We are porting android kitkat 4.4.3_r.1.1 to am43xx.
And we are getting the following logs for basic bring up of display unit.
Please help us to solve this.
shell@am437xevm:/ $ lo[ 27.031392] init: untracked pid 1608 exited
gcat
--------- beginning of /dev/log/main
E/uim-sysfs( 1517): uim: Inside main
E/uim-sysfs( 1517): uim:BT/FM/GPS would be unavailable on system
I/installd( 1525): installd firing up
E/cutils ( 1525): Failed to read /data/.layout_version: No such file or directory
E/installd( 1525): Could not create directories; exiting.
I/DEBUG ( 1519): debuggerd: Jul 30 2014 10:38:05
I/Netd ( 1518): Netd 1.0 starting
W/InterfaceController( 1518): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found)y
E/keystore( 1530): chdir: /data/misc/keystore: No such file or directory
--------- beginning of /dev/log/system
I/Vold ( 1516): Vold 2.1 (the revenge) firing up
I/SurfaceFlinger( 1520): SurfaceFlinger is starting
I/SurfaceFlinger( 1520): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 1520): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1520): loaded /system/lib/egl/libGLESv1_CM.so
D/libEGL ( 1520): loaded /system/lib/egl/libGLESv2.so
W/libEGL ( 1520): eglInitialize(0x1) failed (EGL_BAD_ALLOC)
I/gralloc ( 1520): using (fd=14)
I/gralloc ( 1520): id = omapfb
I/gralloc ( 1520): xres = 800 px
I/gralloc ( 1520): yres = 480 px
I/gralloc ( 1520): xres_virtual = 800 px
I/gralloc ( 1520): yres_virtual = 960 px
I/gralloc ( 1520): bpp = 32
I/gralloc ( 1520): r = 16:8
I/gralloc ( 1520): g = 8:8
I/gralloc ( 1520): b = 0:8
I/gralloc ( 1520): width = 127 mm (160.000000 dpi)
I/gralloc ( 1520): height = 76 mm (160.421051 dpi)
I/gralloc ( 1520): refresh rate = 62.82 Hz
E/SurfaceFlinger( 1520): hwcomposer module not found
W/SurfaceFlinger( 1520): getting VSYNC period from fb HAL: 15918750
W/SurfaceFlinger( 1520): no suitable EGLConfig found, trying a simpler query
F/SurfaceFlinger( 1520): no suitable EGLConfig found, giving up
F/libc ( 1520): Fatal signal 6 (SIGABRT) at 0x000005f0 (code=-6), thread 1520 (surfaceflinger)
I/DEBUG ( 1519): failed to open tombstone file '/data/tombstones/tombstone_00': No such file or directy
I/installd( 1614): installd firing up
E/uim-sysfs( 1616): uim: Inside main
E/cutils ( 1614): Failed to read /data/.layout_version: No such file or directory
E/installd( 1614): Could not create directories; exiting.
E/uim-sysfs( 1616): uim:BT/FM/GPS would be unavailable on system
I/Netd ( 1610): Netd 1.0 starting
W/InterfaceController( 1610): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found)y
E/keystore( 1615): chdir: /data/misc/keystore: No such file or directory
I/SurfaceFlinger( 1611): SurfaceFlinger is starting
I/SurfaceFlinger( 1611): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 1611): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1611): loaded /system/lib/egl/libGLESv1_CM.so
D/libEGL ( 1611): loaded /system/lib/egl/libGLESv2.so
W/libEGL ( 1611): eglInitialize(0x1) failed (EGL_BAD_ALLOC)
I/gralloc ( 1611): using (fd=14)
I/gralloc ( 1611): id = omapfb
I/gralloc ( 1611): xres = 800 px
I/gralloc ( 1611): yres = 480 px
I/gralloc ( 1611): xres_virtual = 800 px
I/gralloc ( 1611): yres_virtual = 960 px
I/gralloc ( 1611): bpp = 32
I/gralloc ( 1611): r = 16:8
I/gralloc ( 1611): g = 8:8
I/gralloc ( 1611): b = 0:8
I/gralloc ( 1611): width = 127 mm (160.000000 dpi)
I/gralloc ( 1611): height = 76 mm (160.421051 dpi)
I/gralloc ( 1611): refresh rate = 62.82 Hz
E/SurfaceFlinger( 1611): hwcomposer module not found
W/SurfaceFlinger( 1611): getting VSYNC period from fb HAL: 15918750
W/SurfaceFlinger( 1611): no suitable EGLConfig found, trying a simpler query
F/SurfaceFlinger( 1611): no suitable EGLConfig found, giving up
F/libc ( 1611): Fatal signal 6 (SIGABRT) at 0x0000064b (code=-6), thread 1611 (surfaceflinger)
[ 30.736041] init: untracked pid 1630 exited
I/installd( 1635): installd firing up
E/uim-sysfs( 1637): uim: Inside main
E/cutils ( 1635): Failed to read /data/.layout_version: No such file or directory
E/installd( 1635): Could not create directories; exiting.
