Can't make syslink helloword example
I try to start syslink helloword example on my LCDK. Syslink is 2_21_01_05 version.
Here is my product.mak file:
#   Copyright (c) 2008-2012, Texas Instruments Incorporated
#   Redistribution and use in source and binary forms, with or without
#   modification, are permitted provided that the following conditions
#   are met:
#   *  Redistributions of source code must retain the above copyright
#      notice, this list of conditions and the following disclaimer.
#   *  Redistributions in binary form must reproduce the above copyright
#      notice, this list of conditions and the following disclaimer in the
#      documentation and/or other materials provided with the distribution.
#   *  Neither the name of Texas Instruments Incorporated nor the names of
#      its contributors may be used to endorse or promote products derived
#      from this software without specific prior written permission.
#   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
#   AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
#   THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
#   PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
#   CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
#   EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
#   PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
#   OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
#   WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
#   OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
#   EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
SYSLINK_INSTALL_DIR = $(CURDIR)
# List of supported devices (choose one): OMAP3530, OMAPL1XX, TI816X, TI814X
#    TI813X, TI811X
DEVICE = OMAPL1XX
# Master core (GPP) OS type (choose one): Linux, Qnx, Bios
GPPOS = Linux
# SysLink Linux driver DEBUG/TRACE options (choose one): 0 or 1
# Note that these options are only used by the Linux HLOS driver.  RTOS
# side libraries, Qnx libraries, and user mode Linux libraries are always
# built in both debug and release profiles, and users can switch between
# them when linking their executable (without rebuilding SysLink).
# Enabling SYSLINK_BUILD_DEBUG enables runtime assertion checking and makes
# some internal 'static' methods and objects global (so you can set
# breakpoints on them and/or inspect them in a debugger).
# Enabling SYSLINK_TRACE_ENABLE enables tracing throughout the SysLink
# code base.  This is especially helpful during development, but may not
# be necessary at production.
SYSLINK_BUILD_DEBUG=1
SYSLINK_TRACE_ENABLE=1
# SysLink OPTIMIZE option (choose one): 0 or 1
# Enabling SYSLINK_BUILD_OPTIMIZE removes many runtime API checks.  As a
# result, if the user uses SysLink in an unsupported way, rather than getting
# a failing return value, the system may crash or become unstable.
# SYSLINK_BUILD_OPTIMIZED is intended to be used in a closed system where all
# code paths are known, and error conditions are ensured never to occur - so
# it's not for everyone.
# Note that SYSLINK_BUILD_OPTIMIZE removes these checks throughout the
# SysLink stack - that includes RTOS, user, and driver layers if applicable
# to your environment.
SYSLINK_BUILD_OPTIMIZE=0
