Other Parts Discussed in Thread: TMS320DM8148
Does anyone know where the DP/DM calibration procedure referenced in the TMS320DM814x errata advisory 3.0.70 is described
Hi William,
See if the below wiki page (and links inside it) will be in help:
http://processors.wiki.ti.com/index.php/Hardware_Design_Checklist#USB
Note also that we have USB bugs fixed in the latest PSP04.04.00.02:
http://processors.wiki.ti.com/index.php/TI81XX_PSP_04.04.00.02_Release_Notes#USB_2
TI81XX
Issue: USB: Truncated packets with CRC error observed during transmit operation causing multiple resets while creating a file on HP flash drive
Known Workaround(s): The requires both (a) following the TI recommended USB PCB Design guideline and (b) SW workaround to fine-tune USBPHY calibration parameters. The SW patch is available as part of release package.
The latest PSP can be found:
http://arago-project.org/git/projects/?p=linux-omap3.git;a=shortlog;h=refs/heads/ti81xx-master
Pavel
Can we use that PSP with RDK 4.01? if not where do we get a new RDK release with this bug fixed?
Richard,
I am not familiar with RDK. What I find is the PSP linux kernel branch:
http://arago-project.org/git/projects/?p=linux-omap3.git;a=shortlog;h=refs/heads/ti81xx-master - for EZSDK
http://arago-project.org/git/projects/?p=linux-dvr-rdk-dm81xx.git;a=shortlog;h=refs/heads/dvrrdk_kernel_int_branch - for DVR RDK
http://arago-project.org/git/projects/?p=linux-ipnc-rdk-dm81xx.git;a=shortlog;h=refs/heads/ipncrdk_psp_dm81xx_kernel - for IPNC RDK
You can check if your linux kernel is up to date with the corresponding branch.
Pavel
Pavel, what I am trying to find out is that code and bug fix are in the following software release because we are seeing still seeing USB lockup with 3G device.
http://www.ti.com/product/TMS320DM8148/toolssoftware#softTools
DVRRDK ver4.1
DVRRDK ver4.1 Docs Package
DVRRDK ver4.1 Binary Package
there is no direct mention of PSP version in documentation except this in release notes.
**** PSP Release documents are from "TI PSP 04.04.00.02". Refer Migration Guide for exact DVR RDK PSP
Version.
and the migration document point to this dead link.
PSP Changes
Refer release specific branch in DVR RDK PSP Arago Git. Refer DVR RDK PSP Arago.
http://ap-fpdsp-swapps.dal.design.ti.com/index.php/DVR_RDK_Main_Page
