RDK3.5 8148
how can i get video from VIN0 PORTA?
my test code:
#include "mcfw/src_linux/mcfw_api/usecases/multich_common.h"
#include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h"
#include "uw_81xx_bas/bas_host/multich_usecase/main_interface_priv.h"
* Externs
/* Merge Link for camera streams */
//#define NUM_DUP_LINK (3)
#define NUM_MERGE_LINK (1)
#define CAM_STREAM_MERGE_IDX (0)
#define NUM_CAPTURE_DEVICES 1
//#define HDMIDIS_DUP_IDX (0)
#define GET_FRAME_FROM_VIP0PORTA (1)
* Use case code
#if GET_FRAME_FROM_VIP0PORTA
static SystemVideo_Ivahd2ChMap_Tbl systemVid_encDecIvaChMapTbl = {
.isPopulated = 1,
.ivaMap[0] = {
.EncNumCh = 2,
.EncChList = {0, 1},
.DecNumCh = 0,
.DecChList = {0, 0},
.ivaMap[1] = {
.EncNumCh = 2,
.EncChList = {2, 3 },
.DecNumCh = 0,
static Void SetIpcFramesOutInQueInfo(System_LinkQueInfo *inQueInfo)
Int i;
inQueInfo->numCh =2;// gVencModuleContext.vencConfig.numPrimaryChn;
for (i = 0; i < inQueInfo->numCh; i++)
inQueInfo->chInfo[i].bufType = SYSTEM_BUF_TYPE_VIDFRAME;
inQueInfo->chInfo[i].dataFormat = SYSTEM_DF_YUV420SP_UV;
inQueInfo->chInfo[i].memType = SYSTEM_MT_NONTILEDMEM;
inQueInfo->chInfo[i].scanFormat = SYSTEM_SF_PROGRESSIVE;
inQueInfo->chInfo[i].startX = 0;
inQueInfo->chInfo[i].startY = 0;
inQueInfo->chInfo[i].width = uw_ch_width;//1920;
inQueInfo->chInfo[i].height = uw_ch_height;//1080;
inQueInfo->chInfo[i].pitch[0] = uw_ch_width;
inQueInfo->chInfo[i].pitch[1] = uw_ch_width;
inQueInfo->chInfo[i].pitch[2] = uw_ch_width;
Int32 multich_create_uw_fullftr()
Int32 i;
// VPSS ---->A8
//A8--->c674
System_LinkInfo framesProducerLinkInfo;
//A8--->VIDEO
CaptureLink_CreateParams capPrm;
UInt32 mergeId[NUM_MERGE_LINK];
MergeLink_CreateParams mergePrm[NUM_MERGE_LINK];
//VPSS ---->A8
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssToHostPrm;
IpcFramesInLinkHLOS_CreateParams ipcFramesInHostPrm;
//A8--->M3Video
UInt32 ipcInVideoFrameId;
IpcFramesOutLinkHLOS_CreateParams ipcFramesOutHostPrm;
IpcFramesInLinkRTOS_CreateParams ipcFramesInVideoFromHostPrm;
EncLink_CreateParams encPrm;
//M3Video --->A8
IpcBitsOutLinkRTOS_CreateParams ipcBitsOutVideoToHostPrm;
IpcBitsInLinkHLOS_CreateParams ipcBitsInHostPrm;
// VCAP_VIDDEC_PARAMS_S vidDecVideoModeArgs[NUM_CAPTURE_DEVICES];
CaptureLink_VipInstParams *pCapInstPrm;
CaptureLink_OutParams *pCapOutPrm;
/* IPC struct init */
MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams, ipcFramesOutVpssToHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkHLOS_CreateParams, ipcFramesInHostPrm);
MULTICH_INIT_STRUCT(IpcFramesOutLinkHLOS_CreateParams, ipcFramesOutHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams, ipcFramesInVideoFromHostPrm);
MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams, ipcBitsOutVideoToHostPrm);
MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams, ipcBitsInHostPrm);
// MULTICH_INIT_STRUCT(CaptureLink_CreateParams, capPrm);
//System_init();
MultiCh_detectBoard();
System_linkControl(SYSTEM_LINK_ID_M3VPSS, SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES, NULL, 0, TRUE);
System_linkControl(SYSTEM_LINK_ID_M3VIDEO, SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
&systemVid_encDecIvaChMapTbl, sizeof(SystemVideo_Ivahd2ChMap_Tbl), TRUE);
gVcapModuleContext.captureId = SYSTEM_LINK_ID_CAPTURE;
mergeId[CAM_STREAM_MERGE_IDX] = SYSTEM_VPSS_LINK_ID_MERGE_0;
gVcamModuleContext.ipcFramesOutVpssToHostId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_0;
gVcamModuleContext.ipcFramesInHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0;
gVcamModuleContext.ipcFramesOutHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_OUT_0;
gMjpegModuleContext.mjpepEncId = SYSTEM_LINK_ID_MJPEG;
