-000000000mmcblk0p2
    Backtrace:
    [<c0048b70>] (dump_backtrace+0x0/0x110) from [<c03b3780>] (dump_stack+0x18/0x1c)
     r7:c6739000 r6:00000000 r5:c002dcec r4:c0541f10
    [<c03b3768>] (dump_stack+0x0/0x1c) from [<c03b37e4>] (panic+0x60/0x17c)
    [<c03b3784>] (panic+0x0/0x17c) from [<c0009258>] (mount_block_root+0x1e0/0x220)
     r3:00000000 r2:00000000 r1:c6423f58 r0:c04793ec
    [<c0009078>] (mount_block_root+0x0/0x220) from [<c0009344>] (mount_root+0xac/0xcc)
    [<c0009298>] (mount_root+0x0/0xcc) from [<c00094d4>] (prepare_namespace+0x170/0x1d4)
     r4:c05417e4
    [<c0009364>] (prepare_namespace+0x0/0x1d4) from [<c0008784>] (kernel_init+0x114/0x154)
     r5:c0008670 r4:c0541780
    [<c0008670>] (kernel_init+0x0/0x154) from [<c006e694>] (do_exit+0x0/0x5e4)
     r5:c0008670 r4:00000000
  • Hi Kiran,
    Are you using EZSDK or DVR RDK or IPNC RDK?
    See if the below e2e thread will be in help:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/716/p/321330/1120624.aspx#1120624
    BR
    Pavel
  • Hi Pavel,
    I am using EZSDK and i followed the procedure to boot from SD Card and NFS for file system.
    when i am giving dhcp in uboot,it's not getting response from dhcp server
    Log:
    TI8148_EVM#dhcp
    link up on port 0, speed 100, full duplex
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    BOOTP broadcast 6
    BOOTP broadcast 7
    BOOTP broadcast 8
    BOOTP broadcast 9
    BOOTP broadcast 10
    Retry count exceeded; starting again
    Instead of dhcp, using static ip addr.Is there any switch setting to load file system using NFS?
    My boot parameters,
    setenv ipaddr 192.168.1.168
    setenv ethaddr 00:18:32:61:57:18
    ping 192.168.1.15
    mmc rescan 0
    fatload mmc 0 0x80009000 uImage
    setenv autoload no
    setenv bootargs 'console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.1.15:/home/coreel/targetfs,nolock rw mem=364M@0x80000000 mem=320M@0x9FC00000 vmalloc=500M notifyk.vpssm3_sva=0xBF900000 ip=192.168.1.168:192.168.1.15:192.168.1.1:255.255.255.0::eth0:off noinitrd'
    bootm 0x80009000
    It is giving same kernel panic error.
    Please help me out to resolve this issue.
    Thanks and regards,
    Kiran S Patil
  • Kiran,
    Log:
    TI8148_EVM#dhcp
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    BOOTP broadcast 6
    BOOTP broadcast 7
    BOOTP broadcast 8
    BOOTP broadcast 9
    BOOTP broadcast 10
    What is the version of the EZSDK you are using? Is it EZSDK 5.05.02.00?
    Do you have something (switch, hub, router) between the DM8148 EVM and your desktop PC?
    Pavel
  • Kiran,
    Regarding the static ip approach, make sure you are aligned with the below wiki:
    http://processors.wiki.ti.com/index.php/TI81XX_PSP_User_Guide#Boot_over_Network_.28Ethernet.29_2
    Pavel
  • Hi Pavel,
    Sorry for delayed response.
    I am able to bring up the board with NFS, in my PC DHCP server has not configured properly.
    Thanks a lot.
    Kiran S Patil
  • Hi Pavel,
    I am working on Mistral TI DM8148 EVM, ported DVR RDK4.0 on EVM, there are some issues while running decode+display demo.
    I am new to DVR RDK,help me out to understand DVR RDK.
