Hi Guys,
I am using mcsdk_video 2.2.0.42. The H265enc example works fine if I use codecParams_h265enc1080VC_2Mbps.cfg. When I change the Gop control setting "gopCntrlParamsPreset" to any value except 0. It always fail. The error is :
DSP codec create on node 0 failed with error code -4!!!!!
Does this version support user defined Gop setting?
By the way, I change codec config file to a 1Mbps, see below. Is it looks OK?
#StaticParams - IVIDENC2_Params
static_param0 = 824 # IVIDEND2_Params :: size
static_param1 = 2 # IVIDEND2_Params :: encodingPreset
static_param2 = 2 # IVIDEND2_Params :: rateControlPreset
static_param3 = 1080 # IVIDEND2_Params :: MaxHeight
static_param4 = 1920 # IVIDEND2_Params :: MaxWidth
static_param5 = 1 # IVIDEND2_Params :: dataEndianness
static_param6 = 1 # IVIDEND2_Params :: MaxInterFrameInterval
static_param7 = 10000000 # IVIDEND2_Params :: maxBitRate
static_param8 = 1000000 # IVIDEND2_Params :: minBitRate
static_param9 = 1 # IVIDEND2_Params :: InputChromaFormat
static_param10 = 0 # IVIDEND2_Params :: InputContentType
static_param11 = 1 # IVIDEND2_Params :: operatingMode: IVIDEO_ENCODE_ONLY = 1
static_param12 = 1 # IVIDEND2_Params :: profile
static_param13 = 41 # IVIDEND2_Params :: level
static_param14 = 3 # IVIDEND2_Params :: InputDataMode: IVIDEO_ENTIREFRAME = 3
static_param15 = 3 # IVIDEND2_Params :: OutputDataMode: IVIDEO_ENTIREFRAME = 3
static_param16 = 1 # IVIDEND2_Params :: numInputDataUnits
static_param17 = 1 # IVIDEND2_Params :: numOutputDataUnits
static_param18 = -1 # IVIDEND2_Params :: metadataType0: IVIDEO_METADATAPLANE_NONE = -1
static_param19 = -1 # IVIDEND2_Params :: metadataType1: IVIDEO_METADATAPLANE_NONE = -1
static_param20 = -1 # IVIDEND2_Params :: metadataType2: IVIDEO_METADATAPLANE_NONE = -1
#StaticParams - IH265VENC_RateControlParams
static_param21 = 1 # RCParams ::rateControlParamsPreset
static_param22 = 0 # RCParams ::rcAlgo
static_param23 = 28 # RCParams ::qpI
static_param24 = 51 # RCParams ::qpMaxI
static_param25 = 12 # RCParams ::qpMinI
static_param26 = 28 # RCParams ::qpP
static_param27 = 51 # RCParams ::qpMaxP
static_param28 = 12 # RCParams ::qpMinP
static_param29 = 4 # RCParams ::QpOffsetB
static_param30 = 51 # RCParams ::qpMaxB
static_param31 = 12 # RCParams ::qpMinB
static_param32 = 0 # RCParams ::enableFrameSkip
static_param33 = 0 # RCParams ::enablePartialFrameSkip
static_param34 = 0 # RCParams ::qualityFactorIP
static_param35 = 2 # RCParams ::cbQPIndexOffset
static_param36 = 2 # RCParams ::crQPIndexOffset
static_param37 = 4000000 # RCParams ::initialBufferLevel
static_param38 = 4000000 # RCParams ::hrdBufferSize
static_param39 = 0 # RCParams ::enableHRDComplianceMode
static_param40 = 0 # RCParams ::maxFrameSkipCnt
static_param41 = 0 # RCParams ::SubFrameRC
static_param42 = 0 # RCParams ::maxDeltaQP
static_param43 = 0 # RCParams ::enablePRC
static_param44 = 0 # RCParams ::reserved0
static_param45 = 0 # RCParams ::reserved1
static_param46 = 0 # RCParams ::reserved2
