I am trying to capture 2 channels and display them through swms.
channel 0 is capturing SYSTEM_CAPTURE_INST_VIP1_PORTA, and channel 1 is capturing SYSTEM_CAPTURE_INST_VIP0_PORTA
I expected to find one channel as display ch 0, and the second channel as display channel 1, but I can only display channel 0. I also tried to see if I find channel #1 by changing swms to 4x4, but I can't see it, only channel 0.
When I create 2 usecases and in each I capture only one channel into channel 0 (in 1 usecase SYSTEM_CAPTURE_INST_VIP1_PORTA and in the second SYSTEM_CAPTURE_INST_VIP0_PORTA), it all works well, but I need them both as channel 0 and channel 1 (for fast switch between them in display/encode).
How can I start debugging this issue ?
Please advise ....
Thank you very much,
Ran
/* ranran new file */ /** \file demo_vcap_venc_vdec_vdis.c \brief */ #include <sys/time.h> #include <demo_vcap_venc_vdec_vdis.h> #include <demo_scd_bits_wr.h> /* Setting secondary out <CIF> for 30 frames - this is the validated frame rate; any higher number will impact performance. */ #define CIF_FPS_ENC_NTSC (30) #define CIF_FPS_ENC_PAL (25) #define CIF_BITRATE (500) #define MJPEG_BITRATE (100) int g_portIn = 0; Void Demo_displayChangeFpsForLayout (VDIS_MOSAIC_S *vdMosaicParam, UInt32 layoutId); static Int64 get_current_time_to_msec(void) { struct timeval tv; gettimeofday(&tv, NULL); return ((Int64)tv.tv_sec*1000 + tv.tv_usec/1000); } /* used in 814x 16ch usecase */ #define H264_PRIMARY_STREAM_PROFILE VENC_CHN_MAIN_PROFILE #define H264_SECONDARY_STREAM_PROFILE VENC_CHN_BASELINE_PROFILE /* used to set resolution / buf size of ipcbits for varying resolutions based on usecase */ VcapVencVdecVdis_chBufInfo ipcBitsChInfo[MCFW_IPCBITS_MAX_CHANNELS]; Void CommitVcapVencVdecVdis_setChannels(int demoId, int *pEnable2ndOut) { Int32 i; printf("ranran CommitVcapVencVdecVdis_setChannels 1"); memset(ipcBitsChInfo, 0, sizeof(ipcBitsChInfo)); switch (demoId) { case DEMO_COMMIT_VENC_VDIS: printf("ranran CommitVcapVencVdecVdis_setChannels 22"); gDemo_info.maxVcapChannels = 2; gDemo_info.maxVdisChannels = 2; gDemo_info.maxVencChannels = 2; gDemo_info.maxVdecChannels = 0; gDemo_info.VsysNumChs = 2; for(i=0; i<gDemo_info.maxVencChannels; i++) { ipcBitsChInfo[i].width = MCFW_IPCBITS_HD_WIDTH; ipcBitsChInfo[i].height = MCFW_IPCBITS_HD_HEIGHT; ipcBitsChInfo[i].chBufSize = ipcBitsChInfo[i].width * ipcBitsChInfo[i].height; } break; default: break; } } Void CommitVcapVencVdecVdis_start( Bool doProgressiveVenc, Bool enableSecondaryOut, int demoId, int port) { UInt32 i, resolutionClass; VSYS_PARAMS_S vsysParams; VCAP_PARAMS_S vcapParams; VENC_PARAMS_S vencParams; VDEC_PARAMS_S vdecParams; VDIS_PARAMS_S vdisParams; Bool forceLowCostScale = FALSE, enableFWrite = FALSE, enableLayerWrite = FALSE; Int32 Enable2ndOut = enableSecondaryOut; static VDIS_MOSAIC_S vdMosaicParam; int startChId; int layoutId = DEMO_LAYOUT_MODE_4CH_4CH; UInt64 wallTimeBase; g_portIn = port; Vsys_params_init(&vsysParams); Vcap_params_init(&vcapParams); Venc_params_init(&vencParams); Vdec_params_init(&vdecParams); Vdis_params_init(&vdisParams); CommitVcapVencVdecVdis_setChannels(demoId, &Enable2ndOut); vcapParams.numChn = gDemo_info.maxVcapChannels; vencParams.numPrimaryChn = gDemo_info.maxVencChannels; vencParams.numSecondaryChn = 0; vdecParams.numChn = gDemo_info.maxVdecChannels; vdisParams.numChannels = gDemo_info.maxVdisChannels; vsysParams.numChs = gDemo_info.VsysNumChs; enableSecondaryOut = (Bool)Enable2ndOut; resolutionClass = DEMO_SCD_RESOLUTION_CLASS_QCIF; if( doProgressiveVenc) { vsysParams.systemUseCase = VSYS_USECASE_COMMIT_VCAP_VENC_VDIS; if (enableSecondaryOut == FALSE) { vsysParams.enableSecondaryOut = FALSE; vsysParams.enableNsf = FALSE; } else { vsysParams.enableSecondaryOut = TRUE; vsysParams.enableNsf = TRUE; vsysParams.enableMjpegEnc = TRUE; } printf("11 vsysParams.systemUseCase = %d %d\n",vsysParams.systemUseCase,DEMO_COMMIT_VENC_VDIS); vsysParams.enableCapture = TRUE; vsysParams.enableNullSrc = FALSE; vsysParams.enableOsd = TRUE; vsysParams.enableScd = FALSE; vsysParams.numDeis = 1; vsysParams.numSwMs = 2; vsysParams.numDisplays = 2; vsysParams.enableAVsync = TRUE; } if (enableSecondaryOut) { vencParams.numSecondaryChn = gDemo_info.maxVencChannels; /*enableMjpegEnc should always be true in all usecases*/ gDemo_info.maxVencChannels *= 3; } printf ("--------------- CHANNEL DETAILS-------------\n"); printf ("Capture Channels => %d\n", vcapParams.numChn); printf ("Enc Channels => Primary %d, Secondary %d\n", vencParams.numPrimaryChn, vencParams.numSecondaryChn); printf ("Dec Channels => %d\n", vdecParams.numChn); printf ("Disp Channels => %d\n", vdisParams.numChannels); printf ("-------------------------------------------\n"); Vsys_enableFastUsecaseSwitch(FALSE); if ((vsysParams.systemUseCase == VSYS_USECASE_MULTICHN_HD_VCAP_VENC) || (vsysParams.systemUseCase == VSYS_USECASE_COMMIT_VCAP_VENC_VDIS)) { printf("ranran osd disable !!!!!!!!!!\n"); vsysParams.enableScd = FALSE; vsysParams.enableOsd = FALSE; vsysParams.numDeis = 1; vsysParams.numSwMs = 1; vsysParams.numDisplays = 1; vsysParams.enableAVsync = FALSE; } /* Override the context here as needed */ Vsys_init(&vsysParams); //ranran vcapParams.enableConfigExtVideoDecoder = FALSE; /* Override the context here as needed */ Vcap_init(&vcapParams); /*Enabling generation of motion vector for channel 0 only, * for other channels please add to the below line*/ vencParams.encChannelParams[0].enableAnalyticinfo = 1; //vencParams.encChannelParams[1].enableAnalyticinfo = 1; vencParams.encChannelParams[0].maxBitRate = -1; /*Note:Specific for h264 Encoder: Enabling this flag adds svc extension headers to the stream, not all decoders are generally able to play back such a stream. */ /* Needs to be enabled to IH264_SVC_EXTENSION_FLAG_ENABLE for the svc extension headers to be present in the stream*/ vencParams.encChannelParams[0].enableSVCExtensionFlag = VENC_IH264_SVC_EXTENSION_FLAG_DISABLE; /** Note: For the encoder to give out frames with SVC-T properties, number of layers needs to be increased as per requirement. A flag enableLayerWrite needs to be set if for any channel the Layer is increased to beyond 1. This check has also been done for Channel 0, just before VcapVencVdecVdis_ipcBitsInit call. For example for Channel 0 it has been set to LAYERS_4, file stream dump will generate four(Base + 3) files with differing frame-rates**/ /** WARNING: SVC-T cannot be used if B Frame is enabled */ vencParams.encChannelParams[0].numTemporalLayer = VENC_TEMPORAL_LAYERS_4; #ifdef USE_CAMERA vencParams.encChannelParams[0].dynamicParam.frameRate = 25 * 1000; #else vencParams.encChannelParams[0].dynamicParam.frameRate = 30 * 1000; #endif //vencParams.encChannelParams[0].dynamicParam.frameRate = 10 * 1000; printf("ranran framerate in demo %d\n",vencParams.encChannelParams[0].dynamicParam.frameRate); /* Override the context here as