TI-RTOS setup segfaults on Ubuntu 14.04
I've downloaded TI-RTOS 2.01.00.03, but when running tirtos_tivac_setuplinux_2_01_00_03.bin all I get is
 [1]    10798 segmentation fault (core dumped)  ./tirtos_tivac_setuplinux_2_01_00_03.bin
and in dmesg
[16943.946462] tirtos_tivac_se[11079]: segfault at 886c4aaa ip 00000000886c4aaa sp 00000000906804f1 error 14 in tirtos_tivac_setuplinux_2_01_00_03.bin[df30b000+bc35000]
I'm using Ubuntu 14.04 (64bit)
  • Hi Ben,
    we've tested TI-RTOS 2.01.00.03 on Ubuntu 12 LTS. I've filed a CQ (SDOCM00113440) to get this fixed.
    I think you should be able to take the installed product from another (Ubuntu 12) machine and copy it to your Ubuntu 14 machine.
  • You can also run the installer in "text" mode from a shell/terminal window to work around the GUI mode segfault:
    linux% ./tirtos_tivac_setuplinux_2_01_00_03.bin --mode text
    NOTE: that is two (2) - in front of mode
    Mark
  • Thank you, the text mode installer works!
  • The installer doesn't set paths correctly though
    ..03_examples/GNU/EK_TM4C123GXL/uartecho % make -f makefile
    Running Configuro...
    /bin/sh: 1: c:/ti/xdctools_3_30_04_52_core/xs: not found
    make: *** [uartecho/linker.cmd] Error 127
    I've run
    find -type f -exec sed -i 's/c:\//\/home\/USERNAME\/ti\//g' {} \;
    After that I had to set
    GCC_INSTALLATION_DIR ?= /usr
    CODEGEN_INSTALLATION_DIR = /usr
    only to get
    ..03_examples/GNU/EK_TM4C123GXL/uartecho % make -f makefile        :(
    making package.mak (because of package.bld) ...
    generating interfaces for package uartecho (because package/package.xdc.inc is older than package.xdc) ...
    /home/benpicco/ti/xdctools_3_30_04_52_core/jre/lib/rt.jar: invalid LOC header (bad signature)
    Exception in thread "main" java.lang.NoClassDefFoundError: com/sun/org/apache/xerces/internal/impl/XMLEntityManager
    	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.<init>(Unknown Source)
    	at com.sun.org.apache.xerces.internal.parsers.XIncludeAwareParserConfiguration.<init>(Unknown Source)
    	at com.sun.org.apache.xerces.internal.parsers.DOMParser.<init>(Unknown Source)
    	at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.<init>(Unknown Source)
    	at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl.newDocumentBuilder(Unknown Source)
    	at xdc.services.intern.gen.JClass.genPkgBuild(JClass.java:911)
    	at xdc.services.intern.gen.JClass.genPkgValues(JClass.java:1062)
    	at xdc.services.intern.gen.JClass.gen(JClass.java:226)
    	at xdc.services.intern.cmd.Builder.gen(Builder.java:249)
    	at xdc.services.intern.cmd.Builder.main(Builder.java:149)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    	at java.lang.reflect.Method.invoke(Unknown Source)
    	at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:126)
    	at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:225)
    	at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1473)
    	at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:815)
    	at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:123)
    	at org.mozilla.javascript.Context.evaluateReader(Context.java:1110)
    	at config.Shell.evaluateLoad(Shell.java:797)
    	at config.Shell.processLoad(Shell.java:679)
    	at config.Shell.load(Shell.java:1215)
    	at org.mozilla.javascript.FunctionObject.call(FunctionObject.java:386)
    	at org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:109)
    	at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)
    	at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3091)
    	at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:120)
    	at config.Shell.evaluateReader(Shell.java:847)
    	at config.Shell.processReader(Shell.java:512)
    	at config.Shell.processFile(Shell.java:571)
    	at config.Shell.exec(Shell.java:781)
    	at config.Shell.main(Shell.java:1414)
    gmake: *** [package/package.xdc.inc] Error 1
    js: "/home/benpicco/ti/xdctools_3_30_04_52_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    java -jar /home/benpicco/ti/xdctools_3_30_04_52_core/jre/lib/rt.jar says
    Error: Invalid or corrupt jarfile /home/benpicco/ti/xdctools_3_30_04_52_core/jre/lib/rt.jar
    I have
    % java -version
    java version "1.8.0_20"
    Java(TM) SE Runtime Environment (build 1.8.0_20-b26)
    Java HotSpot(TM) 64-Bit Server VM (build 25.20-b23, mixed mode)
