DSP Evaluation Board Recommendation
My team is developing a streaming video application that needs to support a webcam
and a small flat panel display. We need to select a TI DSP Evaluation Module or TI
DSP Starter Kit for rapid prototyping purposes. MatLab compatibility is a
requirement since all of the algorithms were developed using MatLab. Ideally, the
Evaluation Board would support a range of DSP devices within the family for
performance evaluation purposes. Thank you in advance for your feedback.
Rick Gregg, VP/CTO, Prism Technologies LLC
  • Hi Rick,
    Welcome to the TI E2E forum. I hope you will find many good answers here and in the TI.com documents and in the TI Wiki Pages (for processor issues). Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics (e2e.ti.com).
    Moved this post to correct forum for faster response.
    You can get DSP codecs and datasheets from:
    http://software-dl.ti.com/dsps/dsps_public_sw/codecs/C6678/index.html
    This package of Multicore Video Infrastructure Demo Built on MCSDK (called as MCSDK Video in short thereafter) provides software development environment to implement and demonstrate real-time video applications on TI C66x multi-core DSPs.
    http://software-dl.ti.com/sdoemb/sdoemb_public_sw/mcsdk_video/latest/index_FDS.html
    Thank you.
  • Hi Rick, if you need to evaluate some algorithms performance maybe better if you try first in our CCS simulation platform and then, depending on your application and algorithm needs, you can pick the right  number of DSPs and hence the correct EVM to get.
    Our C66x has fixed and floating point capabilities and you can have it in multicore architecture if you application requires more processing power
    http://www.ti.com/lit/wp/spry147/spry147.pdf
    http://software-dl.ti.com/public/hpmp/KeyStone/01_Overview/index.html
    We have some video codecs ready to be used in case you need them:
    As Raja mentioned we have a Multi-core Video SDK which has some demos and examples:
    PCIe demos: http://processors.wiki.ti.com/index.php/MCSDK_VIDEO_2.1_PCIE_Demo_Guide
    TFTP demos: http://processors.wiki.ti.com/index.php/MCSDK_VIDEO_2.x_TFTP_Demo_Guide
    thank you,
    Paula
  • Paula,
    Great idea - but looks like there isn't simulator support any more? What are my options? Please advise. Thanks.
    From the TI wiki ....
    "Texas Instruments is moving away from providing simulators and instead is focusing on providing low cost development boards. As a result in the standard installation you will not see any simulators. If you require a simulator they are available on a very limited exception basis. Please contact your TI business contact to request a simulator."
    http://processors.wiki.ti.com/index.php/CCSv6_Changes#Simulation
    Rick.
  • Rick, We have a low cost 8-core DSP EVM that I think could be a good starting point for development.
    http://processors.wiki.ti.com/index.php/TMDXEVM6678L_EVM_Hardware_Setup
    http://www.advantech.com/Support/TI-EVM/6678le_of.aspx
    The good thing is that our solutions are scalable. We have chips with 1, 2, 4 or 8 C66x cores. And Also boards with 4 or 8  8-cores DSP chips, so you can move up and down depending on your processing needs.
    http://www.advantech.com/products/Half-length_PCIe_Card1/DSPC-8681/mod_a9314996-0022-4927-9aa4-6b1060d4e5e8.aspx
    http://www.advantech.com/products/Half-length_PCIe_Card1/DSPC-8682/mod_535c098d-21fc-4980-b06e-5c2ac152de0f.aspx
    Thank you,
    Paula
  • Paula,
    This is excellent! Thanks so much for your help.
    Rick.
  • hi rick
    can I get evaluation board TMDXEVM6614LXE ?
    I would like to learn for wireless network
    thanks
    allagan