#StaticParams - IH265VENC_LoopFilterParams
static_param47 = 1 # LoopFilterParams :: loopFilterParamsPreset
static_param48 = 1 # LoopFilterParams :: enableDeblockFilter
static_param49 = 1 # LoopFilterParams :: enableSaoFilter
static_param50 = 0 # LoopFilterParams :: enableLoopFilterSliceBoundary
static_param51 = 0 # LoopFilterParams :: enableLoopFilterTileBoundary
static_param52 = 0 # LoopFilterParams :: separateCbCrSAO
static_param53 = 0 # LoopFilterParams :: offsetLoopFilterInPPSFlag
static_param54 = 0 # LoopFilterParams :: offsetDeblockBetaDiv2
static_param55 = 0 # LoopFilterParams :: offsetDeblockTcDiv2
#StaticParams - IH265VENC_GopCntrlParams
static_param56 = 1 # GopCntrlParams :: gopCntrlParamsPreset, 0 - Default Layer 1
# 1 : User defined , below parameters will be used,
# 2 : Deafult layer 2, gop size 2 and IPP sequence
# 3 : Deafult layer 3, gop size 4 and IPP sequence
# 4 : Deafult layer 4, gop size 8 and IPP sequence
# 5 : Deafult layer 2, gop size 2 and IBP sequence
# 6 : Deafult layer 4, gop size 4 and IBBBP sequence
# 7 : Deafult layer 8, gop size 8 and IBBBBBBBP sequence
static_param57 = 80 # gopFrameType[8]; GOPFrameType = {I-73, P-80, B-66 } #static_param[57] to static_param[64]
static_param58 = 66 # gopFrameType[8]; GOPFrameType = {I-73, P-80, B-66 } #static_param[57] to static_param[64]
static_param59 = 66 # gopFrameType[8]; GOPFrameType = {I-73, P-80, B-66 } #static_param[57] to static_param[64]
static_param65 = 0 # gopQPOffset[8]; #static_param[65] to static_param[72]
static_param66 = 0 # gopQPOffset[8]; #static_param[65] to static_param[72]
static_param67 = 0 # gopQPOffset[8]; #static_param[65] to static_param[72]
static_param73 = 1 # gopNumRefFrames[8]; #static_param[73] to static_param[80]
static_param74 = 1 # gopNumRefFrames[8]; #static_param[73] to static_param[80]
static_param75 = 1 # gopNumRefFrames[8]; #static_param[73] to static_param[80]
static_param81 = 1 # gopRefFrames/GOPRefIdx[8][4]; #static_param[81] to static_param[112]
static_param85 = 1 # gopRefFrames/GOPRefIdx[8][4]; #static_param[81] to static_param[112]
static_param86 = 1 # gopRefFrames/GOPRefIdx[8][4]; #static_param[81] to static_param[112]
static_param113 = 1 # gopPocNo[8]; #static_param[113] to static_param[120]
static_param114 = 0 # gopPocNo[8]; #static_param[113] to static_param[120]
static_param115 = 0 # gopPocNo[8]; #static_param[113] to static_param[120]
static_param121 = 1 # gopIsReference[8]; #static_param[121] to static_param[128]
static_param122 = 0 # gopIsReference[8]; #static_param[121] to static_param[128]
static_param123 = 0 # gopIsReference[8]; #static_param[121] to static_param[128]
static_param129 = 0 # gopTemporalId[8]; #static_param[129] to static_param[136]
static_param130 = 0 # gopTemporalId[8]; #static_param[129] to static_param[136]
static_param131 = 0 # gopTemporalId[8]; #static_param[129] to static_param[136]
#StaticParams - IH265VENC_SliceCodingParams