needed */ Venc_init(&vencParams); /* Override the context here as needed */ Vdec_init(&vdecParams); /* Override the context here as needed */ vdisParams.deviceParams[VDIS_DEV_HDMI].resolution = DEMO_HD_DISPLAY_DEFAULT_STD; vdisParams.deviceParams[VDIS_DEV_DVO2].resolution = DEMO_HD_DISPLAY_DEFAULT_STD; vdisParams.deviceParams[VDIS_DEV_HDCOMP].resolution = DEMO_HD_DISPLAY_DEFAULT_STD; vdisParams.mosaicLayoutResolution[VDIS_DEV_HDMI] = vdisParams.deviceParams[VDIS_DEV_HDMI].resolution; vdisParams.mosaicLayoutResolution[VDIS_DEV_DVO2] = vdisParams.deviceParams[VDIS_DEV_DVO2].resolution; vdisParams.mosaicLayoutResolution[VDIS_DEV_HDCOMP] = vdisParams.deviceParams[VDIS_DEV_HDCOMP].resolution; Vdis_tiedVencInit(VDIS_DEV_DVO2, VDIS_DEV_HDCOMP, &vdisParams); vdisParams.deviceParams[VDIS_DEV_SD].resolution = VSYS_STD_NTSC; vdisParams.mosaicLayoutResolution[VDIS_DEV_SD] = vdisParams.deviceParams[VDIS_DEV_SD].resolution; vdisParams.enableLayoutGridDraw = FALSE; if (vsysParams.systemUseCase == VSYS_USECASE_MULTICHN_INTERLACED_VCAP_VDIS_VENC_VDEC) forceLowCostScale = TRUE; i = 0; /* set for 2 displays */ Demo_swMsGenerateLayout(VDIS_DEV_HDMI, 0, gDemo_info.maxVdisChannels, DEMO_LAYOUT_MODE_1CH, &vdisParams.mosaicParams[VDIS_DEV_HDMI], forceLowCostScale, gDemo_info.Type, Vdis_getSwMsLayoutResolution(VDIS_DEV_HDMI)); vdisParams.mosaicParams[VDIS_DEV_HDMI].userSetDefaultSWMLayout = TRUE; /* Set swMS outputFPS as 60 or 50 for this default 7x1 layout for TI814X */ Demo_swMsSetOutputFPS(&vdisParams.mosaicParams[VDIS_DEV_HDMI], Demo_swMsGetOutputFPS(&vdisParams.mosaicParams[VDIS_DEV_HDMI])*2); Demo_swMsGenerateLayout(VDIS_DEV_SD, 0, gDemo_info.maxVdisChannels, DEMO_LAYOUT_MODE_1CH, &vdisParams.mosaicParams[VDIS_DEV_SD], forceLowCostScale, gDemo_info.Type, Vdis_getSwMsLayoutResolution(VDIS_DEV_SD)); vdisParams.mosaicParams[VDIS_DEV_SD].userSetDefaultSWMLayout = TRUE; Demo_swMsSetOutputFPS(&vdisParams.mosaicParams[VDIS_DEV_SD], Demo_swMsGetOutputFPS(&vdisParams.mosaicParams[VDIS_DEV_SD])*2); //ranran we don't use this in elbit card vdisParams. enableConfigExtVideoEncoder = FALSE; vdisParams. enableConfigExtThsFilter = FALSE; Vdis_init(&vdisParams); enableFWrite = TRUE; /* Init the application specific module which will handle bitstream exchange */ /*h264 Enc: Needs to be checked for any channel where this flag is enabled, * right now just checking for channel 0, default value for other codecs is 0*/ /* ranran if(vencParams.encChannelParams[0].numTemporalLayer > 1)*/ enableLayerWrite = FALSE; /*ranran */ VcapVencVdecVdis_ipcBitsSetFileExtension("h264"); VcapVencVdecVdis_ipcBitsInit(ipcBitsChInfo, enableFWrite, enableLayerWrite , TRUE); /* Start audio capture */ /* ranran CommitDemo_startAudio(demoId); */ wallTimeBase = get_current_time_to_msec(); //wallTimeBase = 0; Vdis_setWallTimeBase(wallTimeBase); /* Configure display in order to start grpx before video */ Vsys_configureDisplay(); #if USE_FBDEV grpx_init(GRPX_FORMAT_RGB565); #endif /* Create Link instances and connects compoent blocks */ Vsys_create(); /* Start components in reverse order */ Vdis_start(); Vdec_start(); Venc_start(); Vcap_start(); printf("<<<<<<<<<< type %d channels %d res %d [ranran]\n",gDemo_info.Type,gDemo_info.maxVdisChannels,Vdis_getSwMsLayoutResolution(VDIS_DEV_HDMI)); Demo_displaySetResolution(VDIS_DEV_HDMI, VSYS_STD_XGA_60); forceLowCostScale = FALSE; startChId = 