XAR Register Details
What is use of upper 7 bits in XARn register, where are these 7 bits important. When we should consider them during address calculation?
Please reply.
    Team will address your request shortly.
    Thanks & regards,
    Sivaraj K
  • When performing integer arithmetic in the AR registers, the upper 7 bits can be ignored completely.  However, they are always used when you are using the XAR register as an address register.  Even though the instruction syntax typically shows *ARn when using an addressing mode, the whole XARn is actually used.  You must set the upper 7 bits correctly.  If all of your data exists in the first 64k, you can set the upper 7 bits to zero and forget about it.  Otherwise, you must take care to use the correct instructions to set the whole XAR.
