Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e3e044
Hello  ,
Can any one tell me what i made wrong here while building kernel (3.8.13). Or how i can i debug this issue
zImage loading through command in u-boot
U-Boot# load mmc 0:1 0x82000000 zImage
reading zImage
4131736 bytes read in 230 ms (17.1 MiB/s)
U-Boot# load mmc 0:1 0x88000000 am335x-bone.dtb
reading am335x-bone.dtb
25507 bytes read in 7 ms (3.5 MiB/s)
U-Boot# setenv bootargs console=ttyO0,115200n8 capemgr.enable_partno=BB-UART1 root=/dev/mmcblk0p2 rootfstype=ext4
U-Boot# bootz 0x82000000 - 0x88000000
Kernel Log is --------------------------------------------------------------------------
Kernel image @ 0x82000000 [ 0x000000 - 0x3f0b98 ]
   Loading Device Tree to 8fff6000, end 8ffff3a2 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.8.13-dirty (ari_csuser2@ubuntu-3f-21) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu4
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES1.0 (neon )
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0aa7000 s9408 r8192 d15168 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129792
[    0.000000] Kernel command line: console=ttyO0,115200n8 capemgr.enable_partno=BB-UART1 root=/dev/mmcblk0p2 rootfs4
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] __ex_table already sorted, skipping sort
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 511MB = 511MB total
[    0.000000] Memory: 510872k/510872k available, 13416k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0597944   (5695 kB)
[    0.000000]       .init : 0xc0598000 - 0xc05cd4c0   ( 214 kB)
[    0.000000]       .data : 0xc05ce000 - 0xc063e460   ( 450 kB)
[    0.000000]        .bss : 0xc063e460 - 0xc0696f7c   ( 355 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000230] Calibrating delay loop... 993.47 BogoMIPS (lpj=969728)
[    0.029185] pid_max: default: 32768 minimum: 301
[    0.029326] Security Framework initialized
[    0.029384] Mount-cache hash table entries: 512
[    0.035473] Initializing cgroup subsys cpuacct
[    0.035495] Initializing cgroup subsys memory
[    0.035534] Initializing cgroup subsys blkio
[    0.035624] CPU: Testing write buffer coherency: ok
[    0.036004] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.036058] Setting up static identity map for 0x80366688 - 0x803666d4
[    0.036860] Brought up 1 CPUs
[    0.036876] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[    0.037678] devtmpfs: initialized
[    0.046229] omap_hwmod: wd_timer2: _wait_target_disable failed
[    0.098060] pinctrl core: initialized pinctrl subsystem
[    0.098448] regulator-dummy: no parameters
[    0.098760] NET: Registered protocol family 16
[    0.099260] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.099443] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.105169] platform 49000000.edma: alias fck already exists
[    0.105189] platform 49000000.edma: alias fck already exists
[    0.105204] platform 49000000.edma: alias fck already exists
[    0.105946] OMAP GPIO hardware version 0.1
[    0.110569] platform 53100000.sham: Cannot lookup hwmod 'sham'
[    0.110711] platform 53500000.aes: Cannot lookup hwmod 'aes'
[    0.111130] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.111342] omap_init_sham: platform not supported
[    0.111352] omap_init_aes: platform not supported
[    0.119555] bio: create slab <bio-0> at 0
[    0.120237] vmmcsd_fixed: 3300 mV
[    0.121807] SCSI subsystem initialized
[    0.122065] usbcore: registered new interface driver usbfs
[    0.122136] usbcore: registered new interface driver hub
[    0.122317] usbcore: registered new device driver usb
[    0.123086] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring pe
[    0.123121] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[    0.123168] omap_i2c 4819c000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c2_pins, deferring pe
[    0.123189] platform 4819c000.i2c: Driver omap_i2c requests probe deferral
[    0.123258] media: Linux media interface: v0.10
[    0.123310] Linux video capture interface: v2.00
[    0.123375] pps_core: LinuxPPS API ver. 1 registered
[    0.123384] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123701] Advanced Linux Sound Architecture Driver Initialized.
