WLAN driver LInux SDK 6 to 7 issue in EVM SK
Other Parts Discussed in Thread: TPS65910, WL1271
Hi Experts,
I am trying to migrate the WLAN code from the Linux SDK 6 to 7 by updating the DTS file.
I have added the following lines of code into EVMSK DTS file with reference to schematic references.
               /* wl12xx/wl18xx card on mmc2 */
                mmc2_pins: pinmux_mmc2_pins {
                        pinctrl-single,pins = <
                                0x000 0x31      /* gpmc_ad0.mmc1_dat0, INPUT_PULLUP | MODE3 */
                                0x004 0x31      /* gpmc_ad1.mmc1_dat1, INPUT_PULLUP | MODE3 */
                                0x008 0x31      /* gpmc_ad2.mmc1_dat2, INPUT_PULLUP | MODE3 */
                                0x00C 0x31      /* gpmc_ad3.mmc1_dat3, INPUT_PULLUP | MODE3 */
                                0x084 0x32      /* gpmc_csn2.mmc1_cmd, INPUT_PULLUP | MODE3 */
                                0x080 0x32      /* gpmc_csn1.mmc1_clk, INPUT_PULLUP | MODE3 */
                /* wl12xx/wl18xx card enable/irq GPIOs. */
                wlan_pins: pinmux_wlan_pins {
                                0x40 0x07       /* gpmc_a0.gpio1_16, OUTPUT | MODE7 */
                                0x070 0x27      /* mcasp0_ahclkr.gpio3_17, INPUT | MODE7 */
                                0x07C 0x17      /* mcasp0_ahclkx.gpio3_21, OUTPUT_PULLUP | MODE7 */
        wlcore {
                compatible = "wlcore";
                gpio = <113>; /* Bank3, pin17 */
                 * TODO: use edge irqs for suspend/resume.
                 * in newer kerenls, we seem to miss interrupts when
                 * working with edge irqs, so revert back to level irqs.
                 /* platform-quirks = <1>; */
                /* if a 12xx card is there, configure the clock to
                   WL12XX_REFCLOCK_38_XTAL */
                board-ref-clock = <4>;
        kim {
                compatible = "kim";
                nshutdown_gpio = <117>; /* Bank3, pin21 */
                dev_name = "/dev/ttyO1";
                flow_cntrl = <1>;
                baud_rate = <3000000>;
        btwilink {
                compatible = "btwilink";
 wlan_en_reg: fixedregulator@2 {
                compatible = "regulator-fixed";
                regulator-name = "wlan-en-regulator";
                regulator-min-microvolt = <1800000>;
                regulator-max-microvolt = <1800000>;
                /* WLAN_EN GPIO for this board - Bank1, pin16 */
                gpio = <&gpio1 16 0>;
                /* WLAN card specific delay */
                startup-delay-us = <70000>;
                enable-active-high;
&mmc2 {
        /* these are on the crossbar and are outlined in the
           xbar-event-map element */
        dmas = <&edma 12
                &edma 13>;
        dma-names = "tx", "rx";
        status = "okay";
        vmmc-supply = <&wlan_en_reg>;
        bus-width = <4>;
        ti,non-removable;
        ti,needs-special-hs-handling;
        cap-power-off-card;
        keep-power-in-suspend;
But it doesn't worked out.
The bootup log captured is here as follows,
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x EVM-SK
[    0.000000] cma: CMA: reserved 24 MiB at 8d800000
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES1.0 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64256
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 222636K/259072K available (6159K kernel code, 568K rwdata, 2072K rodata, 347K init, 226K bss, 36436K reserved, 0K highm)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc081204c   (8233 kB)
[    0.000000]       .init : 0xc0813000 - 0xc0869cf8   ( 348 kB)
[    0.000000]       .data : 0xc086a000 - 0xc08f81b8   ( 569 kB)
[    0.000000]        .bss : 0xc08f81b8 - 0xc0930d2c   ( 227 kB)
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] OMAP clocksource: timer1 at 24000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000311] Calibrating delay loop... 479.23 BogoMIPS (lpj=2396160)
[    0.119731] pid_max: default: 32768 minimum: 301
[    0.119833] Security Framework initialized
[    0.119884] Mount-cache hash table entries: 512
[    0.128459] CPU: Testing write buffer coherency: ok
[    0.128864] Setting up static identity map for 0xc0609ca8 - 0xc0609d18
[    0.129834] devtmpfs: initialized
[    0.131567] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.193726] omap_hwmod: debugss: _wait_target_disable failed
[    0.194457] pinctrl core: initialized pinctrl subsystem
[    0.195338] regulator-dummy: no parameters
[    0.197764] NET: Registered protocol family 16
[    0.200089] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.202803] cpuidle: using governor ladder
[    0.202821] cpuidle: using governor menu
[    0.211608] platform mpu.1: FIXME: clock-name 'fck' DOES NOT exist in dt!
