DM8148. Send captured data to DSP, process an send back to HDVPSS for displaying - doesn't works
Hello TI' teams.
I would be very grateful if you could help me solve the problem as is following.
I works with dvr-rdk 3.5 from udworks and custom board with DM8148 and my use-case should perform next:
1) Capture video from VIP
2) Send frames by IPC link to DSP sub-core
3) Perform algorithm by DSP and modify captured data (non-uniform correction, image improvement, etc...)
4) Send frames by IPC back to HDVPSS module
5) Display video (on chip HDMI)
I use next links:
SYSTEM_LINK_ID_CAPTURE -> SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_0 -> SYSTEM_DSP_LINK_ID_IPC_FRAMES_IN_0 -> SYSTEM_LINK_ID_OPGAL_ALG_0 ->
-> SYSTEM_DSP_LINK_ID_IPC_FRAMES_OUT_0 -> SYSTEM_VPSS_LINK_ID_IPC_FRAMES_IN_0 -> SYSTEM_LINK_ID_SW_MS_MULTI_INST_0 -> SYSTEM_LINK_ID_DISPLAY_0
SYSTEM_LINK_ID_OPGAL_ALG_0 - this is DSP processing link created by me, recieves frames from input queue, process and put processed frames to output queue.
Links parameters are as following (or please see attached use-case file):
const UInt32 captureLinkId         = SYSTEM_LINK_ID_CAPTURE;
const UInt32 vpssIpcVideoOutLinkId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_0;
const UInt32 dspIpcVideoInLinkId   = SYSTEM_DSP_LINK_ID_IPC_FRAMES_IN_0;
const UInt32 algLinkId             = SYSTEM_LINK_ID_OPGAL_ALG_0;
const UInt32 dspIpcVideoOutLinkId  = SYSTEM_DSP_LINK_ID_IPC_FRAMES_OUT_0;
const UInt32 vpssIpcVideoInLinkId  = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_IN_0;
const UInt32 swMosaicLinkId        = SYSTEM_LINK_ID_SW_MS_MULTI_INST_0;
const UInt32 displayLinkId         = SYSTEM_LINK_ID_DISPLAY_0;
    // CAPTURE
    CaptureLink_CreateParams_Init(&capturePrm);
    capturePrm.numVipInst               = 1;
    capturePrm.outQueParams[0].nextLink = vpssIpcVideoOutLinkId;
    capturePrm.tilerEnable              = FALSE;
    capturePrm.enableSdCrop             = FALSE;
    capturePrm.fakeHdMode               = FALSE;
    capturePrm.doCropInCapture          = FALSE;
    pCaptureInstPrm                     = &capturePrm.vipInst[0];
    pCaptureInstPrm->vipInstId          = SYSTEM_CAPTURE_INST_VIP1_PORTA;
    pCaptureInstPrm->videoDecoderId     = 0u;
    pCaptureInstPrm->inDataFormat       = SYSTEM_DF_YUV422P;
    pCaptureInstPrm->enableTimestampInInterrupt = TRUE;
    pCaptureInstPrm->standard           = captureStandard;
    pCaptureInstPrm->numOutput          = 1;
    pCaptureInstPrm->numChPerOutput     = 1;
    pCaptureOutPrm                      = &pCaptureInstPrm->outParams[0];
    pCaptureOutPrm->dataFormat          = SYSTEM_DF_YUV422I_YUYV;
    pCaptureOutPrm->scEnable            = FALSE;
    pCaptureOutPrm->scOutWidth          = 0;
    pCaptureOutPrm->scOutHeight         = 0;
    pCaptureOutPrm->outQueId            = 0;
    if (pCaptureInstPrm->vipInstId >= SYSTEM_CAPTURE_INST_VIP0_PORTA && pCaptureInstPrm->vipInstId <= SYSTEM_CAPTURE_INST_VIP1_PORTB) {
        printf ("\nPerform capture from FPGA via %s\n", capturePortName[pCaptureInstPrm->vipInstId]);
    // VPSS IPC frame OUT
    IpcFramesOutLinkRTOS_CreateParams_Init(&vpssIpcFrameOut);
    vpssIpcFrameOut.baseCreateParams.numOutQue = 1;
    vpssIpcFrameOut.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.captureId;
    vpssIpcFrameOut.baseCreateParams.inQueParams.prevLinkQueId = 0u;
    vpssIpcFrameOut.baseCreateParams.numChPerOutQue[0] = 1;
    vpssIpcFrameOut.baseCreateParams.outQueParams[0].nextLink = dspIpcVideoInLinkId;
    // DSP IPC frame IN
    IpcFramesInLinkRTOS_CreateParams_Init(&dspIpcFrameIn);
    dspIpcFrameIn.baseCreateParams.inQueParams.prevLinkId = vpssIpcVideoOutLinkId;
    dspIpcFrameIn.baseCreateParams.inQueParams.prevLinkQueId = 0u;
    dspIpcFrameIn.baseCreateParams.numChPerOutQue[0] = 1;
    dspIpcFrameIn.baseCreateParams.numOutQue = 1;
    dspIpcFrameIn.baseCreateParams.outQueParams[0].nextLink = algLinkId;
    // DSP ALG
    AlgOpgalLink_CreateParams_Init(&algorithmPrm);
    algorithmPrm.strSize   = sizeof(algorithmPrm);
    algorithmPrm.imgSizeX  = 320;
    algorithmPrm.imgPitchX = algorithmPrm.imgSizeX;
    algorithmPrm.imgSizeY  = 240;
    algorithmPrm.globalActive = 0u;
    algorithmPrm.maxChannels = 1;
    algorithmPrm.numOutQueues = 1;
    algorithmPrm.notifyNextLink = TRUE;
    algorithmPrm.inQueParams.prevLinkId = dspIpcVideoInLinkId;
    algorithmPrm.inQueParams.prevLinkQueId = 0u;
    algorithmPrm.outQueParams.nextLink = dspIpcVideoOutLinkId;
    // DSP IPC frame OUT
    IpcFramesOutLinkRTOS_CreateParams_Init(&dspIpcFrameOut);