# SysLink HLOS driver Notify options (choose one): NOTIFYDRIVERSHM,
#    NOTIFYDRIVERCIRC
SYSLINK_NOTIFYDRIVER=NOTIFYDRIVERSHM
# SysLink HLOS driver MessageQ Transport options (choose one): TRANSPORTSHM,
#    TRANSPORTSHMNOTIFY, TRANSPORTSHMCIRC
SYSLINK_TRANSPORT=TRANSPORTSHM
# Set SDK type when building for a TI SDK kit (choose one): EZSDK or NONE
SDK = NONE
# Define root dir to install SysLink driver and samples for target file-system
EXEC_DIR = /home/user/ti/sys_result
# Define file format for loader and slave executables (choose one): COFF, ELF
LOADER = ELF
# Optional: recommended to install all dependent components in one folder.
DEPOT = /home/user/ti
# Define the product variables for the device you will be using.
######## For OMAP3530 device ########
ifeq ("$(DEVICE)","OMAP3530")
LINUXKERNEL             = $(DEPOT)/_your_linux_kernel_install_
CGT_ARM_INSTALL_DIR     = $(DEPOT)/_your_arm_code_gen_install_
CGT_ARM_PREFIX          = $(CGT_ARM_INSTALL_DIR)/bin/arm-none-linux-gnueabi-
IPC_INSTALL_DIR         = $(DEPOT)/_your_ipc_install_
BIOS_INSTALL_DIR        = $(DEPOT)/_your_bios_install_
XDC_INSTALL_DIR         = $(DEPOT)/_your_xdctools_install_
# If LOADER=ELF then below elf tools path is required else set C64P path
ifeq ("$(LOADER)","ELF")
CGT_C64P_ELF_INSTALL_DIR= $(DEPOT)/_your_c64pelf_code_gen_install_
else
CGT_C64P_INSTALL_DIR    = $(DEPOT)/_your_c64p_code_gen_install_
endif
######## For TI816X device ########
else ifeq ("$(DEVICE)","TI816X")
CGT_C674_ELF_INSTALL_DIR= $(DEPOT)/_your_c674elf_code_gen_install_
# SYS/BIOS timer frequency (ti.sysbios.timers.dmtimer.Timer.intFreq)
TI81XXDSP_DMTIMER_FREQ  = 32768
# If SDK=NONE then below tools path is required
ifeq ("$(SDK)","NONE")
CGT_M3_ELF_INSTALL_DIR  = $(DEPOT)/_your_m3elf_code_gen_install_
endif
######## For TI814X device ########
else ifeq ("$(DEVICE)","TI814X")
# Set one of the following OS variables
QNX_INSTALL_DIR         = $(DEPOT)/_your_qnx_install_
TI81XXDSP_DMTIMER_FREQ  = 20000000
endif
# If GPPOS=Bios then below tools path is required
ifeq ("$(GPPOS)","Bios")
CGT_A8_ELF_INSTALL_DIR  = $(DEPOT)/_your_a8elf_code_gen_install_
endif
######## For TI813X device ########
else ifeq ("$(DEVICE)","TI813X")
endif
######## For TI811X device ########
else ifeq ("$(DEVICE)","TI811X")
endif
######## For OMAPL1XX device ########
else ifeq ("$(DEVICE)","OMAPL1XX")
LINUXKERNEL             = $(DEPOT)/ti-sdk-omapl138-lcdk-01.00.00/board-support/linux-3.1.10
CGT_ARM_INSTALL_DIR     = $(DEPOT)/arago-2011.09/armv5te
CGT_ARM_PREFIX          = $(CGT_ARM_INSTALL_DIR)/bin/arm-arago-linux-gnueabi-
IPC_INSTALL_DIR         = $(DEPOT)/ipc_1_25_03_15
BIOS_INSTALL_DIR        = $(DEPOT)/bios_6_40_01_15
XDC_INSTALL_DIR         = $(DEPOT)/xdctools_3_30_01_25_core
# If LOADER=ELF then below elf tools path is required else set C674 path
CGT_C674_ELF_INSTALL_DIR= /opt/ti/ccsv5/tools/compiler/c6000_7.4.2
else
CGT_C674_INSTALL_DIR= /opt/ti/ccsv5/tools/compiler/c6000_7.4.2
endif
######## End of device specific variables ########
else ifeq ($(MAKECMDGOALS), clean)
else ifeq ($(MAKECMDGOALS), clobber)
else ifeq ($(MAKECMDGOALS), .show-products)
else ifeq ($(MAKECMDGOALS), help)
else
    $(error DEVICE is set to "$(DEVICE)", which is invalid. Set this in <SysLink Install>/products.mak. Refer to the SysLink Install Guide for more information)