[    0.212710] platform 49000000.edma: FIXME: clock-name 'fck' DOES NOT exist in dt!
[    0.213959] OMAP GPIO hardware version 0.1
[    0.222584] platform 56000000.sgx: FIXME: clock-name 'fck' DOES NOT exist in dt!
[    0.226377] DSS not supported on this SoC
[    0.226398] No ATAGs?
[    0.226408] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.254304] bio: create slab <bio-0> at 0
[    0.269184] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.270126] vbat: 5000 mV
[    0.270513] lis3_reg: no parameters
[    0.270968] wlan-en-regulator: 1800 mV
[    0.274088] vgaarb: loaded
[    0.275412] SCSI subsystem initialized
[    0.276793] usbcore: registered new interface driver usbfs
[    0.276987] usbcore: registered new interface driver hub
[    0.277185] usbcore: registered new device driver usb
[    0.278175] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
[    0.278204] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[    0.278440] media: Linux media interface: v0.10
[    0.278630] Linux video capture interface: v2.00
[    0.278895] pps_core: LinuxPPS API ver. 1 registered
[    0.278904] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.279038] PTP clock support registered
[    0.281719] cfg80211: Calling CRDA to update world regulatory domain
[    0.283137] Switched to clocksource timer1
[    0.302204] NET: Registered protocol family 2
[    0.302862] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.302916] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.302948] TCP: Hash tables configured (established 2048 bind 2048)
[    0.303019] TCP: reno registered
[    0.303033] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.303054] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.303346] NET: Registered protocol family 1
[    0.303758] RPC: Registered named UNIX socket transport module.
[    0.303771] RPC: Registered udp transport module.
[    0.303778] RPC: Registered tcp transport module.
[    0.303785] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.304757] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.305410] PM: Loading am335x-pm-firmware.bin
[    0.474475] VFS: Disk quotas dquot_6.5.2
[    0.474559] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.475170] NFS: Registering the id_resolver key type
[    0.475264] Key type id_resolver registered
[    0.475274] Key type id_legacy registered
[    0.475317] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    0.475507] msgmni has been set to 482
[    0.477125] NET: Registered protocol family 38
[    0.477176] io scheduler noop registered
[    0.477186] io scheduler deadline registered
[    0.477209] io scheduler cfq registered (default)
[    0.479329] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.518857] Console: switching to colour frame buffer device 60x34
[    0.522642] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.525614] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0
[    1.142521] console [ttyO0] enabled
[    1.147718] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    1.164994] brd: module loaded
[    1.173429] loop: module loaded
[    1.177106] (stk) :sysfs entries created
[    1.181300] (stk) : debugfs entries created
[    1.189990] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.200820] usbcore: registered new interface driver zd1201
[    1.207614] usbcore: registered new interface driver asix
[    1.213552] usbcore: registered new interface driver ax88179_178a
[    1.220187] usbcore: registered new interface driver cdc_ether
[    1.226508] usbcore: registered new interface driver r815x
[    1.232519] usbcore: registered new interface driver smsc95xx
[    1.238749] usbcore: registered new interface driver net1080
[    1.244909] usbcore: registered new interface driver rndis_host
[    1.251349] usbcore: registered new interface driver cdc_subset
[    1.257753] usbcore: registered new interface driver zaurus
[    1.263899] usbcore: registered new interface driver cdc_ncm
[    1.270074] usbcore: registered new interface driver cdc_mbim
[    1.276682] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.283611] ehci-pci: EHCI PCI platform driver
[    1.288518] ehci-omap: OMAP-EHCI Host Controller driver
[    1.295026] usbcore: registered new interface driver cdc_acm
[    1.301018] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.309707] usbcore: registered new interface driver cdc_wdm
[    1.315914] usbcore: registered new interface driver usb-storage
[    1.323430] mousedev: PS/2 mouse device common for all mice
[    1.331279] input: ti-tsc as /devices/ocp.2/44e0d000.tscadc/TI-am335x-tsc/input/input0
[    1.341846] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    1.350207] i2c /dev entries driver
[    1.354509] Driver for 1-wire Dallas network protocol.
