audio play channel
Hi, we use DM8168+3101, RDK4.0.
I use audio capture->playback.
I found the playback can not distinguish the right and left channel.
I found some restrictions in the code as following:
#define AUDIO_SAMPLE_RATE_SUPPORTED          16000       //< Only 16KHz supported
#define AUDIO_CHANNELS_SUPPORTED                    1                //< Only mono
when init play device with Audio_initPlayRenderDevice, it sets one channel.
I want to make sure if the playback can only support one channel?
I set to stereo, the sound is not normal.
