Other Parts Discussed in Thread: TVP5150, TVP5150AM1
We are developing a dm8148 custom board.
You can use the GStreamer, and I would like to video processing.
Install the GStreamer library, gst-launch and I was running the command, but an error occurs, the command terminates.
What's wrong?
EZSDK : 5_05_02_00
SoC : DM8148
Hideki
====== startup scripts ===========
echo "load cmemk..." insmod cmemk.ko phys_start=0x96C00000 phys_end=0x98000000 pools=20x4096 allowOverlap=1
echo -e "load syslink..." insmod syslink.ko TRACE=1 TRACEFAILURE=1 TRACECLASS=3 until [[ -e /dev/syslinkipc_ProcMgr && -e /dev/syslinkipc_ClientNotifyMgr ]] do sleep 0.5 done
echo -e "load dm814x_hdvicp..." ./slaveloader_release startup VIDEO-M3 dm814x_hdvicp.xem3 sleep 1
echo -e "load dm814x_hdvpss_v4l2..." ./slaveloader_release startup VPSS-M3 dm814x_hdvpss_v4l2.xem3 sleep 1
echo -e "load vpss..." insmod vpss.ko debug=0 sbufaddr=0xBFB00000 mode=hdmi:1080p-60 sleep 0.5
echo -e "load ti81xxfb..." insmod ti81xxfb.ko debug=0 vram=0:30M,1:10M,2:10M
echo -e "load ti81xxvo..." insmod ti81xxvo.ko debug=0
echo -e "load tvp5150..." insmod tvp5150.ko debug=0
echo -e "load ti81xxvin..." insmod ti81xxvin.ko debug=0
echo -e "load ti81xxvhdmi..." insmod ti81xxhdmi.ko debug=0
====== startup scripts =========== echo "load cmemk..." insmod cmemk.ko phys_start=0x96C00000 phys_end=0x98000000 pools=20x4096 allowOverlap=1 echo -e "load syslink..." insmod syslink.ko TRACE=1 TRACEFAILURE=1 TRACECLASS=3 until [[ -e /dev/syslinkipc_ProcMgr && -e /dev/syslinkipc_ClientNotifyMgr ]] do sleep 0.5 done echo -e "load dm814x_hdvicp..." ./slaveloader_release startup VIDEO-M3 dm814x_hdvicp.xem3 sleep 1 echo -e "load dm814x_hdvpss_v4l2..." ./slaveloader_release startup VPSS-M3 dm814x_hdvpss_v4l2.xem3 sleep 1 echo -e "load vpss..." insmod vpss.ko debug=0 sbufaddr=0xBFB00000 mode=hdmi:1080p-60 sleep 0.5 echo -e "load ti81xxfb..." insmod ti81xxfb.ko debug=0 vram=0:30M,1:10M,2:10M echo -e "load ti81xxvo..." insmod ti81xxvo.ko debug=0 echo -e "load tvp5150..." insmod tvp5150.ko debug=0 echo -e "load ti81xxvin..." insmod ti81xxvin.ko debug=0 echo -e "load ti81xxvhdmi..." insmod ti81xxhdmi.ko debug=0 ====== log =================== U-Boot 2010.061 (Aug 25 2014 - 19:18:30) TI8148-GP rev 3.0 ARM clk: 720MHz DSP clk: 600MHz DDR clk: 400MHz L3 clk: 220MHz DSS clk: 200MHz IVA clk: 306MHz ISS clk: 400MHz I2C: ready DRAM: 2 GiB NAND: HW ECC BCH8 Selected 256 MiB MMC: OMAP SD/MMC: 0 .:;rrr;;. ,5#@@@@#####@@@@@@#2, ,A@@@hi;;;r5;;;;r;rrSG@@@A, r@@#i;:;s222hG;rrsrrrrrr;ri#@@r :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@: B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@ @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@ @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@ G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@ X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@ @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@ @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@ @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@ M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@# :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@, @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@ @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@ ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@; r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@, B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@. .A@@#5r;;;r;;;rrr;r:r#AsM@@H. ;&@@@@MhXS5i5SX9B@@@@G; :ihM#@@@@@##hs, Net: Detected MACID:84:7e:40:e3:f6:f4 cpsw Hit any key to stop autoboot: 3 2 1 0 NAND read: device 0 offset 0x280000, size 0x300000 3145728 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.371 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2516072 Bytes = 2.4 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 2.6.371 (pal@pal-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #28 Mon Aug 25 19:09:51 JST 2014 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8148brast vram size = 52428800 at 0x0 reserved size = 52428800 at 0x0 FB: Reserving 52428800 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback (PAL) ti8148_evm_map_io(1241) OMAP chip is TI8148 3.0 SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000 (PAL) ti8148_evm_map_io(1244) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 79656 Kernel command line: console=ttyO0,115200n8 rootwait rw mem=364M@0x80000000 vmalloc=500M vram=50M notifyk.vpssm3_sva=0xBF900000 root=/dev/nfs nfsroot=192.168.1.15:/home/pal/targetfs/rfs ip=192.168.1.200:192.168.1.15:192.168.1.1:255.255.255.0::eth0:off PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 314MB = 314MB total Memory: 312828k/312828k available, 59908k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd7000000 - 0xf8000000 ( 528 MB) lowmem : 0xc0000000 - 0xd6c00000 ( 364 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .init : 0xc0008000 - 0xc003b000 ( 204 kB) .text : 0xc003b000 - 0xc04be000 (4620 kB) .data : 0xc04be000 - 0xc04ffc80 ( 264 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:375 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ368 Trying to install interrupt handler for IRQ369 Trying to install interrupt handler for IRQ370 Trying to install interrupt handler for IRQ371 Trying to install interrupt handler for IRQ372 Trying to install interrupt handler for IRQ373 Trying to install interrupt handler for IRQ374 Trying to install type control for IRQ375 Trying to set irq flags for IRQ375 OMAP clockevent source: GPTIMER1 at 20000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 719.25 BogoMIPS (lpj=3596288) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting! omap_voltage_add_dev: VDD specified does not exist! OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 4 Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now registered ti81xx_vpss device registered ti81xx_vidout device registered ti81xx on-chip HDMI device registered ti81xx_fb device registered ti81xx_vin device card_name = TI81xx_catalogue name = tvp5150 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb USBSS revision 4ea2080b registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.371 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at d701e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 MUSB controller-1 revision 4ea20800 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.371 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at d7028800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ツゥ 2001-2006 Red Hat, Inc. msgmni has been set to 610 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 console [ttyO0] enabled omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3 omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4 omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5 brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x1 ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst scsi0 : ahci_platform ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16 omap2-nand driver initializing ONFI flash detected ONFI param page 0 valid NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit) Creating 6 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000020000 : "U-Boot-min" 0x000000020000-0x000000260000 : "U-Boot" 0x000000260000-0x000000280000 : "U-Boot Env" 0x000000280000-0x0000006c0000 : "Kernel" 0x0000006c0000-0x00000cee0000 : "File System" 0x00000cee0000-0x000010000000 : "Reserved" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffffe davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 usbcore: registered new interface driver cdc_acm cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbf900000 TCP cubic registered NET: Registered protocol family 17 Registering the dns_resolver key type VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. Detected MACID=84:7e:40:e3:f6:f4 omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) ata1: SATA link down (SStatus 0 SControl 300) CPSW phy found : id is : 0x7c0ec PHY 0:01 not found IP-Config: Complete: device=eth0, addr=192.168.1.200, mask=255.255.255.0, gw=192.168.1.1, host=192.168.1.200, domain=, nis-domain=(none), bootserver=192.168.1.15, rootserver=192.168.1.15, rootpath= PHY: 0:00 - Link is Up - 1000/Full VFS: Mounted root (nfs filesystem) on device 0:15. devtmpfs: mounted Freeing init memory: 204K INIT: version 2.86 booting /etc/rcS.d/S01psplash: line 21: /usr/bin/psplash: not found Please wait: booting... Starting udev udevd (75): /proc/75/oom_adj is deprecated, please use /proc/75/oom_score_adj instead. Root filesystem already rw, not remounting Caching udev devnodes logger: mount: special device /dev/sda1 does not exist ALSA: Restoring mixer settings... NOT configuring network interfaces: / is an NFS mount sbin/ldconfig command by bootmisc.sh /usr/sbin/alsactl: load_state:1625: No soundcards found... /usr/local/lib: libopencv_objdetect.so.2.2 -> libopencv_objdetect.so.2.2.0 libopencv_highgui.so.2.2 -> libopencv_highgui.so.2.2.0 libopencv_core.so.2.2 -> libopencv_core.so.2.2.0 libopencv_video.so.2.2 -> libopencv_video.so.2.2.0 libopencv_imgproc.so.2.2 -> libopencv_imgproc.so.2.2.0 libopencv_ml.so.2.2 -> libopencv_ml.so.2.2.0 /home/root/lib: /usr/lib/gstreamer-0.10: libgstpostproc.so -> libgstpostproc.so libgstvideoscale.so -> libgstvideoscale.so libgstrtsp.so -> libgstrtsp.so libgsttheora.so -> libgsttheora.so libgstdfbvideosink.so -> libgstdfbvideosink.so libgstmpeg2dec.so -> libgstmpeg2dec.so libgstmpegaudioparse.so -> libgstmpegaudioparse.so libgstffmpegscale.so -> libgstffmpegscale.so libgstshapewipe.so -> libgstshapewipe.so libgstjp2kdecimator.so -> libgstjp2kdecimator.so libgstgdkpixbuf.so -> libgstgdkpixbuf.so libgstflxdec.so -> libgstflxdec.so libgstauparse.so -> libgstauparse.so libgstsdl.so -> libgstsdl.so libgstavi.so -> libgstavi.so libgstnsf.so -> libgstnsf.so libgstvideosignal.so -> libgstvideosignal.so libgststridetransform.so -> libgststridetransform.so libgstmpegtsmux.so -> libgstmpegtsmux.so libgstspeex.so -> libgstspeex.so libgstid3tag.so -> libgstid3tag.so libgstxvimagesink.so -> libgstxvimagesink.so libgstsubenc.so -> libgstsubenc.so libgstvideocrop.so -> libgstvideocrop.so libgstx264.so -> libgstx264.so libgstadpcmdec.so -> libgstadpcmdec.so libgstvideofilter.so -> libgstvideofilter.so libgstspeed.so -> libgstspeed.so libgstalpha.so -> libgstalpha.so libgstflac.so -> libgstflac.so libgstfestival.so -> libgstfestival.so libgsthalelements.so -> libgsthalelements.so libgstcdparanoia.so -> libgstcdparanoia.so libgstfreeze.so -> libgstfreeze.so libgstgeometrictransform.so -> libgstgeometrictransform.so libgstreplaygain.so -> libgstreplaygain.so libgstaudiofx.so -> libgstaudiofx.so libgstequalizer.so -> libgstequalizer.so libgstdvb.so -> libgstdvb.so libgstnuvdemux.so -> libgstnuvdemux.so libgsticydemux.so -> libgsticydemux.so libgstcoreelements.so -> libgstcoreelements.so libgstffmpegcolorspace.so -> libgstffmpegcolorspace.so libgstplaybin.so -> libgstplaybin.so libgstasf.so -> libgstasf.so libgstjp2k.so -> libgstjp2k.so libgsteffectv.so -> libgsteffectv.so libgstapetag.so -> libgstapetag.so libgstaudiorate.so -> libgstaudiorate.so libgstcoreindexers.so -> libgstcoreindexers.so libgstvolume.so -> libgstvolume.so libgstvcdsrc.so -> libgstvcdsrc.so libgstmve.so -> libgstmve.so libgstaiff.so -> libgstaiff.so libgstivfparse.so -> libgstivfparse.so libgstflv.so -> libgstflv.so libgstinterleave.so -> libgstinterleave.so libgstmulaw.so -> libgstmulaw.so libgstsdpelem.so -> libgstsdpelem.so libgstapp.so -> libgstapp.so libgstvmnc.so -> libgstvmnc.so libgstsubparse.so -> libgstsubparse.so libgstspectrum.so -> libgstspectrum.so libgstomx.so -> libgstomx.so libgstcog.so -> libgstcog.so libgstwavenc.so -> libgstwavenc.so libgstlevel.so -> libgstlevel.so libgstmxf.so -> libgstmxf.so libgstaudiotestsrc.so -> libgstaudiotestsrc.so libgstgsm.so -> libgstgsm.so libgstwavpack.so -> libgstwavpack.so libgstalphacolor.so -> libgstalphacolor.so libgstgdp.so -> libgstgdp.so libgstaudioconvert.so -> libgstaudioconvert.so libgstgio.so -> libgstgio.so libgstossaudio.so -> libgstossaudio.so libgstiec958.so -> libgstiec958.so libgstcutter.so -> libgstcutter.so