TI DRA7xxx EVM (J6 EVM) : Error in repo sync - Android Filesystem Sources
I am following the instructions mentioned in - http://omapedia.org/wiki/6AK.1.2_Release_Notes , to download and build Android File System.
When doing a - repo sync,  every time I am getting following error :-
Fetching projects: 99% (416/420) fatal: unable to connect to git.ti.com:
git.ti.com[0: 198.47.29.193]: errno=Connection refused
error: Cannot fetch wilink8-wlan/hostap
error: Cannot fetch ipc/ipcdev
error: Exited sync due to fetch errors
Can some one throw light on this problem? Is that IP down?
Souvik
  • Hello Souvik,
    It seems that you have problems with your proxy configurations. I have access and does not observe such errors to 6AK1.2.
    Could check your git settings in .gitconfig file?
    Did you apply following steps before downloading 6AK.1.2 Release?
    • Proxy/Firewall
    If you are behind proxy/firewall, workaround it using the instructions in [1]
    For installing repo make sure you also export https_proxy environment variable.
    export https_proxy=<local_site_proxy_server> eg: http://local.proxyserver.com:80
    • Install latest repo tool
    mkdir ~/bin -p
    sudo apt-get install curl
    curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
    chmod a+x ~/bin/repo
    export PATH=~/bin:$PATH
    Yanko
