Hi Bahubali,
I think you might have the 10-bit I2C addressing confused with the 10-bit EEPROM word addressing. Looking that the AT24C08 specs, we're looking at a device that uses a 7-bit I2C address, but the internal EEPROM memory address is 10-bits in length. For the I2C driver, the EEPROM word address is to be considered as payload, not the I2C address.
Unfortunately, we don't ship a I2C EEPROM example with the TI-RTOS for MSP430, but we do have one in TI-RTOS for C2000 because the Concerto board has an onboard EEPROM.
Here's the example (cut and pasted), which is pretty much generic, but the "Board_" need to be tweaked for your EEPROM. I hope this helps.
* Copyright (c) 2014, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== i2ceeprom.c ========
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
/* TI-RTOS Header files */
#include <ti/drivers/GPIO.h>
#include <ti/drivers/I2C.h>
/* Example/Board Header files */
#include "Board.h"
#include <string.h>
/* I2C EEPROM address */
#define Board_EEPROMADDRESS (0x50)
#define Board_EEPROMPAGESIZE (0x40)
#define Board_EEPROMADDRESSIZE (0x02)
#define Board_EEPROMSTARTADDR (0x00)
I2C_Handle i2c;
uint8_t txBuffer[Board_EEPROMADDRESSIZE + Board_EEPROMPAGESIZE];
uint8_t rxBuffer[Board_EEPROMADDRESSIZE + Board_EEPROMPAGESIZE];
* ======== writeEEPROM ========
* Function performs a write operation onto the EERPOM
* IMPORTANT:
* The transmitBuffer must include the EEPROMs internal address pointer of
* size txAddressLength at the beginning of the transmitBuffer array.
* To send a 64 bytes of data, the transmitBuffer and writeCount must be 64
* bytes + txAddressLength bytes in size.
bool writeEEPROM(uint8_t slaveAddress,
uint8_t *transmitBuffer,
size_t txAddressLength,
size_t txDataLength)
bool transferOK;
I2C_Transaction i2cTransaction;
i2cTransaction.slaveAddress = slaveAddress; /* 7-bit slave address */
i2cTransaction.writeBuf = transmitBuffer; /* txBuffer to be TX'd */
/* Number of bytes to be TX'd */
i2cTransaction.writeCount = txAddressLength + txDataLength;
i2cTransaction.readBuf = NULL; /* rxBuffer to be RX'd */
i2cTransaction.readCount = 0; /* Number of bytes to be RX'd */
transferOK = I2C_transfer(i2c, &i2cTransaction); /* Perform I2C transfer */
return (transferOK);
* ======== readEEPROM ========
* Function performs a read operation from the EEPROM
* IMPORTANT:
* The receiveBuffer must include the EEPROMs internal address pointer of
* size rxAddressLength at the beginning of the receiveBuffer array.
* To receive 64 bytes of data, the receiveBuffer must be 64 bytes +
* rxAddressLength bytes in size.
bool readEEPROM(uint8_t slaveAddress,
uint8_t *receiveBuffer,
size_t rxAddressLength,
size_t rxDataLength)
bool transferOK;
/* Read the Erased Page in the EEPROM */
i2cTransaction.writeBuf = receiveBuffer; /* txBuffer to be TX'd */
i2cTransaction.writeCount = rxAddressLength; /* Number of bytes to TX */
i2cTransaction.readBuf = receiveBuffer + rxAddressLength;
i2cTransaction.readCount = rxDataLength; /* Number of bytes to RX */
* ======== waitEEPROM ========
* The waitEEPROM function polls the EEPROM to determine if it's ready receive
* another I2C command immediately after a write function has been called.
* EEPROMs require some significant amount of time to complete a write
* operation, therefore we need to check when its ready for the next command.
void waitEEPROM(uint8_t slaveAddress)
uint8_t txBuffer[1];
/* Wait for the EEPROM to be ready for the next read/write operation */
txBuffer[0] = 0x00; /* Some dummy value */
i2cTransaction.writeBuf = txBuffer; /* txBuffer to be TX'd */
i2cTransaction.writeCount = 1; /* Number of bytes to be TX'd */
* Perform I2C transfer until a good I2C has been ACK'd by the slave
* indicating that the I2C slave is now ready for the next command
while (!I2C_transfer(i2c, &i2cTransaction)) {
* ======== taskFxn ========
* Task for this function is created statically. See the project's .cfg file.
Void taskFxn(UArg arg0, UArg arg1)
unsigned int i;
bool transferOK;
I2C_Params i2cParams;
/* Create I2C for usage */
I2C_Params_init(&i2cParams);
i2cParams.bitRate = I2C_400kHz;
i2c = I2C_open(Board_I2C_EEPROM, &i2cParams);
if (i2c == NULL) {
System_abort("Error Initializing I2C\n");
else {
System_printf("I2C Initialized!\n");
/* Set txBuffer and rxBuffer EEPROM byte address */
for (i = 0; i < Board_EEPROMADDRESSIZE; i++) {
txBuffer[i] = Board_EEPROMSTARTADDR >> (i * 8); /* EEPROM TX Address */
rxBuffer[i] = Board_EEPROMSTARTADDR >> (i * 8); /* EEPROM RX Address */
/* Write a page with all 0xFF's into the EEPROM */
for (i = Board_EEPROMADDRESSIZE;
i < Board_EEPROMADDRESSIZE + Board_EEPROMPAGESIZE; i++) {
/* Fill with "Erased" content */
txBuffer[i] = 0xFF;
transferOK = writeEEPROM(Board_EEPROMADDRESS, txBuffer,
Board_EEPROMADDRESSIZE, Board_EEPROMPAGESIZE);
if (!transferOK) {
System_abort("Error in I2C Transfer\n");
waitEEPROM(Board_EEPROMADDRESS);
/* Read a page from the EEPROM */
transferOK = readEEPROM(Board_EEPROMADDRESS, rxBuffer,
if (!transferOK) {
/* Compare memory contents */
if (memcmp(txBuffer, rxBuffer,
Board_EEPROMADDRESSIZE + Board_EEPROMPAGESIZE) == 0) {
System_printf("Page has been erased\n");
else {
System_printf("Page was NOT erased\n");
/* Write a page with incremented values into the EEPROM */
txBuffer[i] = i - Board_EEPROMADDRESSIZE;
if (!transferOK) {
if (!transferOK) {
System_printf("Page was successfully written with data\n");
else {
System_printf("Page was NOT written with data\n");
/* Deinitialized I2C */
I2C_close(i2c);
System_printf("I2C Deinitialized!\n");
System_printf("Done\n");
System_flush();
* ======== main ========
int main(void)
/* Call board init functions */
Board_initGeneral();
Board_initGPIO();
Board_initI2C();
/* Turn on user LED */
GPIO_write(Board_LED0, Board_LED_ON);
System_printf("Starting the I2C example\nSystem provider is set to SysMin."
" Halt the target to view any SysMin contents in ROV.\n");
/* SysMin will only print to the console when you call flush or exit */
System_flush();
/* Start BIOS */
BIOS_start();
return (0);
