VoLIB TDU (DTMF+CP)
Hi there,
I am trying to make TDU identify three CP tones (dial tone, ringback and busy tone). Actually initial target is DTMF and CP detection together.
DTMF and CP detection works well but separately. However when I add dtmf between dial tone and ringback TDU cannot identify ringback properly. But other CP tones are detected without problems.
My audio tests are (8khz, 16-bit, u-law)
1. dialtone.pcm - fine
2. ringback.pcm - fine
3. busytone.pcm - fine
4. cp_full.pcm (dial, ringtone, busy) - fine
5. dtmf_cp.pcm (dial, dtmf, ringtone, busy) - ringtone is missed.
Question:
1. Is it possible to detect DTMF and CP tones with one TDU instance?
2. If so how to adjust TDU properly?
For test I am using TDU demo (Volib 2_1_0_1)
My settings:
  tbool overwrite_scr;       /* FALSE: Overwrite scratch buffers between calls */
tduSim.cfgCtl.u.cpt.startFreq = 300; tduSim.cfgCtl.u.cpt.endFreq = 700; tduControl (tduInst, tdu_CTL_CPT_ON, &tduSim.cfgCtl);
  • Stan,
    Your question does not seem to be TI-RTOS related.
    Are you using VoLib?  On which device?
  • I am using DSP/BIOS on 5535 core. The question is for VoLIB performance. If there is another place to post this question please suggest it.
    Thank you.
  • Stan,
    I have escalated your issue to a domain expert.  But he may not be able to respond for a few days...
  • Hi David,
    Thanks a lot. It is ok I can wait.
  • Stan,
    Can you send me the tone PCM examples you mentioned for us analysis?
    Regards, Eric
  • Hi, Eric
    Thank you for reply.
    Here is a pcm file I am interested to detect. It is a sequence  of dial-tone -> dtmf number -> ring-back ->busy tone. Actually I was unable to detect all events properly in this file.
    16-bit, mono, Fs-8000Hz, u-law.
    6471.TDU_TEST_FULL.zip
  • Hello Eric,
    Did you try to detect CP events from the file? The topic is still relevant for me.
    Thank you
  • With your file, I only have 10 digits detected. No other tones, let me know what is your observation.
    Regarsd, Eric
  • Here is the detection report:
    test started .....
    Tone: CPT : Event: ON, Time: 140 ms, Power: -10 dBm0, Frame: 178
    Tone: CPT : Event: OFF, Time: 0 ms, Power: -46 dBm0, Frame: 486
    Digit: "3" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 610
    Digit: "3" : Event: ON, Time: 30 ms, Power: -15 dBm0, Frame: 614
    Digit: "3" : Event: OFF, Time: 20 ms, Power: -1044 dBm0, Frame: 628
    Digit: "0" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 636
    Digit: "0" : Event: ON, Time: 30 ms, Power: -13 dBm0, Frame: 640
    Digit: "0" : Event: OFF, Time: 20 ms, Power: -1072 dBm0, Frame: 654
    Digit: "1" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 662
    Digit: "1" : Event: ON, Time: 30 ms, Power: -14 dBm0, Frame: 666
    Digit: "1" : Event: OFF, Time: 20 ms, Power: -1064 dBm0, Frame: 680
    Digit: "9" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 688
    Digit: "9" : Event: ON, Time: 30 ms, Power: -14 dBm0, Frame: 692
    Digit: "9" : Event: OFF, Time: 20 ms, Power: -1033 dBm0, Frame: 706
    Digit: "4" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 714
    Digit: "4" : Event: ON, Time: 30 ms, Power: -13 dBm0, Frame: 718