[    1.362213] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.371455] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    1.378791] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    1.386046] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[    1.392975] edma-dma-engine edma-dma-engine.0: freeing channel for 24
[    1.399809] edma-dma-engine edma-dma-engine.0: freeing channel for 25
[    1.406743] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[    1.414446] edma-dma-engine edma-dma-engine.0: allocated channel for 0:13
[    1.421640] edma-dma-engine edma-dma-engine.0: allocated channel for 0:12
[    1.502549] omap_hwmod: gpio1: _wait_target_disable failed
[    1.538827] ledtrig-cpu: registered to indicate activity on CPUs
[    1.545722] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[    1.553011] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    1.561611] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    1.567833] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[    1.574953] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[    1.583492] usbcore: registered new interface driver usbhid
[    1.589384] usbhid: USB HID core driver
[    1.595798] oprofile: no performance counters
[    1.600817] oprofile: using timer interrupt.
[    1.605739] TCP: cubic registered
[    1.609242] Initializing XFRM netlink socket
[    1.613796] NET: Registered protocol family 17
[    1.618541] NET: Registered protocol family 15
[    1.623313] 8021q: 802.1Q VLAN Support v1.8
[    1.627815] Key type dns_resolver registered
[    1.632974] cpu cpu0: cpu0 regulator not ready, retry
[    1.638451] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[    1.646839] ThumbEE CPU extension supported.
[    1.654990] tps65910 0-002d: No interrupt support, no core IRQ
[    1.663280] vrtc: 1800 mV
[    1.666410] vrtc: supplied by vbat
[    1.671257] vio: at 1500 mV
[    1.674404] vio: supplied by vbat
[    1.679310] vdd_mpu: 912 <--> 1375 mV at 1137 mV
[    1.684366] vdd_mpu: supplied by vbat
[    1.689621] vdd_core: 912 <--> 1150 mV at 1137 mV
[    1.694766] vdd_core: supplied by vbat
[    1.699836] vdd3: 5000 mV
[    1.703916] vdig1: at 1800 mV
[    1.707216] vdig1: supplied by vbat
[    1.712069] vdig2: at 1800 mV
[    1.715377] vdig2: supplied by vbat
[    1.720256] vpll: at 1800 mV
[    1.723476] vpll: supplied by vbat
[    1.728266] vdac: at 1800 mV
[    1.731458] vdac: supplied by vbat
[    1.736244] vaux1: at 1800 mV
[    1.739537] vaux1: supplied by vbat
[    1.744458] vaux2: at 3300 mV
[    1.747750] vaux2: supplied by vbat
[    1.752621] vaux33: at 3300 mV
[    1.756024] vaux33: supplied by vbat
[    1.760973] vmmc: 1800 <--> 3300 mV at 3300 mV
[    1.765851] vmmc: supplied by vbat
[    1.771236] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.778144] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    1.785386] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    1.893172] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    1.899636] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[    1.907682] libphy: 4a101000.mdio: probed
[    1.911949] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet
[    1.921730] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet
[    1.932338] Missing dual_emac_res_vlan in DT.
[    1.937006] Using 1 as Reserved VLAN for 0 slave
[    1.941908] Missing dual_emac_res_vlan in DT.