    Logs:
    U-Boot 2010.06 (Oct 23 2013 - 12:52:42)
    TI8148-GP rev 2.1
    L3 clk         : 200MHz
    IVA clk        : 410MHz
    ISS clk        : 480MHz
    DSP clk        : 750MHz
    DSS clk        : 200MHz
    ARM clk        : 720MHz
    DDR clk        : 480MHz
    ------------ PLL Settings --------------
    OSC_0_FREQ    : 20MHz
    MODENA_N      : 1
    MODENA_M      : 72
    MODENA_M2     : 1
    L3_N          : 19
    L3_M          : 800
    L3_M2         : 4
    DSP_N         : 19
    DSP_M         : 750
    DSP_M2        : 1
    DSS_N         : 19
    DSS_M         : 800
    DSS_M2        : 4
    IVA_N         : 19
    IVA_M         : 820
    IVA_M2        : 2
    ISS_N         : 19
    ISS_M         : 960
    ISS_M2        : 2
    USB_N         : 19
    USB_M         : 960
    USB_M2        : 5
    DCO_HS2_MIN   : 500
    DCO_HS2_MAX   : 1000
    DCO_HS1_MIN   : 1000
    DCO_HS1_MAX   : 2000
    SELFREQDCO_HS2   : 2049
    SELFREQDCO_HS1   : 4097
    --------- DDR PLL ----------
    DDR_N             : 0x13
    DDR_M             : 0x3C0
    DDR_M2            : 0x2
    ----------EMIF Timings (identical for 0 & 1)-------
    DDR3_EMIF_READ_LATENCY : 0x170209
    DDR3_EMIF_TIM1         : 0xAAAD4DB
    DDR3_EMIF_TIM2         : 0x682F7FDA
    DDR3_EMIF_TIM3         : 0x501F82BF
    DDR3_EMIF_REF_CTRL     : 0xC30
    DDR3_EMIF_SDRAM_CONFIG : 0x61C011B2
    DDR3_EMIF_SDRAM_ZQCR   : 0x50074BE1
    ----------SW LEVEL Info (EMIF 0) -------
    DDR3_PHY_RD_DQS_CS0_BYTE0: 0x00000038
    DDR3_PHY_RD_DQS_CS0_BYTE1: 0x00000037
    DDR3_PHY_RD_DQS_CS0_BYTE2: 0x00000032
    DDR3_PHY_RD_DQS_CS0_BYTE3: 0x00000031
    DDR3_PHY_WR_DQS_CS0_BYTE0: 0x00000043
    DDR3_PHY_WR_DQS_CS0_BYTE1: 0x00000044
    DDR3_PHY_WR_DQS_CS0_BYTE2: 0x00000053
    DDR3_PHY_WR_DQS_CS0_BYTE3: 0x00000050
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE0: 0x000000E4
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE1: 0x00000111
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE2: 0x00000112
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE3: 0x0000013D
    DDR3_PHY_WR_DATA_CS0_BYTE0: 0x00000085
    DDR3_PHY_WR_DATA_CS0_BYTE1: 0x00000083
    DDR3_PHY_WR_DATA_CS0_BYTE2: 0x00000085
    DDR3_PHY_WR_DATA_CS0_BYTE3: 0x0000007F
    ----------SW LEVEL Info (EMIF 1) -------
    DDR3_PHY_RD_DQS_CS0_BYTE0: 0x0000003A
    DDR3_PHY_RD_DQS_CS0_BYTE1: 0x00000036
    DDR3_PHY_RD_DQS_CS0_BYTE2: 0x00000037
    DDR3_PHY_RD_DQS_CS0_BYTE3: 0x00000033
    DDR3_PHY_WR_DQS_CS0_BYTE0: 0x00000049
    DDR3_PHY_WR_DQS_CS0_BYTE1: 0x0000004E
    DDR3_PHY_WR_DQS_CS0_BYTE2: 0x00000054
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE0: 0x000000D3
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE1: 0x000000F7
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE2: 0x00000109
    DDR3_PHY_RD_DQS_GATE_CS0_BYTE3: 0x00000135
    DDR3_PHY_WR_DATA_CS0_BYTE0: 0x0000008A
    DDR3_PHY_WR_DATA_CS0_BYTE1: 0x00000080
    DDR3_PHY_WR_DATA_CS0_BYTE2: 0x0000007F
    DDR3_PHY_WR_DATA_CS0_BYTE3: 0x00000085
    DRAM:  1 GiB
    NAND:  HW ECC BCH8 Selected
    256 MiB
    U-Boot 2010.06 (Oct 23 2013 - 12:56:58)
    TI8148-GP rev 2.1
    L3 clk         : 200MHz
    IVA clk        : 410MHz
    ISS clk        : 480MHz
    DSP clk        : 750MHz
    DSS clk        : 200MHz
    ARM clk        : 720MHz
    DDR clk        : 480MHz
    OSC_0_FREQ    : 20MHz
    MODENA_N      : 1
    MODENA_M      : 72
    MODENA_M2     : 1
    L3_N          : 19
    L3_M          : 800
    L3_M2         : 4
    DSP_N         : 19
    DSP_M         : 750
    DSP_M2        : 1
    DSS_N         : 19
    DSS_M         : 800
    DSS_M2        : 4
    IVA_N         : 19
    IVA_M         : 820
    IVA_M2        : 2
    ISS_N         : 19
    ISS_M         : 960
    ISS_M2        : 2
    USB_N         : 19
    USB_M         : 960
    USB_M2        : 5
    DCO_HS2_MIN   : 500
    DCO_HS2_MAX   : 1000
    DCO_HS1_MIN   : 1000
    DCO_HS1_MAX   : 2000
    DDR_N             : 0x13
    DDR_M             : 0x3C0
    DDR_M2            : 0x2
    I2C:   ready
    DRAM:  1 GiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
                              .:;rrr;;.