libgstivorbisdec.so -> libgstivorbisdec.so libgstfbdevsink.so -> libgstfbdevsink.so libgstvideobox.so -> libgstvideobox.so libgstliveadder.so -> libgstliveadder.so libgstrtp.so -> libgstrtp.so libgstmpeg4videoparse.so -> libgstmpeg4videoparse.so libgstdecodebin.so -> libgstdecodebin.so libgstalaw.so -> libgstalaw.so libgstsndfile.so -> libgstsndfile.so libgstlegacyresample.so -> libgstlegacyresample.so libgstmatroska.so -> libgstmatroska.so libgstdeinterlace.so -> libgstdeinterlace.so libgstrtpmux.so -> libgstrtpmux.so libgstmultifile.so -> libgstmultifile.so libgstaudioresample.so -> libgstaudioresample.so libgstsmpte.so -> libgstsmpte.so libgstpcapparse.so -> libgstpcapparse.so libgstmpegstream.so -> libgstmpegstream.so libgstjpeg.so -> libgstjpeg.so libgstrtpmanager.so -> libgstrtpmanager.so libgstsiren.so -> libgstsiren.so libgstdecodebin2.so -> libgstdecodebin2.so libgstpnm.so -> libgstpnm.so libgstvideorate.so -> libgstvideorate.so libgstrawparse.so -> libgstrawparse.so libgstasfmux.so -> libgstasfmux.so libgstwavparse.so -> libgstwavparse.so libgstoss4audio.so -> libgstoss4audio.so libgstencodebin.so -> libgstencodebin.so libgstrfbsrc.so -> libgstrfbsrc.so libgstadder.so -> libgstadder.so libgstjpegformat.so -> libgstjpegformat.so libgstpango.so -> libgstpango.so libgstsouphttpsrc.so -> libgstsouphttpsrc.so libgstfrei0r.so -> libgstfrei0r.so libgstnavigationtest.so -> libgstnavigationtest.so libgstogg.so -> libgstogg.so libgstvideomixer.so -> libgstvideomixer.so libgstdvbsuboverlay.so -> libgstdvbsuboverlay.so libgstefence.so -> libgstefence.so libgstqtmux.so -> libgstqtmux.so libgstscaletempoplugin.so -> libgstscaletempoplugin.so libgstmpegpsmux.so -> libgstmpegpsmux.so libgststereo.so -> libgststereo.so libgstmpegvideoparse.so -> libgstmpegvideoparse.so libgstdebugutilsbad.so -> libgstdebugutilsbad.so libgsta52dec.so -> libgsta52dec.so libgstlame.so -> libgstlame.so libgstannodex.so -> libgstannodex.so libgstdebug.so -> libgstdebug.so libgstqtdemux.so -> libgstqtdemux.so libgstdvdspu.so -> libgstdvdspu.so libgstgaudieffects.so -> libgstgaudieffects.so libgstdvdlpcmdec.so -> libgstdvdlpcmdec.so libgstcolorspace.so -> libgstcolorspace.so libgstbz2.so -> libgstbz2.so libgstsegmentclip.so -> libgstsegmentclip.so libgstximagesrc.so -> libgstximagesrc.so libgstmpegdemux.so -> libgstmpegdemux.so libgsty4menc.so -> libgsty4menc.so libgsty4mdec.so -> libgsty4mdec.so libgstadpcmenc.so -> libgstadpcmenc.so libgstdccp.so -> libgstdccp.so libgstvideo4linux.so -> libgstvideo4linux.so libgstcoloreffects.so -> libgstcoloreffects.so libgstlibvisual.so -> libgstlibvisual.so libgstapexsink.so -> libgstapexsink.so libgstautodetect.so -> libgstautodetect.so libgstvideomeasure.so -> libgstvideomeasure.so libgstshm.so -> libgstshm.so libgstjack.so -> libgstjack.so libgstdvdsub.so -> libgstdvdsub.so libgstmodplug.so -> libgstmodplug.so libgsttypefindfunctions.so -> libgsttypefindfunctions.so libgsthdvparse.so -> libgsthdvparse.so libgstffmpeg.so -> libgstffmpeg.so libgstfaac.so -> libgstfaac.so libgstinvtelecine.so -> libgstinvtelecine.so libgstgoom.so -> libgstgoom.so libgsttta.so -> libgsttta.so libgstgoom2k1.so -> libgstgoom2k1.so libgsth264parse.so -> libgsth264parse.so libgstinterlace.so -> libgstinterlace.so libgstdataurisrc.so -> libgstdataurisrc.so libgstpulse.so -> libgstpulse.so libgsttcp.so -> libgsttcp.so libgstaudioparsersbad.so -> libgstaudioparsersbad.so libgstmad.so -> libgstmad.so libgstdtmf.so -> libgstdtmf.so libgstid3demux.so -> libgstid3demux.so libgstvideomaxrate.so -> libgstvideomaxrate.so libgstcairo.so -> libgstcairo.so libgstcamerabin.so -> libgstcamerabin.so libgstfaad.so -> libgstfaad.so libgstbayer.so -> libgstbayer.so libgstpng.so -> libgstpng.so libgstvideotestsrc.so -> libgstvideotestsrc.so libgstmms.so -> libgstmms.so libgstudp.so -> libgstudp.so libgstautoconvert.so -> libgstautoconvert.so libgstvorbis.so -> libgstvorbis.so libgstschro.so -> libgstschro.so libgstrsvg.so -> libgstrsvg.so libgstvideo4linux2.so -> libgstvideo4linux2.so libgstmultipart.so -> libgstmultipart.so libgstesd.so -> libgstesd.so libgstalsa.so -> libgstalsa.so libgstcdxaparse.so -> libgstcdxaparse.so libgstrmdemux.so -> libgstrmdemux.so libgstimagefreeze.so -> libgstimagefreeze.so libgstximagesink.so -> libgstximagesink.so /lib: libgcc_s.so.1 -> libgcc_s.so.1 libnsl.so.1 -> libnsl-2.8.so libcidn.so.1 -> libcidn-2.8.so libmemusage.so -> libmemusage.so ld-linux.so.3 -> ld-2.8.so libnss_files.so.2 -> libnss_files-2.8.so librt.so.1 -> librt-2.8.so libnss_compat.so.2 -> libnss_compat-2.8.so libresolv.so.2 -> libresolv-2.8.so libm.so.6 -> libm-2.8.so libcrypt.so.1 -> libcrypt-2.8.so libc.so.6 -> libc-2.8.so libanl.so.1 -> libanl-2.8.so libdl.so.2 -> libdl-2.8.so libnss_dns.so.2 -> libnss_dns-2.8.so libBrokenLocale.so.1 -> libBrokenLocale-2.8.so libpthread.so.0 -> libpthread-2.8.so libutil.so.1 -> libutil-2.8.so /usr/lib: libpulsecommon-0.9.22.so -> libpulsecommon-0.9.22.so libSM.so.6 -> libSM.so.6.0.1 libvisual-0.4.so.0 -> libvisual-0.4.so.0.0.0 libpam.so.0 -> libpam.so.0.82.2 libmpeg2.so.0 -> libmpeg2.so.0.0.0 libgthread-2.0.so.0 -> libgthread-2.0.so.0.2400.1 libschroedinger-1.0.so.0 -> libschroedinger-1.0.so.0.3.0 libfontconfig.so.1 -> libfontconfig.so.1.4.4 libfreetype.so.6 -> libfreetype.so.6.6.1 libgstriff-0.10.so.0 -> libgstriff-0.10.so.0.23.0 libgdbm.so.3 -> libgdbm.so.3.0.0 libattr.so.1 -> libattr.so.1.1.0 libcdda_paranoia.so.0 -> libcdda_paranoia.so.0.10.3pre liborc-0.4.so.0 -> liborc-0.4.so.0.10.0 libgstvideo-0.10.so.0 -> libgstvideo-0.10.so.0.23.0 libSDL-1.2.so.0 -> libSDL-1.2.so.0.11.3 libgstsdp-0.10.so.0 -> libgstsdp-0.10.so.0.23.0 libcdda_interface.so.0 -> libcdda_interface.so.0.10.3pre libFLAC.so.8 -> libFLAC.so.8.2.0 libext2fs.so.2 -> libext2fs.so.2.4 libxtables.so.5 -> libxtables.so.5.0.0 libgobject-2.0.so.0 -> libgobject-2.0.so.0.2400.1 libgcrypt.so.11 -> libgcrypt.so.11.4.4 libthread_db.so.1 -> libthread_db-1.0.so libavformat.so.52 -> libavformat.so.52.102.0 libid3tag.so.0 -> libid3tag.so.0.3.0 libgnutls.so.26 -> libgnutls.so.26.16.13 libvorbisidec.so.1 -> libvorbisidec.so.1.0.2 libpanelw.so.5 -> libpanelw.so.5.9 libpulse.so.0 -> libpulse.so.0.12.3 libtheoraenc.so.1 -> libtheoraenc.so.1.1.2 libiptc.so.0 -> libiptc.so.0.0.0 libmodplug.so.0 -> libmodplug.so.0.0.0 libjasper.so.1 -> libjasper.so.1.0.0 libtheoradec.so.1 -> libtheoradec.so.1.1.4 libe2p.so.2 -> libe2p.so.2.3 libXrender.so.1 -> libXrender.so.1.3.0 libmp3lame.so.0 -> libmp3lame.so.0.0.0 libuuid.so.1 -> libuuid.so.1.3.0 libpangoft2-1.0.so.0 -> libpangoft2-1.0.so.0.2400.4 libOMX_Core -> libOMX_Core.so libcroco-0.6.so.3 -> libcroco-0.6.so.3.0.1 libssl.so.1.0.0 -> libssl.so.1.0.0 libfaad.so.2 -> libfaad.so.2.0.0 libpango-1.0.so.0 -> libpango-1.0.so.0.2400.4 libx264.so.96 -> libx264.so.96 libpcre.so.0 -> libpcre.so.0.0.1 libhal.so.1 -> libhal.so.1.0.0 libgconf-2.so.4 -> libgconf-2.so.4.1.5 libwavpack.so.1 -> libwavpack.so.1.1.4 libgstrtp-0.10.so.0 -> libgstrtp-0.10.so.0.23.0 libip4tc.so.0 -> libip4tc.so.0.0.0 libwrap.so.0 -> libwrap.so.0.7.6 libpostproc.so.51 -> libpostproc.so.51.2.0 libsoup-gnome-2.4.so.1 -> libsoup-gnome-2.4.so.1.3.0 libgstfft-0.10.so.0 -> libgstfft-0.10.so.0.23.0 libncursesw.so.5 -> libncursesw.so.5.9 libcap.so.2 -> libcap.so.2.20 libts-1.0.so.0 -> libts-1.0.so.0.0.0 libmenuw.so.5 -> libmenuw.so.5.9 libgpg-error.so.0 -> libgpg-error.so.0.3.0 libjpeg.so.8 -> libjpeg.so.8.0.2 libogg.so.0 -> libogg.so.0.6.0 libasound.so.2 -> libasound.so.2.0.0 libmms.so.0 -> libmms.so.0.0.2 libpangocairo-1.0.so.0 -> libpangocairo-1.0.so.0.2400.4 libexpat.so.1 -> libexpat.so.1.5.2 libvorbis.so.0 -> libvorbis.so.0.4.3 libpcreposix.so.0 -> libpcreposix.so.0.0.0 libICE.so.6 -> libICE.so.6.3.0 libstdc++.so.6 -> libstdc++.so.6.0.10 libpamc.so.0 -> libpamc.so.0.82.1 libgnome-keyring.so.0 -> libgnome-keyring.so.0.1.1 libgstpbutils-0.10.so.0 -> libgstpbutils-0.10.so.0.23.0 libblkid.so.1 -> libblkid.so.1.1.0 libsoup-2.4.so.1 -> libsoup-2.4.so.1.3.0 libgstrtsp-0.10.so.0 -> libgstrtsp-0.10.so.0.23.0 liba52.so.0 -> liba52.so.0.0.0 libgstphotography-0.10.so.0 -> libgstphotography-0.10.so.0.0.0 libdbus-glib-1.so.2 -> libdbus-glib-1.so.2.1.0 libbz2.so.1 -> libbz2.so.1.0.6 libsqlite3.so.0 -> libsqlite3.so.0.8.6 libusb-1.0.so.0 -> libusb-1.0.so.0.0.0 libpam_misc.so.0 -> libpam_misc.so.0.82.0 libgdk_pixbuf-2.0.so.0 -> libgdk_pixbuf-2.0.so.0.2000.1 libdirect-1.4.so.5 -> libdirect.so libsndfile.so.1 -> libsndfile.so.1.0.24 libgsttag-0.10.so.0 -> libgsttag-0.10.so.0.23.0 libgmodule-2.0.so.0 -> libgmodule-2.0.so.0.2400.1 libXau.so.6 -> libXau.so.6.0.0 libORBit-2.so.0 -> libORBit-2.so.0.1.0 libip6tc.so.0 -> libip6tc.so.0.0.0 libpthread-stubs.so.0 -> libpthread-stubs.so.0.0.0 libpcrecpp.so.0 -> libpcrecpp.so.0.0.0 libQtTest.so.4 -> libQtTest.so.4.7.4 libspeex.so.1 -> libspeex.so.1.5.0 libXdamage.so.1 -> libXdamage.so.1.1.0 libvolume_id.so.1 -> libvolume_id.so.1.1.0 libQtCore.so.4 -> libQtCore.so.4.7.4 libQtGui.so.4 -> libQtGui.so.4.7.4 libtinfo.so.5 -> libtinfo.so.5.9 libpcap.so.1 -> libpcap.so.1.1.1 libgstcontroller-0.10.so.0 -> libgstcontroller-0.10.so.0.28.0 libz.so.1 -> libz.so.1.2.3 libgstbase-0.10.so.0 -> libgstbase-0.10.so.0.28.0 libgstnetbuffer-0.10.so.0 -> libgstnetbuffer-0.10.so.0.23.0 libswscale.so.0 -> libswscale.so.0.12.0 libcrypto.so.1.0.0 -> libcrypto.so.1.0.0 libgio-2.0.so.0 -> libgio-2.0.so.0.2400.1 libXv.so.1 -> libXv.so.1.0.0 libjack.so.0 -> libjack.so.0.0.28 libcurl.so.4 -> libcurl.so.4.2.0 libfusion-1.4.so.5 -> libfusion.so libcairo.so.2 -> libcairo.so.2.11000.0 libesd.so.0 -> libesd.so.0.2.36 libX11.so.6 -> libX11.so.6.3.0 libxcb.so.1 -> libxcb.so.1.1.0 libudev.so.0 -> libudev.so.0.2.0 libXext.so.6 -> libXext.so.6.4.0 libformw.so.5 -> libformw.so.5.9 libdirectfb-1.4.so.5 -> libdirectfb.so libgstbasevideo-0.10.so.0 -> libgstbasevideo-0.10.so.0.0.0 libglib-2.0.so.0 -> libglib-2.0.so.0.2400.1 libxml2.so.2 -> libxml2.so.2.7.8 libQtNetwork.so.4 -> libQtNetwork.so.4.7.4 libpng12.so.0 -> libpng12.so.0.44.0 libvorbisenc.so.2 -> libvorbisenc.so.2.0.6 libdbus-1.so.3 -> libdbus-1.so.3.4.0 libopkg.so.0 -> libopkg.so.0.0.0 libavcodec.so.52 -> libavcodec.so.52.113.2 libgstreamer-0.10.so.0 -> libgstreamer-0.10.so libgstapp-0.10.so.0 -> libgstapp-0.10.so.0.23.0 libproxy.so.0 -> libproxy.so.0.0.0 libfaac.so.0 -> libfaac.so.0.0.0 libss.so.2 -> libss.so.2.0 libtic.so.5 -> libtic.so.5.9 libmad.so.0 -> libmad.so.0.2.1 librsvg-2.so.2 -> librsvg-2.so.2.26.2 libgstdataprotocol-0.10.so.0 -> libgstdataprotocol-0.10.so.0.28.0 libaudiofile.so.0 -> libaudiofile.so.0.0.2 libcom_err.so.2 -> libcom_err.so.2.1 libXfixes.so.3 -> libXfixes.so.3.1.0 libusb-0.1.so.4 -> libusb-0.1.so.4.4.4 libgstaudio-0.10.so.0 -> libgstaudio-0.10.so.0.23.0 libavutil.so.50 -> libavutil.so.50.39.0 libgstinterfaces-0.10.so.0 -> libgstinterfaces-0.10.so.0.23.0 libgsm.so.1 -> libgsm.so.1.0.12 libgstcdda-0.10.so.0 -> libgstcdda-0.10.so.0.23.0 libpixman-1.so.0 -> libpixman-1.so.0.21.6 Mon Apr 28 17:37:00 GMT 2014 INIT: Entering runlevel: 5 -------------------------------------------------------------------------------- Driver Loading... -------------------------------------------------------------------------------- load cmemk... CMEMK module: built on Feb 26 2014 at 15:35:35 Reference Linux version 2.6.37 File /home/pal/ti-ezsdk_dm814x-evm_5_05_02_00/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c allocated heap buffer 0xdc000000 of size 0x13ec000 cmemk initialized load syslink... SysLink version : 2.20.02.20 SysLink module created on Date:Apr 21 2014 Time:11:38:43 Trace enabled Trace SetFailureReason enabled Trace class 3 MemoryOS_map: pa=0x480ca800, va=0xfa0ca800, sz=0x1000 load dm814x_hdvicp... NameServer Module already initialized! SharedRegion Module already initialized! GateMP Module already initialized! MessageQ Module already initialized! HeapBufMP Module already initialized! HeapMemMP Module already initialized! ListMP Module already initialized! ClientNotifyMgr Module already initialized! FrameQBufMgr Module already initialized! FrameQ Module already initialized! ProcMgr_getProcInfo: bootMode: [0] MemoryOS_map: pa=0x48180000, va=0xfa180000, sz=0x2fff MemoryOS_map: pa=0x55080000, va=0xf9080000, sz=0xfff