I am trying to run example demo of video streaming from TI814x_RDK_3.8.0, on my custom board. But application is not able to attach to SYSTEM: Attaching to [VIDEO-M3].
What could be a possible reason for this?
Please find attached log file for reference.
inside finish.sh
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 176
UBI: attached mtd5 to ubi0
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 4/2
UBI: image sequence number: -632789573
UBI: background thread "ubi_bgt0d" started, PID 159
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi1
UBI: max. sequence number: 51
UBI: attached mtd7 to ubi1
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: image sequence number: 424686746
UBI: background thread "ubi_bgt1d" started, PID 171
UBI device number 1, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.21.02.10
SysLink module created on Date:Dec 3 2014 Time:12:30:15
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000002
secss put in low power state
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00070207
Phy Addr : 0x4d0000e4 Data : 0x00000000
Phy Addr : 0x4c0000e4 Data : 0x00170207
Phy Addr : 0x4d0000e4 Data : 0x00100000
DDR IOs RX is shutdown
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
IPNC_3.80.00 (root@AHMCPU0440) (gcc version 4.5.3 20110311 (prerelease)
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
[host] Attached to slave procId 0.
[host] Attached to slave procId 2.
[host] Attached to slave procId 1.
[host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Started slave procId 2.
[host] Started slave procId 0.
[host] After Ipc_loadcallback status [0x00000000]
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[c6xdsp ]
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[c6xdsp ] 2: SYSTEM: Attaching to [HOST] ...
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[host] Started slave procId 1.
[c6xdsp ] 76: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 151: SYSTEM: Attaching to [HOST] ...
[host] After Ipc_startcallback status [0x00000000]
[c6xdsp ] 226: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 229: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 229: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 304: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 379: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 454: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 529: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 604: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 679: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 754: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 829: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 904: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 979: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1054: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1129: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1204: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1279: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1354: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1429: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1504: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1579: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1654: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1729: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1804: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1879: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 1954: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2029: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2104: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2179: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2254: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2329: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2404: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2479: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2554: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2629: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2704: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2779: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2854: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2929: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3004: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3079: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3154: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3229: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3304: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3379: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3454: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3529: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3604: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3679: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3754: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3829: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3904: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3979: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4054: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4129: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4204: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4279: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4354: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4429: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4504: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4579: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4654: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4729: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4804: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4879: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4954: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5029: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5104: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5179: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5254: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5329: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5404: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5479: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5554: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5629: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5704: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5779: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5854: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5929: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6004: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6079: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6154: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6229: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6304: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6379: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6454: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6529: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6604: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6679: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6754: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6829: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6904: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 6979: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7054: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7129: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7204: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7279: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7354: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7429: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7504: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7579: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7654: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7729: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7804: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7879: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 7954: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8029: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8104: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8179: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8254: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8329: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8404: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8479: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8554: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8629: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8704: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8779: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8854: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 8929: SYSTEM: Attach [c6xdsp ] 9154: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9229: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9304: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9379: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9454: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9529: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9604: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9679: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9754: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9829: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9904: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 9979: SYSTEM: Attaching to [VIDEO-M3] ...
inside autorun
[c6xdsp ] 10054: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10129: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10204: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10279: SYSTEM: Attaching to [VIDEO-M3] ...
sbulla: unknown partition table
[c6xdsp ] 10354: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10429: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10504: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10579: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10654: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10729: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10804: SYSTEM: Attaching to [VIDEO-M3] ...
INIT: Entering runlevel: 5
[c6xdsp ] 10879: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 10954: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11029: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11104: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11179: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11254: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11329: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11404: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11479: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11554: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11629: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11704: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11779: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11854: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 11929: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12004: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12079: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12154: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12229: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12304: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12379: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12454: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12529: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12604: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12679: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12754: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12829: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12904: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 12979: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 13054: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 13129: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 13204: SYSTEM: Attaching to [VIDEO-M3] ...
Thanking You,
Krinali Shah
