timer test example on 6657
I want to test all the timers on my 6657 DSP.
I looked at the example : C:\ti\pdk_C6678_1_1_2_5\packages\ti\csl\example\timer
This example tests only tmr_0.
I tried to test tmr_1, tmr_2 and my test didn't pass.
the program stops at
/* Wait for the timer interrupts to fire...*/
while (timerISRCounter != 1);
Please help,
Ivgeni.
  • Hi Ivgeni,
    The TIMER1 interrupt is specific to core 1. Please run the tmr_1 on core 1.
    Please refer the device data manual for more information.
    Thank you.
    how can I set and test timer 2,timer 3,timer 4,timer 5,timer 6,timer 7,timer 8 ?
    Ivgeni.
    Why do you need to test all timers? What is your requirement?
    In C6657, Timer 2 & 3 are primary interrupts to CorePac. All the Corepacs will receive this interrupt. I have tested timer 8 on C6678 and attached the file here. Please modify it for C6657.
     *   @file  timer_test.c
     *   @brief
     *      This is the Example test code for the TIMER CSL Functional layer.
     *      The code also uses utilizes the INTC CSL functional layer to determine
     *      if the timers are functioning properly.
     *  \par
     *  NOTE:
     *      (C) Copyright 2008, 2009 Texas Instruments, Inc.
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdio.h>
    #include <string.h>
    #include <ti/csl/csl_tmr.h>
    #include <ti/csl/csl_tmrAux.h>
    #include <ti/csl/src/intc/csl_intc.h>
    #include <ti/csl/src/intc/csl_intcAux.h>
     ************************** Local Definitions *************************
    /* Maximum delay to wait for to detect spurious interrupts. */
    #define  MAX_DELAY                  0xFFFF
     ************************** Global Variables **************************
    /* Global Handle which keeps track of the WATCH-DOG Timer. */
    CSL_TmrHandle   wdTmr;
    Uint8 u8TI;
    /* INTC Objects */
    CSL_IntcObj                  tmrIntcObj;
    CSL_IntcContext              context;
    CSL_IntcEventHandlerRecord   EventHandler[30];
    /* Global Variable for the INTC Module; useful for debugging. */
    CSL_IntcRegsOvly    gIntcRegisters    = (CSL_IntcRegsOvly)CSL_CGEM0_5_REG_BASE_ADDRESS_REGS;
    /* Counter for Timer ISR */
    volatile Int32 timerISRCounter = 0;
     ************************ TIMER TEST FUNCTIONS ************************
     *  @b Description
     *  @n
     *      This is the Timer ISR handler which is invoked when the timer expires
     *  @param[in]  arg
     *      Event ID which caused the ISR to be invoked.
     *  @retval
     *      Not Applicable.
    static void TimerInterruptHandler (void *arg)
        /* Increment the number of interrupts detected. */
        timerISRCounter++;
        /* Clear the event ID. */
        CSL_intcEventClear((CSL_IntcEventId)arg);
     *  @b Description
     *  @n
     *      This is the Watch Dog ISR handler which is invoked when the Watch Dog
     *      timer expires.
     *  @param[in]  arg
     *  @retval
     *      Not Applicable.
    static void WatchDogTimerHandler (void *arg)
        Uint16  loadVal;
        timerISRCounter++;
        /* Watchdog timer service key1 */
        loadVal = CSL_TMR_WDTCR_WDKEY_CMD1;
        CSL_tmrHwControl(wdTmr, CSL_TMR_CMD_LOAD_WDKEY, (Uint16 *)&loadVal);
        /* Watchdog timer service key2 */
        loadVal = CSL_TMR_WDTCR_WDKEY_CMD2;
     *  @b Description
     *  @n
     *      The functions initializes the INTC module.