[    1.946525] Using 2 as Reserved VLAN for 1 slave
[    1.951406] Detected MACID = d4:94:a1:86:23:7b
[    1.957377] cpsw: Detected MACID = d4:94:a1:86:23:7c
[    1.964833] input: gpio_buttons.8 as /devices/gpio_buttons.8/input/input1
[    1.972765] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[    1.985891] Waiting for root device /dev/mmcblk0p2...
[    1.998341] mmc1: host does not support reading read-only switch. assuming write-enable.
[    2.012010] mmc1: new high speed SDHC card at address aaaa
[    2.018592] mmcblk0: mmc1:aaaa SU04G 3.69 GiB
[    2.026986]  mmcblk0: p1 p2
[    2.110418] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.119104] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.130223] devtmpfs: mounted
[    2.134011] Freeing unused kernel memory: 344K (c0813000 - c0869000)
INIT: version 2.88 booting
Starting udev
[    2.785094] udevd[869]: starting version 182
[    3.000116] bluetooth: disagrees about version of symbol sock_register
[    3.007121] bluetooth: Unknown symbol sock_register (err -22)
[    3.113494] bluetooth: disagrees about version of symbol __sock_recv_ts_and_drops
[    3.121448] bluetooth: Unknown symbol __sock_recv_ts_and_drops (err -22)
[    3.314270] bluetooth: disagrees about version of symbol __sock_recv_timestamp
[    3.321943] bluetooth: Unknown symbol __sock_recv_timestamp (err -22)
[    3.593621] bluetooth: disagrees about version of symbol __sock_recv_wifi_status
[    3.601481] bluetooth: Unknown symbol __sock_recv_wifi_status (err -22)
[    3.694106] PM: CM3 Firmware Version = 0x186
[    3.771897] davinci_evm sound.3: ASoC: CPU DAI (null) not registered
[    3.873479] lis3lv02d: 16 bits lis331dlh sensor found
[    3.905352] davinci_evm sound.3: snd_soc_register_card failed (-517)
[    4.014000] bluetooth: disagrees about version of symbol sock_register
[    4.020998] bluetooth: Unknown symbol sock_register (err -22)
[    4.043826] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input2
[    4.060476] platform sound.3: Driver davinci_evm requests probe deferral
[    4.110365] bluetooth: disagrees about version of symbol __sock_recv_ts_and_drops
[    4.118508] bluetooth: Unknown symbol __sock_recv_ts_and_drops (err -22)
[    4.134664] davinci_evm sound.3: ASoC: CPU DAI (null) not registered
[    4.141434] davinci_evm sound.3: snd_soc_register_card failed (-517)
[    4.275182] platform sound.3: Driver davinci_evm requests probe deferral
[    4.300754] bluetooth: disagrees about version of symbol __sock_recv_timestamp
[    4.308513] bluetooth: Unknown symbol __sock_recv_timestamp (err -22)
[    4.329727] davinci_evm sound.3:  tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[    4.428305] bluetooth: disagrees about version of symbol __sock_recv_wifi_status
[    4.436252] bluetooth: Unknown symbol __sock_recv_wifi_status (err -22)
[    6.135303] musb-hdrc musb-hdrc.0.auto: Enabled SW babble control
[    6.195373] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[    6.263472] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[    6.340373] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    6.347653] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.355311] usb usb1: Product: MUSB HDRC host driver
[    6.360556] usb usb1: Manufacturer: Linux 3.12.10-ti2013.12.01 musb-hcd
[    6.367563] usb usb1: SerialNumber: musb-hdrc.0.auto
[    6.430318] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    6.614340] hub 1-0:1.0: USB hub found
[    6.643450] hub 1-0:1.0: 1 port detected
[    6.678326] musb-hdrc musb-hdrc.1.auto: Enabled SW babble control
[    6.718965] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    6.779300] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[    6.804841] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    6.812071] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.819774] usb usb2: Product: MUSB HDRC host driver
[    6.825035] usb usb2: Manufacturer: Linux 3.12.10-ti2013.12.01 musb-hcd
[    6.832030] usb usb2: SerialNumber: musb-hdrc.1.auto
[    6.851484] hub 2-0:1.0: USB hub found
[    6.855610] hub 2-0:1.0: 1 port detected
[    7.045798] cryptodev: driver 1.6 loaded.
