In the PLL documnet SPRUGV2F it said the PREDIV is not implemented. How about the POSTDIV? There is a postdiv register in the document, but which one it is in the PLL and PLL Controller Bolck Diagram (page 1-1, Figure 1-1)? Maybe OUTPUT DIVIDE?
GanZ
GanZ
Hello GanZ,
Sorry for the misinterpretation.
As mentioned in the revision history of SPRUGV2F, the POSTDIV register has been removed in revision B itself. There is a documentation bug as the POSTDIV register content is not removed yet. Hopefully it will be corrected in the next revision.
The OUTPUT DIVIDE is a part of SECCTL register (Bits 19:22).
Senthil
Senthill,
Thanks for the Clatification.
I have a following up question. In map file used by romparse utility there are three sw_pll parameters
sw_pll_prediv, sw_pll_premult, sw_pll_postdiv. Is sw_pll_premult correspondind to PLLM? How about sw_pll_prediv and sw_pll_postdiv? Which one is used to set PLLD?
GanZ
Hello GanZ,
I believe the sw_pll_parameter is for PLLM and sw_pll_prediv parameter is for PLLD. The sw_pll_postdiv is not applicable for Keystone1 devices as their PLL controller doesn't have POSTDIV block.
Senthil