    Digit: "4" : Event: OFF, Time: 20 ms, Power: -1024 dBm0, Frame: 732
    Digit: "2" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 740
    Digit: "2" : Event: ON, Time: 30 ms, Power: -14 dBm0, Frame: 744
    Digit: "2" : Event: OFF, Time: 20 ms, Power: -1050 dBm0, Frame: 758
    Digit: "6" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 766
    Digit: "6" : Event: ON, Time: 30 ms, Power: -14 dBm0, Frame: 770
    Digit: "6" : Event: OFF, Time: 20 ms, Power: -1072 dBm0, Frame: 784
    Digit: "8" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 792
    Digit: "8" : Event: ON, Time: 30 ms, Power: -13 dBm0, Frame: 796
    Digit: "8" : Event: OFF, Time: 20 ms, Power: -1024 dBm0, Frame: 810
    Digit: "7" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 818
    Digit: "7" : Event: ON, Time: 30 ms, Power: -13 dBm0, Frame: 822
    Digit: "7" : Event: OFF, Time: 20 ms, Power: -1038 dBm0, Frame: 836
    Digit: "5" : Event: ALERT ON, Time: 15 ms, Power: -83 dBm0, Frame: 844
    Digit: "5" : Event: ON, Time: 30 ms, Power: -14 dBm0, Frame: 848
    Digit: "5" : Event: OFF, Time: 20 ms, Power: -1024 dBm0, Frame: 862
    Tone: CPT : Event: ON, Time: 140 ms, Power: -15 dBm0, Frame: 1263
    Tone: CPT : Event: ON, Time: 20 ms, Power: -9 dBm0, Frame: 1271
    Tone: CPT : Event: OFF, Time: 0 ms, Power: -49 dBm0, Frame: 1639
    Tone: CPT : Event: ON, Time: 140 ms, Power: -15 dBm0, Frame: 2463
    Tone: CPT : Event: ON, Time: 20 ms, Power: -9 dBm0, Frame: 2471
    Tone: CPT : Event: OFF, Time: 0 ms, Power: -49 dBm0, Frame: 2839
    Tone: CPT : Event: ON, Time: 140 ms, Power: -9 dBm0, Frame: 3665
    Tone: CPT : Event: OFF, Time: 0 ms, Power: -50 dBm0, Frame: 4039
    Tone: CPT : Event: ON, Time: 140 ms, Power: -10 dBm0, Frame: 4462
    Tone: CPT : Event: OFF, Time: 0 ms, Power: -49 dBm0, Frame: 4540
    So, any tones after 23 seconds (the last 3 tones) are not detected. My previous update was wrong.
    What is your observation?
    Regards, Eric
  • Eric,
    Thank you for update.
    With settings mentioned above I have this log:
    Tone: CPT : Event: ON, Time: 140 ms, Power: -10 dBm0, Frame: 184
    Tone: CPT : Event: OFF, Time: 0 ms, Power: -65 dBm0, Frame: 486
    Digit: "3" : Event: OFF, Time: 20 ms, Power: -1168 dBm0, Frame: 627
    Digit: "0" : Event: OFF, Time: 20 ms, Power: -1283 dBm0, Frame: 654
    Digit: "1" : Event: OFF, Time: 20 ms, Power: -1168 dBm0, Frame: 680
    Digit: "9" : Event: OFF, Time: 20 ms, Power: -1140 dBm0, Frame: 706
    Digit: "4" : Event: OFF, Time: 20 ms, Power: -1056 dBm0, Frame: 732
    Digit: "2" : Event: OFF, Time: 20 ms, Power: -1140 dBm0, Frame: 757
    Digit: "6" : Event: OFF, Time: 20 ms, Power: -1283 dBm0, Frame: 783
    Digit: "8" : Event: OFF, Time: 20 ms, Power: -1104 dBm0, Frame: 810
    Digit: "7" : Event: OFF, Time: 20 ms, Power: -1120 dBm0, Frame: 836
    Digit: "5" : Event: OFF, Time: 20 ms, Power: -1104 dBm0, Frame: 862
    So somehow my result even worse at the end.
  • And one more interesting thing. I have another pcm file where all tones (events) are successfully detected.  It consists of  the same tones but their order is different (ringback ->dialtone-> busytone-> dtmf). There is a small fake detect, but the rest is fine.