    I haven't worked with WLAN.
    Please try to understand the concept behind on enabling WLAN in SDK6.
    I have seen some firmware (*.bin) part for WLAn in SDK6.
    Not only DTS modification but firmware, scripts and drivers etc.,
  • Hi Titus,
    It worked !!! Thanks for the hint.
    The DTS is modified and the firmware is copied.
    But there is an issue in signal strength and client is not getting connected. Any patches ?
    The next obstacle as follows,
    [   38.580548] wlcore: firmware booted (Rev 6.3.10.0.135)
    [   39.127676] wlcore: ERROR ELP wakeup timeout!
    [   39.132310] ------------[ cut here ]------------
    [   39.137311] WARNING: CPU: 0 PID: 9 at drivers/net/wireless/ti/wlcore/main.c:802 wl12xx_queue_recovery_work+0x74/0x80 [wlcore]()
    [   39.149488] Modules linked in: g_mass_storage usb_f_mass_storage libcomposite configfs bufferclass_ti(O) omaplfb(O) cryptodev(O) wl12xx wlcoh
    [   39.192268] CPU: 0 PID: 9 Comm: kworker/u2:1 Tainted: G           O 3.12.10-ti2013.12.01 #2
    [   39.201223] Workqueue: phy0 ieee80211_reconfig_filter [mac80211]
    [   39.207600] Backtrace:
    [   39.210209] [<c0017880>] (dump_backtrace+0x0/0x10c) from [<c0017a1c>] (show_stack+0x18/0x1c)
    [   39.219146]  r6:bf2339fc r5:00000009 r4:00000000 r3:c07fd37c
    [   39.225162] [<c0017a04>] (show_stack+0x0/0x1c) from [<c056ed70>] (dump_stack+0x20/0x28)
    [   39.233652] [<c056ed50>] (dump_stack+0x0/0x28) from [<c0046d08>] (warn_slowpath_common+0x70/0x90)
    [   39.243054] [<c0046c98>] (warn_slowpath_common+0x0/0x90) from [<c0046d4c>] (warn_slowpath_null+0x24/0x2c)
    [   39.253175]  r8:bf250808 r7:ffff99e6 r6:c07fbec0 r5:00000000 r4:cd790c20
    [   39.260342] [<c0046d28>] (warn_slowpath_null+0x0/0x2c) from [<bf2339fc>] (wl12xx_queue_recovery_work+0x74/0x80 [wlcore])
    [   39.271923] [<bf233988>] (wl12xx_queue_recovery_work+0x0/0x80 [wlcore]) from [<bf23e474>] (wl1271_ps_elp_wakeup+0x1b8/0x1e4 [wlcore])
    [   39.284620]  r4:cd790c20 r3:00000001
    [   39.288483] [<bf23e2bc>] (wl1271_ps_elp_wakeup+0x0/0x1e4 [wlcore]) from [<bf22f5e0>] (wl1271_op_configure_filter+0x58/0x12c [wlcore])
    [   39.301243] [<bf22f588>] (wl1271_op_configure_filter+0x0/0x12c [wlcore]) from [<bf1de138>] (ieee80211_configure_filter+0x148/0x1a8 [mac80211)
    [   39.314826] [<bf1ddff0>] (ieee80211_configure_filter+0x0/0x1a8 [mac80211]) from [<bf1de1ac>] (ieee80211_reconfig_filter+0x14/0x18 [mac80211])
    [   39.328260]  r8:00000000 r7:cd078100 r6:cd070800 r5:cd790414 r4:cd0a3840
    [   39.335408] [<bf1de198>] (ieee80211_reconfig_filter+0x0/0x18 [mac80211]) from [<c0059f50>] (process_one_work+0xfc/0x340)
    [   39.346918] [<c0059e54>] (process_one_work+0x0/0x340) from [<c005a558>] (worker_thread+0x130/0x370)
    [   39.356503] [<c005a428>] (worker_thread+0x0/0x370) from [<c005fbdc>] (kthread+0xac/0xb8)
    [   39.365094] [<c005fb30>] (kthread+0x0/0xb8) from [<c00146f8>] (ret_from_fork+0x14/0x3c)
    [   39.373563]  r7:00000000 r6:00000000 r5:c005fb30 r4:cd091e74
    [   39.379577] ---[ end trace 2b8bb478b3b810ec ]---
