Need some help with the amixer settings for BT UL/DL (uplink and Downlink) to work from user space
Have attached the amixer/aplay/arecord settings as a text file.
It will good to know how to route the data from the BT_VX Switch to the Headset or save a raw pcm in user space by running the arecord as shown below.
Currently i'm trying to run these amixer settings, but nothing seems to happen
amixer cset name='MUX_UL10' 7
amixer cset name='MUX_UL11' 8
amixer cset name='DL1 BT_VX Switch' 1
arecord -f S32_LE -d 10 -D hw:0,13 record.wav
Any clues on why this should happen?
Logs attached below:
amixer output :
Simple mixer control 'Sidetone Equalizer',0
Capabilities: enum
Items: 'Flat response' 'High-pass 0dB' 'High-pass -12dB' 'High-pass -18dB'
Item0: 'Flat response'
Simple mixer control 'Sidetone Mixer Capture',0
Capabilities: pswitch pswitch-joined penum
Playback channels: Mono
Mono: Playback [off]
Simple mixer control 'Sidetone Mixer Playback',0
Mono: Playback [on]
Simple mixer control 'Aux FM',0
Capabilities: volume penum
Playback channels: Front Left - Front Right
Capture channels: Front Left - Front Right
Limits: 0 - 7
Front Left: 0 [0%] [-18.00dB]
Front Right: 0 [0%] [-18.00dB]
Simple mixer control 'Capture',0
Capabilities: cvolume penum
Limits: Capture 0 - 4
Front Left: Capture 4 [100%] [30.00dB]
Front Right: Capture 4 [100%] [30.00dB]
Simple mixer control 'Capture Mixer Media Playback',0
Simple mixer control 'Capture Mixer Tones',0
Simple mixer control 'Capture Mixer Voice Capture',0
Simple mixer control 'Capture Mixer Voice Playback',0
Simple mixer control 'Capture Preamplifier',0
Limits: 0 - 1
Front Left: 1 [100%] [0.00dB]
Front Right: 1 [100%] [0.00dB]
Simple mixer control 'AMIC Equalizer',0
Capabilities: enum
Items: 'High-pass 0dB' 'High-pass -12dB' 'High-pass -18dB'
Item0: 'High-pass 0dB'
Simple mixer control 'AMIC UL',0
Limits: 0 - 149
Front Left: 120 [81%] [0.00dB]
Front Right: 120 [81%] [0.00dB]
Simple mixer control 'AUDUL Media',0
Capabilities: volume volume-joined penum
Capture channels: Mono
Limits: 0 - 149
Mono: 0 [0%] [-99999.99dB]
Simple mixer control 'AUDUL Mono Mixer',0
Simple mixer control 'AUDUL Tones',0
Limits: 0 - 149
Simple mixer control 'AUDUL Voice DL',0
Limits: 0 - 149
Simple mixer control 'AUDUL Voice UL',0
Limits: 0 - 149
Mono: 120 [81%] [0.00dB]
Simple mixer control 'AUXL',0
Simple mixer control 'AUXR',0
Simple mixer control 'Analog Left',0
Capabilities: cenum
Items: 'Headset Mic' 'Main Mic' 'Aux/FM Left' 'Off'
Item0: 'Off'
Simple mixer control 'Analog Right',0
Capabilities: cenum
Items: 'Headset Mic' 'Sub Mic' 'Aux/FM Right' 'Off'
Item0: 'Off'
Simple mixer control 'BT UL',0
Limits: 0 - 149
Simple mixer control 'DL1 BT_VX',0
Simple mixer control 'DL1 Capture',0
Capabilities: pvolume pvolume-joined penum
Limits: Playback 0 - 149
Mono: Playback 0 [0%] [-99999.99dB]
Simple mixer control 'DL1 Equalizer',0
Capabilities: enum
Items: 'Flat response' 'High-pass 0dB' 'High-pass -12dB' 'High-pass -20dB' '4Khz LPF 0dB'
Simple mixer control 'DL1 MM_EXT',0
Simple mixer control 'DL1 Media',0
Mono: Playback 90 [60%] [-30.00dB]
Simple mixer control 'DL1 Mixer Capture',0
Simple mixer control 'DL1 Mixer Multimedia',0
Mono: Playback [on]
Simple mixer control 'DL1 Mixer Tones',0
Simple mixer control 'DL1 Mixer Voice',0
Simple mixer control 'DL1 Mono Mixer',0
Simple mixer control 'DL1 PDM',0
Mono: Playback [on]
Simple mixer control 'DL1 Tones',0
Simple mixer control 'DL1 Voice',0
Simple mixer control 'DL2 Capture',0
Simple mixer control 'DL2 Left Equalizer',0
Capabilities: enum
Items: 'Flat response' 'High-pass 0dB' 'High-pass -12dB' 'High-pass -20dB' '450Hz High-pass'
Simple mixer control 'DL2 Media',0
Simple mixer control 'DL2 Mixer Capture',0
Simple mixer control 'DL2 Mixer Multimedia',0
Simple mixer control 'DL2 Mixer Tones',0
Simple mixer control 'DL2 Mixer Voice',0
Simple mixer control 'DL2 Mono Mixer',0
Simple mixer control 'DL2 Right Equalizer',0
Capabilities: enum
Simple mixer control 'DL2 Tones',0
Simple mixer control 'DL2 Voice',0
Simple mixer control 'DMIC Equalizer',0
Capabilities: enum
Simple mixer control 'DMIC1 UL',0
Limits: 0 - 149
Simple mixer control 'DMIC2 UL',0