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 intc_init (void)
        CSL_IntcGlobalEnableState   state;
        /* INTC module initialization */
        context.eventhandlerRecord = EventHandler;
        context.numEvtEntries      = 10;
        if (CSL_intcInit(&context) != CSL_SOK)
            return -1;
        /* Enable NMIs */
        if (CSL_intcGlobalNmiEnable() != CSL_SOK)
            return -1;
        /* Enable global interrupts */
        if (CSL_intcGlobalEnable(&state) != CSL_SOK)
            return -1;
        /* INTC has been initialized successfully. */
        return 0;
     *  @b Description
     *  @n
     *      This funtion is used to test the LO Timer.
     *  @param[in]  IntcInstance
     *      Timer Instance Number
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 test_lo_single_shot_timer (Uint8 IntcInstance)
        CSL_TmrHandle               hTmr;
        CSL_TmrObj                  TmrObj;
        CSL_Status                  intStat, status;
        CSL_TmrHwSetup              hwSetup = CSL_TMR_HWSETUP_DEFAULTS;
        CSL_IntcEventHandlerRecord  EventRecord;
        CSL_IntcParam               vectId;
        Uint32                      LoadValue = 100;
        CSL_IntcHandle              tmrIntcHandle;
        CSL_TmrEnamode              TimeCountMode = CSL_TMR_ENAMODE_ENABLE;
        Uint32                      count;
        Uint32						u32EvtNum, u32EvtArg;
        /* Clear local data structures */
        memset(&TmrObj, 0, sizeof(CSL_TmrObj));
        printf("Debug: Testing Low Timer (Unchained) in Single Shot Mode...\n");
         ********************** INTC related code *********************
        /* Open INTC */
        vectId = CSL_INTC_VECTID_12;
        switch(u8TI)
        case CSL_TMR_0:
        case CSL_TMR_1:
        case CSL_TMR_2:
        case CSL_TMR_3:
        case CSL_TMR_4:
        case CSL_TMR_5:
        case CSL_TMR_6:
        case CSL_TMR_7:
        	u32EvtNum = CSL_GEM_TINTLN;
        	u32EvtArg = CSL_GEM_TINTLN;
        	break;
        case CSL_TMR_8:
        	u32EvtNum = CSL_GEM_TINT8L;
        	u32EvtArg = CSL_GEM_TINT8L;
        	break;
        default:
        	break;
        tmrIntcHandle = CSL_intcOpen(&tmrIntcObj, u32EvtNum, &vectId, &intStat);
        if (tmrIntcHandle == NULL)
            return -1;
        /* Bind ISR to Interrupt */
        EventRecord.handler = (CSL_IntcEventHandler)&TimerInterruptHandler;
        EventRecord.arg     = (void *)u32EvtArg;
        CSL_intcPlugEventHandler(tmrIntcHandle, &EventRecord);
        /* Event Enable */
        CSL_intcHwControl(tmrIntcHandle, CSL_INTC_CMD_EVTENABLE, NULL);
         ********************** Timer related code ********************
        /* Open the timer. */
        hTmr =  CSL_tmrOpen(&TmrObj, IntcInstance, NULL, &status);
        if (hTmr == NULL)
            return -1;
        /* Open the timer with the defaults. */
        CSL_tmrHwSetup(hTmr, &hwSetup);
        /* Stop the Timer */
        status = CSL_tmrHwControl(hTmr, CSL_TMR_CMD_RESET_TIMLO, NULL);
        /* Set the timer mode to unchained dual mode */
        hwSetup.tmrTimerMode = CSL_TMR_TIMMODE_DUAL_UNCHAINED;
        /* Reset the timer ISR Counter. */
        /* Load the period register */
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_LOAD_PRDLO, (void *)&LoadValue);
        /* Start the timer with one shot */
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_START_TIMLO, (void *)&TimeCountMode);
        /* INTC related code */
        /* Good. The timer ISR was invoked; now we wait for some time and make
         * sure that the ISR was not invoked again since this is a ONE SHOT
         * Timer. */
        for (LoadValue = 0; LoadValue < MAX_DELAY; LoadValue++);
        /* Timer ISR Counter should still be the same */
        if (timerISRCounter != 1)
            return -1;
        /* Also the LOW Count Register should remain at the value 0. */