    [   39.386212] wlcore: down
    [   39.389080] wlcore: Hardware recovery in progress. FW ver: Rev 6.3.10.0.135
    [   39.396442] ------------[ cut here ]------------
    [   39.401444] WARNING: CPU: 0 PID: 6 at drivers/net/wireless/ti/wlcore/io.h:65 wlcore_set_partition+0xa0/0x488 [wlcore]()
    [   39.412864] Modules linked in: g_mass_storage usb_f_mass_storage libcomposite configfs bufferclass_ti(O) omaplfb(O) cryptodev(O) wl12xx wlcoh
    [   39.455663] CPU: 0 PID: 6 Comm: kworker/u2:0 Tainted: G        W  O 3.12.10-ti2013.12.01 #2
    [   39.464547] Workqueue: phy0 wl1271_recovery_work [wlcore]
    [   39.470271] Backtrace:
    [   39.472876] [<c0017880>] (dump_backtrace+0x0/0x10c) from [<c0017a1c>] (show_stack+0x18/0x1c)
    [   39.481814]  r6:bf23a510 r5:00000009 r4:00000000 r3:c07fd37c
    [   39.487848] [<c0017a04>] (show_stack+0x0/0x1c) from [<c056ed70>] (dump_stack+0x20/0x28)
    [   39.496325] [<c056ed50>] (dump_stack+0x0/0x28) from [<c0046d08>] (warn_slowpath_common+0x70/0x90)
    [   39.505722] [<c0046c98>] (warn_slowpath_common+0x0/0x90) from [<c0046d4c>] (warn_slowpath_null+0x24/0x2c)
    [   39.515847]  r8:00000000 r7:00000000 r6:bf250808 r5:bf26e8f8 r4:cd790c20
    [   39.523006] [<c0046d28>] (warn_slowpath_null+0x0/0x2c) from [<bf23a510>] (wlcore_set_partition+0xa0/0x488 [wlcore])
    [   39.534106] [<bf23a470>] (wlcore_set_partition+0x0/0x488 [wlcore]) from [<bf233ea0>] (wl1271_recovery_work+0x70/0x53c [wlcore])
    [   39.546251]  r7:cd078100 r6:cd790c54 r5:cd790c20 r4:cd790eb4
    [   39.552301] [<bf233e30>] (wl1271_recovery_work+0x0/0x53c [wlcore]) from [<c0059f50>] (process_one_work+0xfc/0x340)
    [   39.563263] [<c0059e54>] (process_one_work+0x0/0x340) from [<c005a558>] (worker_thread+0x130/0x370)
    [   39.572843] [<c005a428>] (worker_thread+0x0/0x370) from [<c005fbdc>] (kthread+0xac/0xb8)
    [   39.581423] [<c005fb30>] (kthread+0x0/0xb8) from [<c00146f8>] (ret_from_fork+0x14/0x3c)
    [   39.589894]  r7:00000000 r6:00000000 r5:c005fb30 r4:cd07fd4c
    [   39.595890] ---[ end trace 2b8bb478b3b810ed ]---
    [   39.609654] ieee80211 phy0: Hardware restart was requested
    [   40.080564] wlcore: firmware booted (Rev 6.3.10.0.135)
    [   40.097747] cfg80211: Calling CRDA for country: US
    [   40.122631] cfg80211: Regulatory domain changed to country: US
    [   40.128903] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [   40.137556] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
    [   40.145756] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
    [   40.153950] cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   40.162156] cfg80211:   (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   40.170358] cfg80211:   (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   40.178555] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
    [   40.186739] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
    [   41.191259] ip_tables: (C) 2000-2006 Netfilter Core Team
    [   41.217414] nf_conntrack version 0.5.0 (3880 buckets, 15520 max)
  • Great.
    Glad to hear.
