DM365 Resizer
Hi All,
I am trying to run the resizer demo "do_resizer_420.c".
The application is running successfully, but I am getting the output as some junk data instead of resized image.
The input format to the resizer is YUV 4:2:2 (UYVY) and output format is YUV 4:2:0 semiplanar.
I am attaching the demo application that I am using.
Kindly let me know, how to use this resizer application.
Raghavendra
#include <stdio.h>
#include <sys/types.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
#include <sys/mman.h>
#include <getopt.h>
#include <sys/time.h>
#include <asm-arm/arch-davinci/imp_previewer.h>
#include <asm-arm/arch-davinci/imp_resizer.h>
#include <asm-arm/arch-davinci/dm365_ipipe.h>
char dev_name_rsz[1][30] = {"/dev/davinci_resizer"};
void usage()
    printf("Usage:do_preview -i file -o file \n");
#define MAX_WIDTH  176
#define MAX_HEIGHT  144
#define BYTESPERLINE 2
#define INPUT_HEIGHT 144
#define INPUT_WIDTH 176
#define OUTPUT_WIDTH  80
#define OUTPUT_HEIGHT 80
#define BUF_SIZE ((1280*720) + (1280*360) + 32)
char in_buf[MAX_WIDTH*MAX_HEIGHT*BYTESPERLINE];
int main(int argc, char *argp[])
    char shortoptions[] = "i:o:w:h:t:";
    int mode = O_RDWR,c,ret,index;
    int preview_fd, resizer_fd, dev_idx;
    unsigned long oper_mode, user_mode, driver_mode;
    struct prev_channel_config prev_chan_config;
    struct prev_single_shot_config prev_ss_config; // single shot mode configuration
    struct rsz_channel_config rsz_chan_config; // resizer channel config
    struct rsz_single_shot_config rsz_ss_config; // single shot mode configuration
    struct prev_cap cap;
    struct prev_module_param mod_param;
    struct prev_wb wb_params;
    struct imp_reqbufs req_buf;
    struct imp_buffer buf_in[3];
    struct imp_buffer buf_out1[3];
    struct imp_convert convert;
    int i,j;
    char in_file[100], out_file[100];
    FILE *inp_f, *outp_f;
    int width = 0, height = 0, size;
    char *input_buffer, *output_buffer;
    int in_format=0;
    unsigned long level;
    short byte=0;
    char *src, *dest;
    for(;;) {
        c = getopt_long(argc, argp, shortoptions, NULL, (void *)&index);
        if(-1 == c)
            break;
        switch(c) {
            case 'i':
                strcpy(in_file,optarg);
                break;
            case 'o':
                strcpy(out_file,optarg);
                break;
            case 'w':
                width = atoi(optarg);
                break;
            case 'h':
                height = atoi(optarg);
                break;
            case 't':
                in_format = atoi(optarg);
                break;
            default:
                usage();
                exit(1);
    printf("doing preview & resize on in_file = %s and writing out to out_file = %s\n",in_file,out_file);
    oper_mode = IMP_MODE_SINGLE_SHOT;
    printf("starting\n");
    inp_f = fopen(in_file, "rb");
    if (inp_f == NULL) {
        perror("Error in opening input file \n");
        exit(1);
    outp_f = fopen(out_file, "wb");
    if (outp_f == NULL) {
        perror("Error in opening output file \n");
        exit(1);
    size = fread(in_buf,1, (INPUT_WIDTH * INPUT_HEIGHT * BYTESPERLINE), inp_f);
    if (size != (INPUT_WIDTH * INPUT_HEIGHT * BYTESPERLINE)) {
        perror("mismatch between file size and  INPUT_WIDTH * INPUT_HEIGHT * 2\n");
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
// Setup resizer
    /* Open the resizer */
    printf("Configuring resizer in the chain mode\n");
    printf("Opening resizer device, %s\n",dev_name_rsz[0]);
    resizer_fd = open((const char *)dev_name_rsz[0], mode);
    if(resizer_fd <= 0) {
        printf("Cannot open resizer device\n");
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    if (ioctl(resizer_fd,RSZ_S_OPER_MODE, &oper_mode) < 0) {
        perror("Can't get operation mode\n");
        fclose(inp_f);
        fclose(outp_f);
        close(resizer_fd);
        exit(1);
    if (ioctl(resizer_fd,RSZ_G_OPER_MODE, &oper_mode) < 0) {
        fclose(inp_f);
        fclose(outp_f);
        close(resizer_fd);
        exit(1);
    printf("RESIZER: Operating mode changed successfully to");
    if (oper_mode == IMP_MODE_SINGLE_SHOT)
        printf(" %s", "Single Shot\n");
    else
        printf(" %s", "Continuous\n");
    printf("Setting default configuration in Resizer\n");
    bzero(&rsz_ss_config, sizeof(struct rsz_single_shot_config));
    rsz_chan_config.oper_mode = IMP_MODE_SINGLE_SHOT;
    rsz_chan_config.chain = 0;
    rsz_chan_config.len = 0;
    rsz_chan_config.config = NULL; /* to set defaults in driver */
    if (ioctl(resizer_fd, RSZ_S_CONFIG, &rsz_chan_config) < 0) {