0; Demo_swMsGenerateLayout( VDIS_DEV_HDMI, startChId, gDemo_info.maxVdisChannels, layoutId, &vdMosaicParam, forceLowCostScale, gDemo_info.Type, Vdis_getSwMsLayoutResolution(VDIS_DEV_HDMI) ); //Demo_displaySwitchChn(VDIS_DEV_HDMI, startChId); Demo_displayChangeFpsForLayout(&vdMosaicParam,layoutId); Vdis_setMosaicParams(VDIS_DEV_HDMI,&vdMosaicParam); } Void CommitVcapVencVdecVdis_stop() { VSYS_PARAMS_S contextInf; Vsys_getContext(&contextInf); Vsys_enableFastUsecaseSwitch(FALSE); printf("++++++++ VcapVencVdecVdis_stop()\n"); /* Stop components */ VcapVencVdecVdis_ipcBitsStop(); Vcap_stop(); Venc_stop(); Vdec_stop(); Vdis_stop(); #if USE_FBDEV grpx_exit(); #endif Vsys_delete(); Vsys_deConfigureDisplay(); VcapVencVdecVdis_ipcBitsExit(); /* De-initialize components */ Vcap_exit(); Venc_exit(); Vdec_exit(); Vdis_exit(); Vsys_exit(); }
/******************************************************************************* * * * Copyright (c) 2009 Texas Instruments Incorporated - http://www.ti.com/ * * ALL RIGHTS RESERVED * * * ******************************************************************************/ /* ranran new file */ /* Capture (YUV422I) 1CH 720P 60fps | | | DEIH (DEI-SC YUV422I ) | | | DUP | | +--------- ---- NSF (YUV420)-----IPC-OUT(VPSS)---IPC-IN(VIDEO-M3)---ENC--IPCBITS-OUT(M3)---IPCBITS-IN(Host) | | SW Mosaic (SC5 YUV422I) | On-Chip HDMI 1080p60 */ #include "mcfw/src_linux/mcfw_api/usecases/multich_common.h" #include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h" #include "mcfw/src_linux/mcfw_api/ti_vdis_priv.h" #include "mcfw/src_linux/devices/tw2968/src/tw2968_priv.h" #include "mcfw/src_linux/devices/tvp5158/src/tvp5158_priv.h" #include "mcfw/interfaces/link_api/system_tiler.h" #include "mcfw/interfaces/link_api/avsync_hlos.h" #include "mcfw/interfaces/ti_vdis_timings.h" /* ============================================================================= * Use case code * ============================================================================= */ extern int g_portIn; static Void MultiCh_singlewin_layoutprm(SwMsLink_LayoutPrm *layoutInfo,VSYS_VIDEO_STANDARD_E outRes) { SwMsLink_LayoutWinInfo *winInfo; UInt32 outWidth, outHeight, winId, widthAlign, heightAlign; MultiCh_swMsGetOutSize(outRes, &outWidth, &outHeight); widthAlign = 8; heightAlign = 1; /* init to known default */ memset(layoutInfo, 0, sizeof(*layoutInfo)); layoutInfo->onlyCh2WinMapChanged = FALSE; layoutInfo->outputFPS = 60; layoutInfo->numWin = 1; winId = 0; winInfo = &layoutInfo->winInfo[winId]; winInfo->width = SystemUtils_floor(outWidth, widthAlign); winInfo->height = SystemUtils_floor(outHeight, heightAlign); winInfo->startX = 0; winInfo->startY = 0; winInfo->bypass = FALSE; winInfo->channelNum = 0; } #define MAX_NUM_CAPTURE_DEVICES (4) VCAP_DEVICE_CREATE_PARAM_S vidDecVideoModeArgs[MAX_NUM_CAPTURE_DEVICES]; #define NUM_CAPTURE_DEVICES 1 Void CommitCh_createHdDvr() { CaptureLink_CreateParams capturePrm; DeiLink_CreateParams deiPrm; DupLink_CreateParams dupPrm; /* ranran , dupPrm1; */ SwMsLink_CreateParams swMsPrm; DisplayLink_CreateParams displayPrm; NsfLink_CreateParams nsfPrm; CaptureLink_VipInstParams *pCaptureInstPrm; CaptureLink_OutParams *pCaptureOutPrm; EncLink_ChCreateParams *pLinkChPrm; EncLink_ChDynamicParams *pLinkDynPrm; VENC_CHN_DYNAMIC_PARAM_S *pDynPrm; VENC_CHN_PARAMS_S *pChPrm; IpcLink_CreateParams ipcOutVpssPrm; IpcLink_CreateParams ipcInVideoPrm; EncLink_CreateParams encPrm; IpcBitsOutLinkRTOS_CreateParams ipcBitsOutVideoPrm; IpcBitsInLinkHLOS_CreateParams