    dspIpcFrameOut.baseCreateParams.inQueParams.prevLinkId = algLinkId;
    dspIpcFrameOut.baseCreateParams.inQueParams.prevLinkQueId = 0u;
    dspIpcFrameOut.baseCreateParams.numOutQue = 1;
    dspIpcFrameOut.baseCreateParams.numChPerOutQue[0] = 1;
    dspIpcFrameOut.baseCreateParams.outQueParams[0].nextLink = vpssIpcVideoInLinkId;
    // VPSS IPC frame IN
    IpcFramesInLinkRTOS_CreateParams_Init(&vpssIpcFrameIn);
    vpssIpcFrameIn.baseCreateParams.inQueParams.prevLinkId = dspIpcVideoOutLinkId;
    vpssIpcFrameIn.baseCreateParams.inQueParams.prevLinkQueId = 0u;
    vpssIpcFrameIn.baseCreateParams.numChPerOutQue[0] = 1;
    vpssIpcFrameIn.baseCreateParams.numOutQue = 1;
    vpssIpcFrameIn.baseCreateParams.outQueParams[0].nextLink = swMosaicLinkId;
    swMsPrm.numSwMsInst   = 1;
    swMsPrm.swMsInstId[0] = SYSTEM_SW_MS_SC_INST_SC5;
    swMsPrm.swMsInstStartWin[0]  = 0;
    swMsPrm.inQueParams.prevLinkId    = vpssIpcVideoInLinkId;
    swMsPrm.inQueParams.prevLinkQueId = 0;
    swMsPrm.outQueParams.nextLink     = displayLinkId;
    swMsPrm.maxInputQueLen            = SYSTEM_SW_MS_DEFAULT_INPUT_QUE_LEN;
    swMsPrm.maxOutRes                 = VSYS_STD_1080P_60;
    swMsPrm.initOutRes                = VSYS_STD_1080P_60;
    swMsPrm.lineSkipMode              = TRUE;
    swMsPrm.enableLayoutGridDraw      = FALSE;
    MultiCh_swMsGetDefaultLayoutPrm(0, &swMsPrm, FALSE); /* Since only live preview is there, show it on both displays */
    displayPrm.inQueParams[0].prevLinkId    = swMosaicLinkId;
    displayPrm.inQueParams[0].prevLinkQueId = 0;
    displayPrm.displayRes                   = swMsPrm.initOutRes;
Unfortunatelly this use-case always hangs and last string printed on terminal after run:
 [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
After some time (~ 2..3 minutes) on terminal printed next errors:
 [m3vpss ] AVSYNC:WallTime IGNORE Unexpected Discontinuity.PrevTs[18885]/CurTs[207908]
 [m3vpss ] AVSYNC:WallTime IGNORE Unexpected Discontinuity.PrevTs[207908]/CurTs[399264]
 [m3vpss ]  399265: Assertion @ Line: 2504 in links_m3vpss/swMs/swMsLink_drv.c: pDrvObj->fvidHandle != NULL : failed !!!
and its all.
I don't clearly understood reason for this assertion. Why mosaic links have error in this code:
    pDrvObj->fvidHandle = FVID2_create(FVID2_VPS_M2M_SC_DRV,
                                       pDrvObj->drvInstId,
                                       &pDrvObj->cfg.sc.scCreateParams,
                                       &pDrvObj->cfg.sc.scCreateStatus, &cbParams);
What is problem to create scalar back memory-to-memory driver in my use-case?
In additional, please pay attention on next:
- if DSP excluded from use-case (Capture->SwMs->Display only) this use-case and capture works fine, I saw captured data on display
- if DSP ALG instead of put processed data to ALG output queue, return back it to previous link as "empty buffer, this case works fine too
- DSP algorithm link tested in stand-alone application and works without any problems
I hope problem exist in "back pass" and connectivity between "DSP Frame Ipc Out", and "HDVPSS Frame Ipc In".
Please help me resolve it and please let me know if exist any limitation from pass frames (just frames, !not bits buffers!) between DSP and HDVPSS?
For more details please see attached LOG.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.10.13 15:10:53 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot 2010.06-svn365 (Sep 14 2014 - 05:54:11)
TI8148-GP rev 3.0
L3 clk         : 220MHz
IVA clk        : 306MHz
ISS clk        : 400MHz
DSP clk        : 600MHz
DSS clk        : 200MHz
ARM clk        : 720MHz
DDR clk        : 400MHz
------------ PLL Settings --------------
OSC_0_FREQ    : 20MHz
MODENA_N      : 1
MODENA_M      : 72
MODENA_M2     : 1
L3_N          : 19
L3_M          : 880
L3_M2         : 4
DSP_N         : 19
DSP_M         : 600
DSP_M2        : 1
DSS_N         : 19
DSS_M         : 800
DSS_M2        : 4
IVA_N         : 19
IVA_M         : 612
IVA_M2        : 2
ISS_N         : 19
ISS_M         : 800
ISS_M2        : 2
USB_N         : 19
USB_M         : 960
USB_M2        : 5
DCO_HS2_MIN   : 500
DCO_HS2_MAX   : 1000
DCO_HS1_MIN   : 1000
DCO_HS1_MAX   : 2000
SELFREQDCO_HS2   : 2049
SELFREQDCO_HS1   : 4097
--------- DDR PLL ----------
DDR_N             : 0x13
DDR_M             : 0x320
DDR_M2            : 0x2
----------EMIF Timings (identical for 0 & 1)-------
DDR3_EMIF_READ_LATENCY : 0x170209
DDR3_EMIF_TIM1         : 0xAAAD4DB
DDR3_EMIF_TIM2         : 0x682F7FDA
DDR3_EMIF_TIM3         : 0x501F82BF
