DM365 : Disabling dei and resize functions
I am currently working on DM365 IPNC RDK 5.1.0.
The following is the sequence of tasks taking place in capture thread :
Capture -> dei -> resize -> encode -> stream -> display
I am trying to implement just : Capture -> encode -> stream -> display .
I have tried to accomplish this by setting config ->deiTskEnable = FALSE   and
config -> captureSingleResize = FALSE.
I am getting the following errors. Please help me out here ! Is there something else that also has to be done ? Please help me understand this problem better !
Thanks.
AVSERVER UI: Initializing.
 AVSERVER API: Creating TSKs.
 CLK Hz,
 ARM   Hz =  216000000
 DDR   Hz =  171789472
 VPSS  Hz =  171789472
 IMCOP Hz =  171789472
 AVSERVER API: Creating TSKs...DONE
SYSTEM.MSTPRI0 value changed to 00440011
CONFIGURING AVSERVER FOR DM365 .....
Creat queue id:0
queue id:0
 AVSERVER A[   66.772097] mt9p031 1-0048: No MT9P031 chip detected, register read ffffff87
PI: Sending START.
 AVSERVER MAIN: Recevied CMD = 0x0400, state = 0x0000
 AVSERVER MAIN: AVSERVER_tskConnectInit() ...
 *** WARNING  FD: exceeded max input size for FD, disabling FD (current input 720x576)!!!
 AVSERVER MAIN: Create captureTsk ...
 CAPTURE: Recevied CMD = 0x0300
 CAPTURE: Create...
 CAPTURE: Opening capture on imager TVP515X.
 SENSOR FPS VALUE = 25
 Sensor Mode Info,
 Width      =  704
 Height     =  288
 fps        =   25
 Bin Enable =    0
 Sensor Frame Timing Info,
 fps                  = 25
 t_frame (ns)         = 40000000.000000
 t_row   (ns)         = 25062.500000
 t_pclk  (ns)         = 15.625000
 W                    = 704
 H                    = 576
 SW                   = 1595
 SD                   = 0
 HB                   = 450
 VB                   = 1020
 HBmin                = 450
 VBmin                = 9
 f_pclk               = 64000000
 shutterOverhead (ns) = 6656.250000
 col_size             = 703
 row_size             = 575
 col_skip             = 0
 row_skip             = 0
 col_bin              = 0
 row_bin              = 0
 col_start            = 8
 row_start            = 0
 pll_M                = 16
 pll_N                = 1
 pll_DIV              = 2
######Imager Id Check succes
Common Setting Applied
 CAPTURE: Create...DONE
 AVSERVER MAIN: Create encodeTsk ...
 ENCODE: Recevied CMD = 0x0300
 ENCODE: Create...
 AVSERVER MAIN: Create streamTsk ...
 STREAM: Recevied CMD = 0x0300
 STREAM: Create...
 STREAM: Ext 0: 0x0
 STREAM: Ext 1: 704x576
Creat queue id:32769
queue id:32769
 STREAM: Create...DONE
 AVSERVER MAIN: Create fdTsk ...
 FD: Received CMD = 0x0300
 FD: Create...
 AVSERVER MAIN: Create displayTsk ...
 FD: Create...DONE
 DISPLAY: Recevied CMD = 0x0300
 DISPLAY: Create...
 AVSERVER MAIN: Create aewbTsk ...
 2A: Recevied CMD = 0x0300
 2A: Create...
IPNC_DM365_5.1.0 (root@swathi-Dell-System-
Vostro-3460) (gcc version 4.3.3 (GCC
IPNC AUTO_IRIS = 1
 2A: Create...DONE
 AVSERVER MAIN: Create audioPlayTsk ...
 AUDIOPLAY: Recevied CMD = 0x0300
 AUDIOPLAY: Create...
 DISPLAY: Create...DONE
 AUDIOPLAY: Create...DONE
 AVSERVER MAIN: Create motionTsk ...
 MOTION: Recevied CMD = 0x0300
 MOTION: Create...
 AVSERVER MAIN: Create swosdTsk ...
 MOTION: Create...DONE
 SWOSD: Recevied CMD = 0x0300
 AVSERVER MAIN: Allocing Buffers ...
 AVSERVER MAIN: Allocating buffers ...
