HI
i'm trying to use this API after creating Mail box and pending on this API return 0 all of the time , is there is any configuration to use this plz advice
thanks
marwa
HI
thanks
marwa
I have a possible fix for this that I am testing locally. You can try it also.
In your BIOS installation, make a backup copy of this file:
packages/ti/sysbios/knl/Mailbox.c
Then find this line in the Mailbox.c file:
return (Semaphore_getCount(dataSem));
and change it to this:
return (obj->numMsgs - obj->numFreeMsgs);
Then, add this to your .cfg file settings if you are not already using the custom library build option:
var BIOS = xdc.useModule('ti.sysbios.BIOS');
BIOS.libType = BIOS.LibType_Custom;
This will cause a new SYS/BIOS library to built with the changes you made to the Mailbox.c file.
Let me know if this corrects the behavior you're seeing.
Alan
