Run Vcap+Venc+Vdis demo, several minutes the enclink skip all frames
Hi all
   I run the vcap_venc_vdis demo, everything is ok when beginning, several minutes later ,  when type 'i' to print statistics ,find the enclink skip all frame, the fps of other link seems is correct.
[m3vpss ]
[m3vpss ] *** Capture Driver Advanced Statistics ***
[m3vpss ]
[m3vpss ] VIP Parser Reset Count : 0
[m3vpss ]
[m3vpss ] | Total Even Odd Total Even Odd Min / Max Min / Max Dropped Fid Repeat Frame Error Y/C
[m3vpss ] CH | Fields Fields Fields FPS FPS FPS Width Height Fields Count (Desc Error Y/C)
[m3vpss ] ------------------------------------------------------------------------------------------------------------
[m3vpss ] 000 | 113573 113573 0 24 24 0 1920 / 1920 1080 / 1080 1 0 0/0 (0/0)
[m3vpss ] 200 | 272578 136289 136289 59 29 29 1920 / 1920 540 / 540 1 0 0/0 (0/0)
[m3vpss ]
[m3vpss ] VIP Capture Port 0 | DescMissMatch1 = 11, DescMissMatch2 = 0 , DescMissMatch3 = 0
[m3vpss ] VIP Capture Port 2 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[m3vpss ]
[m3vpss ] *** Capture List Manager Advanced Statistics ***
[m3vpss ]
[m3vpss ] List Post Count : 1135858
[m3vpss ] List Stall Count : 0
[m3vpss ] List Post Time (ms) : Max = 0, Min = 0, Avg = 0, Total = 0
[m3vpss ] INTC Timeout Count : (0, 0) (Min timeout value = 981, 991)
[m3vpss ] Descriptor miss found count : 0
[m3vpss ]
[m3vpss ]
[m3vpss ] VIP and VPDMA registers,
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000
[m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00020000
[m3vpss ]
[m3vpss ]
[m3vpss ] 4548155: CAPTURE: Fields = 386148 (fps = 84, CPU Load = 0)
[m3vpss ] 4548155: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 4548155: SYSTEM : FREE SPACE : System Heap = 67504 B, Mbx = 10239 msgs)
[m3vpss ] 4548155: SYSTEM : FREE SPACE : SR0 Heap = 8713728 B (8 MB)
[m3vpss ] 4548155: SYSTEM : FREE SPACE : Frame Buffer = 149058944 B (142 MB)
[m3vpss ] 4548156: SYSTEM : FREE SPACE : Bitstream Buffer = 196248448 B (187 MB)
[m3vpss ] 4548156: SYSTEM : FREE SPACE : Tiler Buffer = 224 B (0 MB) - TILER OFF
[m3vpss ]
[m3vpss ] *** [DEI2 ] DEI Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time : 262 secs
[m3vpss ] Total Fields Processed : 272575
[m3vpss ] Total Fields FPS : 131 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2]
r Out[3] User Out[4] Latency
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS
ip FPS Skip FPS Min / Max
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 60 0 60 0 25 0 0 0 60 0 0 0 0 0 35 0
0 0 16 / 33
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 262 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 33 fps (8755 frames)
[m3vpss ] Output Actual FPS : 33 fps (8755 frames)
[m3vpss ] Output Drop FPS : 0 fps (0 frames)
[m3vpss ] Output Reject FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 29 ms
[m3vpss ] Scaling Internal min : 29 ms
[m3vpss ] Scaling Internal max : 31 ms
[m3vpss ]
[m3vpss ] Win | Window Repeat Drop Recv Que FID Invlid Acc Event Invalid Que Reject Reject Latency OutBufCopy InBufCopy
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS Count (Max/Min) CH Frames Frames Frames Min / Max FPS FPS
[m3vpss ] 0 | 33 8 0 25 25 0 0 ( 0/255) 0 0 0 11 / 64 8 0
[m3vpss ] 1 | 33 8 0 25 25 0 0 ( 0/255) 0 0 0 20 / 81 8 0
[m3vpss ] 2 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 33 0
[m3vpss ] 3 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 33 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 540 | 3840 / 3840 | NON-TILED | 0, 0 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 540 | 3840 / 3840 | NON-TILED | 960, 0 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF
[m3vpss ] 2 | 2 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 540 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON
[m3vpss ] 3 | 3 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 540 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON
[m3vpss ]
[m3vpss ]