static_param137 = 1 # SliceCodingParams :: sliceCodingPreset
static_param138 = 0 # SliceCodingParams :: sliceCodingMode; # 0 : Disable
# 1 : each slice consist of sliceCodingArg LCU
static_param139 = 0 # SliceCodingParams :: sliceCodingArg; # N : each slice consisit of N LCU in raster scan order ; This will be ignored if enableTiles is 1
static_param140 = 0 # SliceCodingParams :: enableTiles
static_param141 = 1 # SliceCodingParams :: numTileColumns
static_param142 = 1 # SliceCodingParams :: numTileRows
static_param143 = 0 # SliceCodingParams :: enableDependentSlice
#StaticParams - IH265VENC_IntraCodingParams
static_param144 = 1 # IntraCodingParams :: intraCodingPreset
static_param145 = 0 # IntraCodingParams :: intraRefreshMethod
static_param146 = 0 # IntraCodingParams :: intraRefreshRate
static_param147 = 0 # IntraCodingParams :: constrainedIntraPredEnable
static_param148 = 1 # IntraCodingParams :: enableStrongIntraSmoothing
static_param149 = 0 # IntraCodingParams :: matchYCbCrIntraMode
static_param150 = 0 # IntraCodingParams :: enableLumaIntra4x4Mode
static_param151 = 0 # IntraCodingParams :: enableLumaIntra8x8Mode
static_param152 = 0 # IntraCodingParams :: enableLumaIntra16x16Mode
static_param153 = 0 # IntraCodingParams :: enableLumaIntra32x32Mode
static_param154 = 0 # IntraCodingParams :: enableChromaIntra4x4Mode
static_param155 = 0 # IntraCodingParams :: enableChromaIntra8x8Mode
static_param156 = 0 # IntraCodingParams :: enableChromaIntra16x16Mode
#StaticParams - IH265VENC_InterCodingParams
static_param157 = 1 # InterCodingParams :: interCodingPreset
static_param158 = 0 # InterCodingParams :: enableTmvp
static_param159 = 72 # InterCodingParams :: searchRangeHorP
static_param160 = 128 # InterCodingParams :: searchRangeVerP
static_param161 = 72 # InterCodingParams :: searchRangeHorB
static_param162 = 128 # InterCodingParams :: searchRangeVerB
static_param163 = 0 # InterCodingParams :: interCodingBias
static_param164 = 0 # InterCodingParams :: skipMVCodingBias
static_param165 = 3 # InterCodingParams :: numMergeCandidates
static_param166 = 1 # InterCodingParams :: enableBiPredMode
static_param167 = 1 # InterCodingParams :: enableFastIntraAlgo
#StaticParams - IH265VENC_CTBCodingParams
static_param168 = 64 # CTBCodingParams :: maxCTBSize
static_param169 = 3 # CTBCodingParams :: maxCUDepth
#StaticParams - IH265VENC_VUICodingParams
static_param170 = 0 # VUICodingParams :: vuiCodingPreset
static_param171 = 0 # VUICodingParams :: aspectRatioInfoPresentFlag
static_param172 = 0 # VUICodingParams :: aspectRatioIdc
static_param173 = 0 # VUICodingParams :: videoSignalTypePresentFlag
static_param174 = 0 # VUICodingParams :: videoFormat
static_param175 = 0 # VUICodingParams :: videoFullRangeFlag
static_param176 = 0 # VUICodingParams :: colourDescriptionPresentFlag
static_param177 = 0 # VUICodingParams :: colourPrimaries
static_param178 = 0 # VUICodingParams :: transferCharacteristics
static_param179 = 0 # VUICodingParams :: matrixCoefficients