DDR3_EMIF_REF_CTRL     : 0xC30
DDR3_EMIF_SDRAM_CONFIG : 0x61C011B2
DDR3_EMIF_SDRAM_ZQCR   : 0x50074BE1
----------SW LEVEL Info (EMIF 0) -------
DDR3_PHY_RD_DQS_CS0_BYTE0: 0x00000038
DDR3_PHY_RD_DQS_CS0_BYTE1: 0x00000037
DDR3_PHY_RD_DQS_CS0_BYTE2: 0x00000032
DDR3_PHY_RD_DQS_CS0_BYTE3: 0x00000031
DDR3_PHY_WR_DQS_CS0_BYTE0: 0x00000043
DDR3_PHY_WR_DQS_CS0_BYTE1: 0x00000044
DDR3_PHY_WR_DQS_CS0_BYTE2: 0x00000053
DDR3_PHY_WR_DQS_CS0_BYTE3: 0x00000050
DDR3_PHY_RD_DQS_GATE_CS0_BYTE0: 0x000000E4
DDR3_PHY_RD_DQS_GATE_CS0_BYTE1: 0x00000111
DDR3_PHY_RD_DQS_GATE_CS0_BYTE2: 0x00000112
DDR3_PHY_RD_DQS_GATE_CS0_BYTE3: 0x0000013D
DDR3_PHY_WR_DATA_CS0_BYTE0: 0x00000085
DDR3_PHY_WR_DATA_CS0_BYTE1: 0x00000083
DDR3_PHY_WR_DATA_CS0_BYTE2: 0x00000085
DDR3_PHY_WR_DATA_CS0_BYTE3: 0x0000007F
----------SW LEVEL Info (EMIF 1) -------
DDR3_PHY_RD_DQS_CS0_BYTE0: 0x0000003A
DDR3_PHY_RD_DQS_CS0_BYTE1: 0x00000036
DDR3_PHY_RD_DQS_CS0_BYTE2: 0x00000037
DDR3_PHY_RD_DQS_CS0_BYTE3: 0x00000033
DDR3_PHY_WR_DQS_CS0_BYTE0: 0x00000049
DDR3_PHY_WR_DQS_CS0_BYTE1: 0x0000004E
DDR3_PHY_WR_DQS_CS0_BYTE2: 0x00000054
DDR3_PHY_RD_DQS_GATE_CS0_BYTE0: 0x000000D3
DDR3_PHY_RD_DQS_GATE_CS0_BYTE1: 0x000000F7
DDR3_PHY_RD_DQS_GATE_CS0_BYTE2: 0x00000109
DDR3_PHY_RD_DQS_GATE_CS0_BYTE3: 0x00000135
DDR3_PHY_WR_DATA_CS0_BYTE0: 0x0000008A
DDR3_PHY_WR_DATA_CS0_BYTE1: 0x00000080
DDR3_PHY_WR_DATA_CS0_BYTE2: 0x0000007F
DDR3_PHY_WR_DATA_CS0_BYTE3: 0x00000085
DRAM:  1 GiB
NAND:  HW ECC BCH8 Selected
512 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till Opgal_SCP# prompt if 2nd stage is already flashed
Hit any key to stop autoboot:  1  0
NAND read: device 0 offset 0x20000, size 0x40000
 262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06-svn365 (Sep 14 2014 - 05:54:56)
TI8148-GP rev 3.0
L3 clk         : 220MHz
IVA clk        : 306MHz
ISS clk        : 400MHz
DSP clk        : 600MHz
DSS clk        : 200MHz
ARM clk        : 720MHz
DDR clk        : 400MHz
OSC_0_FREQ    : 20MHz
MODENA_N      : 1
MODENA_M      : 72
MODENA_M2     : 1
L3_N          : 19
L3_M          : 880
L3_M2         : 4
DSP_N         : 19
DSP_M         : 600
DSP_M2        : 1
DSS_N         : 19
DSS_M         : 800
DSS_M2        : 4
IVA_N         : 19
IVA_M         : 612
IVA_M2        : 2
ISS_N         : 19
ISS_M         : 800
ISS_M2        : 2
USB_N         : 19
USB_M         : 960
USB_M2        : 5
DCO_HS2_MIN   : 500
DCO_HS2_MAX   : 1000
DCO_HS1_MIN   : 1000
DCO_HS1_MAX   : 2000
DDR_N             : 0x13
DDR_M             : 0x320
DDR_M2            : 0x2
I2C:   ready
DRAM:  1 GiB
512 MiB
MMC:   OMAP SD/MMC: 0
           _        _
           \'-.__.-'/
           / (o)(o) \
   | Opgal SmartCore Platform |
Net:   Detected MACID:7c:66:9d:36:b3:96
cpsw
Hit any key to stop autoboot:  3  2  1  0
NAND read: device 0 offset 0x280000, size 0x2c0000
 2883584 bytes read: OK
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-2.6.37+
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2844632 Bytes = 2.7 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37+ (marat@marat-ubuntu) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #1 Mon Jul 28 15:51:33 IDT 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
vram size = 25165824 at 0x0
ti81xx_reserve: ### Reserved DDR region @87f00000
reserved size = 25165824 at 0x0
FB: Reserving 25165824 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 3.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 26112
Kernel command line: mem=128M ddr_mem=512M console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=10.0.0.131:/home/marat/workdir/SmartCore/trunk/target/rfs_814x ip=dhcp rootdelay=5 vram=24M notifyk.vpssm3_sva=0xbfd00000
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 102MB 1MB = 103MB total
Memory: 98248k/98248k available, 32824k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc8800000 - 0xf8000000   ( 760 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0042000   ( 232 kB)
      .text : 0xc0042000 - 0xc0556000   (5200 kB)
      .data : 0xc0556000 - 0xc05acb00   ( 347 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 719.25 BogoMIPS (lpj=3596288)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x87f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
clk get on i2c3 fck failed
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
registered ti81xx_vin device
NSS Crypto DMA hardware revision 1.9 @ IRQ 116
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xc8830000
ti81xx_pcie: forcing link width - x1
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
ti81xx_pcie: PCI scan done.
