Qualiti tool - test failing the VIDDEC_COPY Sample
I am Trying with QualiTI Compliance and Performance Testing for the given sample VIDDEC_COPY, which is failing the test .
can you please help us in solving this,
in the Algorithm tab i have set the following,
Module: VIDDEC_COPY    BaseDir:   /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/lib
Vendor: TI                             Library: ./lib/viddec_copy.a64P
Interface: IVIDDEC_COPY    Headers: ./ividdec_copy.h
in tools tab, i have set the TI 'cg_xml' tools folder to "/home/uma/dvsdk_2_00_00_22/cg_xml_2_12_00/bin"
and C6000 TI 'cgtools' Dir: /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools
The test execution log reports
TMS320 DSP Algorithm Interoperability Standard
Date      Fri Mar 05 2010 10:25:36 GMT+0530 (GMT+05:30)
Vendor TI
Algorithm            VIDDEC_COPY
Architecture       C6x
TI Compiler         true
Library Format   COFF
Compiler Version             TMS320C6x Compressor PC v6.0.8 Copyright (c) 1996-2006 Texas Instruments Incorporated
Test Execution Log          Test execution log for compiler info
Algorithm Base Directory: /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc
Algorithm Archive(s):
Header File(s):
   ./ividdec_copy.h
Compliance Test Report
Test Results        PASS: 1
FAIL: 4     [ XDAIS Rules 8, 9 and 10   XDAIS Rule 12   XDAIS Rule 13+   XDAIS Rule 26   ]
Skipped: 0
Not apply: 0
Total: 5
Test Notes
 This report has been generated with QualiTI Version 6.23 - the XDAIS compliance and performance test suite.
XDAIS Rules 8, 9, 10: Namespace compliance
Report: Failed
Test Description:  (Rule 8) All external definitions must be either API identifiers or API and vendor prefixed.
(Rule 9) All undefined references must refer either to the operations specified in Appendix B (a subset of C runtime support library functions and a subset of the DSP/BIOS HWI API functions), or TI's DSPLIB or IMGLIB functions or other XDAIS-compliant modules.
(Rule 10) All modules must follow the eXpressDSP naming conventions for those external declarations disclosed to the client.
Test Status Details:  Test failed.  Problem: Not all global symbols defined by the module have the "VIDDEC_COPY_TI_" prefix (i.e. module_vendor_).
The following is the list of offending symbols:
viddec_copy__versionNumArray
viddec_copy__versionString
viddec_copy__whatString
Test Execution Log: XDAIS Rules 8, 9 and 10 execution log
XDAIS Rule 12: IALG interface implementation
Report: Failed
Test Description: All algorithms must implement the IALG interface.
Test Status Details: Test failed. The module does not define data objects 'VIDDEC_COPY_TI_IALG' and 'VIDDEC_COPY_TI_IVIDDEC_COPY'.
Test Execution Log: XDAIS Rule 12 execution log
XDAIS Rule 13+: correct linker section names
Report: Failed to execute
Test Description: Each of the IALG methods implemented by an algorithm must be independently relocatable.
Additional rule: there should be no non-standard linker sections. (Standard linker sections are: ".cinit", ".switch", ".far", ".text", ".const", ".bss", ".pinit".)
An unknown command line execution error occured. Please check the execution log and try to repeat the commands in the shell to see what the problem could be. Most likely the Settings are somehow wrong.
Test Execution Log: XDAIS Rule 13+ execution log
XDAIS Rule 25: All C6x algorithms must be supplied in little-endian format
Report: Passed
Test Description:  All C6x algorithms must be supplied in little-endian format.
Test Status Details:   Test passed.
Test Execution Log: XDAIS Rule 25 execution log
XDAIS Rule 26: All static/global data must be far on c6x
Test Description:  All C6x algorithms must access all static and global data as far data.
Test Execution Log: XDAIS Rule 26 execution log
Performance Test Report
Test Results        PASS: 0
FAIL: 2     [ XDAIS Rule 20   XDAIS Rules 21, 22   ]
Skipped: 0
Not apply: 0
Total: 2
Test Notes
XDAIS Rule 20: must declare worst-case stack requirements
Test Description: All algorithms must characterize their worst-case stack space memory requirements (including alignment).
Test Status Details:   An unknown command line execution error occured. Please check the execution log and try to repeat the commands in the shell to see what the problem could be. Most likely the Settings are somehow wrong.
Test Execution Log: XDAIS Rule 20 execution log
XDAIS Rules 21, 22: must characterize static data & program memory requirements
Test Description:  All algorithms must characterize their static data & program memory requirements
Test Execution Log: XDAIS Rules 21, 22 execution log
Test execution log for Compiler Info:
Determining compiler info.
Checking if this library was created with a TI compiler...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/ofd6x -x --xml_indent=0 --obj_display=none /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | grep "<ti_coff>"
This library was  created with a TI compiler.
