I'm trying to send video data over the network using GStreamer, but I found an error with the camera (LI-5M02) that I'm using. Does anybody have a solution for this?.
root@dm365-evm:~# gst-launch -v v4l2src always-copy=FALSE ! 'video/x-raw-yuv, \
> format=(fourcc)NV12, framerate=(fraction)30/1, width=(int)1280, height=(int)72
0' \
> ! tidisplaysink2 video-standard=720p display-output=component
Setting pipeline to PAUSED ...
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
davinci_previewer davinci_previewer.2: ipipe_set_preview_config
vpfe-capture vpfe-capture: IPIPE Chained
vpfe-capture vpfe-capture: Resizer present
mt9p031 1-005d: control id -2147483648 not supported
vpfe-capture vpfe-capture: input information not found for the subdev
mt9p031 1-005d: control id 9963776 not supported
mt9p031 1-005d: control id 9963777 not supported
mt9p031 1-005d: control id 9963778 not supported
mt9p031 1-005d: control id 9963779 not supported
mt9p031 1-005d: control id 9963780 not supported
mt9p031 1-005d: control id 9963781 not supported
mt9p031 1-005d: control id 9963782 not supported
mt9p031 1-005d: control id 9963783 not supported
mt9p031 1-005d: control id 9963784 not supported
mt9p031 1-005d: control id 9963785 not supported
mt9p031 1-005d: control id 9963786 not supported
mt9p031 1-005d: control id 9963787 not supported
mt9p031 1-005d: control id 9963788 not supported
mt9p031 1-005d: control id 9963789 not supported
mt9p031 1-005d: control id 9963790 not supported
mt9p031 1-005d: control id 9963791 not supported
mt9p031 1-005d: control id 9963792 not supported
mt9p031 1-005d: control id 9963794 not supported
mt9p031 1-005d: control id 9963798 not supported
mt9p031 1-005d: control id 9963799 not supported
mt9p031 1-005d: control id 9963800 not supported
mt9p031 1-005d: control id 9963801 not supported
mt9p031 1-005d: control id 9963802 not supported
mt9p031 1-005d: control id 9963803 not supported
mt9p031 1-005d: control id 9963804 not supported
mt9p031 1-005d: control id 9963805 not supported
mt9p031 1-005d: control id 9963806 not supported
mt9p031 1-005d: control id 9963807 not supported
mt9p031 1-005d: control id 9963808 not supported
mt9p031 1-005d: control id 9963809 not supported
vpfe-capture vpfe-capture: width = 1, height = 1, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 16, height = 2, bpp = 2, bytesperline = 32, sizeimage = 64
vpfe-capture vpfe-capture: width = 32768, height = 32768, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 2176, height = 1536, bpp = 2, bytesperline = 4352, sizeimage = 6684672
vpfe-capture vpfe-capture: width = 1, height = 1, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 32, height = 2, bpp = 1, bytesperline = 32, sizeimage = 96
vpfe-capture vpfe-capture: width = 32768, height = 32768, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 2176, height = 1536, bpp = 1, bytesperline = 2176, sizeimage = 5013504
vpfe-capture vpfe-capture: width = 8, height = 2, bpp = 2
vpfe-capture vpfe-capture: width = 32775, height = 32769, bpp = 2
ERROR: Pipeline doesn't want to pause.
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to set input 2 on device /dev/video0.
Additional debug info:
v4l2_calls.c(975): gst_v4l2_set_input (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: Invalid argument
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not negotiate format
gstbasesrc.c(2755): gst_base_src_start (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Check your filtered caps, if any
Setting pipeline to NULL ...
Or, what other thing can I do to get the video data from the encoder?, I need it digital, composite and component outputs give me the data in analog.