                           :ihM#@@@@@##hs,
    cpsw
    NAND read: device 0 offset 0x280000, size 0x300000
     3145728 bytes read: OK
    Error writing the chip. SII9022A not accessible or not present
    VPDMA Firmware Version = 0x4d0001ad
    NAND read: device 0 offset 0x580000, size 0x300000
       Data Size:    2794332 Bytes = 2.7 MiB
    OK
    Starting kernel ...
    Linux version 2.6.37 (a0393400@bangvideoapps01) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Wed Oct 23 13:13:24 IST 2013
    Machine: ti8148evm
    bootconsole [earlycon0] enabled
    OMAP chip is TI8148 2.1
    Kernel command line: console=ttyO0,115200n8  root=/dev/nfs nfsroot=192.168.1.5:/home/coreel/dvrrdk/DVRRDK_04.01.00.02/target/rfs_814x,nolock rw mem=128M ip=dhcp earlyprintk notifyk.vpssm3_sva=0xBFD00000 ddr_mem=512M vram=20M
    Memory: 102384k/102384k available, 28688k reserved, 0K highmem
          .text : 0xc0042000 - 0xc054c000   (5160 kB)
          .data : 0xc054c000 - 0xc05a2a00   ( 347 kB)
    NR_IRQS:407
    GPMC revision 6.0
    Calibrating delay loop... 719.25 BogoMIPS (lpj=3596288)
    regulator: dummy:
    NSS Crypto DMA hardware revision 1.9 @ IRQ 116
    ti81xx_pcie: Register base mapped @0xc8830000
    vgaarb: loaded
    Cppi41 Init Done
    regulator: VDD1: 600 <--> 1500 mV at 1100 mV
    usb2phy: computed values rxcalib(15)DACs(35 13 16)
    usb2phy: override computed values rxcalib(15)DACs(35 13 16)
    usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f71db86
    usb2phy: computed values rxcalib(15)DACs(31 14 13)
    usb2phy: override computed values rxcalib(15)DACs(31 14 13)
    usb2phy_config: musb(1) rxcalib done, rxcalib read value 6f6fdd6e
    musb-hdrc musb-hdrc.1: USB Host mode controller at c882a800 using DMA, IRQ 19
    TCP reno registered
    msgmni has been set to 199
    alg: No test for stdrng (krng)
    nss_rng nss_rng: NSS Random Number Generator ver. 2.0
    console [ttyO0] enabled, bootconsole disabled
    brd: module loaded
    loop: module loaded
    ONFI param page 0 valid
    ONFI flash detected
    NAND device: Maf ID: 0x2c, Chip ID: 0xca (Micron, NAND 256MiB 3,3V 16-bit)
    omap2-nand: detected x16 NAND flash
    0x00000d1e0000-0x000010000000 : "Reserved"
    nss_aes_mod_init: loading NSS AES driver
    nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 0 @0x41140000)
    nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 1 @0x41141000)
    nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 2 @0x411a0000)
    nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 3 @0x411a1000)
    nss_aes_probe: probe() done
    nss_des_mod_init: loading NSS DES driver
    nss-des nss-des: NSS DES hw accel rev: 2.2 (context 0 @0x41160000)
    nss-des nss-des: NSS DES hw accel rev: 2.2 (context 1 @0x41161000)
    nss_des_probe: probe() done
    nss_sham_mod_init: loading NSS SHA/MD5 driver
    nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 0 @0x41100000)
    nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 1 @0x41101000)
    nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 2 @0x411c0000)
    nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 3 @0x411c1000)
    nss_sham_probe: probe() done
    *** Forcing SW CTS!
    ALSA device list:
      #0: TI81XX SOUND0
      #1: TI81XX SOUND1
    Sending DHCP requests .
