how to detect a connection when my usb connector conect my board to my PC in linux c?
in usb host case,i can found info in /sys/block/sda1/
where i can find the info of usb gadget
Tracy,
From what I understand, your DM814x board is USB device/gadget, and your linux PC is USB host, is that correct?
And you need to know where in linux PC you should check that DM814x USB is detected?
BR
Pavel
board is USB gadget and PC is USB host,correct.
I want to check if usb is connect or not in DM814x not in my linux pc.
insmod g_file_storage.ko file=/dev/sbulla stall=0 removable=1
when the first time 8148 connect to PC,USB can be detected
but if i remove it in my linux PC,the second time ,can not detect..
i think i must rmmod g_file_storage.ko and insmod again after disconnect from my pc,so i need to detect the status of usb connection in 8148.
now i found another way is :
but i still don't konw how to detect the usb connection status in 8148..
tracy mcgrady said:but i still don't konw how to detect the usb connection status in 8148
This should be possible through the sysfs, debugfs and/or procfs, see the below wiki pages for more info:
BR
Pavel