MemoryOS_map: pa=0x55020000, va=0xf9020000, sz=0x8 DM8168VIDEOM3PROC_attach: Mapping memory regions MemoryOS_map: pa=0x55020004, va=0xf9020004, sz=0x4 MemoryOS_map: entry already exists mapInfo->src [0x48180000] mapInfo->dst [0xfa180000] mapInfo->size [0x2fff] DM8168VIDEOM3PROC_attach: slave is now in reset MemoryOS_map: pa=0x55020000, va=0xf9020000, sz=0x4000 MemoryOS_map: pa=0x55024000, va=0xf9024000, sz=0xc000 MemoryOS_map: pa=0x40300000, va=0xdb700000, sz=0x40000 _ProcMgr_map for SlaveVirt: dstAddr [0x300000] sgList.paddr [0x40300000] sgList.offset [0x0] sgList.size [0x40000] DM8168VIDEOM3PROC_map: found static entry: [2] sva=0x300000, mpa=0x40300000 size=0x40000 MemoryOS_map: pa=0x40400000, va=0xdb780000, sz=0x40000 _ProcMgr_map for SlaveVirt: dstAddr [0x400000] sgList.paddr [0x40400000] sgList.offset [0x0] sgList.size [0x40000] DM8168VIDEOM3PROC_map: found static entry: [3] sva=0x400000, mpa=0x40400000 size=0x40000 ProcMgr_getProcInfo: bootMode: [0] OsalDrv_mmap(): setting cache disabled for physical address 55020000 OsalDrv_mmap(): setting cache disabled for physical address 55024000 OsalDrv_mmap(): setting cache disabled for physical address 40300000 OsalDrv_mmap(): setting cache disabled for physical address 40400000 Attached to slave procId 1. Loading procId 1. DLOAD: ELF: ELF DLOAD: ELF file header entry point: 9e3c4a65 ElfLoaderTrgWrite_copy: translated 0x0 (sva) --> 0x55020000 (mpa) MemoryOS_map: pa=0x55020000, va=0xf9020000, sz=0x3c _ProcMgr_map for SlaveVirt: dstAddr [0x0] sgList.paddr [0x55020000] sgList.offset [0x0] sgList.size [0x3c] DM8168VIDEOM3PROC_map: found static entry: [0] sva=0x0, mpa=0x55020000 size=0x4000 ElfLoaderTrgWrite_copy: translated 0x400 (sva) --> 0x55020400 (mpa) MemoryOS_map: pa=0x55020400, va=0xf9020400, sz=0x140 _ProcMgr_map for SlaveVirt: dstAddr [0x0] sgList.paddr [0x55020000] sgList.offset [0x400] sgList.size [0x540] DM8168VIDEOM3PROC_map: found static entry: [0] sva=0x0, mpa=0x55020000 size=0x4000 ElfLoaderTrgWrite_copy: translated 0x7f0 (sva) --> 0x550207f0 (mpa) MemoryOS_map: pa=0x550207f0, va=0xf90207f0, sz=0x10 _ProcMgr_map for SlaveVirt: dstAddr [0x0] sgList.paddr [0x55020000] sgList.offset [0x7f0] sgList.size [0x800] DM8168VIDEOM3PROC_map: found static entry: [0] sva=0x0, mpa=0x55020000 size=0x4000 ElfLoaderTrgWrite_copy: translated 0x9dd00000 (sva) --> 0x9dd00000 (mpa) MemoryOS_map: pa=0x9dd00000, va=0xdb800000, sz=0x2c3b85 _ProcMgr_map for SlaveVirt: dstAddr [0x9dd00000] sgList.paddr [0x9dd00000] sgList.offset [0x0] sgList.size [0x2c3b85] DM8168VIDEOM3PROC_map: adding dynamic entry: [4] sva=0x9dd00000, mpa=0x9dd00000, size=0x2c3b85 ElfLoaderTrgWrite_copy: translated 0x9dfc3b88 (sva) --> 0x9dfc3b88 (mpa) MemoryOS_map: pa=0x9dfc3b88, va=0xdbc00b88, sz=0x291be4 _ProcMgr_map for SlaveVirt: dstAddr [0x9dfc3000] sgList.paddr [0x9dfc3000] sgList.offset [0xb88] sgList.size [0x29276c] DM8168VIDEOM3PROC_map: adding dynamic entry: [5] sva=0x9dfc3000, mpa=0x9dfc3000, size=0x29276c ElfLoaderTrgWrite_copy: translated 0x9e255780 (sva) --> 0x9e255780 (mpa) MemoryOS_map: pa=0x9e255780, va=0xdb77c780, sz=0x34 _ProcMgr_map for SlaveVirt: dstAddr [0x9e255000] sgList.paddr [0x9e255000] sgList.offset [0x780] sgList.size [0x7b4] DM8168VIDEOM3PROC_map: adding dynamic entry: [6] sva=0x9e255000, mpa=0x9e255000, size=0x7b4 ElfLoaderTrgWrite_copy: translated 0x9e258000 (sva) --> 0x9e258000 (mpa) MemoryOS_map: pa=0x9e258000, va=0xdbb00000, sz=0x75038 _ProcMgr_map for SlaveVirt: dstAddr [0x9e258000] sgList.paddr [0x9e258000] sgList.offset [0x0] sgList.size [0x75038] DM8168VIDEOM3PROC_map: adding dynamic entry: [7] sva=0x9e258000, mpa=0x9e258000, size=0x75038 ElfLoaderTrgWrite_copy: translated 0x9e330000 (sva) --> 0x9e330000 (mpa) MemoryOS_map: pa=0x9e330000, va=0xdbf00000, sz=0x9a5b6 _ProcMgr_map for SlaveVirt: dstAddr [0x9e330000] sgList.paddr [0x9e330000] sgList.offset [0x0] sgList.size [0x9a5b6] DM8168VIDEOM3PROC_map: adding dynamic entry: [8] sva=0x9e330000, mpa=0x9e330000, size=0x9a5b6 ElfLoaderTrgWrite_copy: translated 0x9e510000 (sva) --> 0x9e510000 (mpa) MemoryOS_map: pa=0x9e510000, va=0xdd500000, sz=0xed000 _ProcMgr_map for SlaveVirt: dstAddr [0x9e510000] sgList.paddr [0x9e510000] sgList.offset [0x0] sgList.size [0xed000] DM8168VIDEOM3PROC_map: adding dynamic entry: [9] sva=0x9e510000, mpa=0x9e510000, size=0xed000 ElfLoaderTrgWrite_copy: translated 0xbffff000 (sva) --> 0xbffff000 (mpa) MemoryOS_map: pa=0xbffff000, va=0xdb7ce000, sz=0x4 _ProcMgr_map for SlaveVirt: dstAddr [0xbffff000] sgList.paddr [0xbffff000] sgList.offset [0x0] sgList.size [0x4] DM8168VIDEOM3PROC_map: adding dynamic entry: [10] sva=0xbffff000, mpa=0xbffff000, size=0x4 Loaded file dm81 DM8168VIDEOM3PROC_start: Configuring boot register Reset vector [0x9e3c4a65]! 4x_hdvicp.xem3 o DM8168VIDEOM3PROC_start: Slave successfully started! n slave procId 1. Started slave Notify: Termination packet procId 1. load dm814x_hdvpss_v4l2... NameServer Module already initialized! SharedRegion Module already initialized! GateMP Module already initialized! MessageQ Module already initialized! HeapBufMP Module already initialized! HeapMemMP Module already initialized! ListMP Module already initialized! ClientNotifyMgr Module already initialized! FrameQBufMgr Module already initialized! FrameQ Module already initialized! ProcMgr_getProcInfo: bootMode: [0] MemoryOS_map: entry already exists mapInfo->src [0x48180000] mapInfo->dst [0xfa180000] mapInfo->size [0x2fff] MemoryOS_map: entry already exists mapInfo->src [0x55080000] mapInfo->dst [0xf9080000] mapInfo->size [0xfff] MemoryOS_map: entry already exists mapInfo->src [0x55020000] mapInfo->dst [0xf9020000] mapInfo->size [0x8] DM8168VPSSM3PROC_attach: Mapping memory regions MemoryOS_map: entry already exists mapInfo->src [0x55020004] mapInfo->dst [0xf9020004] mapInfo->size [0x4] MemoryOS_map: entry already exists mapInfo->src [0x48180000] mapInfo->dst [0xfa180000] mapInfo->size [0x2fff] DM8168VPSSM3PROC_attach: slave is now in reset MemoryOS_map: entry already exists mapInfo->src [0x55020000] mapInfo->dst [0xf9020000] mapInfo->size [0x4000] MemoryOS_map: entry already exists mapInfo->src [0x55024000] mapInfo->dst [0xf9024000] mapInfo->size [0xc000] MemoryOS_map: entry already exists mapInfo->src [0x40300000] mapInfo->dst [0xdb700000] mapInfo->size [0x40000] _ProcMgr_map for SlaveVirt: dstAddr [0x300000] sgList.paddr [0x40300000] sgList.offset [0x0] sgList.size [0x40000] DM8168VPSSM3PROC_map: found static entry: [2] sva=0x300000, mpa=0x40300000 size=0x40000 MemoryOS_map: entry already exists mapInfo->src [0x40400000] mapInfo->dst [0xdb780000] mapInfo->size [0x40000] _ProcMgr_map for SlaveVirt: dstAddr [0x400000] sgList.paddr [0x40400000] sgList.offset [0x0] sgList.size [0x40000] DM8168VPSSM3PROC_map: found static entry: [3] sva=0x400000, mpa=0x40400000 size=0x40000 ProcMgr_getProcInfo: bootMode: [0] OsalDrv_mmap(): setting cache disabled for physical address 55020000 OsalDrv_mmap(): setting cache disabled for physical address 55024000 OsalDrv_mmap(): setting cache disabled for physical address 40300000 OsalDrv_mmap(): setting cache disabled for physical address 40400000 Attached to slave procId 2. Loading procId 2. DLOAD: ELF: ELF DLOAD: ELF file header entry point: 9f669685 DM8168VPSSM3PROC_translate: translated [0] srcAddr=0x0 --> dstAddr=0x55020000 ElfLoaderTrgWrite_copy: translated 0x0 (sva) --> 0x55020000 (mpa) MemoryOS_map: entry already exists mapInfo->src [0x55020000] mapInfo->dst [0xf9020000] mapInfo->size [0x3c] _ProcMgr_map for SlaveVirt: dstAddr [0x0] sgList.paddr [0x55020000] sgList.offset [0x0] sgList.size [0x3c] DM8168VPSSM3PROC_map: found static entry: [0] sva=0x0, mpa=0x55020000 size=0x4000 DM8168VPSSM3PROC_translate: translated [0] srcAddr=0x7f0 --> dstAddr=0x550207f0 ElfLoaderTrgWrite_copy: translated 0x7f0 (sva) --> 0x550207f0 (mpa) MemoryOS_map: entry already exists mapInfo->src [0x550207f0] mapInfo->dst [0xf90207f0] mapInfo->size [0x10] _ProcMgr_map for SlaveVirt: dstAddr [0x0] sgList.paddr [0x55020000] sgList.offset [0x7f0] sgList.size [0x800] DM8168VPSSM3PROC_map: found static entry: [0] sva=0x0, mpa=0x55020000 size=0x4000 DM8168VPSSM3PROC_translate: translated [0] srcAddr=0x800 --> dstAddr=0x55020800 ElfLoaderTrgWrite_copy: translated 0x800 (sva) --> 0x55020800 (mpa) MemoryOS_map: pa=0x55020800, va=0xf9020800, sz=0x140 _ProcMgr_map for SlaveVirt: dstAddr [0x0] sgList.paddr [0x55020000] sgList.offset [0x800] sgList.size [0x940] DM8168VPSSM3PROC_map: found static entry: [0] sva=0x0, mpa=0x55020000 size=0x4000 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9e700000 --> dstAddr=0x9e700000 ElfLoaderTrgWrite_copy: translated 0x9e700000 (sva) --> 0x9e700000 (mpa) MemoryOS_map: pa=0x9e700000, va=0xdd800000, sz=0x5dcf34 _ProcMgr_map for SlaveVirt: dstAddr [0x9e700000] sgList.paddr [0x9e700000] sgList.offset [0x0] sgList.size [0x5dcf34] DM8168VPSSM3PROC_map: adding dynamic entry: [4] sva=0x9e700000, mpa=0x9e700000, size=0x5dcf34 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9ecdcf38 --> dstAddr=0x9ecdcf38 ElfLoaderTrgWrite_copy: translated 0x9ecdcf38 (sva) --> 0x9ecdcf38 (mpa) MemoryOS_map: pa=0x9ecdcf38, va=0xdbbb0f38, sz=0x30c8 _ProcMgr_map for SlaveVirt: dstAddr [0x9ecdc000] sgList.paddr [0x9ecdc000] sgList.offset [0xf38] sgList.size [0x4000] DM8168VPSSM3PROC_map: adding dynamic entry: [5] sva=0x9ecdc000, mpa=0x9ecdc000, size=0x4000 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9ece0000 --> dstAddr=0x9ece0000 ElfLoaderTrgWrite_copy: translated 0x9ece0000 (sva) --> 0x9ece0000 (mpa) MemoryOS_map: pa=0x9ece0000, va=0xde000000, sz=0x7325f8 _ProcMgr_map for SlaveVirt: dstAddr [0x9ece0000] sgList.paddr [0x9ece0000] sgList.offset [0x0] sgList.size [0x7325f8] DM8168VPSSM3PROC_map: adding dynamic entry: [6] sva=0x9ece0000, mpa=0x9ece0000, size=0x7325f8 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9f4125f8 --> dstAddr=0x9f4125f8 ElfLoaderTrgWrite_copy: translated 0x9f4125f8 (sva) --> 0x9f4125f8 (mpa) MemoryOS_map: pa=0x9f4125f8, va=0xdbbba5f8, sz=0x8 _ProcMgr_map for SlaveVirt: dstAddr [0x9f412000] sgList.paddr [0x9f412000] sgList.offset [0x5f8] sgList.size [0x600] DM8168VPSSM3PROC_map: adding dynamic entry: [7] sva=0x9f412000, mpa=0x9f412000, size=0x600 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9f412600 --> dstAddr=0x9f412600 ElfLoaderTrgWrite_copy: translated 0x9f412600 (sva) --> 0x9f412600 (mpa) MemoryOS_map: pa=0x9f412600, va=0xdd600600, sz=0xed000 _ProcMgr_map for SlaveVirt: dstAddr [0x9f412000] sgList.paddr [0x9f412000] sgList.offset [0x600] sgList.size [0xed600] DM8168VPSSM3PROC_map: adding dynamic entry: [8] sva=0x9f412000, mpa=0x9f412000, size=0xed600 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9f4ff600 --> dstAddr=0x9f4ff600 ElfLoaderTrgWrite_copy: translated 0x9f4ff600 (sva) --> 0x9f4ff600 (mpa) MemoryOS_map: pa=0x9f4ff600, va=0xdbbe0600, sz=0x13149 _ProcMgr_map for SlaveVirt: dstAddr [0x9f4ff000] sgList.paddr [0x9f4ff000] sgList.offset [0x600] sgList.size [0x13749] DM8168VPSSM3PROC_map: adding dynamic entry: [9] sva=0x9f4ff000, mpa=0x9f4ff000, size=0x13749 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9f512760 --> dstAddr=0x9f512760 ElfLoaderTrgWrite_copy: translated 0x9f512760 (sva) --> 0x9f512760 (mpa) MemoryOS_map: pa=0x9f512760, va=0xdbea0760, sz=0x17000 _ProcMgr_map for SlaveVirt: dstAddr [0x9f512000] sgList.paddr [0x9f512000] sgList.offset [0x760] sgList.size [0x17760] DM8168VPSSM3PROC_map: adding dynamic entry: [10] sva=0x9f512000, mpa=0x9f512000, size=0x17760 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9f529780 --> dstAddr=0x9f529780 ElfLoaderTrgWrite_copy: translated 0x9f529780 (sva) --> 0x9f529780 (mpa) MemoryOS_map: pa=0x9f529780, va=0xdbbca780, sz=0x34 _ProcMgr_map for SlaveVirt: dstAddr [0x9f529000] sgList.paddr [0x9f529000] sgList.offset [0x780] sgList.size [0x7b4] DM8168VPSSM3PROC_map: adding dynamic entry: [11] sva=0x9f529000, mpa=0x9f529000, size=0x7b4 DM8168VPSSM3PROC_translate: (default) srcAddr=0x9f590000 --> dstAddr=0x9f590000 ElfLoaderTrgWrite_copy: translated 0x9f590000 (sva) --> 0x9f590000 (mpa) MemoryOS_map: pa=0x9f590000, va=0xdd700000, sz=0xdf256 _ProcMgr_map for