E/uim-sysfs( 1637): uim:BT/FM/GPS would be unavailable on system
I/Netd ( 1631): Netd 1.0 starting
W/InterfaceController( 1631): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found)y
E/keystore( 1636): chdir: /data/misc/keystore: No such file or directory
I/SurfaceFlinger( 1632): SurfaceFlinger is starting
I/SurfaceFlinger( 1632): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 1632): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1632): loaded /system/lib/egl/libGLESv1_CM.so
D/libEGL ( 1632): loaded /system/lib/egl/libGLESv2.so
W/libEGL ( 1632): eglInitialize(0x1) failed (EGL_BAD_ALLOC)
I/gralloc ( 1632): using (fd=14)
I/gralloc ( 1632): id = omapfb
I/gralloc ( 1632): xres = 800 px
I/gralloc ( 1632): yres = 480 px
I/gralloc ( 1632): xres_virtual = 800 px
I/gralloc ( 1632): yres_virtual = 960 px
I/gralloc ( 1632): bpp = 32
I/gralloc ( 1632): r = 16:8
I/gralloc ( 1632): g = 8:8
I/gralloc ( 1632): b = 0:8
I/gralloc ( 1632): width = 127 mm (160.000000 dpi)
I/gralloc ( 1632): height = 76 mm (160.421051 dpi)
I/gralloc ( 1632): refresh rate = 62.82 Hz
E/SurfaceFlinger( 1632): hwcomposer module not found
W/SurfaceFlinger( 1632): getting VSYNC period from fb HAL: 15918750
W/SurfaceFlinger( 1632): no suitable EGLConfig found, trying a simpler query
F/SurfaceFlinger( 1632): no suitable EGLConfig found, giving up
F/libc ( 1632): Fatal signal 6 (SIGABRT) at 0x00000660 (code=-6), thread 1632 (surfaceflinger)
I/installd( 1656): installd firing up
E/uim-sysfs( 1658): uim: Inside main
E/cutils ( 1656): Failed to read /data/.layout_version: No such file or directory
E/installd( 1656): Could not create directories; exiting.
E/uim-sysfs( 1658): uim:BT/FM/GPS would be unavailable on system
I/Netd ( 1652): Netd 1.0 starting
W/InterfaceController( 1652): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found)y
E/keystore( 1657): chdir: /data/misc/keystore: No such file or directory
I/SurfaceFlinger( 1653): SurfaceFlinger is starting
I/SurfaceFlinger( 1653): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 1653): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1653): loaded /system/lib/egl/libGLESv1_CM.so
D/libEGL ( 1653): loaded /system/lib/egl/libGLESv2.so
W/libEGL ( 1653): eglInitialize(0x1) failed (EGL_BAD_ALLOC)
I/gralloc ( 1653): using (fd=14)
I/gralloc ( 1653): id = omapfb
I/gralloc ( 1653): xres = 800 px
I/gralloc ( 1653): yres = 480 px
I/gralloc ( 1653): xres_virtual = 800 px
I/gralloc ( 1653): yres_virtual = 960 px
I/gralloc ( 1653): bpp = 32
I/gralloc ( 1653): r = 16:8
I/gralloc ( 1653): g = 8:8
I/gralloc ( 1653): b = 0:8
I/gralloc ( 1653): width = 127 mm (160.000000 dpi)
I/gralloc ( 1653): height = 76 mm (160.421051 dpi)
I/gralloc ( 1653): refresh rate = 62.82 Hz
E/SurfaceFlinger( 1653): hwcomposer module not found
W/SurfaceFlinger( 1653): getting VSYNC period from fb HAL: 15918750
W/SurfaceFlinger( 1653): no suitable EGLConfig found, trying a simpler query
F/SurfaceFlinger( 1653): no suitable EGLConfig found, giving up
F/libc ( 1653): Fatal signal 6 (SIGABRT) at 0x00000675 (code=-6), thread 1653 (surfaceflinger)
[ 41.114794] init: untracked pid 1671 exited
