HI,
When I ran the script /etc/init.d/335x-demo at Linux command prompt after the AM335x EVM boots up,there was a mistake :
0x10205 release8.x installing 8.x SGX release user libraries Installing PowerVR Consumer/Embedded DDK 'sgxddk_1.10@2359475' on target File system installation root is / Uninstalling existing version sgxddk_1.10@2359475 Uninstallation completed. boot script rc.pvr -> /etc/init.d/rc.pvr kernel module pvrsrvkm.ko -> /lib/modules/3.12.10-ti2013.12.01/extra/pvrsrvkm.ko kernel module omaplfb.ko -> /lib/modules/3.12.10-ti2013.12.01/extra/omaplfb.ko shared library libGLES_CM.so -> /usr/lib/libGLES_CM.so.1.10.2359475 shared library libusc.so -> /usr/lib/libusc.so.1.10.2359475 shared library libGLESv2.so -> /usr/lib/libGLESv2.so.1.10.2359475 shared library libglslcompiler.so -> /usr/lib/libglslcompiler.so.1.10.2359475 shared library libIMGegl.so -> /usr/lib/libIMGegl.so.1.10.2359475 shared library libEGL.so -> /usr/lib/libEGL.so.1.10.2359475 shared library libpvr2d.so -> /usr/lib/libpvr2d.so.1.10.2359475 shared library libpvrPVR2D_BLITWSEGL.so -> /usr/lib/libpvrPVR2D_BLITWSEGL.so.1.10.2359475 shared library libpvrPVR2D_FLIPWSEGL.so -> /usr/lib/libpvrPVR2D_FLIPWSEGL.so.1.10.2359475 shared library libpvrPVR2D_FRONTWSEGL.so -> /usr/lib/libpvrPVR2D_FRONTWSEGL.so.1.10.2359475 shared library libpvrPVR2D_LINUXFBWSEGL.so -> /usr/lib/libpvrPVR2D_LINUXFBWSEGL.so.1.10.2359475 shared library libsrv_um.so -> /usr/lib/libsrv_um.so.1.10.2359475 shared library libsrv_init.so -> /usr/lib/libsrv_init.so.1.10.2359475 shared library libPVRScopeServices.so -> /usr/lib/libPVRScopeServices.so.1.10.2359475 binary pvrsrvctl -> /usr/local/bin/pvrsrvctl binary sgx_init_test -> /usr/local/bin/sgx_init_test binary services_test -> /usr/local/bin/services_test binary sgx_blit_test -> /usr/local/bin/sgx_blit_test binary sgx_clipblit_test -> /usr/local/bin/sgx_clipblit_test binary sgx_flip_test -> /usr/local/bin/sgx_flip_test binary sgx_render_flip_test -> /usr/local/bin/sgx_render_flip_test binary pvr2d_test -> /usr/local/bin/pvr2d_test shader glsltest1_vertshader.txt -> /usr/local/bin/glsltest1_vertshader.txt shader glsltest1_fragshaderA.txt -> /usr/local/bin/glsltest1_fragshaderA.txt shader glsltest1_fragshaderB.txt -> /usr/local/bin/glsltest1_fragshaderB.txt Installation complete! You may now reboot your target. ./rc.pvr: line 92: /usr/local/bin/pvrsrvctl: not found
