SDMA transfer from NAND flash in AM3517
I would like to know how to do sDMA trasfer from NAND flash.
The below is a source code of sDMA of my customer.
static void dma_read(UCHAR* dst_addr, ULONG len)
unsigned int sdmaChNum=10;
ULONG* pd = (ULONG*)dst_addr;
ULONG src = BSP_NAND_REGS_PA+0x01F0;
ULONG dst = OALVAtoPA(dst_addr);
PutTextLn("DMA start");
CacheDataInvalidateBuff(dst_addr, len);
/* CSDP */
sdmaRegs->CH[sdmaChNum].CSDP
= CSL_FMKT(SDMA_CSDP_SRC_ENDIAN,LITTLEENDIAN) /* LITTLEENDIAN,BIGENDIAN */
| CSL_FMK (SDMA_CSDP_SRC_ENDIAN_LOCK,0) /* ?? */
| CSL_FMKT(SDMA_CSDP_DST_ENDIAN,LITTLEENDIAN) /* LITTLEENDIAN,BIGENDIAN */
| CSL_FMK (SDMA_CSDP_DST_ENDIAN_LOCK,0) /* ?? */
| CSL_FMK (SDMA_CSDP_WRITE_MODE,0)
| CSL_FMKT(SDMA_CSDP_DST_BURST,1BYTE) /* 1BYTE,16BYTE,32BYTE,64BYTE */
| CSL_FMKT(SDMA_CSDP_DST_PACKED,NONPACKED) /* NONPACKED,PACKED */
| CSL_FMKT(SDMA_CSDP_SRC_BURST,1BYTE)
| CSL_FMKT(SDMA_CSDP_SRC_PACKED,NONPACKED) /* NONPACKED,PACKED */
| CSL_FMKT(SDMA_CSDP_DATA_TYPE,16BIT); /* 8BIT,16BIT,32BIT */
/* CEN : Element per Frame (24bit) */
len /= 2;
sdmaRegs->CH[sdmaChNum].CEN = len;
/* CFN : Frame per Block (16bit) */
sdmaRegs->CH[sdmaChNum].CFN = 1;
/* Src and Dst */
sdmaRegs->CH[sdmaChNum].CSSA = src;
sdmaRegs->CH[sdmaChNum].CDSA = dst;
/* CCR */
sdmaRegs->CH[sdmaChNum].CCR
= CSL_FMKT(SDMA_CCR_WRITE_PRIORITY, HIGH) /* LOW,HIGH */
| CSL_FMKT(SDMA_CCR_BUFFERING, DISABLE) /* ENABLE,DISABLE */
| CSL_FMK (SDMA_CCR_SEL_SRC_DST_SYNC, 1)
| CSL_FMKT(SDMA_CCR_PREFETCH, DISABLE) /* DISABLE,ENABLE */
| CSL_FMKT(SDMA_CCR_SUPERVISOR, DISABLE) /* DISABLE,ENABLE */
| CSL_FMKT(SDMA_CCR_SECURE, DISABLE) /* DISABLE,ENABLE */
| CSL_FMK (SDMA_CCR_SYNCHRO_CONTROL_UPPER ,0)
| CSL_FMK (SDMA_CCR_BS, 0)
| CSL_FMKT(SDMA_CCR_TRANSPARENT_COPY, DISABLE) /* DISABLE,ENABLE */
| CSL_FMKT(SDMA_CCR_CONST_FILL, DISABLE) /* DISABLE,ENABLE */
| CSL_FMK (SDMA_CCR_DST_AMODE, 1) /* 0::CONST,1:POST_INC,2:SingleIndex,3:DblIndex */
| CSL_FMK (SDMA_CCR_SRC_AMODE, 0) /* 0::CONST,1:POST_INC,2:SingleIndex,3:DblIndex */
| CSL_FMKT(SDMA_CCR_WR_ACTIVE, INACTIVE) /* INACTIVE,ACTIVE */
| CSL_FMKT(SDMA_CCR_RD_ACTIVE, INACTIVE) /* INACTIVE,ACTIVE */
| CSL_FMK (SDMA_CCR_SUSPEND_SENSITIVE, 0)
| CSL_FMKT(SDMA_CCR_CHANNEL, DISABLE) /* DISABLE,ENABLE */
| CSL_FMKT(SDMA_CCR_READ_PRIORITY, HIGH) /* LOW,HIGH */
| CSL_FMK (SDMA_CCR_FS, 0)
| CSL_FMK (SDMA_CCR_SYNCHRO_CONTROL, 0);
/* INDEX */
sdmaRegs->CH[sdmaChNum].CSEI = 1; /* Source Element Index */
sdmaRegs->CH[sdmaChNum].CSFI = 1; /* Source Frame Index */
sdmaRegs->CH[sdmaChNum].CDEI = 1; /* Dst Element Index */
sdmaRegs->CH[sdmaChNum].CDFI = 1; /* Dst Frame Index */
sdmaRegs->CH[sdmaChNum].CICR = 0x0FFF; /* Interrupt Ebable */
/* START DMA */
CSL_FINST( sdmaRegs->CH[sdmaChNum].CCR, SDMA_CCR_CHANNEL, ENABLE);
while( (sdmaRegs->CH[sdmaChNum].CSR & 0x28) == 0 ) {}
PutTextLn("DMA end");
I checked the above source code based on "SDMA Basic Programming Model". But I could not find any issue.
Customer said me. This code works and transfer is completed. But the data of memory is not changed.
Could you find something wrong in the above source code?
Also I  posted the  dump list of DMA register.
CCR:    0x07004040
    CICR:    0x00000FBE
    CSR:    0X0000003C
    CSDR:    0X00000001
    CEN:    0X00000100
    CFN:    0X00000001
    CSSA:    0X060001F0
    CDSA:    0X8FE50AA0
    CSEI:    0X00000001
    CSFI:    0X00000001
    CDEI:    0X00000001
    CDFI:    0X00000001
    CSAC:    0X000001F0
    CDAC:    0X8FE50CA0
    CCEN:    0X00000100
    CCFN:    0X00000000
I appreciate your quick reply.
Michi
