Other Parts Discussed in Thread: OMAP3530, PCM4204
I need to connect the DSS port of the OMAP3530 to a LCD panel. However, the simplest routing would be to connect the device in RGB not BGR. Can the dss port be made to output RGB?
Basically, I need R on DSS_DATA[0:8] and B on DSS_DATA[16:23] otherwise I will need to cross A LOT of traces. If this can't be done can anyone suggest a driver chip which can cross the lines like this?