ipcInVideoFrameId = SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_IN_0;
gVencModuleContext.encId = SYSTEM_LINK_ID_VENC_0;
gVencModuleContext.ipcBitsOutRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;
gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
/* Camera Link params */
CaptureLink_CreateParams_Init(&capPrm);
capPrm.outQueParams[0].nextLink = mergeId[CAM_STREAM_MERGE_IDX];
capPrm.outQueParams[1].nextLink = mergeId[CAM_STREAM_MERGE_IDX];
/* This is for TVP5158 Audio Channels - Change it to 16 if there are 16
* audio channels connected in cascade */
capPrm.numVipInst = 1;
capPrm.tilerEnable = FALSE;
capPrm.numBufsPerCh = 6;
capPrm.numExtraBufs = 6;
capPrm.numAudioChannels= 0;
capPrm.fakeHdMode = FALSE;
capPrm.isPalMode=TRUE;
capPrm.enableSdCrop=FALSE;
capPrm.doCropInCapture=FALSE;
gVcapModuleContext.vcapConfig.enableConfigExtVideoDecoder = FALSE;
pCapInstPrm = &capPrm.vipInst[0];
pCapInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP0_PORTA;
//SYSTEM_DEVICE_VID_DEC_TVP7002_DRV;
pCapInstPrm->videoDecoderId = MultiCh_getSensorId(gUI_mcfw_config.sensorId);
pCapInstPrm->inDataFormat = SYSTEM_DF_YUV422P;// SYSTEM_DF_YUV420SP_UV;
pCapInstPrm->standard = SYSTEM_STD_1080P_30;
pCapInstPrm->numOutput = 2;
/* First stream */
pCapOutPrm = &pCapInstPrm->outParams[0];
pCapOutPrm->dataFormat = SYSTEM_DF_YUV420SP_UV;
pCapOutPrm->scEnable = FALSE;
pCapOutPrm->scOutWidth = uw_ch_width;
pCapOutPrm->scOutHeight = uw_ch_height;
pCapOutPrm->outQueId = 0;
/* second stream */
pCapOutPrm = &pCapInstPrm->outParams[1];
pCapOutPrm->outQueId = 1;
// Vcap_configVideoDecoder(vidDecVideoModeArgs, NUM_CAPTURE_DEVICES);
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[0].prevLinkId = gVcapModuleContext.captureId;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[0].prevLinkQueId = 0;
mergePrm[CAM_STREAM_MERGE_IDX].numInQue = 2;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[1].prevLinkId = gVcapModuleContext.captureId;
mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[1].prevLinkQueId = 1;
mergePrm[CAM_STREAM_MERGE_IDX].outQueParams.nextLink = gVcamModuleContext.ipcFramesOutVpssToHostId;
mergePrm[CAM_STREAM_MERGE_IDX].notifyNextLink = TRUE;
//set Frames out vpss to host link info
ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId = mergeId[CAM_STREAM_MERGE_IDX];
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcamModuleContext.ipcFramesInHostId;
ipcFramesOutVpssToHostPrm.baseCreateParams.numOutQue=1;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyProcessLink=FALSE;
ipcFramesInHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = FALSE;//TRUE;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcamModuleContext.ipcFramesOutVpssToHostId;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID;;
ipcFramesInHostPrm.baseCreateParams.numOutQue = 1;
ipcFramesInHostPrm.exportOnlyPhyAddr = TRUE;
ipcFramesInHostPrm.cbCtx = &gVcamModuleContext;
ipcFramesInHostPrm.cbFxn = Vcam_ipcFramesInCbFxn;
//A8 Frames to M3Video set
ipcFramesOutHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutHostPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesOutHostPrm.baseCreateParams.numOutQue = 1;
ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID;
ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutHostPrm.baseCreateParams.outQueParams[0].nextLink = ipcInVideoFrameId;
SetIpcFramesOutInQueInfo(&ipcFramesOutHostPrm.inQueInfo);
ipcFramesInVideoFromHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInVideoFromHostPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesInVideoFromHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesInVideoFromHostPrm.baseCreateParams.numOutQue = 1;
ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcamModuleContext.ipcFramesOutHostId;
ipcFramesInVideoFromHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInVideoFromHostPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.encId;
// init encode params
/* Video Encoder Link params */
MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
encPrm.numBufPerCh[0] = 4; //D1
encPrm.numBufPerCh[1] = 4; //CIF]]
EncLink_ChCreateParams *pLinkChPrm;
EncLink_ChDynamicParams *pLinkDynPrm;
VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
VENC_CHN_PARAMS_S *pChPrm;
for (i = 0; i < VENC_PRIMARY_CHANNELS; i++)
pLinkChPrm = &encPrm.chCreateParams[i];
pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
pChPrm = &gVencModuleContext.vencConfig.encChannelParams[i];
pDynPrm = &pChPrm->dynamicParam;
pLinkChPrm->format = IVIDEO_H264HP;
pLinkChPrm->profile = gVencModuleContext.vencConfig.h264Profile[i];
pLinkChPrm->dataLayout = IVIDEO_PROGRESSIVE;
pLinkChPrm->fieldMergeEncodeEnable = FALSE;
pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo;
pLinkChPrm->maxBitRate = pChPrm->maxBitRate;
pLinkChPrm->encodingPreset = pChPrm->encodingPreset;
pLinkChPrm->rateControlPreset = IVIDEO_USER_DEFINED; //pChPrm->rcType;
pLinkChPrm->enableHighSpeed = FALSE;
pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking;
pLinkChPrm->StreamPreset = gUI_mcfw_config.StreamPreset[i];
/* pLinkChPrm->profile = VENC_CHN_BASELINE_PROFILE ;//gVencModuleContext.vencConfig.h264Profile[i];
pLinkChPrm->enableHighSpeed = TRUE;//FALSE;
pLinkDynPrm->intraFrameInterval = 30;//pDynPrm->intraFrameInterval;
pLinkDynPrm->targetBitRate = 1000*1000;//pDynPrm->targetBitRate;
pLinkDynPrm->interFrameInterval = 1;
pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
// pLinkDynPrm->inputFrameRate = 60;//pDynPrm->inputFrameRate;
pLinkDynPrm->rcAlg = pDynPrm->rcAlg;
pLinkDynPrm->qpMin = pDynPrm->qpMin;
pLinkDynPrm->qpMax = pDynPrm->qpMax;
pLinkDynPrm->qpInit = pDynPrm->qpInit;
pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration;
pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity;
// encPrm.numBufPerCh[i] = 4;
// gVencModuleContext.encFormat[i] = pLinkChPrm->format;
/* Video Encoder Framerate */
// encPrm.chCreateParams[0].defaultDynamicParams.interFrameInterval = 0;
encPrm.chCreateParams[0].defaultDynamicParams.inputFrameRate = 30;
encPrm.chCreateParams[1].defaultDynamicParams.inputFrameRate = 30;
encPrm.vsEnable = 0;//gUI_mcfw_config.vsEnable;
encPrm.isVaUseCase = 0;
for (i =0 ; i < 1; i++)
encPrm.chCreateParams[i].format = IVIDEO_MJPEG;
encPrm.chCreateParams[i].profile = 0;
encPrm.chCreateParams[i].dataLayout = IVIDEO_PROGRESSIVE;
encPrm.chCreateParams[i].fieldMergeEncodeEnable = FALSE;
encPrm.chCreateParams[i].defaultDynamicParams.intraFrameInterval = 30;
encPrm.chCreateParams[i].encodingPreset = 0;
encPrm.chCreateParams[i].enableAnalyticinfo = 0;
encPrm.chCreateParams[i].enableWaterMarking = 0;
// encPrm.chCreateParams[i].defaultDynamicParams.inputFrameRate = 25;
encPrm.chCreateParams[i].rateControlPreset = 0;
encPrm.chCreateParams[i].defaultDynamicParams.targetBitRate =
1000 * 1000;
encPrm.chCreateParams[i].defaultDynamicParams.interFrameInterval = 1;
encPrm.chCreateParams[i].defaultDynamicParams.mvAccuracy = 0;
encPrm.inQueParams.prevLinkId = ipcInVideoFrameId;
encPrm.inQueParams.prevLinkQueId = 0;
encPrm.outQueParams.nextLink = gVencModuleContext.ipcBitsOutRTOSId;
/* IPC Bits Out VIDEO Link params */
ipcBitsOutVideoToHostPrm.baseCreateParams.noNotifyMode = TRUE;//FALSE;
ipcBitsOutVideoToHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcBitsOutVideoToHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcBitsOutVideoToHostPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
ipcBitsOutVideoToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsOutVideoToHostPrm.baseCreateParams.numOutQue = 1;
ipcBitsOutVideoToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoToHostPrm, TRUE);
/* IPC Bits In HOST Link params */
ipcBitsInHostPrm.baseCreateParams.noNotifyMode = TRUE;//FALSE;
ipcBitsInHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcBitsInHostPrm.baseCreateParams.notifyPrevLink = FALSE;//TRUE;
ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm);
/* Links Creation */
/* Camera Link */
System_linkCreate (gVcapModuleContext.captureId, &capPrm, sizeof(capPrm));
/* Merge Link */
System_linkCreate(mergeId[CAM_STREAM_MERGE_IDX], &mergePrm[CAM_STREAM_MERGE_IDX], sizeof(mergePrm[CAM_STREAM_MERGE_IDX]));
//out yuv 420 1080P to A8
System_linkCreate(gVcamModuleContext.ipcFramesOutVpssToHostId, &ipcFramesOutVpssToHostPrm, sizeof(ipcFramesOutVpssToHostPrm));
System_linkCreate(gVcamModuleContext.ipcFramesInHostId, &ipcFramesInHostPrm, sizeof(ipcFramesInHostPrm));
System_linkGetInfo(gVcamModuleContext.ipcFramesInHostId,&framesProducerLinkInfo);
OSA_assert(framesProducerLinkInfo.numQue == 1);
ipcFramesOutHostPrm.inQueInfo = framesProducerLinkInfo.queInfo[0];
//A8 out yuv420 to M3Video
System_linkCreate(gVcamModuleContext.ipcFramesOutHostId, &ipcFramesOutHostPrm, sizeof(ipcFramesOutHostPrm));
System_linkCreate(ipcInVideoFrameId, &ipcFramesInVideoFromHostPrm, sizeof(ipcFramesInVideoFromHostPrm));
#if 1
// Video Encoder Link
System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
//M3Video to A8
System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoToHostPrm, sizeof(ipcBitsOutVideoToHostPrm));
System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm, sizeof(ipcBitsInHostPrm));
#endif
return 0;
Void multich_delete_uw_fullftr()
System_linkDelete(gVencModuleContext.ipcBitsInHLOSId);
System_linkDelete(gVencModuleContext.ipcBitsOutRTOSId);
System_linkDelete(gVencModuleContext.encId);
System_linkDelete(ipcInVideoFrameId);
System_linkDelete(gVcamModuleContext.ipcFramesOutHostId);
System_linkDelete(gVcamModuleContext.ipcFramesInHostId);
System_linkDelete(gVcamModuleContext.ipcFramesOutVpssToHostId);
System_linkDelete(mergeId[CAM_STREAM_MERGE_IDX]);
System_linkDelete(gVcapModuleContext.captureId);
/* Reset the accumulated timer ticks */
MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE);
OSA_printf("USECASE TEARDOWN DONE\n");
Int32 multich_start_uw_fullftr()
//start Links
#if 1
System_linkStart(gVencModuleContext.ipcBitsInHLOSId);
System_linkStart(gVencModuleContext.ipcBitsOutRTOSId);
System_linkStart(gVencModuleContext.encId);
#endif
System_linkStart(ipcInVideoFrameId);
System_linkStart(gVcamModuleContext.ipcFramesOutHostId);
System_linkStart(gVcamModuleContext.ipcFramesInHostId);
System_linkStart(gVcamModuleContext.ipcFramesOutVpssToHostId);
System_linkStart(mergeId[CAM_STREAM_MERGE_IDX]);
System_linkStart(gVcapModuleContext.captureId);
return 0;
Void multich_stop_uw_fullftr()
//start Links
System_linkStop(gVcapModuleContext.captureId);
System_linkStop(mergeId[CAM_STREAM_MERGE_IDX]);
System_linkStop(gVcamModuleContext.ipcFramesOutVpssToHostId);
System_linkStop(gVcamModuleContext.ipcFramesInHostId);
System_linkStop(gVcamModuleContext.ipcFramesOutHostId);
System_linkStop(ipcInVideoFrameId);
System_linkStop(gVencModuleContext.encId);
System_linkStop(gVencModuleContext.ipcBitsOutRTOSId);
System_linkStop(gVencModuleContext.ipcBitsInHLOSId);
#endif
pCapInstPrm->inDataFormat = SYSTEM_DF_YUV422P; is run ok, but can not get video;
pCapInstPrm->inDataFormat = SYSTEM_DF_YUV422I_UYVY; is run error;
how can i get the video from vin0 portA ?