[    0.124424] Switching to clocksource gp_timer
[    0.134463] NET: Registered protocol family 2
[    0.135072] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.135154] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[    0.135237] TCP: Hash tables configured (established 4096 bind 4096)
[    0.135300] TCP: reno registered
[    0.135316] UDP hash table entries: 256 (order: 1, 12288 bytes)
[    0.135341] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[    0.135565] NET: Registered protocol family 1
[    0.135951] RPC: Registered named UNIX socket transport module.
[    0.135963] RPC: Registered udp transport module.
[    0.135970] RPC: Registered tcp transport module.
[    0.135978] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.136538] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[    0.136781] CPU PMU: attempt to register multiple PMU devices!
[    0.136807] arm-pmu: probe of arm-pmu failed with error -28
[    0.137065] omap2_mbox_probe: platform not supported
[    0.139373] VFS: Disk quotas dquot_6.5.2
[    0.139498] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.140265] NFS: Registering the id_resolver key type
[    0.140328] Key type id_resolver registered
[    0.140337] Key type id_legacy registered
[    0.140377] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.140657] msgmni has been set to 997
[    0.142336] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.142351] io scheduler noop registered
[    0.142360] io scheduler deadline registered
[    0.142383] io scheduler cfq registered (default)
[    0.142934] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.143905] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.145355] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[    0.145609] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[    0.822564] console [ttyO0] enabled
[    0.826781] [drm] Initialized drm 1.1.0 20060810
[    0.839029] brd: module loaded
[    0.846220] loop: module loaded
[    0.850402] OneNAND driver initializing
[    0.855393] usbcore: registered new interface driver asix
[    0.861138] usbcore: registered new interface driver cdc_ether
[    0.867304] usbcore: registered new interface driver smsc95xx
[    0.873357] usbcore: registered new interface driver net1080
[    0.879323] usbcore: registered new interface driver cdc_subset
[    0.885567] usbcore: registered new interface driver zaurus
[    0.891500] usbcore: registered new interface driver cdc_ncm
[    0.897903] usbcore: registered new interface driver cdc_acm
[    0.903842] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.912204] Initializing USB Mass Storage driver...
[    0.917370] usbcore: registered new interface driver usb-storage
[    0.923649] USB Mass Storage support registered.
[    0.928595] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.936018] mousedev: PS/2 mouse device common for all mice
[    0.942732] Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e3e044
[    0.950727] Internal error: : 1028 [#1] SMP THUMB2
[    0.955727] Modules linked in:
[    0.958920] CPU: 0    Not tainted  (3.8.13-dirty #8)
[    0.964121] PC is at rtc_wait_not_busy+0xa/0x30
[    0.968846] LR is at omap_rtc_read_time+0xb/0x64
[    0.973656] pc : [<c025fdb2>]    lr : [<c026013b>]    psr: 000001b3
[    0.973656] sp : df06fd90  ip : 00000000  fp : 00000000
[    0.985629] r10: c05ca030  r9 : 00000001  r8 : 00000000
[    0.991081] r7 : df06fdd0  r6 : c068ff6c  r5 : c0614a54  r4 : 00000032
[    0.997891] r3 : f9e3e000  r2 : 00000000  r1 : df06fdd0  r0 : df107010
[    1.004708] Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment kernel
[    1.012593] Control: 50c5387d  Table: 80004019  DAC: 00000015
[    1.018582] Process swapper/0 (pid: 1, stack limit = 0xdf06e240)
