Other Parts Discussed in Thread: CCSTUDIO, CSD
I have been facing difficulties in DSP 5515 programming using one of the example projects available with my evaluation kit (USBSTIK5515). I was using the example (MMCSD_sdcardexample.out) project for my project based testing.
Im getting an error which is as follows:-
Description Resource Path Location Type
Build-configuration 'com.ti.ccstudio.buildDefinitions.C5500.Debug.1599296540' does not exist in the referenced project 'C55XXCSL_LP'. Use the 'Properties > Build > Dependencies' page to select an existing build-configuration. CSL_MMCSD_SdCardFSExample_Out CSL_MMCSD_SdCardFSExample_Out Problems
I have already given all the right paths which are required to run the code.
Could you please help me out in fixing this up...
Nishad.
