I use dvrrdk3.5 development package probability process appears to hang, sleep problems, the phenomenon is the mouse got stuck, the entire QT interface card death does not move, 16 OSD got stuck, date and time are no longer updated, but the 16 preview to normal, indicating that DSP and M3 didn't die, some process is simply the end arm hang, dormant, reappearance did not seize the rules, sometimes just start, sometimes is the operation of a certain interface. Problems can also be Telnet, using top -d 1 command after the discovery of the remaining memory 100MB or so, should not run out of memory problem, also found that the CPU occupancy rate of 0.
This problem arises when the bottom has the following print:
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:176,TimeSinceLastFree:176
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:192,TimeSinceLastFree:192
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:208,TimeSinceLastFree:208
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:224,TimeSinceLastFree:224
I would like to ask everyone who encountered a similar problem? Please advice or make a suggestion, thank you!
yours!
