Error format patition mmcblk1 on BBB
hello, I have the following problem in my BBB RevB. I can not format the partitions mmcblk1 (EMMC memory).
1 - booting on sdcard, all Correctly load system - when will the EMMC memory partition using FDISK, to close using the command 'w', the following error occurs.
Disk / dev / mmcblk1: [44.747476] mmcblk1: error -84 Transferring data, sector 0, nr 8, cmd response 0x900, card status 0xd00
58624 cylinders, [44.758539] end_request: I / O error, dev mmcblk1, sector 0
  4 heads, 16 sec [44.765531] Buffer I / O error on device mmcblk1, logical block 0
tors / track
2 - Booting on SDCard using BBB-eMMC-flasher-ubuntu-14:04 image, the following error occurs and part of log inicialization.
[    1.657665] OneNAND driver initializing
[    1.662556] usbcore: registered new interface driver cdc_ether
[    1.668689] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[    1.677469] usbcore: registered new interface driver rndis_host
[    1.683704] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[    1.692349] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.701129] usbcore: registered new interface driver cdc_ncm
[    1.707063] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware 'cape-bone-2g-emmc1.dtbo' for board-name 'Bone-LT-eMMC-2G', version '00A0'
[    1.721063] usbcore: registered new interface driver cdc_acm
[    1.726988] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.735332] Initializing USB Mass Storage driver...
[    1.740441] bone-capemgr bone_capemgr.9: slot #4: dtbo 'cape-bone-2g-emmc1.dtbo' loaded; converting to live tree
[    1.751101] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware 'cape-boneblack-hdmi-00A0.dtbo' for board-name 'Bone-Black-HDMI', version '00A0'
[    1.765224] usbcore: registered new interface driver usb-storage
[    1.771494] USB Mass Storage support registered.
[    1.776517] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[    1.783083] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[    1.789932] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[    1.798598] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.807347] bone-capemgr bone_capemgr.9: slot #5: dtbo 'cape-boneblack-hdmi-00A0.dtbo' loaded; converting to live tree
[    1.818658] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    1.825187] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[    1.830390] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[    1.839668] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[    1.847040] platform 4830e000.fb: alias fck already exists
[    1.853013] musb-hdrc musb-hdrc.0.auto: *** mode=3
[    1.858049] musb-hdrc musb-hdrc.0.auto: *** power=250
[    1.864202] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[    1.871073] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[    1.879641] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.888841] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[    1.894046] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[    1.902804] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.911658] musb-hdrc musb-hdrc.1.auto: *** mode=1
[    1.916686] musb-hdrc musb-hdrc.1.auto: *** power=250
[    1.921970] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.927995] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware 'cape-boneblack-hdmin-00A0.dtbo' for board-name 'Bone-Black-HDMIN', version '00A0'
[    1.942316] bone-capemgr bone_capemgr.9: slot #6: dtbo 'cape-boneblack-hdmin-00A0.dtbo' loaded; converting to live tree
[    1.953849] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.962230] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.969338] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.976893] usb usb1: Product: MUSB HDRC host driver
[    1.982076] usb usb1: Manufacturer: Linux 3.8.13-bone59 musb-hcd
[    1.988349] usb usb1: SerialNumber: musb-hdrc.1.auto
[    1.993752] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[    2.003375] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[    2.010143] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    2.020636] hub 1-0:1.0: USB hub found
[    2.024635] hub 1-0:1.0: 1 port detected
[    2.029578] mousedev: PS/2 mouse device common for all mice
[    2.036869] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    2.044337] 44e3e000.rtc: already running
[    2.048702] i2c /dev entries driver
[    2.053345] pps_ldisc: PPS line discipline registered
[    2.058736] Driver for 1-wire Dallas network protocol.
[    2.065246] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.072847] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[    2.081739] cpuidle: using governor ladder
[    2.086054] cpuidle: using governor menu
[    2.090439] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[    2.097639] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[    2.104286] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    2.111431] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    2.118697] mmc.5 supply vmmc_aux not found, using dummy regulator
[    2.125470] omap_hsmmc mmc.5: pins are not configured from the driver
[    2.158490] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[    2.164623] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[    2.172576] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[    2.178879] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[    2.185947] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[    2.193307] mmc.11 supply vmmc_aux not found, using dummy regulator
[    2.199950] omap_hsmmc mmc.11: pins are not configured from the driver
[    2.234734] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[    2.246386] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[    2.253670] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[    2.262599] leds-gpio gpio-leds.8: pins are not configured from the driver
[    2.270509] ledtrig-cpu: registered to indicate activity on CPUs
[    2.277057] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[    2.284209] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    2.291577] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    2.297784] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[    2.304911] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[    2.314757] usbcore: registered new interface driver usbhid
[    2.320622] usbhid: USB HID core driver
[    2.325504] ashmem: initialized
[    2.329119] logger: created 256K log 'log_main'
[    2.334161] logger: created 256K log 'log_events'
[    2.339340] logger: created 256K log 'log_radio'
[    2.344218] mmc0: host does not support reading read-only switch. assuming write-enable.
