Hi
I would like to know if I can use C5504 ROM memory (or some part of it) for my own application data.
(Can I burn some fixed data to ROM and read it when my application is running).
Yaron
Hi
Yaron
Team will work on this and will provide an update on the same.
Thanks & regards,
Sivaraj K
ROM is Read Only Memory which provides only read access for the applications. You cannot load your own program to ROM memory. You can only access factory programmed ROM data from your application. You may refer to http://www.ti.com/lit/an/sprabd7b/sprabd7b.pdf for the details of ROM memory contents.
- Pratap.