    .., OK
    IP-Config: Got DHCP answer from 192.168.1.5, my address is 192.168.1.239
         device=eth0, addr=192.168.1.239, mask=255.255.255.0, gw=192.168.1.1,
         host=192.168.1.239, domain=, nis-domain=(none),
         bootserver=192.168.1.5, rootserver=192.168.1.5, rootpath=
    VFS: Mounted root (nfs filesystem) on device 0:15.
    devtmpfs: mounted
    Freeing init memory: 232K
    INIT: version 2.88 booting
     Mounting /dev/shm              :  Mounting /dev/pts          :  Mounting other filesystems :  Mounting /dev/sda1              : mount: mounting /dev/sda1 on /media/sda1 failed: No such file or directory
    Sync command ...Error opening /dev/fb0: No such file or directory
    Starting udev
    udev[113]: starting version 164
    Starting Bootlog daemon: bootlogd.
    Applying sync command
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dm814x ttyO0
    Arago 2012.10 dm814x ttyO0
    dm814x login: root
    root@dm814x:~# cd /opt/dvr_rdk/ti814x/
    root@dm814x:/opt/dvr_rdk/ti814x# ./init.sh
    *** Bootargs Validated for mem param ***
    *** Bootargs Validated for notifyk.vpssm3 params ***
    Kernel bootargs validated
    numid=1,iface=MIXER,name='PCM Playback Volume'
      ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
      : values=127,127
      | dBscale-min=-63.50dB,step=0.50dB,mute=0
     [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
     [m3video] Remote Debug Shared Memory @ 0xbff10820
     [m3vpss ] Remote Debug Shared Memory @ 0xbff21040
    SysLink version : 2.20.02.20
    SysLink module created on Date:Oct 23 2013 Time:13:14:36
    Trace enabled
    Trace SetFailureReason enabled
     Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
     Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
     *** TVP5158 probe : START ***
     TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
     TI DVR    : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b
     Device found     : I2C (0xXX): 0x08 = 0x51
                        I2C (0xXX): 0x09 = 0x58
     Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5c): 0x08 = 0x02
     I2C (0x5c): 0x09 = 0x80
     I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x59): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5b): Read ERROR !!! (reg[0x08], count = 2)
     *** TVP5158 probe : END ***
    /opt/dvr_rdk/ti814x
    root@dm814x:/opt/dvr_rdk/ti814x# ./load.sh
    Attached to slave procId 2.
    Loaded file ../firmware/dvr_rdk_fw_m3vpss_512M_128M.xem3 on slave procId 2.
    Started slave procId 2.
    After Ipc_loadcallback status [0x00000000]
     [m3vpss ]     ISS Freq  : 480 MHz
    After Ipc_startcallback status [0x00000000]
     [m3vpss ] ***** VPSS Firmware build time 13:27:33 Oct 23 2013  EDG gcc 3.0 mode
     [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 240000000
     [m3vpss ] notify_attach  rtnVal  0
     [m3vpss ] initProxyServer  rtnVal  0
     [m3vpss ]
     [m3vpss ]  *** UTILS: CPU KHz = 480000 Khz ***
     [m3vpss ]
     [m3vpss ]  43: SYSTEM  : System Common Init in progress !!!
     [m3vpss ]  43: SYSTEM: IPC init in progress !!!
     [m3vpss ]  44: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  46: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    Attached to slave procId 1.
    Loaded file ../firmware/dvr_rdk_fw_m3video_512M_128M.xem3 on slave procId 1.
    Started slave procId 1.
     [m3video]     ISS Freq  : 480 MHz
     [m3video] ***** VIDEO Firmware build time 13:28:27 Oct 23 2013  EDG gcc 3.0 mode
     [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 240000000
     [m3video]
     [m3video]  *** UTILS: CPU KHz = 480000 Khz ***
     [m3video]
     [m3video]  414: SYSTEM  : System Common Init in progress !!!