static_param180 = 0 # VUICodingParams :: timingInfoPresentFlag
#StaticParams - IH265VENC_SEIParams
static_param181 = 0 # SEIParams :: enableSEIFlag
static_param182 = 0 # SEIParams :: reservedSEI0
static_param183 = 0 # SEIParams :: reservedSEI1
static_param184 = 0 # SEIParams :: reservedSEI2
static_param185 = 0 # SEIParams :: reservedSEI3
static_param186 = 0 # SEIParams :: reservedSEI4
static_param187 = 0 # SEIParams :: reservedSEI5
static_param188 = 0 # SEIParams :: reservedSEI6
static_param189 = 0 # SEIParams :: reservedSEI7
static_param190 = 0 # SEIParams :: reservedSEI8
static_param191 = 0 # SEIParams :: reservedSEI9
#StaticParams - Misc
static_param193 = 0 # MiscParams :: scalingMatrixPreset, # flag to enable scaling list
# 0 : Disabled
# 1 : Default scaling list as defined by standard
# 2 : User defined scaling list sent in SPS
# 3 : User defined scaling list sent in PPS
static_param194 = 0 # MiscParams :: decRefreshType
static_param195 = 0 # MiscParams :: decRefreshInterval
static_param196 = 0 # MiscParams :: enableTransQuantBypass
static_param197 = 256 # MiscParams :: maxPoc
static_param198 = 0 # MiscParams :: enableTransformSkip
static_param199 = 10000 # MiscParams :: maxIntraFrameInterval
static_param200 = 0 # MiscParams :: enableWPP
static_param201 = 1 # MiscParams :: maxNumRefFrames
static_param202 = 21 # MiscParams :: enableVirtualTile
static_param203 = 0 # MiscParams :: disableVirtualTileDependency
static_param204 = 0 # MiscParams :: debugTraceLevel
static_param205 = 0 # MiscParams :: lastNFramesToLog
#DynamicParams - IVIDENC2_DynamicParams
dynamic_param0 = 372 # IVIDENC2_DynamicParams :: size
dynamic_param1 = 1080 # IVIDENC2_DynamicParams :: inputHeight
dynamic_param2 = 1920 # IVIDENC2_DynamicParams :: inputWidth
dynamic_param3 = 60000 # IVIDENC2_DynamicParams :: refFrameRate
dynamic_param4 = 60000 # IVIDENC2_DynamicParams :: targetFrameRate
dynamic_param5 = 1000000 # IVIDENC2_DynamicParams :: targetBitRate
dynamic_param6 = 1000 # IVIDENC2_DynamicParams :: intraFrameInterval
dynamic_param7 = 0 # IVIDENC2_DynamicParams :: generateHeader
dynamic_param8 = 0 # IVIDENC2_DynamicParams :: captureWidth
dynamic_param9 = -1 # IVIDENC2_DynamicParams :: forceIFrame
dynamic_param10 = 1 # IVIDENC2_DynamicParams :: interFrameInterval
dynamic_param11 = 2 # IVIDENC2_DynamicParams :: mvAccuracy
dynamic_param12 = 1 # IVIDENC2_DynamicParams :: sampleAspectRatioHeight
dynamic_param13 = 1 # IVIDENC2_DynamicParams :: sampleAspectRatioWidth
dynamic_param14 = 0 # IVIDENC2_DynamicParams :: ignoreOutbufSizeFlag
dynamic_param15 = 0 # IVIDENC2_DynamicParams :: putDataFxn
dynamic_param16 = 0 # IVIDENC2_DynamicParams :: putDataHandle
dynamic_param17 = 0 # IVIDENC2_DynamicParams :: getDataFxn
dynamic_param18 = 0 # IVIDENC2_DynamicParams :: getDataHandle
dynamic_param19 = 0 # IVIDENC2_DynamicParams :: getBufferFxn
dynamic_param20 = 0 # IVIDENC2_DynamicParams :: getBufferHandle
dynamic_param21 = 0 # IVIDENC2_DynamicParams :: lateAcquireArg