 AVSERVER MAIN: Stream 0: Allocating DEI buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 0: Allocating LDC buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 0: Allocating VNF buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 0: Allocating Encode IN buffers: 3 of size 636032 bytes
 AVSERVER MAIN: Stream 0: Assigning Resize IN buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 0: Capture OUT buffers 0
 AVSERVER MAIN: Stream 0: Capture OUT buffers 1
 AVSERVER MAIN: Stream 0: Capture OUT buffers 2
 AVSERVER MAIN: Stream 1: Allocating DEI buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 1: Allocating LDC buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 1: Allocating VNF buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 1: Allocating Encode IN buffers: 3 of size 636032 bytes
 AVSERVER MAIN: Stream 1: Assigning Resize IN buffers: 0 of size 636032 bytes
 AVSERVER MAIN: Stream 1: Capture OUT buffers 0
 AVSERVER MAIN: Stream 1: Capture OUT buffers 1
 AVSERVER MAIN: Stream 1: Capture OUT buffers 2
 AVSERVER MAIN: Allocating FD buffers: 3 of size 368768 bytes
 AVSERVER MAIN: Allocating DMVA buffers: 0 of size 848000 bytes
 AVSERVER MAIN: Assigning Display buffers: 3 of size 848000 bytes
 AVSERVER MAIN: Stream 0: Alloc[   68.255139] CMEMK Error: get_phys: Unable to find phys addr for 0x5f3ab5e8
ating Encrypt bu[   68.262960] CMEMK Error: get_phys: get_user_pages() failed: -14
ffers: 0 of size[   68.271237] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f3ab5e8 to physical.
 203776 bytes
 [   68.279875] CMEMK Error: get_phys: Unable to find phys addr for 0x5a5bd7a8
AVSERVER MAIN: S[   68.287493] CMEMK Error: get_phys: get_user_pages() failed: -14
tream 0: Allocat[   68.294940] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a5bd7a8 to physical.
ing Stream buffers: 3 of size 203776 bytes
 AVSERVER MAIN: Stream 1: Allocating Encrypt buffers: 0 of size 406528 bytes
 AVSERVER MAIN: Stream 1: Allocating Stream buffers: 3 of size 406528 bytes
 AVSERVER MAIN: Allocating MotionDetect b[   68.323630] CMEMK Error: get_phys: Unable to find phys addr for 0x5f48c5a8
uffers: 3 of siz[   68.331871] CMEMK Error: get_phys: get_user_pages() failed: -14
e 0 bytes
 AVSE[   68.340091] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f48c5a8 to physical.
RVER MAIN: Alloc[   68.348393] CMEMK Error: get_phys: Unable to find phys addr for 0x5a69e768
ating buffers ..[   68.356548] CMEMK Error: get_phys: get_user_pages() failed: -14
.DONE
 AVSERVER[   68.363793] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a69e768 to physical.
 MAIN: Start aewbTsk ...
 2A: Start...
 2A: Start...DONE
 AVSERVER MAIN: Start captureTsk ...
 CAPTURE: Start...
 SWOSD: Create...DONE
 CAPTURE: Start...DONE
 AVSERVER MAIN: Start audioPlayTsk ...
 AUDIOPLAY: Start..[   68.391459] CMEMK Error: get_phys: Unable to find phys addr for 0x5f4c77e8
 AUDIOPLAY: S[   68.399338] CMEMK Error: get_phys: get_user_pages() failed: -14
tart...DONE
 AV[   68.407519] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f4c77e8 to physical.
SERVER MAIN: Sta[   68.416053] CMEMK Error: get_phys: Unable to find phys addr for 0x5a77a2a8
rt DONE
 AVSERV[   68.424003] CMEMK Error: get_phys: get_user_pages() failed: -14
ER API: Sending [   68.431292] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a77a2a8 to physical.
START...DONE
 CAPTURE: Isif Buf 0
 ENCODE: Stream 0 InBuf 0 OutBuf 0 (1711374344, 536941576)
 2A: H3a Buf 0
 2A: H3a Buf 0 ... DONE
 2A: H3a Buf 0
CMEM Error: getPhys: Failed to[   68.458215] CMEMK Error: get_phys: Unable to find phys addr for 0x5f3ab5e8
 get physical ad[   68.465477] CMEMK Error: get_phys: get_user_pages() failed: -14
dress of 0x5f3ab[   68.473743] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f3ab5e8 to physical.
5e8
 2A: H3a Bu[   68.482199] CMEMK Error: get_phys: Unable to find phys addr for 0x5a5bd7a8
f 1
 2A: H3a Bu[   68.490191] CMEMK Error: get_phys: get_user_pages() failed: -14
f 1 ... DONE
 2[   68.497286] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a5bd7a8 to physical.
A: H3a Buf 1
 2A: H3a Buf 1 ... DONE
CMEM Error: getPhys: Failed to get physical address of 0x5a5bd7a8
 2A: H3a Buf 2
 2A: H3a Buf 2 ... DONE
 2A: H3a Buf 2
 ALGVIDENC  |          68.00 |      [   68.524500] CMEMK Error: get_phys: Unable to find phys addr for 0x5f48c5a8
14.71 |         [   68.532978] CMEMK Error: get_phys: get_user_pages() failed: -14
68 |            [   68.541194] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f48c5a8 to physical.
1 |
 ENCODE FRA[   68.549689] CMEMK Error: get_phys: Unable to find phys addr for 0x5a69e768
ME 0: Stream 0 S[   68.557472] CMEMK Error: get_phys: get_user_pages() failed: -14
ize 26267 bytes [   68.564927] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a69e768 to physical.