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power:  -7 dBm0,  Frame: 662
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -42 dBm0,  Frame: 1038
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power: -11 dBm0,  Frame: 1863
     Tone: CPT     :  Event:  ON,  Time:   20 ms,  Power:  -5 dBm0,  Frame: 1871  ----- STRANGE
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -48 dBm0,  Frame: 2239
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power:  -7 dBm0,  Frame: 3062
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -44 dBm0,  Frame: 3438
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power: -10 dBm0,  Frame: 4324
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -65 dBm0,  Frame: 4626
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power:  -6 dBm0,  Frame: 5301
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -51 dBm0,  Frame: 5379
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power:  -6 dBm0,  Frame: 5501
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -47 dBm0,  Frame: 5579
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power:  -6 dBm0,  Frame: 5701
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -46 dBm0,  Frame: 5779
     Tone: CPT     :  Event:  ON,  Time:  140 ms,  Power:  -6 dBm0,  Frame: 5902
     Tone: CPT     :  Event: OFF,  Time:    0 ms,  Power: -47 dBm0,  Frame: 5978
     Digit: "3"     :  Event: ALERT  ON,  Time:   20 ms,  Power: -83 dBm0,  Frame: 6071
     Digit: "3"     :  Event:  ON,  Time:   30 ms,  Power: -22 dBm0,  Frame: 6074
     Digit: "3"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6087
     Digit: "0"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6096
     Digit: "0"     :  Event:  ON,  Time:   30 ms,  Power: -20 dBm0,  Frame: 6100
     Digit: "0"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6113
     Digit: "1"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6122
     Digit: "1"     :  Event:  ON,  Time:   30 ms,  Power: -21 dBm0,  Frame: 6126
     Digit: "1"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6139
     Digit: "9"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6148
     Digit: "9"     :  Event:  ON,  Time:   30 ms,  Power: -21 dBm0,  Frame: 6152
     Digit: "9"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6165
     Digit: "4"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6174
     Digit: "4"     :  Event:  ON,  Time:   30 ms,  Power: -20 dBm0,  Frame: 6178
     Digit: "4"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6191
     Digit: "2"     :  Event: ALERT  ON,  Time:   20 ms,  Power: -83 dBm0,  Frame: 6201
     Digit: "2"     :  Event:  ON,  Time:   30 ms,  Power: -22 dBm0,  Frame: 6204
     Digit: "2"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6217
     Digit: "6"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6226
     Digit: "6"     :  Event:  ON,  Time:   30 ms,  Power: -22 dBm0,  Frame: 6230
     Digit: "6"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6243
     Digit: "8"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6252
     Digit: "8"     :  Event:  ON,  Time:   30 ms,  Power: -20 dBm0,  Frame: 6256
     Digit: "8"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6269
     Digit: "7"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6278
     Digit: "7"     :  Event:  ON,  Time:   30 ms,  Power: -20 dBm0,  Frame: 6282
     Digit: "7"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6295
     Digit: "5"     :  Event: ALERT  ON,  Time:   15 ms,  Power: -83 dBm0,  Frame: 6304
     Digit: "5"     :  Event:  ON,  Time:   30 ms,  Power: -21 dBm0,  Frame: 6308
     Digit: "5"     :  Event: OFF,  Time:   20 ms,  Power: -1283 dBm0,  Frame: 6321
    3438.st_test.zip
  • Can you specify what is the platform? C55x, C64x+, C66x? COFF or ELF? Rel 2.1.0.1?
  • For testing purposes I am using TMS320C5515EVM.
    So it is:
    CCS 5.5,
    C5515,
    COFF,
    volib_C55_2_1_0_1 CPU3
  • IN the previous test, I used C66x package. Then I tried C55x volib_C55_2_1_0_1 CPU3, I saw the same issue as you did. I will open a ticket and track it.
    Regards, Eric
  • Many thanks) I appreciate it.
  • Hi Eric,
    Is there any news?
  • Stan,
    I haven't get any update when this can be fixed yet. As you might know, the last VoLIB was released in 2013, it was not an actively developed project. So, the expectation is that there need some time for this to be resolved. Sorry for this!
    Regards, Eric
  • Eric,
    Thank you. It is OK. I just want to make sure that question is still there.
  • Hi Eric,
    How long it might take to get an answer? The issue has not been resolved and I still hope to get a solution.
    Thank you
  • Stan,
    Sorry, Volib is our legacy product. In this month, we may have a meeting to discuss when will be the next release. I don't have an answer at this moment but will keep you updated.
    Regards, Eric
  • Eric,
    Thank you for updating. Hope next release will come soon.