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
I2C: Read failed at pcf8575_cir_enable 274 with error code: -121
I2C: Transfer failed at pcf8575_cir_enable 281 with error code: -121
pcf857x: probe of 1-0021 failed with error -121
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1200 mV
regulator: VDD2: 600 <--> 1500 mV at 1200 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65910 1-002d: No interrupt support, no core IRQ
omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(29 11 14)
usb2phy: override computed values rxcalib(15)DACs(29 11 14)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6ed776
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c881e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(22 15 15)
usb2phy: override computed values rxcalib(15)DACs(22 15 15)
usb2phy_config: musb(1) rxcalib done, rxcalib read value 6f6b5f7e
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c882a800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) � 2001-2006 Red Hat, Inc.
msgmni has been set to 191
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
nss_rng nss_rng: NSS Random Number Generator ver. 2.0
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
ahci probe: devid name is ahci
ahci CAP register dump =0x6726ff80
Modified ahci CAP register dump =0x6f26ff80
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
omap2-nand driver initializing
ONFI param page 0 valid
ONFI flash detected
NAND device: Maf ID: 0x2c, Chip ID: 0xbc (Micron, NAND 512MiB 1,8V 16-bit)
 erasesize: 0x20000, writesize: 2048, oobsize: 64
omap2-nand: detected x16 NAND flash
Creating 7 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000580000 : "U-Boot Logo"
0x000000580000-0x0000009c0000 : "Kernel"
0x0000009c0000-0x00000d1e0000 : "File System"
0x00000d1e0000-0x000020000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
CAN device driver interface
CAN bus driver for Bosch D_CAN controller 1.0
d_can d_can: d_can device registered (irq=52, irq_obj=53)
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
ata1: SATA link down (SStatus 0 SControl 300)
hub 2-0:1.0: over-current change on port 1
qt602240_ts 1-004a: __qt602240_read_reg: i2c transfer failed
qt602240_ts: probe of 1-004a failed with error -5
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
nss_aes_mod_init: loading NSS AES driver
nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 0 @0x41140000)
nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 1 @0x41141000)
nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 2 @0x411a0000)
nss-aes nss-aes: NSS AES hw accel rev: 3.2 (context 3 @0x411a1000)
nss_aes_probe: probe() done
nss_des_mod_init: loading NSS DES driver
nss-des nss-des: NSS DES hw accel rev: 2.2 (context 0 @0x41160000)
nss-des nss-des: NSS DES hw accel rev: 2.2 (context 1 @0x41161000)
nss_des_probe: probe() done
nss_sham_mod_init: loading NSS SHA/MD5 driver
nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 0 @0x41100000)
nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 1 @0x41101000)
nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 2 @0x411c0000)
nss-sham nss-sham: NSS SHA/MD5 hw accel rev: 4.03 (context 3 @0x411c1000)
nss_sham_probe: probe() done
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbfd00000
usbcore: registered new interface driver snd-usb-audio
Registered tvp5158 audio codec
*** Forcing SW CTS!
asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
  #0: TI81XX SOUND0
  #1: TI81XX SOUND1
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=7c:66:9d:36:b3:96
omap_rtc omap_rtc: setting system clock to 2014-07-01 00:00:00 UTC (1404172800)
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 MMC32G 29.5 GiB
 mmcblk0: unknown partition table
CPSW phy found : id is : 0x1410dd1
PHY 0:01 not found
Sending DHCP requests .
PHY: 0:00 - Link is Up - 1000/Full
., OK
IP-Config: Got DHCP answer from 0.0.0.0, my address is 10.0.0.181
IP-Config: Complete:
     device=eth0, addr=10.0.0.181, mask=255.255.254.0, gw=10.0.0.254,
     host=10.0.0.181, domain=opgal.com, nis-domain=(none),
     bootserver=0.0.0.0, rootserver=10.0.0.131, rootpath=
Waiting 5sec before mounting root device...
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 232K
INIT: version 2.86 bootingError opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (119): /proc/119/oom_adj is deprecated, please use /proc/119/oom_score_adj instead.
udev: starting version 141
udevd[119]: unable to move watches dir '/dev/.udev/watch', old watches will not be restored: Directory not emptyudevd-event[128]: error changing netif name eth0 to eth1: Device or resource busy
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cacheFAT: bogus number of reserved sectors
VFS: Can't find a valid FAT filesystem on dev mmcblk0.
EXT3-fs (mmcblk0): error: can't find ext3 filesystem on dev mmcblk0.
EXT2-fs (mmcblk0): error: can't find an ext2 filesystem on dev mmcblk0.
ISOFS: Unable to identify CD-ROM format.
ALSA: Restoring mixer settings...
NOT configuring network interfaces: / is an NFS mount
Fri Aug 17 21:11:00 UTC 2012
INIT: Entering runlevel: 5Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
    __________
   / ___  ___ \
  \ \___/\___/ /\
   \____\/____/||
     \______/\\\\
      _||_||_
| http://www.opgal.com  |
OPGAL SmartCore Board (2014.07)
root@scp:~# cd /opt
root@scp:~# cd /opt/dvr
root@scp:~# cd /opt/dvr_rdk/ti814
root@scp:~# cd /opt/dvr_rdk/ti814x/
root@scp:/opt/dvr_rdk/ti814x# ./demo_ru
root@scp:/opt/dvr_rdk/ti814x# ./demo_run.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=1,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
  : values=127,127
  | dBscale-min=-63.50dB,step=0.50dB,mute=0
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff05020
 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.20.02.20
SysLink module created on Date:Oct 13 2014 Time:14:03:16
Trace enabled
Trace SetFailureReason enabled
 Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
 Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
 *** TVP5158 probe : START ***
 I2C (0x5c): 0x08 = 0x51
 I2C (0x5c): 0x09 = 0x58
 *** TVP5158 probe : END ***
/opt/dvr_rdk/ti814x
ENV_DDR_MEM =  512M
ENV_LINUX_MEM =  128M
ENV_NOTIFYK_VPSSM3_SVA_ADDR =  0xbfd00000
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_512M_128M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
 [m3vpss ] ISS Freq  : 400 MHz
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 200000000
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 400000 Khz ***
 [m3vpss ]
 [m3vpss ]  51: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  52: SYSTEM: IPC init in progress !!!
 [m3vpss ]  52: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1051: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1053: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
 [m3vpss ]  1054: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_512M_128M.xem3 on slave procId 1.
Started slave procId 1.
 [m3video] ISS Freq  : 400 MHz
 [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 200000000
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 400000 Khz ***
 [m3video]
 [m3video]  1206: SYSTEM  : System Common Init in progress !!!
 [m3video]  1207: SYSTEM: IPC init in progress !!!
 [m3video]  1207: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  2053: SYSTEM: Attaching to [DSP] ...
 [m3video]  2206: SYSTEM: Attaching to [HOST] ...
 [m3video]  2213: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  2213: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_512M_128M.xe674 on slave procId 0.
Started slave procId 0.