Keyframe 1
 STREAM: Stream 0 InBuf 0, Frame size 26267 bytes, Key frame 1
 STREAM: Stream 0, saveToFile = 0, fileSaveState = 0, frame size = 26267, key frame = 1
 CAPTURE: Isif Buf 1
 ENCODE: Stream 0 InBuf 1 OutBuf 1 (1[   68.592198] CMEMK Error: get_phys: Unable to find phys addr for 0x5f4c77e8
174503432, 53694[   68.600438] CMEMK Error: get_phys: get_user_pages() failed: -14
1576)
 2A: H3a [   68.607543] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f4c77e8 to physical.
Buf 0
[   68.618049] CMEMK Error: get_phys: Unable to find phys addr for 0x5a77a2a8
 2A: H3a Buf 0
[   68.626396] CMEMK Error: get_phys: get_user_pages() failed: -14
 2A: H3a Buf 0 .[   68.633707] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a77a2a8 to physical.
.. DONE
CMEM Error: getPhys: Failed to get physical address of 0x5f48c5a8
 2A: H3a Buf 1
 2A: H3a Buf 1
CMEM Error: getPhys: Failed to get physical addres[   68.659862] CMEMK Error: get_phys: Unable to find phys addr for 0x5f3ab5e8
s of 0x5a69e768[   68.668558] CMEMK Error: get_phys: get_user_pages() failed: -14
 2A: H3a Buf 2[   68.675135] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f3ab5e8 to physical.
 2A: H3a Buf 2 [   68.684446] CMEMK Error: get_phys: Unable to find phys addr for 0x5a5bd7a8
... DONE
 2A: H[   68.692471] CMEMK Error: get_phys: get_user_pages() failed: -14
3a Buf 2
 2A: H[   68.699691] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a5bd7a8 to physical.
3a Buf 2 ... DONE
 ALGVIDENC  |          65.00 |      15.38 |         65 |            1 |
 ENCODE FRAME 1: Stream 0 Size 17385 bytes Keyframe 0
 STREAM: Stream 0 InBuf 1, Frame size 17385 bytes, Key frame 0
 STREAM: Stre[   68.726772] CMEMK Error: get_phys: Unable to find phys addr for 0x5f48c5a8
am 0, saveToFile[   68.736234] CMEMK Error: get_phys: get_user_pages() failed: -14
 = 0, fileSaveSt[   68.742581] CMEMK Error: GETPHYS: Failed to convert virtual 0x5f48c5a8 to physical.
ate = 0, frame s[   68.751939] CMEMK Error: get_phys: Unable to find phys addr for 0x5a69e768
ize = 17385, key[   68.759908] CMEMK Error: get_phys: get_user_pages() failed: -14
 frame = 0
 CAP[   68.767079] CMEMK Error: GETPHYS: Failed to convert virtual 0x5a69e768 to physical.
TURE: Isif Buf 2
 ENCODE: Stream 0 InBuf 2 OutBuf 2 (1711375368, 536941576)
 2A: H3a Buf 0
 2A: H3a Buf 0
CMEM Error: getPhys: Failed to get physical address of 0x5f4c77e8
 2A: H3a Buf 1
 2A: H3a Buf 1
CMEM Error: getPhys: Failed to get physical address of 0x5a77a2a8
 2A: H3a Buf 2
 2A: H3a Buf 2
 ALGVIDENC  |          64.00 |      15.62 |         64 |            1 |
 ENCODE FRAME 2: Stream 0 Size 3969 bytes Keyframe 0
 STREAM: Stream 0 InBuf 2, Frame size 3969 bytes, Key frame 0
 STREAM: Stream 0, saveToFile = 0, fileSaveState = 0, frame size = 3969, key frame = 0
 CAPTURE: Isif Buf 0
 2A: H3a Buf 0
 2A: H3a Buf 0
CMEM Error: getPhys: Failed to get physical address of 0x5f3ab5e8
 2A: H3a Buf 1
 2A: H3a Buf 1
 2A: H3a Buf 2
 2A: H3a Buf 2
 ENCODE FRAME 3: Stream 0 Size 2412 bytes Keyframe 0
 STREAM: Stream 0 InBuf 0, Frame size 2412 bytes, Key frame 0
 STREAM: Stream 0, saveToFile = 0, fileSaveState = 0, frame size = 2412, key frame = 0
 CAPTURE: Isif Buf 1
 ENCODE: Stream 0 InBuf 1 OutBuf 1 (1174503432, 536941576)
 2A: H3a Buf 0
 2A: H3a Buf 0
 2A: H3a Buf 1
 2A: H3a Buf 1
CMEM Error: getPhys: Failed to get physical address of 0x5a69e768
 2A: H3a Buf 2
 2A: H3a Buf 2
 ENCODE FRAME 4: Stream 0 Size 2470 bytes Keyframe 0
