Error about main pll with TMDSEVM6657LS
hi:
I have a TMDSEVM6657LS ,bought from TI.
Now it does not work in the right way.Please Help me to check the errors.
i used the XDS200 Emulator to run the program ,it's ok.
And one time , I try to test the EMIF with a ADC .at the very beginning,it does work,but then ,there was something wrong with it.
when I try to Debug,It's the log in the console window:
[C66xx_0] Initialize DSP main clock = 100.00MHz/1x10 = 1000MHz
C66xx_0: Power Failure on Target CPU
C66xx_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
C66xx_1: No Clock Signal On Target CPU
C66xx_1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
And then i  lanuched a config file "xx.ccxml",
connect core0
load GEL ,“evmc6657l.gel”,
Global_Default_Setup
C66xx_0: GEL Output: Setup_Memory_Map...
C66xx_0: GEL Output: Setup_Memory_Map... Done.
C66xx_0: GEL Output: C6657L GEL file Ver is 1.002
C66xx_0: GEL Output: Global Default Setup...
C66xx_0: GEL Output: Setup Cache...
C66xx_0: GEL Output: L1P = 32K
C66xx_0: GEL Output: L1D = 32K
C66xx_0: GEL Output: L2 = ALL SRAM
C66xx_0: GEL Output: Setup Cache... Done.
C66xx_0: GEL Output: Main PLL (PLL1) Setup ...
C66xx_0: GEL Output: PLL in Bypass ...
C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz.
C66xx_0: GEL Output: SYSCLK2 = 333.3333 MHz, SYSCLK5 = 200.0 MHz.
C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz.
C66xx_0: GEL Output: PLL1 Setup... Done.
C66xx_0: GEL Output: DSP core #64 cannot set PSC.
C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ...
C66xx_0: GEL Output: DSP core #64 cannot set DDR3 PLL
C66xx_0: GEL Output: DDR3 Init begin (1333 auto)
C66xx_0: GEL Output: XMC Setup ... Done
DDR3 initialization is complete.
C66xx_0: GEL Output: DDR3 Init done
C66xx_0: GEL Output: DDR3 memory test... Started
C66xx_0: GEL Output: DDR3 memory test... Failed
C66xx_0: GEL Output: DSP core #64 cannot set PLL1.
C66xx_0: GEL Output: Error in Setting up main PLL, please power cycle the board and re-run Global Default Setup...
so I don't know what's wrong with it.
My code works ok before connecting the ADC.
Is the DSP chip broken?How can I test it?
Thanks!!!!!
    Welcome to the TI E2E forum. I hope you will find many good answers here and in the TI.com documents and in the TI Wiki Pages (for processor issues). Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics (e2e.ti.com).
    From above log: After PLL initialization, chip failed to read the core number. The chip could have got damaged.
    Please find the attached gel file log with C6657 EVM.
    Connecting Target...
    C66xx_0: GEL Output: DSP core #0
    C66xx_0: GEL Output: C6657L GEL file Ver is 1.003
    C66xx_0: GEL Output: Power on all PSC modules and DSP domains...
    C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=12, md=4!
    C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done.
    C66xx_0: GEL Output: DDR3 PLL Setup... Done.
    C66xx_0: GEL Output: DDR3 memory test... Passed
    C66xx_0: GEL Output: PLL and DDR3 Initialization completed(0) ...
    C66xx_0: GEL Output: configSGMIISerdes Setup... Begin
    C66xx_0: GEL Output: SGMII SERDES has been configured.
    C66xx_0: GEL Output: Enabling EDC ...
    C66xx_0: GEL Output: L1P error detection logic is enabled.
    C66xx_0: GEL Output: L2 error detection/correction logic is enabled.
    C66xx_0: GEL Output: MSMC error detection/correction logic is enabled.
    C66xx_0: GEL Output: Enabling EDC ...Done
    C66xx_0: GEL Output: Global Default Setup... Done.
    C66xx_1: GEL Output: Setup_Memory_Map...
    C66xx_1: GEL Output: Setup_Memory_Map... Done.
    C66xx_1: GEL Output: DSP core #1
    C66xx_1: GEL Output: C6657L GEL file Ver is 1.003
    C66xx_1: GEL Output: Global Default Setup...
    C66xx_1: GEL Output: Setup Cache...
    C66xx_1: GEL Output: L1P = 32K
    C66xx_1: GEL Output: L1D = 32K
    C66xx_1: GEL Output: L2 = ALL SRAM
    C66xx_1: GEL Output: Setup Cache... Done.
    C66xx_1: GEL Output: Global Default Setup... Done.
    Thank you.
    Please post some information about,
    1. How the ADC is interfaced with EMIF?
    2. What is steps followed to test the same?
    I will check with our team. Thank you