 [c6xdsp ] DSP Freq  : 600 MHz
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 500000000, <NEW> - 600000000
 [c6xdsp ]
 [c6xdsp ]  *** UTILS: CPU KHz = 600000 Khz ***
 [c6xdsp ]
 [c6xdsp ]  1: SYSTEM  : System Common Init in progress !!!
 [c6xdsp ]  1: SYSTEM: IPC init in progress !!!
 [c6xdsp ]  1: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  3053: SYSTEM: Attaching to [DSP] ...
 [m3video]  3213: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1001: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  1003: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [c6xdsp ]  1003: SYSTEM: Attaching to [VIDEO-M3] ...
DMA: Module install successful, device major num = 251
DRV: Module install successful
DRV: Module built on Oct 13 2014 14:03:51
 [m3vpss ]  4053: SYSTEM: Attaching to [DSP] ...
 [m3video]  4213: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2003: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3vpss ]  5053: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2820: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  5213: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2820: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  5214: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3video]  5214: SYSTEM: Attaching to [VPSS-M3] ...
 [m3vpss ]  6053: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  3820: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  6213: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  4660: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  7053: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  4660: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
 [m3vpss ]  7054: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [c6xdsp ]  4661: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [m3vpss ]  7054: SYSTEM: Attaching to [VIDEO-M3] ...
 [c6xdsp ]  4661: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [c6xdsp ]  4661: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  4661: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [c6xdsp ]  4662: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [c6xdsp ]  4662: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  4664: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
 [c6xdsp ]  4664: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4674: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4684: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4694: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4704: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4714: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4724: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4734: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4744: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4754: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4764: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4774: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4784: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4794: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4804: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4814: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [m3video]  7213: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  4824: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4834: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4844: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4854: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4864: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4874: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4884: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4894: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4904: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4914: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4924: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4934: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4944: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4954: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4964: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4974: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4984: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  4994: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5004: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5014: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5024: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5034: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5044: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5054: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5064: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5074: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5084: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5094: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5104: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5114: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5124: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5134: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5144: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5154: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5164: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5174: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5184: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5194: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5204: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5214: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5224: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5234: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5244: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5254: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5264: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5274: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5284: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5294: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5304: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5314: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5324: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5334: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5344: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5354: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5364: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5374: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5384: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5394: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5404: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5414: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5424: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5434: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5444: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5454: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5464: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5474: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5484: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5494: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5504: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5514: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5524: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5534: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5544: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5554: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5564: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5574: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5584: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5594: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5604: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5614: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5624: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5634: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5644: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [c6xdsp ]  5654: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [m3video]  8054: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  8053: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  8054: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
 [m3vpss ]  8054: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3vpss ]  8054: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
 [c6xdsp ]  5664: MEM: ERROR: SharedRegion_setEntry (2, 0x8f5c583c) FAILED !!!  (status=-1)
 [m3video]  8055: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  8054: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  8055: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  8055: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [m3video]  8057: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3vpss ]  8057: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3video]  8057: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3vpss ]  8057: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3video]  8058: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3vpss ]  8057: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [m3video]  8058: SYSTEM: IPC init DONE !!!
 [m3vpss ]  8058: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  5674: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04000000 (64 MB)
 [m3video]  8067: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
 [m3vpss ]  8066: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
 [c6xdsp ]  5674: SYSTEM  : System Common Init Done !!!
 [m3video]  8067: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04000000 (64 MB)
 [m3vpss ]  8067: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04000000 (64 MB)
 [c6xdsp ]  5673: SYSTEM  : System DSP Init in progress !!!
 [m3video]  8069: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  8069: SYSTEM  : System Common Init Done !!!
 [c6xdsp ]  5674: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
 [m3video]  8070: SYSTEM  : System Video Init in progress !!!
 [m3vpss ]  8069: SYSTEM  : System VPSS Init in progress !!!
 [c6xdsp ]  5679: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
 [m3video]  8070: SYSTEM  : System Video Init Done !!!
 [c6xdsp ]  5679: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
 [m3video]  8071: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  5679: SYSTEM: ListElem Shared Addr = 0xbf177300
 [m3video]  8071: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  5680: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
 [m3video]  8071: SYSTEM: ListElem Shared Addr = 0xbf173e00
 [c6xdsp ]  5680: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
 [m3video]  8074: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [c6xdsp ]  5680: SYSTEM: ListElem Shared Addr = 0xbf19cb00
 [m3video]  8074: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [c6xdsp ]  5681: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
 [m3video]  8075: SYSTEM: ListElem Shared Addr = 0xbf1c2300
 [c6xdsp ]  5682: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
 [c6xdsp ]  5682: SYSTEM: ListElem Shared Addr = 0xbf1c5800
 [c6xdsp ]  5683: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [m3video]  8083: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
 [c6xdsp ]  5683: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [m3video]  8083: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
 [c6xdsp ]  5683: SYSTEM: ListElem Shared Addr = 0xbf1eb000
 [m3video]  8084: SYSTEM: ListElem Shared Addr = 0xbf226600
 [c6xdsp ]  5684: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [c6xdsp ]  5684: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [c6xdsp ]  5684: SYSTEM: ListElem Shared Addr = 0xbf208b00
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  5684: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  5685: SYSTEM  : FREE SPACE : System Heap      = 6393472 B, Mbx = 10240 msgs)
 [m3video]  8087: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
 [m3vpss ] === I2C0/2 Clk is active ===
 [m3video]  8088: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
 [m3vpss ]  8088: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  5684: ALGORITHM OPGAL     : Init [0 | 69112]
 [m3video]  8088: SYSTEM: ListElem Shared Addr = 0xbf24be00
 [m3vpss ]  8089: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  5684: ALGORITHM OPGAL     : CPU Frequency = 600000 kHz
 [m3video]  8092: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
 [m3vpss ]  8089: SYSTEM: ListElem Shared Addr = 0xbf271600
 [c6xdsp ]  5688: ALGORITHM OPGAL     : link 35 initialization completed with status 0 [69112]
 [m3video]  8092: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
 [m3vpss ]  8092: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [c6xdsp ]  5688: ALGORITHM OPGAL     : Init [0 | 69112] completed SUCCESSFULLY.
 [m3video]  8092: SYSTEM: ListElem Shared Addr = 0xbf275080
 [m3vpss ]  8092: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [c6xdsp ]  5697: SYSTEM  : Initializing Links ... DONE !!!