[m3vpss ] 4548162: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 65 / 86 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 83
[m3vpss ] 4548162: DISPLAY DRV: HDDAC(BP0) : Q:[151456] Display:[272624], Repeat:[121169], DQ:[151454]
[m3vpss ] 4548162: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 15774, HDDAC(BP0) 32176, DVO2(BP1) 32175, SDDAC(SEC1) 32064
[m3vpss ] 4548162: SYSTEM : FREE SPACE : System Heap = 67504 B, Mbx = 10239 msgs)
[m3vpss ] 4548162: SYSTEM : FREE SPACE : SR0 Heap = 8713728 B (8 MB)
[m3vpss ] 4548163: SYSTEM : FREE SPACE : Frame Buffer = 149058944 B (142 MB)
[m3vpss ] 4548163: SYSTEM : FREE SPACE : Bitstream Buffer = 196248448 B (187 MB)
[m3vpss ] 4548163: SYSTEM : FREE SPACE : Tiler Buffer = 224 B (0 MB) - TILER OFF
[m3video] 4554163: HDVICP-ID:0
[m3video] All percentage figures are based off totalElapsedTime
[m3video] totalAcquire2wait :0 %
[m3video] totalWait2Isr :28 %
[m3video] totalIsr2Done :0 %
[m3video] totalWait2Done :28 %
[m3video] totalDone2Release :0 %
[m3video] totalAcquire2Release :29 %
[m3video] totalAcq2acqDelay :70 %
[m3video] totalElapsedTime in msec : 2853574
[m3video] numAccessCnt: 71333
[m3video] IVA-FPS : 25
[m3video] Average time spent per frame in microsec: 11200
[m3video] 4554164: HDVICP-ID:1
[m3video] totalElapsedTime in msec : 2853590
[m3video] numAccessCnt: 71334
[m3video] 4554165: HDVICP-ID:2
[m3video] totalWait2Isr :0 %
[m3video] totalWait2Done :0 %
[m3video] totalAcquire2Release :0 %
[m3video] totalAcq2acqDelay :0 %
[m3video] totalElapsedTime in msec : 0
[m3video] numAccessCnt: 0
[m3video] IVA-FPS : 0
[m3video] Average time spent per frame in microsec: 0
[m3video]
[m3video] *** ENCODE Statistics ***
[m3video]
[m3video] Elasped Time : 262 secs
[m3video]
[m3video]
[m3video] CH | In Recv In Skip In User Out Latency
[m3video] Num | FPS FPS Skip FPS FPS Min / Max
[m3video] --------------------------------------------
[m3video] 0 | 25 25 0 0 255 / 0
[m3video] 1 | 25 25 0 0 255 / 0
[m3video]
[m3video] Multi Channel Encode Average Submit Batch Size
[m3video] Max Submit Batch Size : 24
[m3video] IVAHD_0 Average Batch Size : 0
[m3video] IVAHD_0 Max achieved Batch Size : 0
[m3video] IVAHD_1 Average Batch Size : 0
[m3video] IVAHD_1 Max achieved Batch Size : 0
[m3video] IVAHD_2 Average Batch Size : 0
[m3video] IVAHD_2 Max achieved Batch Size : 0
[m3video]
[m3video] Multi Channel Encode Batch break Stats
[m3video] Total Number of Batches created: 0
[m3video] All numbers are based off total number of Batches created
[m3video] Batch breaks due to batch sizeexceeding limit: 0 %
[m3video] Batch breaks due to ReqObj Que being empty: 0 %
[m3video] Batch breaks due to changed resolution class: 0 %
[m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
[m3video] Batch breaks due to channel repeat: 0 %
[m3video] Batch breaks due to different codec: 0 %
[m3vpss ]
[m3vpss ] 4557169: LOAD: CPU: 8.0% HWI: 1.3%, SWI:1.2%
[m3vpss ]
[m3vpss ] 4557169: LOAD: TSK: IPC_FRAMES_OUT0 : 0.8%
[m3vpss ] 4557169: LOAD: TSK: CAPTURE : 0.4%
[m3vpss ] 4557169: LOAD: TSK: DEI2 : 1.1%
[m3vpss ] 4557169: LOAD: TSK: DISPLAY0 : 0.2%
[m3vpss ] 4557169: LOAD: TSK: DUP0 : 0.1%
[m3vpss ] 4557169: LOAD: TSK: SWMS0 : 0.9%
[m3vpss ] 4557169: LOAD: TSK: MERGE0 : 0.1%
[m3vpss ] 4557169: LOAD: TSK: MISC : 1.9%
[m3vpss ]
[m3video]
[m3video] 4557670: LOAD: CPU: 2.7% HWI: 0.5%, SWI:0.6%
[m3video]
[m3video] 4557670: LOAD: TSK: IPC_FRAMES_IN0 : 0.5%
[m3video] 4557670: LOAD: TSK: IPC_BITS_OUT0 : 0.1%
[m3video] 4557670: LOAD: TSK: ENC0 : 0.6%
[m3video] 4557670: LOAD: TSK: MISC : 0.4%
[m3video]
[c6xdsp ]
[c6xdsp ] 4557562: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 4557562: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
*** Encode Bitstream Received Statistics ***
Elased time = 262.7 secs
CH | Bitrate (Kbps) | FPS | Key-frame FPS | Width (max/min) | Height (max/min) | Latency (max/min)
[host]
*** SCD Frame Results Received Statistics ***
CH | Bitrate (Kbps) | FPS | Width (max/min) | Height (max/min)
Run-Time Menu