ipcBitsInHostPrm; /* MergeLink_CreateParams mergePrm; ranran */ UInt32 grpxId[VDIS_DEV_MAX]; UInt32 dupId; /*ranran UInt32 mergeId, dupId1;*/ UInt32 deiOutQue; UInt32 ipcOutVpssId; UInt32 ipcInVideoId; UInt32 chId; int vipInstId; MULTICH_INIT_STRUCT(CaptureLink_CreateParams ,capturePrm); MULTICH_INIT_STRUCT(DeiLink_CreateParams ,deiPrm); MULTICH_INIT_STRUCT(NsfLink_CreateParams ,nsfPrm); MULTICH_INIT_STRUCT(IpcLink_CreateParams ,ipcInVideoPrm); MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams,ipcBitsOutVideoPrm); MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams,ipcBitsInHostPrm); MULTICH_INIT_STRUCT(DisplayLink_CreateParams,displayPrm); MULTICH_INIT_STRUCT(SwMsLink_CreateParams ,swMsPrm); MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm); MultiCh_detectBoard(); System_linkControl( SYSTEM_LINK_ID_M3VPSS, SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES, NULL, 0, TRUE ); //ranran #ifdef USE_CAMERA gVcapModuleContext.isPalMode = TRUE; #else gVcapModuleContext.isPalMode = FALSE; #endif capturePrm.isPalMode = Vcap_isPalMode(); printf("ranran pal mode = %d (0-ntsc, 1 - pal)\n", capturePrm.isPalMode); gVcapModuleContext.captureId = SYSTEM_LINK_ID_CAPTURE; gVcapModuleContext.nsfId[0] = SYSTEM_LINK_ID_NSF_0; gVcapModuleContext.deiId[0] = SYSTEM_LINK_ID_DEI_0; dupId = SYSTEM_VPSS_LINK_ID_DUP_0; /* ranran dupId1 = SYSTEM_VPSS_LINK_ID_DUP_1; mergeId = SYSTEM_VPSS_LINK_ID_MERGE_0; */ gVdisModuleContext.swMsId[0] = SYSTEM_LINK_ID_SW_MS_MULTI_INST_0; swMsPrm.numSwMsInst = 1; swMsPrm.swMsInstId[0] = SYSTEM_SW_MS_SC_INST_SC5; /* ranran was SYSTEM_SW_MS_SC_INST_DEI_SC */ gVdisModuleContext.displayId[0] = SYSTEM_LINK_ID_DISPLAY_0; // ON CHIP HDMI grpxId[0] = SYSTEM_LINK_ID_GRPX_0; ipcOutVpssId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0; ipcInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0; gVencModuleContext.encId = SYSTEM_LINK_ID_VENC_0; gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0; gVencModuleContext.ipcBitsOutRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0; capturePrm.numVipInst = 1; capturePrm.outQueParams[0].nextLink = gVcapModuleContext.deiId[0]; capturePrm.tilerEnable = FALSE; capturePrm.enableSdCrop = FALSE; capturePrm.fakeHdMode = FALSE; vipInstId = 0; pCaptureInstPrm = &capturePrm.vipInst[vipInstId]; //ranran printf("ranran xxxx\n"); pCaptureInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP1_PORTA; //#endif pCaptureOutPrm = &pCaptureInstPrm->outParams[0]; printf(" ranran >>>>> vipInstId=%d\n",pCaptureInstPrm->vipInstId); pCaptureInstPrm->inScanFormat = SYSTEM_SF_INTERLACED; pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_TVP5158_DRV; /* ranran set to tvp5158 */ /* DONT set it to TVP5158 */ pCaptureInstPrm->standard = SYSTEM_STD_D1; /* ranran changed from 1080I */ pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P; pCaptureOutPrm->scOutWidth = 0; pCaptureOutPrm->scOutHeight = 0; pCaptureInstPrm->videoCaptureMode = DEVICE_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC; pCaptureInstPrm->videoIfMode = SYSTEM_CAPT_VIDEO_IF_MODE_8BIT; /* ranran changed from 16 */ pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV422I_YUYV; pCaptureInstPrm->numOutput = 1; pCaptureOutPrm->scEnable = FALSE; pCaptureOutPrm->outQueId = 0; vipInstId = 1; pCaptureInstPrm = &capturePrm.vipInst[vipInstId]; pCaptureInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP0_PORTA; pCaptureOutPrm = &pCaptureInstPrm->outParams[0]; pCaptureInstPrm->inScanFormat = SYSTEM_SF_INTERLACED; pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_TVP5158_DRV; pCaptureInstPrm->standard = SYSTEM_STD_D1; pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P; pCaptureOutPrm->scOutWidth = 0; pCaptureOutPrm->scOutHeight = 0; pCaptureInstPrm->videoCaptureMode = DEVICE_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC; pCaptureInstPrm->videoIfMode = SYSTEM_CAPT_VIDEO_IF_MODE_8BIT; pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV422I_YUYV; pCaptureInstPrm->numOutput = 1; pCaptureOutPrm->scEnable = FALSE; pCaptureOutPrm->outQueId = 0; /* use ELBIT_BOARD when required to work with EVM instead of readl board. * put define in component.mk */ printf("ranran gVcapModuleContext.vcapConfig.enableConfigExtVideoDecoder is FALSE\n"); gVcapModuleContext.vcapConfig.enableConfigExtVideoDecoder = FALSE; deiOutQue = DEI_LINK_OUT_QUE_DEI_SC; deiPrm.inQueParams.prevLinkId = gVcapModuleContext.captureId; deiPrm.inQueParams.prevLinkQueId = 0; deiPrm.outQueParams[deiOutQue].nextLink = dupId; deiPrm.enableOut[deiOutQue] = TRUE; deiPrm.tilerEnable[deiOutQue] = FALSE; deiPrm.comprEnable = FALSE; deiPrm.setVipScYuv422Format = FALSE; deiPrm.enableDeiForceBypass = FALSE; /* ranran */ // deiPrm.interlacedBypassMode = TRUE; #ifdef USE_CAMERA deiPrm.inputFrameRate[deiOutQue] = 50;/*ranran was 60 */ deiPrm.outputFrameRate[deiOutQue] = 25; #else deiPrm.inputFrameRate[deiOutQue] = 60;/*ranran was 60 */ deiPrm.outputFrameRate[deiOutQue] = 30; #endif /* VIP Scalar ratio is 1:1 */ deiPrm.outScaleFactor[deiOutQue][0].scaleMode = DEI_SCALE_MODE_RATIO; deiPrm.outScaleFactor[deiOutQue][0].ratio.widthRatio.numerator = 1; deiPrm.outScaleFactor[deiOutQue][0].ratio.widthRatio.denominator = 1; deiPrm.outScaleFactor[deiOutQue][0].ratio.heightRatio.numerator = 1; deiPrm.outScaleFactor[deiOutQue][0].ratio.heightRatio.denominator = 1; for (chId=1; chId < DEI_LINK_MAX_CH; chId++) deiPrm.outScaleFactor[deiOutQue][chId] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0]; dupPrm.inQueParams.prevLinkId = gVcapModuleContext.deiId[0]; dupPrm.inQueParams.prevLinkQueId = deiOutQue; dupPrm.numOutQue = 2; dupPrm.outQueParams[0].nextLink = gVdisModuleContext.swMsId[0]; dupPrm.outQueParams[1].nextLink = gVcapModuleContext.nsfId[0]; dupPrm.notifyNextLink = TRUE; nsfPrm.bypassNsf = TRUE; /* ranran was false */ nsfPrm.tilerEnable = FALSE; nsfPrm.inQueParams.prevLinkId = dupId; nsfPrm.inQueParams.prevLinkQueId = 1; nsfPrm.numOutQue = 1; nsfPrm.outQueParams[0].nextLink = ipcOutVpssId; /* ranran gVdisModuleContext.swMsId[0]; */ /*ranran dupPrm1.inQueParams.prevLinkId = gVcapModuleContext.nsfId[0]; dupPrm1.inQueParams.prevLinkQueId = 0; dupPrm1.numOutQue = 2; dupPrm1.outQueParams[0].nextLink = mergeId; dupPrm1.outQueParams[1].nextLink = mergeId; dupPrm1.notifyNextLink = TRUE; mergePrm.numInQue = 2; mergePrm.inQueParams[0].prevLinkId = dupId1; mergePrm.inQueParams[0].prevLinkQueId = 0; mergePrm.inQueParams[1].prevLinkId = dupId1; mergePrm.inQueParams[1].prevLinkQueId = 1; mergePrm.outQueParams.nextLink = ipcOutVpssId; mergePrm.notifyNextLink = TRUE; */ swMsPrm.inQueParams.prevLinkId = dupId; swMsPrm.inQueParams.prevLinkQueId = 0; swMsPrm.outQueParams.nextLink = gVdisModuleContext.displayId[0]; swMsPrm.maxInputQueLen = SYSTEM_SW_MS_DEFAULT_INPUT_QUE_LEN; swMsPrm.maxOutRes = VSYS_STD_1080P_60; swMsPrm.initOutRes = VSYS_STD_1080P_60; swMsPrm.lineSkipMode = FALSE; swMsPrm.enableLayoutGridDraw = gVdisModuleContext.vdisConfig.enableLayoutGridDraw; MultiCh_singlewin_layoutprm(&swMsPrm.layoutPrm,swMsPrm.initOutRes); displayPrm.inQueParams[0].prevLinkId = gVdisModuleContext.swMsId[0]; displayPrm.inQueParams[0].prevLinkQueId = 0; displayPrm.displayRes = swMsPrm.initOutRes; ipcOutVpssPrm.inQueParams.prevLinkId = gVcapModuleContext.nsfId[0]; ipcOutVpssPrm.inQueParams.prevLinkQueId = 0; ipcOutVpssPrm.numOutQue = 1; ipcOutVpssPrm.outQueParams[0].nextLink = ipcInVideoId; ipcOutVpssPrm.notifyNextLink = TRUE; /* ranran was FALSE; */ ipcOutVpssPrm.notifyPrevLink = TRUE; ipcOutVpssPrm.noNotifyMode = FALSE; /* ranran was TRUE; */ ipcInVideoPrm.inQueParams.prevLinkId = ipcOutVpssId; ipcInVideoPrm.inQueParams.prevLinkQueId = 0; ipcInVideoPrm.numOutQue = 1; ipcInVideoPrm.outQueParams[0].nextLink = gVencModuleContext.encId; ipcInVideoPrm.notifyNextLink = TRUE; ipcInVideoPrm.notifyPrevLink = TRUE; /* ranran was FALSE; */ ipcInVideoPrm.noNotifyMode = FALSE; /* was TRUE; */ ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId; ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0; ipcBitsOutVideoPrm.baseCreateParams.numOutQue = 1; ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId; MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoPrm, TRUE); ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId; ipcBitsInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0; ipcBitsInHostPrm.baseCreateParams.numOutQue = 1; ipcBitsInHostPrm.baseCreateParams.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID; MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm); EncLink_CreateParams_Init(&encPrm); /* ranran added */ encPrm.inQueParams.prevLinkId = ipcInVideoId; encPrm.inQueParams.prevLinkQueId= 0; encPrm.outQueParams.nextLink = gVencModuleContext.ipcBitsOutRTOSId; pLinkChPrm = &encPrm.chCreateParams[0]; pLinkDynPrm = &pLinkChPrm->defaultDynamicParams; pChPrm = &gVencModuleContext.vencConfig.encChannelParams[0]; pDynPrm = &pChPrm->dynamicParam; encPrm.numBufPerCh[0] = 6; encPrm.numBufPerCh[1] = 6; encPrm.numBufPerCh[2] = 6; pLinkChPrm->format = IVIDEO_H264HP; pLinkChPrm->profile = gVencModuleContext.vencConfig.h264Profile[0]; pLinkChPrm->dataLayout = VCODEC_FIELD_SEPARATED; pLinkChPrm->fieldMergeEncodeEnable = FALSE; pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo; pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking; pLinkChPrm->maxBitRate = pChPrm->maxBitRate; pLinkChPrm->encodingPreset = pChPrm->encodingPreset; pLinkChPrm->rateControlPreset = pChPrm->rcType; pLinkChPrm->enableSVCExtensionFlag = pChPrm->enableSVCExtensionFlag; pLinkChPrm->numTemporalLayer = pChPrm->numTemporalLayer; pLinkDynPrm->intraFrameInterval = pDynPrm->intraFrameInterval; pLinkDynPrm->targetBitRate = pDynPrm->targetBitRate; pLinkDynPrm->interFrameInterval = 1; pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL; pLinkDynPrm->inputFrameRate = pDynPrm->inputFrameRate; pLinkDynPrm->rcAlg = pDynPrm->rcAlg; pLinkDynPrm->qpMin = pDynPrm->qpMin; pLinkDynPrm->qpMax = pDynPrm->qpMax; pLinkDynPrm->qpInit = pDynPrm->qpInit; pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration; pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity; /* same params for 2nd channel */ encPrm.chCreateParams[1] = encPrm.chCreateParams[0]; System_linkCreate (gVcapModuleContext.captureId, &capturePrm, sizeof(capturePrm)); System_linkCreate(gVcapModuleContext.deiId[0] , &deiPrm, sizeof(deiPrm)); System_linkCreate(dupId, &dupPrm, sizeof(dupPrm)); System_linkCreate(gVcapModuleContext.nsfId[0] , &nsfPrm, sizeof(nsfPrm)); /* ranran