[    1.024840] Stack: (0xdf06fd90 to 0xdf070000)
[    1.029376] fd80:                                     df06fdd0 df06fdd0 00000000 c026013b
[    1.037910] fda0: df2c3400 c025de51 df04eac0 df2c35c8 df2c3400 c025e413 c025e775 df06fe38
[    1.046436] fdc0: df2c3400 df107010 df106200 c025e57b 00000000 00000000 00000000 00000000
[    1.054975] fde0: 00000000 00000000 00000000 00000000 00000000 001b001a 0000000f 00000113
[    1.063504] fe00: 80000000 c0366529 c062a748 c0191a89 c062a748 00000000 df106200 c008d1af
[    1.072035] fe20: df2c3400 00000000 df107010 df106200 00000000 c025dbf5 df10711c 40000113
[    1.080563] fe40: df107080 df107010 df107080 00070006 00000000 40000113 df107080 c0366529
[    1.089098] fe60: 00000000 c068ff6c df107000 df107010 c062a900 df2d3b00 00000000 c05b01f9
[    1.097634] fe80: 00000000 00000000 00000000 df107010 df107044 c062a87c c062a87c 000000ed
[    1.106165] fea0: c05981bd c01e2a1f c01e2a13 c01e1fe1 00000000 df107010 df107044 c062a87c
[    1.114700] fec0: 00000000 c01e20e1 c062a87c df06fed8 c01e20b1 c01e1201 df049478 df0b9380
[    1.123234] fee0: c062a87c c062a87c df2d4d40 c061bc50 00000000 c01e1a91 c050b3f5 df001348
[    1.131772] ff00: c062a87c c05b0115 00000000 c063e480 000000ed c01e23c9 c01e2a35 c062a868
[    1.140302] ff20: c05b0115 00000000 c063e480 000000ed c05981bd c01e2b4d 00000006 c05b0115
[    1.148828] ff40: 00000000 c000866f 00000006 00000006 00010000 00000006 c05b83b8 00000006
[    1.157366] ff60: c05b83bc c05b839c c063e480 000000ed c05981bd c059866b 00000006 00000006
[    1.165897] ff80: c05981bd 00000000 00000000 c035e8cd 00000000 00000000 00000000 00000000
[    1.174420] ffa0: 00000000 c035e8d3 00000000 c000c47d 00000000 00000000 00000000 00000000
[    1.182953] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.191476] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[    1.200027] [<c025fdb2>] (rtc_wait_not_busy+0xa/0x30) from [<c026013b>] (omap_rtc_read_time+0xb/0x64)
[    1.209646] [<c026013b>] (omap_rtc_read_time+0xb/0x64) from [<c025de51>] (__rtc_read_time+0x25/0x32)
[    1.219179] [<c025de51>] (__rtc_read_time+0x25/0x32) from [<c025e413>] (rtc_read_time+0x1d/0x28)
[    1.228353] [<c025e413>] (rtc_read_time+0x1d/0x28) from [<c025e57b>] (__rtc_read_alarm+0x11/0x18a)
[    1.237700] [<c025e57b>] (__rtc_read_alarm+0x11/0x18a) from [<c025dbf5>] (rtc_device_register+0xed/0x1bc)
[    1.247691] [<c025dbf5>] (rtc_device_register+0xed/0x1bc) from [<c05b01f9>] (omap_rtc_probe+0xd5/0x26c)
[    1.257503] [<c05b01f9>] (omap_rtc_probe+0xd5/0x26c) from [<c01e2a1f>] (platform_drv_probe+0xd/0xe)
[    1.266948] [<c01e2a1f>] (platform_drv_probe+0xd/0xe) from [<c01e1fe1>] (driver_probe_device+0x69/0x138)
[    1.276847] [<c01e1fe1>] (driver_probe_device+0x69/0x138) from [<c01e20e1>] (__driver_attach+0x31/0x44)
[    1.286644] [<c01e20e1>] (__driver_attach+0x31/0x44) from [<c01e1201>] (bus_for_each_dev+0x29/0x46)
[    1.296096] [<c01e1201>] (bus_for_each_dev+0x29/0x46) from [<c01e1a91>] (bus_add_driver+0x65/0x158)
[    1.305532] [<c01e1a91>] (bus_add_driver+0x65/0x158) from [<c01e23c9>] (driver_register+0x4d/0xac)
[    1.314876] [<c01e23c9>] (driver_register+0x4d/0xac) from [<c01e2b4d>] (platform_driver_probe+0x11/0x5c)
[    1.324780] [<c01e2b4d>] (platform_driver_probe+0x11/0x5c) from [<c000866f>] (do_one_initcall+0x63/0xe8)
[    1.334669] [<c000866f>] (do_one_initcall+0x63/0xe8) from [<c059866b>] (kernel_init_freeable+0xbb/0x14c)
[    1.344575] [<c059866b>] (kernel_init_freeable+0xbb/0x14c) from [<c035e8d3>] (kernel_init+0x7/0x90)
[    1.354019] [<c035e8d3>] (kernel_init+0x7/0x90) from [<c000c47d>] (ret_from_fork+0x11/0x34)
[    1.362731] Code: 2432 4e07 4d08 6833 (f893) 2044
[    1.367756] ---[ end trace 6be2f587d5dec120 ]---
[    1.372902] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    1.372902]