#DynamicParams - IH265VENC_RateControlParams
dynamic_param22 = 1 # RCParams ::rateControlParamsPreset
dynamic_param23 = 0 # RCParams ::rcAlgo
dynamic_param24 = 28 # RCParams ::qpI
dynamic_param25 = 51 # RCParams ::qpMaxI
dynamic_param26 = 12 # RCParams ::qpMinI
dynamic_param27 = 28 # RCParams ::qpP
dynamic_param28 = 51 # RCParams ::qpMaxP
dynamic_param29 = 12 # RCParams ::qpMinP
dynamic_param30 = 4 # RCParams ::QpOffsetB
dynamic_param31 = 51 # RCParams ::qpMaxB
dynamic_param32 = 12 # RCParams ::qpMinB
dynamic_param33 = 0 # RCParams ::enableFrameSkip
dynamic_param34 = 0 # RCParams ::enablePartialFrameSkip
dynamic_param35 = 0 # RCParams ::qualityFactorIP
dynamic_param36 = 2 # RCParams ::cbQPIndexOffset
dynamic_param37 = 2 # RCParams ::crQPIndexOffset
dynamic_param38 = 4000000 # RCParams ::initialBufferLevel
dynamic_param39 = 4000000 # RCParams ::hrdBufferSize
dynamic_param40 = 0 # RCParams ::enableHRDComplianceMode
dynamic_param41 = 0 # RCParams ::maxFrameSkipCnt
dynamic_param42 = 0 # RCParams ::SubFrameRC
dynamic_param43 = 0 # RCParams ::maxDeltaQP
dynamic_param44 = 0 # RCParams ::enablePRC
dynamic_param45 = 0 # RCParams ::reserved0
dynamic_param46 = 0 # RCParams ::reserved1
dynamic_param47 = 0 # RCParams ::reserved2
#DynamicParams - IH265VENC_LoopFilterParams
dynamic_param48 = 1 # LoopFilterParams :: loopFilterParamsPreset
dynamic_param49 = 1 # LoopFilterParams :: enableDeblockFilter
dynamic_param50 = 1 # LoopFilterParams :: enableSaoFilter
dynamic_param51 = 0 # LoopFilterParams :: enableLoopFilterSliceBoundary
dynamic_param52 = 0 # LoopFilterParams :: enableLoopFilterTileBoundary
dynamic_param53 = 0 # LoopFilterParams :: separateCbCrSAO
dynamic_param54 = 0 # LoopFilterParams :: offsetLoopFilterInPPSFlag
dynamic_param55 = 0 # LoopFilterParams :: offsetDeblockBetaDiv2
dynamic_param56 = 0 # LoopFilterParams :: offsetDeblockTcDiv2
#DynamicParams - IH265VENC_IntraCodingParams
dynamic_param57 = 1 # IntraCodingParams :: intraCodingPreset
dynamic_param58 = 0 # IntraCodingParams :: intraRefreshMethod
dynamic_param59 = 0 # IntraCodingParams :: intraRefreshRate
dynamic_param60 = 0 # IntraCodingParams :: constrainedIntraPredEnable
dynamic_param61 = 1 # IntraCodingParams :: enableStrongIntraSmoothing
dynamic_param62 = 0 # IntraCodingParams :: matchYCbCrIntraMode
dynamic_param63 = 0 # IntraCodingParams :: enableLumaIntra4x4Mode
dynamic_param64 = 0 # IntraCodingParams :: enableLumaIntra8x8Mode
dynamic_param65 = 0 # IntraCodingParams :: enableLumaIntra16x16Mode
dynamic_param66 = 0 # IntraCodingParams :: enableLumaIntra32x32Mode
dynamic_param67 = 0 # IntraCodingParams :: enableChromaIntra4x4Mode
dynamic_param68 = 0 # IntraCodingParams :: enableChromaIntra8x8Mode
dynamic_param69 = 0 # IntraCodingParams :: enableChromaIntra16x16Mode
#DynamicParams - IH265VENC_InterCodingParams
dynamic_param70 = 1 # InterCodingParams :: interCodingPreset
dynamic_param71 = 0 # InterCodingParams :: enableTmvp
