Hi
Iam working with Vayu EVM. I would like to know what are the high speed data interface(150Mbps) available inorder to drive in raw video data? Isit possible to develop USB interface via SPI?
Jayakishor Y
Hi
Jayakishor Y
Hi Jayakishor,
For what application are you working on?
Vayu have already one USB3.0 and three USB2.0 subsystems.
Boyko
Hi Boyko
Iam working on Vision Mid 28 Eco. Does this support the same? If so, do we need to configure the PCIe controller for supporting the USB?
Jayakishor
Hi Jayakishor,
Do you have access for the J6 TRM, if not please contact your nearest TI representative in order to obtain access.
If I understood your query correctly, you don’t have to configure the PCIe in order to use the USB sub-system.
Boyko
Hi Boyko
Does J6 and Vision Mid 28 Eco refer the same? Coz i could see only I2c, SPI, Uart,CAN,Audio Serial ports and PCIe controller as the communication interface. And if my Soc has to support USB2.0/3.0, PCIe controller should be configured. Please suggest.
Jayakishor Y
Well,
Check the Device TRM in order to familiarize yourself with the device, there alswo you will see programing guide for the different subsystems which will allow you to set them accordingly
Boyko
Hi Boyko
Iam sorry, little confused. Please let me know the following?
Does J6 and Vision Mid 28 Eco refer the same? Coz i could see only I2c, SPI, Uart,CAN,Audio Serial ports and PCIe controller as the communication interface. And if my Soc has to support USB2.0/3.0, PCIe controller should be configured. Thanks!
Jayakishor Y
