6713 dsk error
Dear all,
We have a Spectrum digital DSK 6713.
recently i reinstalled the OS ( winxp)
CCS 3.1 was also reinstalled.
DSK 6713 diagnostic is sucessful but on launching CCS the following error message appears
"Your Code Composer does not support the connected target. Device driver name: "C:\CCStudio_v3.1\drivers\sdgo6713dsk.dvr" "
Thank you
  • Hi Joaquim,
    Have you enabled the "C67xx" platform support while you install the CCS ?
    Have you faced any issues or got any errors while you install the CCS ?
    I would like to suggest to install the latest CCS versions on your host PC.
    Thanks for your post.
    Most probably, it could be an registry clean up issue after uninstall and reinstall CCSv3.1. There is a existing workaround for this and I think, this should fix your issue. Please check the workaround provided for this issue from the below E2E post:
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/55463.aspx
    Also, one more suggestion, after you reinstall CCSv3.1, please ensure to install the emulation support package for DSK6713 emulator configuration which is provided from Spectrum Digital. Example code is also provided in the DSK6713 page. Please check this at http://support.spectrumdigital.com
    For more references on the possibility of this issue could be found at the below E2E posts:
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/95559.aspx
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/95991.aspx
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/55159.aspx
    Kindly check the above E2E links for the same issue.
    Thanks & regards,
    Sivaraj K
    Please click the Verify Answer button on this post if it answers your question
