I have compilation errors using the "ipnc_app", here is the error message :
======== Building encode_stream ========
Configuring application using encode_stream.cfg
XDCPATH=";/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/dvsdk_demos_3_10_00_16/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/dmai_2_10_00_12/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/linuxutils_2_25_04_10/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/dm355_codecs_03_10_00_02/packages;/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/examples" /AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/xs xdc.tools.configuro -c /usr/local/montavista/pro/devkit/arm/v5t_le -o encode_stream_config -t gnu.targets.MVArm9 -p ti.platforms.evmDM6446 encode_stream.cfg
making package.mak (because of package.bld) ...
generating interfaces for package encode_stream_config (because package/package.xdc.inc is older than package.xdc) ...
configuring encode_stream.x470MV from package/cfg/encode_stream_x470MV.cfg ...
ti.sdo.ce.alg.close(): Setting GROUPUTILS...
Auto register ti.sdo.fc.ires.edma3chan.EDMA3CHAN
Auto register ti.sdo.fc.ires.vicp.VICP2
Auto register ti.sdo.fc.ires.addrspace.ADDRSPACE
Auto register ti.sdo.fc.ires.grouputils.GROUPUTILS
js: "/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/vicp/VICP2.xdt", line 56: ReferenceError: "platform" is not defined.
"/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/vicp/VICP2.xdt", line 75
gmake: *** [package/cfg/encode_stream_x470MV.c] Error 1
gmake: *** Deleting file `package/cfg/encode_stream_x470MV.c'
js: "/AppData/tmp_file/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
make[2]: *** [encode_stream_config] 错误 1
make[2]: Leaving directory `/home/jiangmb/code/dm355/ipc_dm355/multimedia/encode_stream'
make[1]: *** [encode_stream] 错误 2
make[1]: Leaving directory `/home/jiangmb/code/dm355/ipc_dm355/multimedia'
make: *** [multimedia] 错误 2
[root@localhost ipc_dm355]#
Thank you !