Limits: 0 - 149
Simple mixer control 'DMIC3 UL',0
Limits: 0 - 149
Simple mixer control 'Earphone',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Limits: Playback 0 - 15
Mono: Playback 0 [0%] [-24.00dB] [off]
Simple mixer control 'Handsfree',0
Capabilities: pvolume penum
Limits: Playback 0 - 29
Mono:
Front Left: Playback 0 [0%] [-52.00dB]
Front Right: Playback 0 [0%] [-52.00dB]
Simple mixer control 'Handsfree Left Playback',0
Capabilities: enum
Items: 'Off' 'HF DAC' 'Line-In amp'
Item0: 'Off'
Simple mixer control 'Handsfree Right Playback',0
Capabilities: enum
Item0: 'Off'
Simple mixer control 'Headset',0
Mono:
Front Left: Playback 13 [87%] [-4.00dB]
Front Right: Playback 13 [87%] [-4.00dB]
Simple mixer control 'Headset Left Playback',0
Capabilities: enum
Items: 'Off' 'HS DAC' 'Line-In amp'
Item0: 'HS DAC'
Simple mixer control 'Headset Power Mode',0
Capabilities: enum
Items: 'Low-Power' 'High-Perfomance'
Item0: 'Low-Power'
Simple mixer control 'Headset Right Playback',0
Capabilities: enum
Item0: 'HS DAC'
Simple mixer control 'MUX_UL00',0
Capabilities: enum
Items: 'None' 'DMic0L' 'DMic0R' 'DMic1L' 'DMic1R' 'DMic2L' 'DMic2R' 'BT Left' 'BT Right' 'MMExt Left' 'MMExt Right' 'AMic0' 'AMic1' 'VX Left' 'VX Right'
Item0: 'MMExt Left'
Simple mixer control 'MUX_UL01',0
Capabilities: enum
Item0: 'MMExt Right'
Simple mixer control 'MUX_UL02',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL03',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL04',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL05',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL06',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL07',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL10',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_UL11',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_VX0',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'MUX_VX1',0
Capabilities: enum
Item0: 'None'
Simple mixer control 'PLL Selection',0
Capabilities: enum
Item0: 'Low-Power'
Simple mixer control 'SDT DL',0
Limits: 0 - 149
Simple mixer control 'SDT UL',0
Limits: 0 - 149
Simple mixer control 'VXREC Media',0
Limits: 0 - 149
Simple mixer control 'VXREC Tones',0
Limits: 0 - 149
Simple mixer control 'VXREC Voice DL',0
Limits: 0 - 149
Simple mixer control 'VXREC Voice UL',0
Limits: 0 - 149
Simple mixer control 'Vibra Left Playback',0
Capabilities: enum
Items: 'Input FF' 'Audio PDM'
Item0: 'Input FF'
Simple mixer control 'Vibra Right Playback',0
Capabilities: enum
Item0: 'Input FF'
Simple mixer control 'Voice Capture Mixer Capture',0
Simple mixer control 'Voice Capture Mixer Media Playback',0
Simple mixer control 'Voice Capture Mixer Tones Playback',0
aplay >
**** List of PLAYBACK Hardware Devices ****
card 0: PandaES [PandaES], device 0: Multimedia (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PandaES [PandaES], device 2: Voice (*) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 3: Tone Playback (*) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 4: VIB-DL (*) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 5: MODEM (*) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 6: Multimedia (*) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 8: Headset Playback twl6040-legacy-8 []
Subdevices: 1/1
card 0: PandaES [PandaES], device 9: (HS Playback) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 11: (HF Playback) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 12: (Vibra) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 13: (BT Capture) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 14: (BT Playback) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 15: (FM Playback) []
Subdevices: 1/1
card 0: PandaES [PandaES], device 16: (FM Capture) []
Subdevices: 1/1
card 1: OMAPHDMI [OMAPHDMI], device 0: HDMI omap-hdmi-hifi-0 []
Subdevices: 1/1
arecord >
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PandaES [PandaES], device 1: Multimedia Capture (*) []
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
card 0: PandaES [PandaES], device 10: (Analog Capture) []
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
arecord: main:682: audio open error: No such file or directory