Attempting to determine library format...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/ofd6x -x --xml_indent=0 --obj_display=none /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | grep -E "<.*coff>|<.*elf>"
The library is in COFF format.
Attempting to determine the compiler version...
 Running command:> strings /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P|grep "Texas Instruments"
The compiler is TMS320C6x Compressor PC v6.0.8 Copyright (c) 1996-2006 Texas Instruments Incorporated.
back
Test execution log for XDAIS Rules 8, 9 and 10:
Running test 'XDAIS Rules 8, 9 and 10'
Extracting names of global symbols defined by the algorithm...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/nm6x -g /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | grep " [TBCU] "
Verifying that all global symbols are named XXX_TI_xxx ...
and that no blacklisted external references are made
Found bad symbol '...__dummy__' but pretending to have not because the algorithm is in an XDC package.
Error: here-defined global name 'viddec_copy__versionNumArray' does not comply.
Error: here-defined global name 'viddec_copy__versionString' does not comply.
Error: here-defined global name 'viddec_copy__whatString' does not comply.
back Test execution log for XDAIS Rule 12:
Running test 'XDAIS Rule 12'
Extracting names of global BSS data symbols...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/nm6x -g /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | grep " [BD] "
Verifying that objects 'VIDDEC_COPY_TI_IALG' and 'VIDDEC_COPY_TI_IVIDDEC_COPY' are defined...
Error: data object 'VIDDEC_COPY_TI_IALG' not found.
Error: data object 'VIDDEC_COPY_TI_IVIDDEC_COPY' not found.
back Test execution log for XDAIS Rule 13+:
Running test 'XDAIS Rule 13+'
Extracting names of all sections in which all algorithms' symbols are...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/ofd6x -x --xml_indent=0 --obj_display=none,sections,header /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | /home/uma/dvsdk_2_00_00_22/cg_xml_2_12_00/bin/sectti --csv
  Reading from stdin ...
 Can't locate object method "new" via package "XML::Parser" at XML/Simple.pm line 404, <STDIN> line 1.
Error: Command execution failed.
back Test execution log for XDAIS Rule 20:
Running test 'XDAIS Rule 20'
Using call_graph on ofd output to find out worst case stack...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/ofd6x -xg --xml_indent=0 --obj_display=none,header,optheader,symbols --dwarf_display=none,dinfo  /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | /home/uma/dvsdk_2_00_00_22/cg_xml_2_12_00/bin/call_graph --stack_max
back Test execution log for XDAIS Rules 21, 22:
Running test 'XDAIS Rules 21, 22'
Using sectti on ofd output to find static data & program memory requirements...
back Test execution log for XDAIS Rule 25:
Running test 'XDAIS Rule 25'
Using ofd output to parse for endianness attribute...
 Running command:> /home/uma/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/qualiti/cgtools/bin/ofd6x -x --xml_indent=0 --obj_display=none,header /home/uma/dvsdk_2_00_00_22/ceutils_1_06/examples/viddec_copy_packaged/mycompany/mygroup/codecs/vc/./lib/viddec_copy.a64P | grep "<endian>"
back Test execution log for XDAIS Rule 26:
Running test 'XDAIS Rule 26'
Extracting names of all used sections to see if there is a '.bss' in there.
[Using output generated by the command from test 'XDAIS Rule 13+"]:
[end of reused output]
Uma
  • I'm getting similar problems but with VIDDEC2_COPY (DVSDK 3.10.00.19). It fails on rule 13+ and has a "run error" on rule 20.
    If I run the command for rule 20 manually this is what I get:
    viper@cobalt:~/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11$ /home/viper/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/qualiti/cgtools/bin/ofd6x -xg --xml_indent=0 --obj_display=none,header,optheader,symbols --dwarf_display=none,dinfo  /home/viper/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/examples/ti/xdais/dm/examples/viddec2_copy/./package/lib/lib/whole_program/viddec2_copy/viddec2_copy.o64P | /home/viper/dvsdk/dvsdk_3_10_00_19/cg_xml/bin/call_graph --stack_max
    Cannot find entry point.  Stopped at script/call_graph.pl line 977, <STDIN> line 1.
    It's a sad day when TI's codecs fail their own compatibility tests. Please correct me if I'm wrong. I'm going to try and edit the code to correct the rule 13+ failure and see if that fixes both problems.
    Update: interestingly, although most of the binaries fail the compatibility test at least the one in the "lib/release" folder passes which is good news.
    Ralph
  • The failures and run error are happening because the file being tested is an object file(.o64P), not a library(.a64P). Try testing dvsdk_3_10_00_19/xdais_6_25_02_11/examples/ti/xdais/dm/examples/viddec2_copy/lib/whole_program/viddec2_copy.a64P.  In response to your post, we will modify QualiTI to try to detect an invalid library being loaded, and notify the user.
    Joe
  • Hi, thanks for the information. That clears up the confusion.
    Ralph