endif
# Use this goal to print your product variables.
.show-products:
    @echo "DEPOT                    = $(DEPOT)"
    @echo "DEVICE                   = $(DEVICE)"
    @echo "GPPOS                    = $(GPPOS)"
    @echo "SDK                      = $(SDK)"
    @echo "TI81XXDSP_DMTIMER_FREQ   = $(TI81XXDSP_DMTIMER_FREQ)"
    @echo "SYSLINK_BUILD_DEBUG      = $(SYSLINK_BUILD_DEBUG)"
    @echo "SYSLINK_BUILD_OPTIMIZE   = $(SYSLINK_BUILD_OPTIMIZE)"
    @echo "SYSLINK_TRACE_ENABLE     = $(SYSLINK_TRACE_ENABLE)"
    @echo "LOADER                   = $(LOADER)"
    @echo "SYSLINK_INSTALL_DIR      = $(SYSLINK_INSTALL_DIR)"
    @echo "IPC_INSTALL_DIR          = $(IPC_INSTALL_DIR)"
    @echo "BIOS_INSTALL_DIR         = $(BIOS_INSTALL_DIR)"
    @echo "XDC_INSTALL_DIR          = $(XDC_INSTALL_DIR)"
    @echo "LINUXKERNEL              = $(LINUXKERNEL)"
    @echo "QNX_INSTALL_DIR          = $(QNX_INSTALL_DIR)"
    @echo "CGT_ARM_PREFIX           = $(CGT_ARM_PREFIX)"
    @echo "CGT_C64P_INSTALL_DIR     = $(CGT_C64P_INSTALL_DIR)"
    @echo "CGT_C64P_ELF_INSTALL_DIR = $(CGT_C64P_INSTALL_DIR)"
    @echo "CGT_C674_INSTALL_DIR     = $(CGT_C674_INSTALL_DIR)"
    @echo "CGT_C674_ELF_INSTALL_DIR = $(CGT_C674_ELF_INSTALL_DIR)"
    @echo "CGT_M3_ELF_INSTALL_DIR   = $(CGT_M3_ELF_INSTALL_DIR)"
    @echo "CGT_A8_ELF_INSTALL_DIR   = $(CGT_A8_ELF_INSTALL_DIR)"
    @echo "EXEC_DIR                 = $(EXEC_DIR)"
Making syslink is success. Making examples isn't.
here is making helloword examle log:
# Making all ...
make -C host all
make[1]: Entering directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/host'
# Making all ...
make PROFILE=debug app_host
make[2]: Entering directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/host'
make[2]: Nothing to be done for `app_host'.
make[2]: Leaving directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/host'
make PROFILE=release app_host
make[1]: Leaving directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/host'
make -C dsp all
make[1]: Entering directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp'
make PROFILE=debug server_dsp.x
make[2]: Entering directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp'
# Making bin/debug/server_dsp.xe674 ...
/opt/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/lnk6x --abi=eabi -w -q -c -m bin/debug/obj/server_dsp.xe674.map -o bin/debug/server_dsp.xe674 bin/debug/obj/main_dsp.oe674 bin/debug/obj/Server.oe674 configuro/linker.cmd -l /opt/ti/ccsv5/tools/compiler/c6000_7.4.2/lib/rts6740_elf.lib
 undefined                                   first referenced
  symbol                                         in file
 ti_sdo_ipc_gates_GateMPSupportNull_query__E /home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp/configuro/package/cfg/Dsp_pe674.oe674
 ti_sdo_ipc_gates_GatePeterson_query__E      /home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp/configuro/package/cfg/Dsp_pe674.oe674
 ti_sdo_ipc_heaps_HeapMemMP_isBlocking__E    /home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp/configuro/package/cfg/Dsp_pe674.oe674
error: unresolved symbols remain
error: errors encountered during linking; "bin/debug/server_dsp.xe674" not
   built
make[2]: *** [bin/debug/server_dsp.xe674] Error 1
make[2]: Leaving directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/user/ti/syslink_2_21_01_05/examples/ex01_helloworld/dsp'
make: *** [all] Error 2
Could you tell me, why does making of server_dsp.xe674 is unsuccessful?
Thanks.
    Please refer the following TI wiki to build syslink.
    PFA of my modified "product.mak" file.