SlaveVirt: dstAddr [0x9f590000] sgList.paddr [0x9f590000] sgList.offset [0x0] sgList.size [0xdf256] DM8168VPSSM3PROC_map: adding dynamic entry: [12] sva=0x9f590000, mpa=0x9f590000, size=0xdf256 DM8168VPSSM3PROC_translate: (default) srcAddr=0xbfd00000 --> dstAddr=0xbfd00000 ElfLoaderTrgWrite_copy: translated 0xbfd00000 (sva) --> 0xbfd00000 (mpa) MemoryOS_map: pa=0xbfd00000, va=0xde800000, sz=0x1ff060 _ProcMgr_map for SlaveVirt: dstAddr [0xbfd00000] sgList.paddr [0xbfd00000] sgList.offset [0x0] sgList.size [0x1ff060] DM8168VPSSM3PROC_map: adding dynamic entry: [13] sva=0xbfd00000, mpa=0xbfd00000, size=0x1ff060 DM8168VPSSM3PROC_translate: (default) srcAddr=0xbffff800 --> dstAddr=0xbffff800 ElfLoaderTrgWrite_copy: translated 0xbffff800 (sva) --> 0xbffff800 (mpa) MemoryOS_map: pa=0xbffff800, va=0xdbbd6800, sz=0x4 _ProcMgr_map for SlaveVirt: dstAddr [0xbffff000] sgList.paddr [0xbffff000] sgList.offset [0x800] sgList.size [0x804] DM8168VPSSM3PROC_map: adding dynamic entry: [14] sva=0xbffff000, mpa=0xbffff000, size=0x804 Loaded file dm81 DM8168VPSSM3PROC_start: Configuring boot register Reset vector [0x9f669685]! 4x_hdvpss_v4l2.x DM8168VPSSM3PROC_start: Slave successfully started! em3 on slave procId 2. Started Notify: Termination packet slave procId 2. load vpss... VPSS_FVID2: M3 firmware version 0x1000145 is newer,driver may not work properly. load ti81xxfb... load ti81xxvo... load tvp5150... load ti81xxvin... tvp5150 1-005c: chip found @ 0xb8 (OMAP I2C adapter) tvp5150 1-005c: tvp5150am1 detected. ti81xxvin ti81xxvin: registered sub device tvp5150 ti81xxvin ti81xxvin: TI81xx HDVPSS Capture driver initialized load ti81xxvhdmi... HDMI W1 rev 4.0 HDMI CEC Spec version 1.2 I2C No Ack load gpio... Starting system message bus: dbus. Starting telnet daemon. Starting syslogd/klogd: done Starting thttpd. SGX reading sgx pwrstst /dev/mem opened. Memory mapped at address 0x40256000. Read at address 0x48180F04 (0x40256f04): 0x00000001 /dev/mem opened. Memory mapped at address 0x40147000. Read at address 0x48180920 (0x40147920): 0x00070000 Write at address 0x48180920 (0x40147920): 0x00000000, readback 0x00000000 /dev/mem opened. Memory mapped at address 0x402aa000. Read at address 0x48180900 (0x402aa900): 0x00000001 Write at address 0x48180900 (0x402aa900): 0x00000001, readback 0x00000001 /dev/mem opened. Memory mapped at address 0x4029a000. Read at address 0x48180F00 (0x4029af00): 0x00030000 Write at address 0x48180F00 (0x4029af00): 0x00000000, readback 0x00000000 reading sgx pwrstst /dev/mem opened. Memory mapped at address 0x4017d000. Read at address 0x48180F04 (0x4017df04): 0x00000001 Create Ramdisk mkdir: cannot create directory '/mnt/ram': File exists ntsc composite I2C No Ack Start User Application... -------------------------------------------------------------------------------- 2013.06.21 dm814x-evm ttyO0 dm814x-evm login: root root@dm814x-evm:~# root@dm814x-evm:~# gst-launch --gst-debug=3 -v videotestsrc num-buffers=1000 ! omx_h264enc ! filesink location=sample.264 0:00:00.002063992 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_INIT gstquery.c:108:_gst_query_initialize:[00m init queries 0:00:00.008289519 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_INIT gstmessage.c:73:_gst_message_initialize:[00m init messages 0:00:00.009814965 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:350:_gst_plugin_initialize:[00m registering 0 static plugins 0:00:00.010789712 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:255:gst_plugin_register_static:[00m registered static plugin "staticelements" 0:00:00.010879712 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:257:gst_plugin_register_static:[00m added static plugin "staticelements", result: 1 0:00:00.010954812 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistry.c:1599:ensure_current_registry:[00m reading registry cache: /tmp/gst_registry.bin 0:00:00.012036209 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistrybinary.c:532:gst_registry_binary_read_cache:[00m Unable to mmap file /tmp/gst_registry.bin : Failed to open file '/tmp/gst_registry.bin': open() failed: No such file or directory 0:00:00.012292258 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistrybinary.c:542:gst_registry_binary_read_cache:[00m Unable to read file /tmp/gst_registry.bin : Failed to open file '/tmp/gst_registry.bin': No such file or directory 0:00:00.012376358 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistry.c:1469:scan_and_update_registry:[00m Validating plugins from registry cache: /tmp/gst_registry.bin (gst-plugin-scanner:1214): GLib-GObject-WARNING **: cannot register existing type `GstVideoMixerPad' 0:00:03.598943706 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistry.c:1570:scan_and_update_registry:[00m Registry cache changed. Writing new registry cache 0:00:03.599206556 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistrybinary.c:364:gst_registry_binary_write_cache:[00m Building binary registry cache image 0:00:03.657083506 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistrybinary.c:396:gst_registry_binary_write_cache:[00m Writing binary registry cache 0:00:03.748426906 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistrybinary.c:258:gst_registry_binary_cache_finish:[00m Wrote binary registry cache 0:00:03.748666856 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistry.c:1578:scan_and_update_registry:[00m Registry cache written successfully 0:00:03.748736856 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m GST_REGISTRY gstregistry.c:1628:ensure_current_registry:[00m registry reading and updating done, result = 1 0:00:03.748796256 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_INIT gst.c:792:init_post:[00m GLib runtime version: 2.24.1 0:00:03.748863956 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_INIT gst.c:794:init_post:[00m GLib headers version: 2.24.1 0:00:03.749212156 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_PIPELINE gstparse.c:299:gst_parse_launch_full:[00m parsing pipeline description 'videotestsrc num-buffers=1000 ! omx_h264enc ! filesink location=sample.264 ' 0:00:03.753393056 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file:[00m plugin "/usr/lib/gstreamer-0.10/libgstvideotestsrc.so" loaded 0:00:03.753520606 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create:[00m creating element "videotestsrc" 0:00:03.759252756 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSrc@0x1e4080>[00m adding pad 'src' 0:00:03.802107256 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m omx gstomx_videomixer.c:2183:init_interfaces:[00m GstChildProxy interface registered 0:00:03.802276556 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file:[00m plugin "/usr/lib/gstreamer-0.10/libgstomx.so" loaded 0:00:03.802357306 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create:[00m creating element "omx_h264enc" 0:00:03.804626706 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x1e60b8>[00m adding pad 'sink' 0:00:03.804749956 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x1e60b8>[00m adding pad 'src' 0:00:03.809101256 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file:[00m plugin "/usr/lib/gstreamer-0.10/libgstcoreelements.so" loaded 0:00:03.809227556 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create:[00m creating element "filesink" 0:00:03.810369406 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSink@0x1ea138>[00m adding pad 'sink' 0:00:03.810801556 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create:[00m creating element "pipeline" 0:00:03.811411206 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_PIPELINE ./grammar.y:568:gst_parse_perform_link:[00m linking videotestsrc0:(any) to omxh264enc0:(any) (0/0) with caps "(nil)" 0:00:03.811535956 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full:[00m trying to link element videotestsrc0:(any) to element omxh264enc0:(any) 0:00:03.811643956 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1028:gst_pad_check_link:[00m trying to link videotestsrc0:src and omxh264enc0:sink 0:00:03.812830456 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting:[00m videotestsrc0 and omxh264enc0 in same bin, no need for ghost pads 0:00:03.813060506 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstpad.c:1941:gst_pad_link_prepare:[00m trying to link videotestsrc0:src and omxh264enc0:sink 0:00:03.814079056 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2124:gst_pad_link_full:[00m linked videotestsrc0:src and oNameServer Module already initialized! mxh264enc0:sink,SharedRegion Module already initialized! successful 0:0GateMP Module already initialized! 0:03.814249006 [332m 1213[00m MessageQ Module already initialized! 0x16050 [32;HeapBufMP Module already initialized! 01mINFO [00m HeapMemMP Module already initialized! [00;01;37;41m ListMP Module already initialized! GST_PIPELIClientNotifyMgr Module already initialized! NE ./grammar.y:5FrameQBufMgr Module already initialized! 68:gst_parse_perFrameQ Module already initialized! form_link:[00m ProcMgr_getProcInfo: bootMode: [0] linking omxh264eOsalDrv_mmap(): setting cache disabled for physical address 55020000 nc0:(any) to filOsalDrv_mmap(): setting cache disabled for physical address 55024000 esink0:(any) (0/OsalDrv_mmap(): setting cache disabled for physical address 40300000 0) with caps "(nOsalDrv_mmap(): setting cache disabled for physical address 40400000 il)" 0:00:04.14OsalDrv_mmap(): setting cache disabled for physical address 55020000 9712206 [332m 1OsalDrv_mmap(): setting cache disabled for physical address 55020000 213[00m 0x16OsalDrv_mmap(): setting cache disabled for physical address 55020000 050 [32;01mINFOOsalDrv_mmap(): setting cache disabled for physical address 9dd00000 [00m [00;01OsalDrv_mmap(): setting cache disabled for physical address 9dfc3000 ;37;41m GST_EOsalDrv_mmap(): setting cache disabled for physical address 9e255000 LEMENT_PADS gstuOsalDrv_mmap(): setting cache disabled for physical address 9e258000 tils.c:1568:gst_OsalDrv_mmap(): setting cache disabled for physical address 9e330000 element_link_padOsalDrv_mmap(): setting cache disabled for physical address 9e510000 s_full:[00m tryOsalDrv_mmap(): setting cache disabled for physical address bffff000 ing to link elemAssertion at Line no: 467 in /home/pal/ti-ezsdk_dm814x-evm_5_05_02_00/component-sources/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/Linux/SharedRegionDrv.c: (heapHandle != NULL) : failed ent omxh264enc0:OsalSemaphore_pend: Semaphore pend interrupted Handle [0xdbfae000] (any) to element filesink0:(any) 0:00:04.149807356 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1028:gst_pad_check_link:[00m trying to link omxh264enc0:src and filesink0:sink 0:00:04.149911456 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting:[00m omxh264enc0 and filesink0 in same bin, no need for ghost pads 0:00:04.150030756 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstpad.c:1941:gst_pad_link_prepare:[00m trying to link omxh264enc0:src and filesink0:sink 0:00:04.150121056 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2124:gst_pad_link_full:[00m linked omxh264enc0:src and filesink0:sink, successful Setting pipeline to PAUSED ... 0:00:04.151767606 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_STATES gstelement.c:2341:gst_element_continue_state:<filesink0>[00m completed state change to READY 0:00:04.151873556 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<filesink0>[00m posting state-changed NULL to READY 0:00:04.152104606 [332m 1213[00m 0x16050 [32;01mINFO [00m [00;01;31m GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' changed state to 2(READY) successfully 0:00:04.152224706 [332m 1213[00m 0x16050 [32;01mINFO [00m [00m omx gstomx_base_filter.c:153:change_state:<omxh264enc0>[00m begin: changing state NULL -> READY Assertion at Line no: 1349 in /home/pal/ti-ezsdk_dm814x-evm_5_05_02_00/component-sources/syslink_2_20_02_20/packages/ti/syslink/ipc/hlos/usr/HeapMemMP.c: (hpHandle != NULL) : failed gst-launch-0.10: DmmDelegateHeap.c:193: DmmDelegate_createIpcHeap: Assertion `(heapHandle != 0)' failed. Aborted root@dm814x-evm:~#