dynamic_param72 = 72 # InterCodingParams :: searchRangeHorP
dynamic_param73 = 128 # InterCodingParams :: searchRangeVerP
dynamic_param74 = 72 # InterCodingParams :: searchRangeHorB
dynamic_param75 = 128 # InterCodingParams :: searchRangeVerB
dynamic_param76 = 0 # InterCodingParams :: interCodingBias
dynamic_param77 = 0 # InterCodingParams :: skipMVCodingBias
dynamic_param78 = 3 # InterCodingParams :: numMergeCandidates
dynamic_param79 = 1 # InterCodingParams :: enableBiPredMode
dynamic_param80 = 1 # InterCodingParams :: enableFastIntraAlgo
#DynamicParams - IH265VENC_CTBCodingParams
dynamic_param81 = 64 # CTBCodingParams :: maxCTBSize
dynamic_param82 = 3 # CTBCodingParams :: maxCUDepth
#DynamicParams - IH265VENC_SliceCodingParams
dynamic_param83 = 1 # SliceCodingParams :: sliceCodingPreset
dynamic_param84 = 0 # SliceCodingParams :: sliceCodingMode; # 0 : Disable
dynamic_param85 = 0 # SliceCodingParams :: sliceCodingArg; # N : each slice consisit of N LCU in raster scan order ; This will be ignored if enableTiles is 1
dynamic_param86 = 0 # SliceCodingParams :: enableTiles
dynamic_param87 = 1 # SliceCodingParams :: numTileColumns
dynamic_param88 = 1 # SliceCodingParams :: numTileRows
dynamic_param89 = 0 # SliceCodingParams :: enableDependentSlice
#DynamicParams - Misc
dynamic_param90 = 0 # MiscParams :: enableTransQuantBypass
dynamic_param91 = 0 # MiscParams :: enableTransformSkip
dynamic_param92 = 0 # MiscParams :: enableROI
# scaling matrix
metaDataType0Size = 992
metaDataType0 =
# /* Intra Y - 4x4 */
16 24 32 40
24 32 40 48
32 40 48 56
40 48 56 64
# /* Intra Cb - 4x4 */
16 24 32 40
24 32 40 48
32 40 48 56
40 48 56 64
# /* Intra Cr - 4x4 */
16 24 32 40
24 32 40 48
32 40 48 56
40 48 56 64
# /* Inter Y - 4x4 */
16 32 48 64
32 48 64 80
48 64 80 96
64 80 96 112
# /* Inter Cb - 4x4 */
16 32 48 64
32 48 64 80
48 64 80 96
64 80 96 112
# /* Inter Cr - 4x4 */
16 32 48 64
32 48 64 80
48 64 80 96
64 80 96 112
# /* Intra Y - 8x8 */
16 20 20 22 20 22 24 24
24 24 26 26 26 26 26 28
28 28 28 28 28 30 30 30
30 30 30 30 32 32 32 32
32 32 32 32 34 34 34 34
34 34 34 36 36 36 36 36
36 38 38 38 38 38 41 41
41 41 44 44 44 47 47 50
# /* Intra Cb - 8x8 */
# /* Intra Cr - 8x8 */
# /* Inter Y - 8x8 */
16 24 24 26 24 26 28 28
28 28 30 30 30 30 30 32
32 32 32 32 32 34 34 34
34 34 34 34 36 36 36 36
36 36 36 36 38 38 38 38
38 38 38 40 40 40 40 40
40 42 42 42 42 42 45 45
45 45 49 49 49 51 51 54
# /* Inter Cb - 8x8 */
# /* Inter Cr - 8x8 */
# /* Intra Y - 16x16 */
# /* Intra Cb - 16x16 */
# /* Intra Cr - 16x16 */
# /* Inter Y - 16x16 */
# /* Inter Cb - 16x16 */
# /* Inter Cr - 16x16 */
# /* Intra Y - 32x32 */
# /* Inter Y - 32x32 */
# 0 : Disabled
# scaling matrix
metaDataType0 =
16 24 32 40
24 32 40 48
32 40 48 56
40 48 56 64
16 24 32 40
24 32 40 48
32 40 48 56
40 48 56 64
16 24 32 40
24 32 40 48
32 40 48 56
40 48 56 64
16 32 48 64
32 48 64 80
48 64 80 96
64 80 96 112
16 32 48 64
32 48 64 80
48 64 80 96
64 80 96 112
16 32 48 64
32 48 64 80
48 64 80 96
64 80 96 112
