tcf to cfg
I got the following output when converting mailbox.tcf to cfg file (spraas7g mailbox example):
Platform: ti.platforms.evmDM6437
        params.clockRate:594
        params.catalogName:ti.catalog
        params.deviceName:DM6437
Target: ti.targets.C64P
Clock Rate: 594
Illegal filename: null
js: "./packages/xdc/tools/Cmdr.xs", l
r: Cannot call method "readLine" of n
    "C:/Program Files/Texas Instrumen
ion/Main.xs", line 91
    "./packages/xdc/tools/ICmd.xs", l
    "./packages/xdc/xs.js", line 173
Besides, mailboxcfg.h file is not created.
XDCTool version: 3_22_01_21; 3_23_04_60; 3_25_03_72
bios: 6_32_02_39; 6_33_06_50; 6_35_04_50
None of them work. But for bios 6_33_06_50; 6_35_04_50, I got different errors.
  • Hi Cindy,
    Can you please post the command you are running to run the conversion tool?
    Steve
  • copy of the cmd window:
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
    C:\Users\work>xs --xp "C:/Program Files/Texas Instruments/bios_6_32_02_39/packag
    es" ti.bios.conversion --pr "C:\myRepository" --pn mbx_evmDm6437 -i "C:\Users\wo
    rk\Desktop\mailbox\mailbox.tcf"
            params.catalogName:ti.catalog.c6000
    Clock Rate: 594
    js: "C:/Program Files/Texas Instruments/bios_6_32_02_39/packages/ti/bios/convers
    ion/Main.xs", line 91: Error: ti.bios.conversion: TypeError: Cannot call method
    "readLine" of null
    C:\Users\work>cd C:\Program Files\Texas Instruments\xdctools_3_22_01_21
    C:\Program Files\Texas Instruments\xdctools_3_22_01_21>xs --xp "C:/Program Files
    /Texas Instruments/bios_6_32_02_39/packages" ti.bios.conversion --pr "C:\myRepos
    itory" --pn mbx_evmDm6437 -i "C:\Users\work\Desktop\mailbox\mailbox.tcf"
    Clock Rate: 594
    js: "./packages/xdc/tools/Cmdr.xs", line 51: Error: ti.bios.conversion: TypeErro
    r: Cannot call method "readLine" of null
        "./packages/xdc/tools/ICmd.xs", line 50
  • Hi Cindy,
    What files do you have in your folder "C:\Users\work\Desktop\mailbox"?
    I see from your command above that the mailbox.tcf file is in that folder.  But, did you also copy the following files into that same folder?
    • evmDM6437_common.tci
    • mailbox.tci
    • mailbox_evmDM6437_custom.tci
    If these files are not there, where are they located?
    If they are there, could you try running the command from that folder?
    cd C:\Users\work\Desktop\mailbox
    Then, run the command like this:
    C:\Users\work\Desktop\mailbox>"C:\Program Files\Texas Instruments\xdctools_3_22_01_21\xs.exe" --xp "C:/Program Files/Texas Instruments/bios_6_32_02_39/packages" ti.bios.conversion --pr "C:\myRepository" --pn mbx_evmDm6437 -i mailbox.tcf
    I am suspecting that the *.tci files are not being found, resulting in those errors you are seeing.
    Steve