        CSL_tmrGetTimLoCount(hTmr, &count);
        if (count != 0)
            return -1;
        /* Disable the interrupts. */
        CSL_intcHwControl(tmrIntcHandle, CSL_INTC_CMD_EVTDISABLE, NULL);
        /* Close the Timer and Interrupt Handles. */
        CSL_tmrClose(hTmr);
        CSL_intcClose(tmrIntcHandle);
        /* Test has been completed successfully. */
        return 0;
     *  @b Description
     *  @n
     *      This function is used to test the HI Timer in Single Shot Mode
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 test_high_single_shot_timer (Uint8 IntcInstance)
        CSL_TmrHandle               hTmr;
        CSL_TmrObj                  TmrObj;
        CSL_Status                  status;
        Uint32                      count;
        printf("Debug: Testing High Timer (Unchained) in Single Shot Mode...\n");
        switch(u8TI)
           case CSL_TMR_0:
           case CSL_TMR_1:
           case CSL_TMR_2:
           case CSL_TMR_3:
           case CSL_TMR_4:
           case CSL_TMR_5:
           case CSL_TMR_6:
           case CSL_TMR_7:
           	u32EvtNum = CSL_GEM_TINTHN;
           	break;
           case CSL_TMR_8:
           	u32EvtNum = CSL_GEM_TINT8H;
           	break;
           default:
           	break;
        /* Open INTC */
        vectId = CSL_INTC_VECTID_13;
        tmrIntcHandle = CSL_intcOpen(&tmrIntcObj, u32EvtNum, &vectId, NULL);
            return -1;
        /* Event Enable */
        if (hTmr == NULL)
            return -1;
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_RESET_TIMHI, NULL);
        status = CSL_tmrHwControl(hTmr, CSL_TMR_CMD_LOAD_PRDHI, (void *)&LoadValue);
        /* Start the timer in SINGLE SHOT Mode. */
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_START_TIMHI, (void *)&TimeCountMode);
         * Timer. */
            return -1;
        /* Also the HIGH Count Register should remain at the value 0. */
        CSL_tmrGetTimHiCount(hTmr, &count);
        if (count != 0)
            return -1;
        /* Disable the events. */
        /* Close the Tmr and Interrupt handles. */
        CSL_tmrClose(hTmr);
        /* Test has completed successfully. */
        return 0;
     *  @b Description
     *  @n
     *      This function is used to test the HI Timer in Continuous Mode
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 test_high_continuous_timer (Uint8 IntcInstance)
        CSL_TmrHandle               hTmr;
        CSL_TmrObj                  TmrObj;
        CSL_Status                  status;
        Uint32                      LoadValue = 1000;
        CSL_TmrEnamode              TimeCountMode = CSL_TMR_ENAMODE_CONT;
        Uint32                      count;
        printf("Debug: Testing High Timer (Unchained) in Continuous Mode....\n");
        switch(u8TI)
              case CSL_TMR_0:
              case CSL_TMR_1:
              case CSL_TMR_2:
              case CSL_TMR_3:
              case CSL_TMR_4:
              case CSL_TMR_5:
              case CSL_TMR_6:
              case CSL_TMR_7:
              	break;
              case CSL_TMR_8:
              	break;
              default:
              	break;
        /* Open INTC */
            return -1;
        /* Event Enable */
        if (hTmr == NULL)
            return -1;
        /* Start the timer in CONTINUOUS Mode. */
        while (timerISRCounter <= 5);
        /* Since the HIGH Counter is operating in Continuous Mode; the value here should
         * be non-zero. Though there is a small probability that the value here could be 0. */
        if (count == 0)
            /* Taking into account the small probability; lets confirm out again.
             * This time for sure the value should be non-zero. */
            if (count == 0)
                return -1;
        CSL_tmrClose(hTmr);
        return 0;
     *  @b Description
     *  @n
     *      This function is used to test the timers while operating in CHAINED mode.