     [m3video]  414: SYSTEM: IPC init in progress !!!
     [m3video]  414: SYSTEM: Attaching to [HOST] ...
     [m3video]  417: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    Attached to slave procId 0.
    Loaded file ../firmware/dvr_rdk_fw_c6xdsp_512M_128M.xe674 on slave procId 0.
    Started slave procId 0.
     [c6xdsp ]     DSP Freq  : 750 MHz
     [m3video]  518: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3vpss ]  520: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [c6xdsp ] ***** VIDEO Firmware build time 13:26:24 Oct 23 2013  EDG gcc 3.0 mode
     [m3video]  521: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  521: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 500DMA: Module install successful, device major num = 251
    000000, <NEW> - DRV: Module install successful
    750000000
     [m3vDRV: Module built on Oct 23 2013 13:15:33
    ideo]  521: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
     [m3vpss ]  521: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
     [c6xdsp ]
     [m3video]  521: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  521: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
     [c6xdsp ]  *** UTILS: CPU KHz = 750000 Khz ***
     [m3video]  522: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
     [m3vpss ]  521: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
     [c6xdsp ]
     [m3video]  523: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  523: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  1: SYSTEM  : System Common Init in progress !!!
     [m3video]  524: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3vpss ]  524: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [c6xdsp ]  1: SYSTEM: IPC init in progress !!!
     [m3video]  524: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3vpss ]  524: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [c6xdsp ]  1: SYSTEM: Attaching to [HOST] ...
     [m3video]  524: SYSTEM: IPC init DONE !!!
     [m3vpss ]  524: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  4: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [c6xdsp ]  5: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [c6xdsp ]  7: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [c6xdsp ]  7: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
     [c6xdsp ]  7: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [c6xdsp ]  7: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [c6xdsp ]  7: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  7: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [c6xdsp ]  7: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [c6xdsp ]  8: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  10: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
     [c6xdsp ]  10: MEM: ERROR: SharedRegion_setEntry (2, 0x8fcef2dc) FAILED !!!  (status=-1)
     [m3video]  531: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
     [m3vpss ]  531: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
     [m3video]  532: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
     [m3vpss ]  531: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
     [m3video]  534: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  534: SYSTEM  : System Common Init Done !!!
     [m3video]  534: SYSTEM  : System Video Init in progress !!!
     [m3vpss ]  534: SYSTEM  : System VPSS Init in progress !!!
     [m3video]  534: SYSTEM  : System Video Init Done !!!
     [m3vpss ]  534: SYSTEM: All VPDMA Free !!!
     [m3video]  535: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [m3video]  535: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [m3video]  535: SYSTEM: ListElem Shared Addr = 0xbf173e00
     [m3video]  538: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [m3video]  538: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [m3video]  538: SYSTEM: ListElem Shared Addr = 0xbf177300
     [m3video]  545: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [m3video]  546: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [m3video]  546: SYSTEM: ListElem Shared Addr = 0xbf17a800
     [m3video]  549: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
     [m3video]  549: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
     [m3video]  549: SYSTEM: ListElem Shared Addr = 0xbf1a0000
     [m3video]  552: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
     [m3video]  552: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
     [m3video]  553: SYSTEM: ListElem Shared Addr = 0xbf1c5800
     [m3video]  569: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
     [m3vpss ] === I2C0/2 Clk is active ===
     [m3video]  570: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
     [m3vpss ]  557: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [m3video]  570: SYSTEM: ListElem Shared Addr = 0xbf1f1a00
     [m3vpss ]  557: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [m3video]  573: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
     [m3vpss ]  558: SYSTEM: ListElem Shared Addr = 0xbf1eb000
     [m3video]  573: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
     [m3vpss ]  560: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [m3video]  573: SYSTEM: ListElem Shared Addr = 0xbf210480
     [m3vpss ]  561: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
     [m3video]  575: HDVICP: Doing PRCM for IVAHD[0] ...
     [m3vpss ]  561: SYSTEM: ListElem Shared Addr = 0xbf1ee500
     [m3video]  576: HDVICP: PRCM for IVAHD[0] ... DONE.