    #   are met:
    #Titus
    #    TI813X, TI811X
    DEVICE = OMAPL1XX
    GPPOS = Linux
    #    NOTIFYDRIVERCIRC
    SDK = NONE
    EXEC_DIR = /home/titus/workdir/ti-e2e/src/syslink_2_21_01_05/INSTALL
    LOADER = ELF
    DEPOT = _your_depot_install_
    else
    endif
    endif
    endif
    endif
    endif
    endif
    #Titus
    LINUXKERNEL             = /home/titus/workdir/ti-e2e/src/DaVinci-PSP-SDK-03.22.00.06/src/kernel/linux-davinci
    CGT_ARM_INSTALL_DIR     = /opt/toolchain/arago-2011.09-armv7a-linux-gnueabi-sdk/arago-2011.09/armv7a
    IPC_INSTALL_DIR         = /opt/ti/ipc_1_25_03_15
    BIOS_INSTALL_DIR        = /opt/ti/bios_6_35_04_50
    XDC_INSTALL_DIR         = /opt/ti/xdctools_3_25_03_72
    CGT_C674_ELF_INSTALL_DIR= /opt/ti/C6000CGT7.4.6
    else
    CGT_C674_INSTALL_DIR= /opt/ti/C6000CGT7.4.6
    endif
    else
    endif
    .show-products:
  • I can't see any significant differences in our product.mak file.
    I refer this two links:
    http://processors.wiki.ti.com/index.php/MCSDK_OMAPL138_User_Guide_Chapter_Exploring#Syslink
    http://processors.wiki.ti.com/index.php/SysLink_Install_Guide
    I solved problem with kernel 3.3 and successfuly build syslink. Then I made changes in syslink_2_21_01_05/examples/ex33_umsg_ori/linux/Makefile but it didn't help.
    Are there another special features that I should know?
    Thanks.
  • Hi Alex,
    Are you able to fix the problem ?
    Why did you modify the "Makefile" ?
    Any requirements ?
  • If i were able to fix this problem, I wouldn't ask this question here.
    because this link:
    NOTE : While building syslink and examples if arago toolchain is used then we have update ex33_umsg for correct toolchain
    From CFLAGS = CROSS_COMPILE=arm-none-linux-gnueabi- ARCH=arm
    to CFLAGS = CROSS_COMPILE=arm-arago-linux-gnueabi- ARCH=arm
  • Hi Alex,
    Did you mean that you are not able to build after changed to arago toolchain in Makefile ?
    I have modified and built successfully the example "ex33_umsg".
    #  Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
    #  This program is free software: you can redistribute it and/or modify
    #  it under the terms of the GNU General Public License as published by
    #  the Free Software Foundation; version 2 of the License.
    #  This program is distributed in the hope that it will be useful,
    #  but WITHOUT ANY WARRANTY; without even the implied warranty of
    #  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    #  GNU General Public License for more details.
    #  You should have received a copy of the GNU General Public License
    #  along with this program.  If not, see <http://www.gnu.org/licenses/>
    ifeq ($(KERNELRELEASE),)
    EXBASE = ..
    include $(EXBASE)/products.mak
    EXTRA_CFLAGS = "-I$(IPC_INSTALL_DIR)/packages -I$(SYSLINK_INSTALL_DIR)/packages"
    all:PATH:=$(CGT_ARM_INSTALL_DIR)/bin:$(PATH)
    all:
    	echo "CGT_ARM_INSTALL_DIR=$(CGT_ARM_INSTALL_DIR)"
    	$(MAKE) -C $(LINUXKERNEL) M=$(CURDIR) $(CFLAGS) \
                EXTRA_CFLAGS=$(EXTRA_CFLAGS) modules
    clean::
    	$(MAKE) -C $(LINUXKERNEL) M=$(CURDIR) clean
    	rm -f modules.order
    	rm -f Modules.symvers
    else
    obj-m := umsg.o
    umsg-objs := driver.o umsg_drv.o
    endif
  • Hi Titus,
    no, I mean that I'm not able to build examples by "make examples" command and there is no metter is there arm-none-linux-gnueabi- or arm-arago-linux-gnueabi in ex33_umsg makefile.
    I have built successfully this example too, but only with arm-arago-linux-gnueabi in make file.
    As I can see at the log it doesn't work with server_dsp.xe674.
    Can you make ex01_helloword which unsuccessful try to make this server?
    p.s.
    I noticed that you are using compiler 7.4.4 and I use 7.4.2, can be problem in this difference?
  • Just update all tools to the latest versions and everythig became work fine! Thank Titus for help!
  • Hi Alex,
    Sounds good.
    Thanks for your update.