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 test_chained_timer (Uint8 IntcInstance)
        CSL_TmrHandle               hTmr;
        CSL_TmrObj                  TmrObj;
        CSL_Status                  status;
        Uint32                      LoadValue1 = 0;
        Uint8                       preScalValue = 0;
        printf("Debug: Testing Timer (Chained) in Single Shot Mode....\n");
        switch(u8TI)
              case CSL_TMR_0:
              case CSL_TMR_1:
              case CSL_TMR_2:
              case CSL_TMR_3:
              case CSL_TMR_4:
              case CSL_TMR_5:
              case CSL_TMR_6:
              case CSL_TMR_7:
              	break;
              case CSL_TMR_8:
              	break;
              default:
              	break;
        /* Open INTC */
            return -1;
        /* Event Enable */
        if (hTmr == NULL)
            return -1;
        /* Reset the Timer */
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_RESET64, NULL);
        /* Set the timer mode to dual chained mode */
        hwSetup.tmrTimerMode = CSL_TMR_TIMMODE_DUAL_CHAINED;
        /* Load the prescale value */
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_LOAD_PSCHI, (void *)&preScalValue);
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_LOAD_PRDHI, (void *)&LoadValue1);
        /* Start the timer with SINGLE SHOT Mode. */
        CSL_tmrHwControl(hTmr, CSL_TMR_CMD_START64, (void *)&TimeCountMode);
         * Timer. */
            return -1;
        /* Close the Tmr and interrupt handles */
        CSL_tmrClose(hTmr);
        return 0;
     *  @b Description
     *  @n
     *      This function is used to test the General Purpose Timer.
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 test_gp_timer (Uint8 IntcInstance)
        CSL_TmrHandle               hTmr;
        CSL_TmrObj                  TmrObj;
        CSL_Status                  status;
        Uint32                      delayCount;
        printf("Debug: Testing 64bit Timer in Single Shot Mode...\n");
        switch(u8TI)
              case CSL_TMR_0:
              case CSL_TMR_1:
              case CSL_TMR_2:
              case CSL_TMR_3:
              case CSL_TMR_4:
              case CSL_TMR_5:
              case CSL_TMR_6:
              case CSL_TMR_7:
              	break;
              case CSL_TMR_8:
              	break;
              default:
              	break;
        /* Open INTC */
        /* Event Enable */
        if (hTmr == NULL)
            return -1;
        /* Set the timer mode to 64bit GP Timer Mode and set the PRD registers */
        hwSetup.tmrTimerMode     = CSL_TMR_TIMMODE_GPT;
        hwSetup.tmrTimerPeriodLo = 0x0f;
        hwSetup.tmrTimerPeriodHi = 0x00;
         * Timer. */
        for (delayCount = 0; delayCount < MAX_DELAY; delayCount++);
            return -1;
        CSL_tmrClose(hTmr);
        return 0;
     *  @b Description
     *  @n
     *      This function is used to test the timer in watchdog mode.
