quesion about omx nf component
My qusition is that my input video is 1920* 1080 yuv422,and I want to chage it to nv12. so I use the Nf component.but I find that sometimes there will be get a green frame. how to solve it?
the set omx nf code is under this: the m_inWidth =1920, the m_inHeight=1080.
bool setNfParams() {
if (NULL == m_pNfHandle) {
return false;
OMX_ERRORTYPE eError = OMX_ErrorNone;
OMX_PARAM_BUFFER_MEMORYTYPE memTypeCfg;
OMX_PARAM_PORTDEFINITIONTYPE paramPort;
OMX_PARAM_VFPC_NUMCHANNELPERHANDLE sNumChPerHandle;
OMX_CONFIG_ALG_ENABLE algEnable;
OMX_CONFIG_VIDCHANNEL_RESOLUTION chResolution;
OMX_INIT_PARAM(&memTypeCfg);
memTypeCfg.nPortIndex = OMX_VFPC_INPUT_PORT_START_INDEX;
memTypeCfg.eBufMemoryType = OMX_BUFFER_MEMORY_DEFAULT;
eError = OMX_SetParameter (m_pNfHandle, (OMX_INDEXTYPE)OMX_TI_IndexParamBuffMemType, &memTypeCfg);
if (eError != OMX_ErrorNone) {
printf("failed to set memory Type at input port\n");
return false;
/* Setting Memory type at output port to Raw Memory */
memTypeCfg.nPortIndex = OMX_VFPC_OUTPUT_PORT_START_INDEX;
printf("failed to set memory Type at output port\n");
return false;
/* set input height/width and color format */
OMX_INIT_PARAM(&paramPort);
paramPort.nPortIndex = OMX_VFPC_INPUT_PORT_START_INDEX;
OMX_GetParameter(m_pNfHandle, OMX_IndexParamPortDefinition, &paramPort);
paramPort.format.video.nFrameWidth = UTIL_ALIGN(m_inWidth, 32);
paramPort.format.video.nFrameHeight = UTIL_ALIGN(m_inHeight, 32);
paramPort.format.video.nStride = UTIL_ALIGN(m_inWidth * 2, 32);
paramPort.format.video.eCompressionFormat = OMX_VIDEO_CodingUnused;
paramPort.format.video.eColorFormat = OMX_COLOR_FormatYCbYCr;
paramPort.nBufferSize = (paramPort.format.video.nStride * paramPort.format.video.nFrameHeight);
paramPort.nBufferAlignment = 0;
paramPort.bBuffersContiguous = OMX_FALSE;
paramPort.nBufferCountActual = KOtherComponentInOutPutNum;
OMX_SetParameter(m_pNfHandle, OMX_IndexParamPortDefinition, &paramPort);
/* set output height/width and color format */
paramPort.nPortIndex = OMX_VFPC_OUTPUT_PORT_START_INDEX;
paramPort.format.video.eColorFormat = OMX_COLOR_FormatYUV420SemiPlanar;
paramPort.format.video.nStride = UTIL_ALIGN(m_inWidth, 32);
paramPort.nBufferSize = (paramPort.format.video.nStride * paramPort.format.video.nFrameHeight * 3) >> 1;
OMX_INIT_PARAM(&sNumChPerHandle);
sNumChPerHandle.nNumChannelsPerHandle = 1;
eError = OMX_SetParameter (m_pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexParamVFPCNumChPerHandle, &sNumChPerHandle);
printf("failed to set num of channels\n");
return false;
/* set VFPC input and output resolution information */
printf("set input resolution \n");
OMX_INIT_PARAM(&chResolution);
chResolution.Frm0Width = UTIL_ALIGN(m_inWidth, 32);
chResolution.Frm0Height = UTIL_ALIGN(m_inHeight, 32);
chResolution.Frm0Pitch = UTIL_ALIGN(m_inWidth * 2, 32);
chResolution.Frm1Width = 0;
chResolution.Frm1Height = 0;
chResolution.Frm1Pitch = 0;
chResolution.FrmStartX = 0;
chResolution.FrmStartY = 0;
chResolution.FrmCropWidth = m_inWidth;
chResolution.FrmCropHeight = m_inHeight;
chResolution.eDir = OMX_DirInput;
chResolution.nChId = 0;
eError = OMX_SetConfig (m_pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexConfigVidChResolution, &chResolution);
printf("failed to set input channel resolution\n");
printf("set output resolution \n");
chResolution.Frm0Pitch = UTIL_ALIGN(m_inWidth, 32);
chResolution.eDir = OMX_DirOutput;
printf("failed to set output channel resolution\n");
return false;
/* disable algo bypass mode */
OMX_INIT_PARAM(&algEnable);
algEnable.nPortIndex = 0;
algEnable.nChId = 0;
algEnable.bAlgBypass = OMX_FALSE;
eError = OMX_SetConfig (m_pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexConfigAlgEnable, &algEnable);
return true;
and the empty this buffer is like this:
int size = 1920*1080*2;
read(InportParamsPtr->ipBufPipe[0], &pBufferIn, sizeof(pBufferIn));
OMX_PTR pTempPhyAddr = (OMX_PTR) DomxCore_mapUsrVirtualAddr2phy( (uint32_t) pBufferIn->pBuffer);
m_pKernel->getEdmaInstance()->copy((unsigned char*)pTempPhyAddr, pPhyAddr,
m_inWidth * 2, m_inWidth * 2, size, 1);
pBufferIn->nFilledLen = size;
err = OMX_EmptyThisBuffer (m_pNfHandle, pBufferIn);
Thanks for your reply!!