        perror("Error in setting default configuration for single shot mode\n");
        fclose(inp_f);
        fclose(outp_f);
        close(resizer_fd);
        exit(1);
    printf("default configuration setting in Resizer successfull\n");
    rsz_chan_config.len = sizeof(struct rsz_single_shot_config);
    rsz_chan_config.config = &rsz_ss_config;
    if (ioctl(resizer_fd, RSZ_G_CONFIG, &rsz_chan_config) < 0) {
        perror("Error in getting resizer channel configuration from driver\n");
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    // in the chain mode only output configurations are valid
    // input params are set at the previewer
    rsz_ss_config.input.image_width = INPUT_WIDTH;
    rsz_ss_config.input.image_height = INPUT_HEIGHT;
    rsz_ss_config.input.ppln = rsz_ss_config.input.image_width + 8;
    rsz_ss_config.input.lpfr = rsz_ss_config.input.image_height + 10;
    rsz_ss_config.input.pix_fmt = IPIPE_UYVY;
    rsz_ss_config.output1.pix_fmt = IPIPE_YUV420SP;
    rsz_ss_config.output1.enable = 1;
    rsz_ss_config.output1.width = OUTPUT_WIDTH;
    rsz_ss_config.output1.height = OUTPUT_HEIGHT;
    rsz_ss_config.output2.enable = 0;
        fclose(inp_f);
        fclose(outp_f);
        close(resizer_fd);
        exit(1);
    // read again and verify
        perror("Error in getting configuration from driver\n");
        fclose(inp_f);
        fclose(outp_f);
        close(resizer_fd);
        exit(1);
    //Request buffer
    req_buf.buf_type = IMP_BUF_IN;
    req_buf.size = (INPUT_WIDTH * INPUT_HEIGHT * BYTESPERLINE);
    req_buf.count = 1;
    if (ioctl(resizer_fd, RSZ_REQBUF, &req_buf) < 0) {
        perror("Error in PREV_REQBUF for IMP_BUF_IN\n");
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    for (i = 0; i < 1; i++) {
        buf_in[i].index = i;
        buf_in[i].buf_type = IMP_BUF_IN;
        if (ioctl(resizer_fd, RSZ_QUERYBUF, &buf_in[i]) < 0) {
            perror("Error in PREV_QUERYBUF for IMP_BUF_IN\n");
            close(resizer_fd);
            fclose(inp_f);
            fclose(outp_f);
            exit(1);
    printf("PREV_QUERYBUF successful for IMP_BUF_IN\n");
    req_buf.buf_type = IMP_BUF_OUT1;
    req_buf.size = (OUTPUT_WIDTH*OUTPUT_HEIGHT*BYTESPERLINE);
    req_buf.count = 1;
        perror("Error in PREV_REQBUF for IMP_BUF_OUT1\n");
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
        buf_out1[i].index = i;
        buf_out1[i].buf_type = IMP_BUF_OUT1;
        if (ioctl(resizer_fd, RSZ_QUERYBUF, &buf_out1[i]) < 0) {
            perror("Error in PREV_QUERYBUF for IMP_BUF_OUT1\n");
            close(resizer_fd);
            fclose(inp_f);
            fclose(outp_f);
            exit(1);
    printf("PREV_QUERYBUF successful for IMP_BUF_OUT1\n");
    input_buffer = mmap(
            NULL,buf_in[0].size,
            PROT_READ|PROT_WRITE,
            MAP_SHARED,
            resizer_fd,
            buf_in[0].offset);
    printf("input offset = %x\n", buf_in[0].offset);
    if (input_buffer == MAP_FAILED) {
        perror("Error in MMAP\n");
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    output_buffer = mmap(
            NULL,buf_out1[0].size,
            MAP_SHARED,
            resizer_fd,
            buf_out1[0].offset);
    printf("output offset = %x\n", buf_out1[0].offset);
    if (output_buffer == MAP_FAILED) {
        munmap(input_buffer, buf_in[0].size);
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    bzero(&convert,sizeof(convert));
    memcpy(input_buffer,in_buf,(INPUT_WIDTH*INPUT_HEIGHT*BYTESPERLINE));
    convert.in_buff.buf_type = IMP_BUF_IN;
    convert.in_buff.index = 0;
    convert.in_buff.offset = buf_in[0].offset;
    convert.in_buff.size = buf_in[0].size;
    convert.out_buff1.buf_type = IMP_BUF_OUT1;
    convert.out_buff1.index = 0;
    convert.out_buff1.offset = buf_out1[0].offset;
    convert.out_buff1.size = buf_out1[0].size;
    printf("\n size = ", buf_out1[0].size);
    bzero(output_buffer,(OUTPUT_WIDTH*OUTPUT_HEIGHT*1.5));
    if (ioctl(resizer_fd, RSZ_RESIZE, &convert) < 0) {
        perror("Error in doing preview\n");
        munmap(output_buffer, buf_out1[0].size);
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    size = (OUTPUT_WIDTH * OUTPUT_HEIGHT ) + ( OUTPUT_WIDTH * OUTPUT_HEIGHT/2 );
    if (fwrite(output_buffer,1,size,outp_f) != (
            size)) {
        perror("Error in doing resize\n");
        close(resizer_fd);
        fclose(inp_f);
        fclose(outp_f);
        exit(1);
    if (!close(resizer_fd))
        printf("resizer closed successfully\n");
    else
        printf("Error in closing resizer\n");
    fclose(inp_f);
    fclose(outp_f);
    return 0;