[    2.352841] logger: created 256K log 'log_system'
[    2.360300] davinci_evm sound.14:  nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[    2.368019] mmc0: new high speed SDHC card at address aaaa
[    2.374206] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[    2.380779] TCP: cubic registered
[    2.384985] NET: Registered protocol family 10
[    2.389757]  mmcblk0: p1 p2
[    2.393575] NET: Registered protocol family 17
[    2.399248] Key type dns_resolver registered
[    2.403956] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    2.412079] ThumbEE CPU extension supported.
[    2.416602] Registering SWP/SWPB emulation handler
[    2.422244] registered taskstats version 1
[    2.428018] tilcdc 4830e000.fb: No power control GPIO
[    2.474315] mmc1: BKOPS_EN bit is not set
[    2.481057] mmc1: new high speed MMC card at address 0001
[    2.487204] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[    2.492161] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[    2.498718] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[    2.506704]  mmcblk1: unknown partition table
[    2.512718]  mmcblk1boot1: unknown partition table
[    2.519139]  mmcblk1boot0: unknown partition table
[    2.553299] tilcdc 4830e000.fb: found TDA19988
[    2.558518] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    2.565430] [drm] No driver support for vblank timestamp query.
[    2.571888] tilcdc 4830e000.fb: No connectors reported connected with modes
[    2.579165] [drm] Cannot find any crtc or sizes - going 1024x768
[    2.594077] Console: switching to colour frame buffer device 128x48
[    2.606059] tilcdc 4830e000.fb: fb0:  frame buffer device
[    2.611702] tilcdc 4830e000.fb: registered panic notifier
[    2.617353] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[    2.671956] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    2.678339] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    2.690636] libphy: 4a101000.mdio: probed
[    2.694901] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    2.704655] Detected MACID = 90:59:af:8f:d0:f1
[    2.709254] cpsw 4a100000.ethernet: NAPI disabled
[    2.715595] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:16:08 UTC (946685768)
[    2.729039] ALSA device list:
[    2.732179]   #0: TI BeagleBone Black
[    2.736660] Freeing init memory: 252K
Loading, please wait...
[    2.823561] systemd-udevd[104]: starting version 204
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
[    4.336934] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Begin: Running /scripts/local-bottom ... done.
done.
Begin: Running /scripts/init-bottom ... done.
Valid EEPROM header found
debug copying: [/dev/mmcblk0] -> [/dev/mmcblk1]
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk1boot0 179:16   0     1M  1 disk
mmcblk1boot1 179:24   0     1M  1 disk
mmcblk0      179:0    0   7.4G  0 disk
|-mmcblk0p1  179:1    0    96M  0 part /boot/uboot
`-mmcblk0p2  179:2    0   1.6G  0 part /
mmcblk1      179:8    0   1.8G  0 disk
Erasing: /dev/mmcblk1
108+0 records in
108+0 records out
113246208 bytes (113 MB) copied, 32.3521 s, 3.5 MB/s
108+0 records in
108+0 records out
113246208 bytes (113 MB) copied, 5.42605 s, 20.9 MB/s
Formatting: /dev/mmcblk1
Checking that no[   42.818386]  mmcblk1: unknown partition table
-one is using this disk right now ...
OK
Disk /dev/mmcblk1: [   44.747476] mmcblk1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xd00
58624 cylinders,[   44.758539] end_request: I/O error, dev mmcblk1, sector 0
 4 heads, 16 sec[   44.765531] Buffer I/O error on device mmcblk1, logical block 0
tors/track
sf[   44.773089] lost page write due to I/O error on mmcblk1
[   44.785042]  mmcblk1: unknown partition tablemsdos signature
 /dev/mmcblk1: unrecognized par[   44.792188] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[   44.792188]
[   44.802491] [<c0011039>] (unwind_backtrace+0x1/0x94) from [<c04bfe39>] (panic+0x75/0x174)
[   44.811017] [<c04bfe39>] (panic+0x75/0x174) from [<c00355e1>] (do_exit+0x651/0x6d0)
[   44.819000] [<c00355e1>] (do_exit+0x651/0x6d0) from [<c00356a5>] (do_group_exit+0x29/0x6c)
[   44.827609] [<c00356a5>] (do_group_exit+0x29/0x6c) from [<c00356f5>] (__wake_up_parent+0x1/0x14)
[   44.836770] drm_kms_helper: panic occurred, switching back to text console
tition table type
Old situation:
No partitions found
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start   End    MiB    #blocks   Id  System
/dev/mmcblk1p1   *     1     96     96      98304    e  W95 FAT16 (LBA)
/dev/mmcblk1p2        97   1831   1735    1776640   83  Linux
/dev/mmcblk1p3         0      -      0          0    0  Empty
/dev/mmcblk1p4         0      -      0          0    0  Empty
/dev/mmcblk1: Input/output error
sfdisk: Failed writing the partition on /dev/mmcblk1
Re-reading the partition table ...
Error closing /dev/mmcblk1
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
I appreciate your attention and I hope you can help me.    :(