System_linkCreate(dupId1, &dupPrm1, sizeof(dupPrm1)); System_linkCreate(mergeId , &mergePrm , sizeof(mergePrm)); */ System_linkCreate(ipcOutVpssId , &ipcOutVpssPrm , sizeof(ipcOutVpssPrm) ); System_linkCreate(ipcInVideoId , &ipcInVideoPrm , sizeof(ipcInVideoPrm) ); System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm)); System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm)); System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm, sizeof(ipcBitsInHostPrm)); System_linkCreate(gVdisModuleContext.swMsId[0] , &swMsPrm, sizeof(swMsPrm)); System_linkCreate(gVdisModuleContext.displayId[0], &displayPrm, sizeof(displayPrm)); MultiCh_memPrintHeapStatus(); Vdis_sysfsCmd(3, VDIS_SYSFSCMD_SET_GRPX, VDIS_SYSFS_GRPX0, VDIS_OFF); Vdis_sysfsCmd(3, VDIS_SYSFSCMD_SET_GRPX, VDIS_SYSFS_GRPX1, VDIS_OFF); } Void CommitCh_deleteHdDvr() { UInt32 grpxId[VDIS_DEV_MAX]; UInt32 dupId; /* ranran , dupId1, mergeId;*/ UInt32 ipcOutVpssId; UInt32 ipcInVideoId; gVcapModuleContext.captureId = SYSTEM_LINK_ID_CAPTURE; gVcapModuleContext.nsfId[0] = SYSTEM_LINK_ID_NSF_0; gVcapModuleContext.deiId[0] = SYSTEM_LINK_ID_DEI_0; dupId = SYSTEM_VPSS_LINK_ID_DUP_0; /*ranran dupId1 = SYSTEM_VPSS_LINK_ID_DUP_1; mergeId = SYSTEM_VPSS_LINK_ID_MERGE_0;*/ gVdisModuleContext.swMsId[0] = SYSTEM_LINK_ID_SW_MS_MULTI_INST_0; gVdisModuleContext.displayId[0] = SYSTEM_LINK_ID_DISPLAY_0; // ON CHIP HDMI grpxId[0] = SYSTEM_LINK_ID_GRPX_0; ipcOutVpssId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0; ipcInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0; gVencModuleContext.encId = SYSTEM_LINK_ID_VENC_0; gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0; gVencModuleContext.ipcBitsOutRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0; System_linkDelete(gVcapModuleContext.captureId); System_linkDelete(gVcapModuleContext.deiId[0]); System_linkDelete(dupId); /*ranran System_linkDelete(dupId1); System_linkDelete(mergeId);*/ System_linkDelete(gVdisModuleContext.swMsId[0] ); System_linkDelete(gVdisModuleContext.displayId[0]); System_linkDelete(gVcapModuleContext.nsfId[0]); System_linkDelete(ipcOutVpssId); System_linkDelete(ipcInVideoId); System_linkDelete(gVencModuleContext.encId); System_linkDelete(gVencModuleContext.ipcBitsInHLOSId); System_linkDelete(gVencModuleContext.ipcBitsOutRTOSId); /* Print the HWI, SWI and all tasks load */ /* Reset the accumulated timer ticks */ MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE); } /* Dummy functions */ Int32 CommitCh_hdDvrSetCapDynamicParamChn(VCAP_CHN vcChnId, VCAP_CHN_DYNAMIC_PARAM_S *psCapChnDynaParam, VCAP_PARAMS_E paramId) { vcChnId = vcChnId; psCapChnDynaParam = psCapChnDynaParam; paramId = paramId; return 0; } Int32 CommitCh_hdDvrGetCapDynamicParamChn(VCAP_CHN vcChnId, VCAP_CHN_DYNAMIC_PARAM_S *psCapChnDynaParam, VCAP_PARAMS_E paramId) { vcChnId = vcChnId; psCapChnDynaParam = psCapChnDynaParam; paramId = paramId; return 0; } Int32 CommitCh_hdDvrSetCapFrameRate(VCAP_CHN vcChnId, VCAP_STRM vcStrmId, Int32 inputFrameRate, Int32 outputFrameRate) { vcChnId = vcChnId; vcStrmId = vcStrmId; inputFrameRate = outputFrameRate; return 0; } Int32 CommitCh_hdDvrEnableDisableCapChn(VCAP_CHN vcChnId, VCAP_STRM vcStrmId, Bool enableChn) { vcChnId = vcChnId; vcStrmId = vcStrmId; enableChn = enableChn; return 0; } void CommitCh_hdDvrSwmsChReMap(VDIS_MOSAIC_S *psVdMosaicParam) { psVdMosaicParam = psVdMosaicParam; }