     [m3vpss ]  579: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
     [m3video]  577: UTILS: DMA: HWI Create for INT62 !!!
     [m3vpss ]  579: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
     [m3video]  577: SYSTEM  : ISS Init in progress !!!
     [m3vpss ]  579: SYSTEM: ListElem Shared Addr = 0xbf22ef00
     [m3video]  578: SYSTEM  : ISS Power-ON in progress !!!
     [m3vpss ]  582: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
     [m3video]  587: SYSTEM  : ISS Power-ON in progress DONE !!!
     [m3vpss ]  582: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
     [m3video]  587: SYSTEM  : ISS Init in progress DONE !!!
     [m3vpss ]  582: SYSTEM: ListElem Shared Addr = 0xbf254700
     [m3video]  587: VCOP BOOST BIT is Set
     [m3vpss ]  585: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
     [m3video]  587: SYSTEM  : VCOP Init in progress !!!
     [m3vpss ]  586: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
     [m3video]  588: SYSTEM  : VCOP needs 172 B of memory !!!
     [m3vpss ]  586: SYSTEM: ListElem Shared Addr = 0xbf279f00
     [m3video]  589: SYSTEM  : VCOP Init in progress DONE !!!
     [m3vpss ]  588: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
     [m3video]  589: SYSTEM  : Initializing Links !!!
     [m3vpss ]  588: SYSTEM  : FVID2 Init in progress !!!
     [m3video]  589: SYSTEM  : FREE SPACE : System Heap      = 6263296 B, Mbx = 10240 msgs)
     [m3video]  590: SYSTEM  : FREE SPACE : SR0 Heap         = 6426368 B (6 MB)
     [m3vpss ] TILER_STATS: CNT :8BIT
     [m3video]  590: SYSTEM  : FREE SPACE : Frame Buffer     = 117440384 B (111 MB)
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 5440
     [m3video]  590: SYSTEM  : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 5436
     [m3video]  590: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  592: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89063424 B (84 MB)  - TILER ON
     [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  1
     [m3video]  592: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ] TILER_STATS: NUM USED BUCKETS:  0
     [m3video]  652: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   89063424 (99 %)
     [m3vpss ] Received character 's'
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   0 (0 %)
     [m3video] Received character 's'
     [m3vpss ] TILER_STATS: CNT :16BIT
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 1344
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 1344
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   44040192 (100 %)
     [m3vpss ]  668: SYSTEM  : FVID2 Init in progress DONE !!!
     [m3vpss ]  668: SYSTEM  : Device Init in progress !!!
     [m3vpss ]  756: SYSTEM  : Device Init in progress DONE !!!
     [m3vpss ]     HDVPSS Freq  : 220 MHz
     [m3vpss ]  802: SYSTEM  : System VPSS Init Done !!!
     [m3vpss ]  803: UTILS: DMA: HWI Create for INT63 !!!
     [m3vpss ]  804: SYSTEM  : Initializing Links !!!
     [m3vpss ]  804: SYSTEM  : FREE SPACE : System Heap      = 250280 B, Mbx = 10240 msgs)
     [m3vpss ]  804: SYSTEM  : FREE SPACE : SR0 Heap         = 6426368 B (6 MB)
     [m3vpss ]  804: SYSTEM  : FREE SPACE : Frame Buffer     = 113130368 B (107 MB)
     [m3vpss ]  804: SYSTEM  : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
     [m3vpss ]  806: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89063424 B (84 MB)  - TILER ON
     [m3vpss ]  806: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ]  954: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  954: SYSTEM  : Set Static L3 pressure for HDVPSS as High
     [c6xdsp ]  1010: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
     [c6xdsp ]  1010: SYSTEM  : System Common Init Done !!!
     [c6xdsp ]  1009: SYSTEM  : System DSP Init in progress !!!
     [c6xdsp ]  1009: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
     [c6xdsp ]  1014: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  1014: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
     [c6xdsp ]  1014: SYSTEM: ListElem Shared Addr = 0xbf29f700
     [c6xdsp ]  1015: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
     [c6xdsp ]  1015: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
     [c6xdsp ]  1015: SYSTEM: ListElem Shared Addr = 0x[module] vpss probe done.
    bf2c4f00
     [c6xdsp ]  1016: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
     [c6xdsp ]  1016: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
     [c6xdsp ]  1016: SYSTEM: ListElem Shared Addr = 0xbf2ea700
     [c6xdsp ]  1017: SYSTEM: Creating[module] ti81xxfb probe done.