     *  @retval
     *      Success -   0
     *  @retval
     *      Error   -   <0
    static Int32 test_wd_timer (Uint8 IntcInstance)
        CSL_TmrObj                  TmrObj;
        CSL_Status                  status;
        Uint16                      loadVal;
        printf("Debug: Testing Watch Dog Timer...\n");
        switch(u8TI)
              case CSL_TMR_0:
              case CSL_TMR_1:
              case CSL_TMR_2:
              case CSL_TMR_3:
              case CSL_TMR_4:
              case CSL_TMR_5:
              case CSL_TMR_6:
              case CSL_TMR_7:
              	break;
              case CSL_TMR_8:
              	break;
              default:
              	break;
        /* Open INTC */
            return -1;
        EventRecord.handler = (CSL_IntcEventHandler)&WatchDogTimerHandler;
        /* Event Enable */
        wdTmr = CSL_tmrOpen(&TmrObj, IntcInstance, NULL, &status);
        if (wdTmr == NULL)
            return -1;
        /* Set the timer mode to WATCHDOG mode */
        hwSetup.tmrTimerMode    = CSL_TMR_TIMMODE_WDT;
        hwSetup.tmrPulseWidthLo = CSL_TMR_PWID_THREECLKS;
        hwSetup.tmrClksrcLo     = CSL_TMR_CLKSRC_INTERNAL;
        hwSetup.tmrClockPulseLo = CSL_TMR_CP_PULSE;
        hwSetup.tmrClockPulseHi = CSL_TMR_CP_PULSE;
        hwSetup.tmrIpGateLo     = CSL_TMR_CLOCK_INP_NOGATE;
        /* load the PRDLO */
        hwSetup.tmrTimerPeriodLo = 0x100;
        /* load the PRDHI */
        hwSetup.tmrTimerPeriodHi = 0x0;
        /* Configure the timer. */
        CSL_tmrHwSetup(wdTmr, &hwSetup);
        /* Reset the timer ISR counter. */
        CSL_tmrHwControl(wdTmr, CSL_TMR_CMD_RESET64, NULL);
        CSL_tmrHwControl(wdTmr, CSL_TMR_CMD_START_WDT, (void *)&TimeCountMode);
        /* Wait for the timer interrupts to fire; since the watchdog timers run continuously
         * we wait for at least 5 interrupts to fire... */
        while (timerISRCounter != 5);
        CSL_tmrClose(wdTmr);
        return 0;
     *  @b Description
     *  @n
     *      Entry point for the test code.
     *  @retval
     *      Not Applicable.
    void main (void)
    	printf ("**************************************************\n");
        printf ("****************** Timer Testing  ****************\n");
        u8TI = CSL_TMR_8;
        /* Initialize the INTC Module. */
        if (intc_init() < 0)
            printf ("Error: Initialization of the INTC module failed\n");
            return;
        /* Initialize timer CSL module */
        CSL_tmrInit(NULL);
        /* Start the testing for the LOW Timer. */
        if (test_lo_single_shot_timer(u8TI) < 0)
            printf("Error: Testing Low Timer (Unchained) in Single Shot Mode FAILED\n");
            return;
        printf("Debug: Testing Low Timer (Unchained) in Single Shot Mode Passed\n");
        /* Start the testing for the High Timer. */
        if (test_high_single_shot_timer(u8TI) < 0)
            printf("Error: Testing High Timer (Unchained) in Single Shot Mode FAILED\n");
            return;
        printf("Debug: Testing High Timer (Unchained) in Single Shot Mode Passed\n");
        /* Start the testing for the High Timer in Continuous Mode. */
        if (test_high_continuous_timer(u8TI) < 0)
            printf("Error: Testing High Timer (Unchained) in Continuous Mode FAILED\n");
            return;
        printf("Debug: Testing High Timer (Unchained) in Continuous Mode Passed\n");
        /* Start the testing for the 64bit General Purpose Timer. */
        if (test_gp_timer(u8TI) < 0)
            printf("Error: Testing 64bit Timer in Single Shot Mode FAILED\n");
            return;
        printf("Debug: Testing 64bit Timer in Single Shot Mode Passed\n");
        /* Start the testing for the the timers in Chained Mode. */
        if (test_chained_timer(u8TI) < 0)
            printf("Error: Testing Timer (Chained) in Single Shot Mode FAILED\n");
            return;
        printf("Debug: Testing Timer (Chained) in Single Shot Mode Passed\n");
    #if 0
        /* Start the testing for Watch Dog. */
        if (test_wd_timer(u8TI) < 0)
            printf("Error: Testing Watch Dog Timer FAILED\n");
            return;
        printf("Debug: Testing Watch Dog Timer Passed\n");
    #endif
        /* All the timer tests have passed. */
        printf ("************* Timer Testing Successful ***********\n");
        return;
    In C6657, Timer 4-7 are secondary interrupts to Corepac through CIC0.
    Please refer hyperlink example project for secondary interrupt mapping to corepac.(Available part of MCSDK).
    Thank you.