 [m3video]  8112: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  8093: SYSTEM: ListElem Shared Addr = 0xbf29a300
 [m3video]  8113: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  8113: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
 [c6xdsp ]  5697: SYSTEM  : System DSP Init Done !!!
 [m3video]  8113: SYSTEM: ListElem Shared Addr = 0xbf29d800
 [m3vpss ]  8114: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
 [m3video]  8116: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  8114: SYSTEM: ListElem Shared Addr = 0xbf2bb300
 [m3video]  8117: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  8117: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
 [m3video]  8117: SYSTEM: ListElem Shared Addr = 0xbf2e0b00
 [m3vpss ]  8118: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
 [m3video]  8119: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3vpss ]  8118: SYSTEM: ListElem Shared Addr = 0xbf2fe600
 [m3video]  8120: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3vpss ]  8122: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
 [m3video]  8121: UTILS: DMA: HWI Create for INT62 !!!
 [m3vpss ]  8122: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
 [m3video]  8122: SYSTEM  : ISS Init in progress !!!
 [m3vpss ]  8122: SYSTEM: ListElem Shared Addr = 0xbf323e00
 [m3video]  8122: SYSTEM  : ISS Power-ON in progress !!!
 [m3vpss ]  8125: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
 [m3video]  8132: SYSTEM  : ISS Power-ON in progress DONE !!!
 [m3vpss ]  8125: SYSTEM  : FVID2 Init in progress !!!
 [m3video]  8133: SYSTEM  : ISS Init in progress DONE !!!
 [m3vpss ]  8214: SYSTEM  : FVID2 Init in progress DONE !!!
 [m3video]  8133: VCOP BOOST BIT is Set
 [m3vpss ]  8214: SYSTEM  : Device Init in progress !!!
 [m3video]  8133: SYSTEM  : VCOP Init in progress !!!
 [m3video]  8133: SYSTEM  : VCOP needs 172 B of memory !!!
 [m3vpss ] initPrms.isI2cInitReq = 0
 [m3video]  8135: SYSTEM  : VCOP Init in progress DONE !!!
 [m3video]  8135: SYSTEM  : Initializing Links !!!
 [m3vpss ]  8315: SYSTEM  : Device Init in progress DONE !!!
 [m3video]  8135: SYSTEM  : FREE SPACE : System Heap      = 6263296 B, Mbx = 10240 msgs)
 [m3vpss ] HDVPSS Freq  : 220 MHz
 [m3video]  8135: SYSTEM  : FREE SPACE : SR0 Heap         = 5730304 B (5 MB)
 [m3vpss ]  8371: SYSTEM  : System VPSS Init Done !!!
 [m3video]  8135: SYSTEM  : FREE SPACE : Frame Buffer     = 117440384 B (111 MB)
 [m3vpss ]  8372: UTILS: DMA: HWI Create for INT63 !!!
 [m3vpss ]  8373: SYSTEM  : Initializing Links !!!
 [m3video]  8136: SYSTEM  : FREE SPACE : Bitstream Buffer = 67108736 B (63 MB)
 [m3vpss ]  8373: SYSTEM  : FREE SPACE : System Heap      = 250280 B, Mbx = 10240 msgs)
 [m3video]  8136: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  8137: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
 [m3vpss ]  8373: SYSTEM  : FREE SPACE : SR0 Heap         = 5730304 B (5 MB)
 [m3video]  8137: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
 [m3vpss ]  8373: SYSTEM  : FREE SPACE : Frame Buffer     = 113130368 B (107 MB)
 [m3vpss ] Received character 's'
 [m3video]  8206: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  8373: SYSTEM  : FREE SPACE : Bitstream Buffer = 67108736 B (63 MB)
 [m3vpss ]  8374: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
 [m3video] Received character 's'
 [m3vpss ]  8374: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
 [m3vpss ]  8550: SYSTEM  : Initializing Links ... DONE !!!
 [c6xdsp ] Received character 's'
/opt/dvr_rdk/ti814x
 [m3vpss ]  8550: SYSTEM  : Set Static L3 pressur[module] vpss probe done.
e for HDVPSS as High
[module] ti81xxfb probe done.
HDMI W1 rev 4.0
HDMI CEC Spec version 1.2
 ORG 0x46c00524: 0
 NEW 0x46c00524: 2
 ========= Main Menu ========= 1: 4CH VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode 2: 8CH <D1+CIF> VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode 3: 16CH RT VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode 4: 16CH NRT <D1+CIF> VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode 5:               VDEC + VDIS  - SD/HD Decode ONLY o: OPGAL CAPTURE AND DISPALY f: OPGAL_FPGA_CAPTURE_AND_DISPLAY r: OPGAL ALGORITHM OFFLINE DEMO usecase
 e: Exit Enter Choice: f
 Selected DEMO - DEMO_OPGAL_FPGA_USECASE [demo.c.390]opgal_fpga_demo.c::OPGAL_fpga_capture_display_start: Initializing vsys ...  0: SYSTEM: System Common Init in progress !!!
 0: SYSTEM: IPC init in progress !!!
 10: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
 10: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
 10: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
 10: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
 10: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
 15: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 16: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 17: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 18: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 19: SYSTEM: IPC init DONE !!!
 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
 23: SYSTEM: ListElem Shared Addr = 0x40760880
 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
 26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
 27: SYSTEM: ListElem Shared Addr = 0x4077e380
 28: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
 30: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
 31: SYSTEM: ListElem Shared Addr = 0x4079be80
 32: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
 34: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
 35: SYSTEM: ListElem Shared Addr = 0x407c1680
 36: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
 38: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
 39: SYSTEM: ListElem Shared Addr = 0x407e6e80
 61: SYSTEM: System Common Init Done !!!
done
opgal_fpga_demo.c::OPGAL_fpga_capture_display_start: Initializing vcap ... done
Tied result HDMI -> DVO2 : 0
 [host] HDMI Ctrl :Initializing
 [host] HDMI Ctrl :Initialized
 [host] HDMI Ctrl :Sink Connected
[ti_vsys.c.246] gVsysModuleContext.vsysConfig.systemUseCase = 19
Lets check platform defined ...