     ListMP [DSP_IPC_OUT_24] in region 0 ...
     [c6xdsp ]  1017: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
     [c6xdsp ]  1017: SYSTEM: ListElem Shared Addr = 0xbf30ff00
     [c6xdsp ]  1018: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
     [c6xdsp ]  1018: SYSTEM: CreatingHDMI W1 rev 4.0
     ListMP [DSP_IPCHDMI CEC Spec version 1.2
     [c6xdsp ]  1018: SYSTEM: ListElem Shared Addr = 0xbf32e980
     [c6xdsp ] !!WARNING.Resource already registered:2
     [c6xdsp ]  1018: SYSTEM  : Initializing Links !!!
     [c6xdsp ]  1019: SYSTEM  : FREE SPACE : System Heap      = 6393472 B, Mbx = 10240 msgs)
     [c6xdsp ] Received character 's'
    /opt/dvr_rdk/ti814x
     [c6xdsp ]  1031: SYSTEM  : Initializing Links ... DONE !!!
     [c6xdsp ]  1031: SYSTEM  : System DSP Init Done !!!
    I2C No Ack
    HDMI failed to read E-EDID
     ORG 0x46c00524: 0
     NEW 0x46c00524: 2
    root@dm814x:/opt/dvr_rdk/ti814x# ./run.sh
     Main Menu
     1: 4CH VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     2: 8CH <D1+CIF> VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     3: 16CH RT VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     4: 16CH NRT <D1+CIF> VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     5:               VDEC + VDIS  - SD/HD Decode ONLY
     e: Exit
     Enter Choice: 5
     Sample ini files available in ./demo_ini folder.
     Enter the .ini filename with full path : /opt/dvr_rdk/ti814x/demo_ini/704x576_01_1CH.ini
     *** a new param codec is needed for ini, if you not sure about this
     *** please reference demo_ini/704x576_02_32CH.ini
     *** H264:  codec = h264
     *** MPEG4: codec = mpeg4
     *** MJPEG: codec = mjpeg
     *** MPEG2: codec = mpeg2
     *** Four new params numbuf ,displaydelay,tilerEnable,fieldPicture has been added for ini, if not defaults are set
     *** Generate header files ***
     This will take very long time if the file is large.
     - For first time you MUST select YES.
     - If you already have the header file on disk, you can select NO.
     Do you want to generate header ? (YES - y, NO - n) : yes
     0: Opening file [/data/704x576_01.h264] of 704 x 576  Codec: h264...
     0: WARNING: Either the displaydelay was not set or Default value was set as 0
     0: WARNING: Either the Num of output buffers not set or Default value was set as zero
     0: ERROR: File [/data/704x576_01.h264] not found !!!
     !!! There were some errors in accessing the one of the input files or width x height of the bitstreams. !!!
     !!! Please check, Continuing with the rest!!!
     File open ... DONE !!!
    --------------- CHANNEL DETAILS-------------
    Dec Channels => 1
    Disp Channels => 1
     0: SYSTEM: System Common Init in progress !!!
     0: SYSTEM: IPC init in progress !!!
     10: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
     10: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
     11: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
     11: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
     11: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
     13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
     14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
     16: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     17: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     18: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     19: SYSTEM: IPC init DONE !!!
     20: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     23: SYSTEM: ListElem Shared Addr = 0x40f38680
     24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     25: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
     27: SYSTEM: ListElem Shared Addr = 0x40f6f480
     28: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     32: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     33: SYSTEM: ListElem Shared Addr = 0x40fa6280
     34: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     36: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     37: SYSTEM: ListElem Shared Addr = 0x40fe9580
     38: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     40: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     41: SYSTEM: ListElem Shared Addr = 0x4102c880
     59: SYSTEM: System Common Init Done !!!
    ch[0], h264
     IOCTL_DEVICE_SII9022A_QUERY_HPD Failed!! This can happen because
     1. enableConfigExtVideoEncoder is set to TRUE and Sii9022A is absent in the system OR
     ASSERT (ti_vdis.c|Vdis_init|404)
     2. Loose connection between the board and the daugther card
    Thanks and regards,
    Kiran S Patil
