Hello ,
I'm using the function of grlib given in usb keyboard example to display text on the screen. The example work, Now i would like to write on video, I mixed the project that display video running in sys/bios. I would know how to display the video and the text at the some time.
To display text i use this function :
RasterDMAFBConfig(SOC_LCDC_0_REGS,
(unsigned int)(g_pucBuffer+PALETTE_OFFSET),
(unsigned int)(g_pucBuffer+PALETTE_OFFSET) + sizeof(g_pucBuffer) - 2 - PALETTE_OFFSET,
0);
1);
To display video i use the function given in the video loopbacj example:
if (display_buff_1)
if (status & RASTER_END_OF_FRAME0_INT_STAT)
RasterDMAFBConfig(SOC_LCDC_0_REGS, (unsigned int) Rgb_buffer1,
(unsigned int) (Rgb_buffer1 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 0);
updated = updated | 0x1;
if (status & RASTER_END_OF_FRAME1_INT_STAT)
(unsigned int) (Rgb_buffer1 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 1);
updated = updated | 0x2;
else
RasterDMAFBConfig(SOC_LCDC_0_REGS, (unsigned int) Rgb_buffer2,
(unsigned int) (Rgb_buffer2 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 0);
(unsigned int) (Rgb_buffer2 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 1);
I tried this but i have the both the text and video. But video flashes and not run correctly :
if (display_buff_1)
0);
1);
else
0);
1);
Thank you very much for your help !!