Will be selected usecase for TI_814X_BUILD
[ti_vsys.c.330] call to Opgal_fpga_camera_usecase_create()
 129: MCFW  : CPU Revision [ES3.0] !!!  129: MCFW  : Detected [UNKNOWN] Board !!!  129: MCFW  : Base Board Revision [REV A] !!!
Perform capture from FPGA via VIP1_PORTA
 [m3vpss ]  18662: CAPTURE: Create in progress !!!
 [m3vpss ]  18699: CAPTURE: VIP1 PortA frame size 320 x 240 pixels, PROGRESSIVE
 [m3vpss ]  18699: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
 [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
 [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
 [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
 [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
 [c6xdsp ]  16324: IPC_FRAMES_IN_016h   : Create in progress !!!
 [c6xdsp ]  16324: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
 [m3vpss ] CAPTURE::HEAPID:0USED:328
 [c6xdsp ]  16324: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
 [m3vpss ] CAPTURE::HEAPID:4USED:5990400
 [c6xdsp ]  16325: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3vpss ]  18713: CAPTURE: Create Done !!!
 [m3vpss ]  18714: IPC_FRAMES_OUT_020000013h   : Create in progress !!!
 [c6xdsp ] IPC_FRAMES_IN:HEAPID:0USED:304
 [c6xdsp ]  16327: IPC_FRAMES_IN_016h   : Create Done !!!
 [m3vpss ]  18717: IPC_FRAMES_OUT_020000013h   : Create Done !!!
 [c6xdsp ]  16326: ALGORITHM OPGAL     : Task started [link 35/0]
 [c6xdsp ]  16369: ALGORITHM OPGAL     :  OPGAL codec created for channel 00. [8e406120]
 [c6xdsp ]  16369: ALGORITHM OPGAL     : Fill channel info for queueId = 0. [1]
 [c6xdsp ]  16370: ALGORITHM OPGAL     :  OPGAL codec instances created successfully [link = 35/0]. Service channels = 1
 [m3vpss ]  18766: IPC_FRAMES_IN_020000016h   : Create in progress !!!
 [c6xdsp ] ALGORITHM OPGAL::HEAPID:0USED:2384
 [m3vpss ]  18766: SYSTEM: Opening ListMP [DSP_IPC_OUT_19] ...
 [c6xdsp ] ALGORITHM OPGAL::HEAPID:1USED:32896
 [m3vpss ]  18766: SYSTEM: Opening ListMP [DSP_IPC_IN_19] ...
 [c6xdsp ]  16369: ALGORITHM OPGAL     : Task AlgOpgalLink_drvCreate() completed
 [m3vpss ]  18768: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 [c6xdsp ]  16370: IPC_FRAMES_OUT_013h   : Create in progress !!!
 [m3vpss ] IPC_FRAMES_IN:HEAPID:0USED:304
 [c6xdsp ]  16372: IPC_FRAMES_OUT_013h   : Create Done !!!
 [m3vpss ]  18770: IPC_FRAMES_IN_020000016h   : Create Done !!!
 [c6xdsp ]  16371: ALGORITHM OPGAL     : Link 35/0 start main loop...
 [m3vpss ]  18771: SWMS: Create in progress !!!
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
 [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
 *                        ALL RIGHTS RESERVED                                  *
#include "mcfw/src_linux/mcfw_api/usecases/multich_common.h"
#include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h"
 * Externs
#define     NUM_CAPTURE_DEVICES             (1)
const char capturePortName[][16] = {"VIP0_PORTA", "VIP0_PORTB", "VIP1_PORTA", "VIP1_PORTB"};
// Used Links' ID
Void Opgal_fpga_print_capture_statistics (void)
    int err = 0;
    if (SYSTEM_LINK_ID_INVALID != gVcapModuleContext.captureId) {
        printf("\nMCFW: print statistics for capture link id 0x%Xh\n", gVcapModuleContext.captureId);
        err |= System_linkControl (gVcapModuleContext.captureId, CAPTURE_LINK_CMD_PRINT_ADV_STATISTICS, NULL, 0, TRUE);
        err |= System_linkControl (gVcapModuleContext.captureId, CAPTURE_LINK_CMD_PRINT_BUFFER_STATISTICS, NULL, 0, TRUE);
        printf("\n\n");
    }else{
        printf("Captute link invalid id\n");
    if (0 != err) {
        printf("Capture link error = %d\n", err);
    }else{
        OSA_waitMsecs(1000); // allow for print to complete
    return;
Int32 dsp_alg_start (void)
    Int32 err = 0;
    err |= System_linkStart (vpssIpcVideoInLinkId);
    err |= System_linkStart (dspIpcVideoOutLinkId);
    err |= System_linkStart (algLinkId);
    err |= System_linkStart (dspIpcVideoInLinkId);
    return err;
 * Use case code
Void Opgal_fpga_camera_usecase_create ()
    CaptureLink_CreateParams      capturePrm;
    SwMsLink_CreateParams         swMsPrm;
    DisplayLink_CreateParams      displayPrm;
    VDIS_MOSAIC_S vDisMosaic;
    VCAP_DEVICE_CREATE_PARAM_S  vidDecVideoModeArgs;
    IpcFramesOutLinkRTOS_CreateParams vpssIpcFrameOut;
    IpcFramesInLinkRTOS_CreateParams  dspIpcFrameIn;
    AlgOpgalLink_CreateParams         algorithmPrm;
    IpcFramesOutLinkRTOS_CreateParams dspIpcFrameOut;
    IpcFramesInLinkRTOS_CreateParams  vpssIpcFrameIn;
    CaptureLink_VipInstParams* pCaptureInstPrm = NULL;
    CaptureLink_OutParams*     pCaptureOutPrm  = NULL;
    const UInt32 captureStandard = SYSTEM_OPGAL_QVGA_PROGRESSIVE_60;
    UInt32 vipInstId = 0u;
    UInt32 i = 0u;
    MULTICH_INIT_STRUCT(DisplayLink_CreateParams,   displayPrm);
    MULTICH_INIT_STRUCT(SwMsLink_CreateParams,      swMsPrm);
    MULTICH_INIT_STRUCT(AlgOpgalLink_CreateParams,  algorithmPrm);
    MultiCh_detectBoard();
    // reset VPSS
    System_linkControl(
        SYSTEM_LINK_ID_M3VPSS,
        SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,
        NULL,
        0,
        TRUE
    // ==== capture module context
    gVcapModuleContext.captureId                = captureLinkId;
    gVcapModuleContext.ipcFramesOutVpssId[0]    = vpssIpcVideoOutLinkId;
    gVcapModuleContext.ipcFramesInDspId[0]      = dspIpcVideoInLinkId;
    gVcapModuleContext.dspAlgId[0]              = algLinkId;
    // ==== display module context
    gVdisModuleContext.swMsId[0]                = swMosaicLinkId;
    gVdisModuleContext.displayId[0]             = displayLinkId; /* ON CHIP HDMI */
    // CAPTURE
//    pCaptureInstPrm->enableTimestampInInterrupt = TRUE;
    pCaptureInstPrm->standard          |= SYSTEM_STD_OPGAL_VIDEO_MODE_16_BITS;
    // DSP IPC frame IN
    // DSP ALG
    // VPSS: CAPTURE -> IPC_OUT
    System_linkCreate (captureLinkId,         &capturePrm,      sizeof(capturePrm));
    System_linkCreate (vpssIpcVideoOutLinkId, &vpssIpcFrameOut, sizeof(vpssIpcFrameOut));
    // IPC_IN -> ALG -> IPC_OUT
    System_linkCreate (dspIpcVideoInLinkId,   &dspIpcFrameIn,   sizeof(dspIpcFrameIn));
    System_linkCreate (algLinkId,             &algorithmPrm,    sizeof(algorithmPrm));
    System_linkCreate (dspIpcVideoOutLinkId,  &dspIpcFrameOut,  sizeof(dspIpcFrameOut));
    // VPSS: IPC_IN -> SW_MS -> DISPLAY
    System_linkCreate (vpssIpcVideoInLinkId,  &vpssIpcFrameIn,  sizeof(vpssIpcFrameIn));
    System_linkCreate (swMosaicLinkId,        &swMsPrm,         sizeof(swMsPrm));
    System_linkCreate (displayLinkId,         &displayPrm,      sizeof(displayPrm));
    // get default mosaic parameters
    Vdis_getMosaicParams (VDIS_DEV_HDMI, &vDisMosaic);
    vDisMosaic.displayWindow.start_X = 0u;
    vDisMosaic.displayWindow.start_Y = 0u;
    vDisMosaic.displayWindow.width   = 1920u;
    vDisMosaic.displayWindow.height  = 1080u;
    vDisMosaic.onlyCh2WinMapChanged = FALSE;
    vDisMosaic.chnMap [0] = 0u;
    vDisMosaic.winList[0].start_X = 0u;
    vDisMosaic.winList[0].start_Y = 0u;
    vDisMosaic.winList[0].width  = 320;
    vDisMosaic.winList[0].height = 240;
    // update mosaic parameters
    Vdis_setMosaicParams(VDIS_DEV_HDMI, &vDisMosaic);
    printf ("[%s|%s]: Update mosaic: %u x %u\n", __FILE__, __FUNCTION__, vDisMosaic.winList[0].width, vDisMosaic.winList[0].height);
    MultiCh_memPrintHeapStatus();
    return;
Void Opgal_fpga_camera_usecase_delete ()
    UInt32 i;
    const UInt32 numSubChains = 1u;
    UInt32 enableSdtv   = FALSE;
    System_linkDelete (gVcapModuleContext.captureId);
//    System_linkDelete (dupId);
    for (i = 0; i < numSubChains; i++)
        System_linkDelete (gVdisModuleContext.swMsId[i] );
        System_linkDelete(gVdisModuleContext.displayId[i]);
    if (enableSdtv) {
        System_linkDelete(gVdisModuleContext.displayId[2]);
    /* Print the HWI, SWI and all tasks load */
    /* Reset the accumulated timer ticks */
    MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE);
    return;
  • I will notify our DVR RDK expert for help.
    Pavel
  • Thanks alot Pavel.
    In additional I modified my use-case, remove mosaic and display links and connect VpssIpcFrameIn link to VpssNull link for test data passing.
    So my modified use-case looked as:
    -> SYSTEM_DSP_LINK_ID_IPC_FRAMES_OUT_0 -> SYSTEM_VPSS_LINK_ID_IPC_FRAMES_IN_0 -> SYSTEM_VPSS_LINK_ID_NULL_0.
    With NULL link this use-case works fine, video buffers passed from capture via my algorithm link to NULL without any problems, so I sure really exist problem in pass video buffer from DSP back to VPSS module. (Or, maybe this is undocumented limitation?)
  • please help me resolve the problem. This issue is very important for me.
  • The algLink on the DSP does not support Frames output. It only supports BitsOutput. Have you modified the DSP algLink to add this feature ? The error looks like the input format is not correct due to which the scaler driver create fails.
    Do you really require an output buffer. If the DSP frame modification can be done inplace in the input buffer then you can have configuration as
    Capture -> ipcFramesOutVpss -> (processLink) -> ipcFramesInDsp -> algLink
                                                      -> (nextLink) -> SwMs -> display
    Also you don't seem to be configuring the ipcNotifyNextlink/NotifyPrevlink params correctly. Although it is not related to the issue you are seeing without correct configuration you will see issues with runtime data flow.Pls check this also.
  • Hello Badri,
    I'm very glad for your answer. I'll check it and notify you. ThanX again :-)
    "Have you modified the DSP algLink to add this feature ?" - yes, it's my own link
  • Capture -> ipcFramesOutVpss -> (processLink) -> ipcFramesInDsp -> algLink
    Hello Badri.
    Please let me know, what you mean "processLink" and "nextLink"?
    Is SwMs link can be directly connected to ipcFramesOutVpss link?
  • Hello Badri.
    When DSP worked as process link (as you recommend - return processed buffer via iinput queue) - my usecase works Ok.
    When DSP worked as, let say, "traditional" link with output queue and return processed buffer via output queue:
    - if DSP connected via IPC to encoder - works Ok
    - if DSP connected via IPC back to VPSS - use case hangs on creation stage.
    May I ask you explain me - why DSP/ALG link with output queue is very sensitive to type of next link?
